berari
Ethiopian flying B737 MAX 8 to Moscow
Thu Dec 27, 2018 3:14 am
Ethiopian Airlines opened a new route to Moscow on the 17th, nonstop from Addis Ababa. This route, when it was initially announced, was to operate via Istanbul using B788 aircraft. Istanbul launch has been delayed for lack of rights, and the first flight to DME operated using a B788. Subsequent flights and future flights are operating on an off with the B7M8. The route spans 3,200 mi in great circle distance.
https://www.flightradar24.com/data/flights/et760
Newbiepilot
Re: Ethiopian flying B737 MAX 8 to Moscow
Thu Dec 27, 2018 3:37 am
That's a long flight. 737 MAX has been opening up many 2500nm + routes.
ADD-Moscow is going to be really stretching the range since ADD is at a high elevation. I wonder what type of weight restrictions they may see.
ikolkyo
Thu Dec 27, 2018 3:44 am
The larger fuel tanks of the 737 really show up on the MAX.
dcajet
Thu Dec 27, 2018 3:57 am
Absent ADD's elevation, this route is well below GOL's BSB-MCO and AR's EZE-PUJ, to the tune of 500 miles.
ikolkyo
Thu Dec 27, 2018 4:02 am
arcticcruiser
Thu Dec 27, 2018 7:26 am
arcticcruiser wrote:
Huh? Larger compared to what?
ikolkyo
Thu Dec 27, 2018 7:36 am
A320 has a lower fuel capacity compared to the 737.
ikarlson
Thu Dec 27, 2018 8:46 am
7 hours 30 minutes block time. I doubt that this route will success, really don't understand whats in Moscow for Ethiopian Airlines. ME3 covers Moscow well
[email protected]
Thu Dec 27, 2018 12:15 pm
Exceptional coverage of Africa.
TK is also very strong to this end.
berari
Sat Dec 29, 2018 6:46 am
Time will tell. ET is in the business of connecting Africa to the rest of the world. We have wondered the same when it opened routes to Shanghai, Chengdu, Brussels and even Oslo.
MIflyer12
Sat Dec 29, 2018 2:07 pm
'Absent elevation' may as well be 'absent gravity.' You outline a worthless comparison.
sxf24
Sat Dec 29, 2018 2:50 pm
I think this is a short term change due to 787s down for maintenance (mostly RR engine swaps).
Newbiepilot
Sat Dec 29, 2018 4:51 pm
Well at 7200ft of elevation, the MTOW will be reduced by about 10K lbs depending on temperature (the 1145pm departure should be helpful). A 737-8 burns about 10lbs per mile so the elevation factor is equivalent to about 1000 miles of range. However, Ethiopian only has 160 seats on their 737-8 compared to 170 for AR and 189 for GOL which is 2000 to 7500 lbs of passengers and luggage. A quick look at the numbers shows that what Ethiopian is doing with the 737-8 isn’t that different from AR or GOL.
TWA772LR
Sat Dec 29, 2018 5:06 pm
You do know how high above sea level ADD is compared to EZE, PUJ, MCO and to an extent BSB are right?
