gatibosgru wrote:Will their later models get the newer one or will they keep them all the same to standardize their fleet?
TTailedTiger wrote:I think the better question is why Airbus needs winglets at all. Boeing has never need them with the 777 and 787. Did Boeing patent the integrated raked wingtip?
trex8 wrote:TTailedTiger wrote:I think the better question is why Airbus needs winglets at all. Boeing has never need them with the 777 and 787. Did Boeing patent the integrated raked wingtip?
Isnt the reason why some have winglets and some raked tips is that one-winglets - lets you have a shorter wingspan? .
gatibosgru wrote:TTailedTiger wrote:How different is a ranked wingtip vs a winglet anyway? They're both achieving a common goal, regardless for if one of them points up.I think the better question is why Airbus needs winglets at all. Boeing has never need them with the 777 and 787. Did Boeing patent the integrated raked wingtip?
HIA350 wrote:a330 a340 were first
Aesma wrote:Boeing wings and Airbus wings are quite different, following different philosophies, so there is no reason for their tips to be identical.
gatibosgru wrote:Sorry if this is a dumb question, but since airbus increased the size of the Sharklets for the standard A359, what happens to operators who've received a few examples with the "old" shorter one like LH and DL. Will their later models get the newer one or will they keep them all the same to standardize their fleet? Can they get the first few delivered models refurbished with the taller ones or is the savings not worth the hassle/cost.
shamrock350 wrote:The introduction of the new, larger winglet was originally part of the A350-900ULR study which also came with improvements to the wing itself. Without the new wing twist, the bigger winglet is near pointless so older models are better off keeping their original winglet.
workhorse wrote:gatibosgru wrote:Will their later models get the newer one or will they keep them all the same to standardize their fleet?
I may be wrong, but I don't think commonality is a huge factor here. You don't replace winglets, unless your plane has hit something, which fortunately doesn't happen often. So I don't see a problem for Delta or anyone else to operate A350 fleets with different winglets.
gatibosgru wrote:Can they get the first few delivered models refurbished with the taller ones or is the savings not worth the hassle/cost.
caoimhin wrote:HIA350 wrote:a330 a340 were first
First relative to what? These aircraft were certainly not the first implementation of wingtip devices.
HIA350 wrote:caoimhin wrote:HIA350 wrote:a330 a340 were first
but before the 737 and 767 implemented they were already deployed or built this way from factory
RalXWB wrote:HIA350 wrote:a330 a340 were first
That title goes to the A300/310.
JerseyFlyer wrote:Aesma wrote:Boeing wings and Airbus wings are quite different, following different philosophies, so there is no reason for their tips to be identical.
If they were identical, someone would accuse one of copying the other
jagraham wrote:JerseyFlyer wrote:Aesma wrote:Boeing wings and Airbus wings are quite different, following different philosophies, so there is no reason for their tips to be identical.
As was accused - and proven (after a decade of litigation) - with the A320 sharklet vs the Aviation Partners blended winglet.
TTailedTiger wrote:The primary reason for winglets is better fuel efficiency. Boeing had to use folding wingtips for the 777X so that it could fit in current gates though.
HIA350 wrote:RalXWB wrote:HIA350 wrote:a330 a340 were first
you are correct, same manufacturer Airbusthank you for correcting me lmao
OA940 wrote:Does the -1000 have the new winglets? It doesn't seem like it from pics but I'm not sure
WIederling wrote:The basic patent is from 1879 or thereabouts.
rjsampson wrote:WIederling wrote:The basic patent is from 1879 or thereabouts.
Wow, talk about a manufacturer being WAY ahead of its time... Before the first powered aircraft, muchless jet engine were invented![]()
Obvious mistake, but I had to get that one in there
Chaostheory wrote:jagraham wrote:JerseyFlyer wrote:If they were identical, someone would accuse one of copying the other
Was it actually proven though?
I thought the courts dismissed the claims and counter-claims of the two and compelled them to arbitration?
jagraham wrote:Settled in Aviation Partners favor in 2017. After a lot of filings and refilings. It did take a decade. After Airbus officially collaborated with Aviation Partners for 5 years.
https://www.bizjournals.com/seattle/new ... spute.html
WIederling wrote:jagraham wrote:Settled in Aviation Partners favor in 2017. After a lot of filings and refilings. It did take a decade. After Airbus officially collaborated with Aviation Partners for 5 years.
The relevant patent was invalidated years ago.
If money was passed it must have been for other "services".
Try again noobs, first commercial airliner with wingtip devices comes from Tupolev, they first appeared in the Tu-204. Not everything was invented in the West you know.
WIederling wrote:WIederling wrote:jagraham wrote:Settled in Aviation Partners favor in 2017. After a lot of filings and refilings. It did take a decade. After Airbus officially collaborated with Aviation Partners for 5 years.
and again wrong.
AP stood back from patent infringement and instead litigated for getting "services" paid. all around 2012 afair.
pretty long commented articles on Leehamnews, law360.com, ainonline,com and some other sites at the time.
and again wrong.
jwjsamster wrote:I'm not too sure that I've noticed a difference in wingtips between different A350s, could someone perhaps show the two types for clarity?
HELyes wrote:
The old and the new A350 sharklets: https://twitter.com/mpylkko/status/1074565096637108224
Am I not enough tech or whatever difference there is minimal? I struggle to see differences?!
jagraham wrote:Links please
WIederling wrote:jagraham wrote:Links please
https://worldwide.espacenet.com/publica ... ale=en_EP#
to witt:
Code Expl.: + REEXAMINATION CERTIFICATE FIRST REEXAMINATION
FURTHER INFORMATION : CLAIM 1 IS CANCELLED. CLAIMS 2-5 WERE NOT REEXAMINED.
More If I find the time to unearth my link stash from the time ...
