flyPIT
Re: PIT Update Discussion Thread - 2019
Thu Jul 25, 2019 6:20 pm
Here's the original "Our Region's Business" interview with Condor a couple weeks ago. It offers a bit more context than the print interview.
https://www.youtube.com/watch?v=2QQMottx78M
- Pittsburgh has "more potential than we ever saw".
FLYi
Runway28L
Thu Jul 25, 2019 8:53 pm
Currently going through the WN schedule now that the MAX has been pushed back to 1/5/2020. The only noteworthy things I see are:
- MSY's season stops running on 12/15
- DEN goes back up to 2x daily (this will actually up a frequency YoY) on 12/15
- LAX goes up from Sun-only to 1x daily on 12/15
ctrabs0114
Fri Jul 26, 2019 7:49 am
That's reassuring that WN isn't completely giving up on PIT-LAX. It's also noteworthy that WN announced the consolidation of New York City ops to LGA, closing EWR in November.
2019: DAL, MCI, PHX, LAS, DFW, SAT, ORD, SLC, SEA, DTW; B73G (WN x3), B738 (WN, AA, DL), A20N (NK), MD83 (AA), B788 (AA x2), CS1 (DL), 739 (DL), 712 (DL)
Next: AA: DFW-PHL (752), PHL-MIA (763), MIA-LAX (77W), LAX-DFW (789)
ctrabs0114
Fri Jul 26, 2019 7:53 am
Apparently, a US-based firm is attempting to re-launch WOW Air (or at least build a (ahem) reasonable facsimile of WW). The relevant quote from this article that jumped out at me:
Looking at Southwest Airlines as a model, she said she aimed to use three A321-200neo, a model the employees of the now-bankrupt carrier are familiar with, and to increase the size of the fleet to ten to twelve aircraft of the same or similar type within twenty-four months.
Destinations would be similar to those of WOW air, she said, with the addition of Washington Dulles, the location of the headquarters of USAerospace Associates.
I wonder if this means we could see the return of PIT-KEF within the next few years...
ConcourseZ
Fri Jul 26, 2019 3:09 pm
If the resurrected WW could just concentrate on the northeast and upper midwest of the US with the A321NEO, they should do well. Expand much later after the business is well-established. I would expect PIT is on the shortlist of cities given the performance here. Good idea to add cargo flights too imho.
flyPIT
Fri Jul 26, 2019 5:18 pm
For those that like maps and layout plans of the airport, I came across this copy. Probably the nicest layout plan of PIT I've seen online:
http://www.iaff1038.org/documents/Fence_Gates.pdf
I know the trains have broke in the past, but has the maintenance tunnel between the trains ever been used for passengers before?
https://triblive.com/local/pittsburgh-allegheny/pittsburgh-airport-trains-running-after-breakdown/
I agree. WW seemed to go off the rails when they added A333s to places such as DFW and SFO that already had excellent nonstop service to Europe. We'll see what happens.
FLYi
ncflyer
Fri Jul 26, 2019 6:19 pm
If WW comes to fruition they ought to pick CLE or PIT but not both. For a low fare carrier pax will Make that easy drive. Advertising would help.
ConcourseZ
Fri Jul 26, 2019 8:07 pm
FI was serving CLE but canceled the summer service due to financial concerns and the Max 8 grounding. That route used Max 8 aircraft. IF they return to CLE, then WW can use PIT, only.
Jshank83
Fri Jul 26, 2019 11:10 pm
They haven't updated their December schedule for the MAX yet. It is still the original one.
GSP psgr
Fri Jul 26, 2019 11:30 pm
A part of me is surprised that Delta hasn't taken advantage of WN's MAX problems to at least give PIT-LAX a go, as DL isn't affected by the MAX grounding. I have heard that DL is at capacity gate wise in LAX until they finish the complete refurb of T3 at LAX.
ConcourseZ
Sat Jul 27, 2019 12:38 am
When is that scheduled to be completed....T3 at LAX?
GSP psgr
Sat Jul 27, 2019 1:35 am
Mid-2023, I believe.
corkscrew
Sat Jul 27, 2019 1:40 am
GSP psgr wrote:
I believe it. Both arriving through T2 and departing through T3 last year it was extremely crowded. When I departed, it was a red-eye to Minneapolis and even at that hour the place was packed and constantly refilling even as flights went out.
I think airlines know the demand for PIT-LAX is there. I suspect that given the fares it commands it's not worth the displacement of another flight on the other end.
ConcourseZ
Sat Jul 27, 2019 1:44 am
Is there room for DL at LAX to enplane/deplane on a ramp and no gate?
flyPIT
Sat Jul 27, 2019 10:47 pm
Here are the fastest growing airports in terms of seats offered for 2018:
https://www.oag.com/hubfs/Free_Reports/NAM%20Growth%20Index/NAM%20Fastest%20Growing%20Airports.pdf?hsCtaTracking=a0e323bd-a3c3-4c51-9a5c-4876025513a8%7Cbd412812-8dab-4527-8456-6ab007359cd1
PIT ranked #10 out of the 42 medium sized hubs (p6-7). I love how in the top 10 "Ones To Watch" section that follows they skip #10 and go to #11 :sarcastic:
FLYi
Runway28L
Sat Jul 27, 2019 11:10 pm
AS is changing their flight number on SEA-PIT-SEA from AS198/199 to AS412/413 on August 27. Nice nod to Pittsburgh's area code.
AaronPGH
Sun Jul 28, 2019 1:08 am
This is actually super thoughtful. Is that normal with them?
ConcourseZ
Sun Jul 28, 2019 2:28 am
"Cleveland is a United hub.".....um....no.
OAG needs to correct their PIT slight immediately.
Runway28L
Sun Jul 28, 2019 8:45 pm
Airlines sometimes do this. For example, Spirit’s afternoon MYR-LBE flight operates under NK412.
flyPIT
Sun Jul 28, 2019 8:50 pm
Which is ironic because LBE is in the 724 area code. I like Alaska's previous fight numbers more. The lower the better.
FLYi
ctrabs0114
Mon Jul 29, 2019 1:54 am
FWIW, NK does that on quite a few of their flights; NK412 is MYR-LBE (yes, I know Latrobe is in the 724 area code), while NK724 is FLL-LBE.
F9LASDEN
Mon Jul 29, 2019 2:22 am
I’ve noticed this as well. 720 is one of Denver’s two area codes, and NK720 is LAS-DEN-DFW.
Spirit of the West...A Whole Different Animal...Low Fares Done Right
ConcourseZ
Mon Jul 29, 2019 6:20 pm
Assuming the China charters aren' materializing this year. Anyone have info about this?
worldtraveler2
Mon Jul 29, 2019 7:09 pm
There are some fun flight numbers out there, e.g. flight "500" for Indianapolis - UA 500 is IND-SFO, DL 500 is IND-CDG; "1776" for Philadelphia - UA 1776 is IAH-PHL, AA 1776 is PHL-BOS. I recall more in the past e.g. "1492" for Columbus. "49" for San Francisco, etc.
Delta28L
Mon Jul 29, 2019 7:17 pm
No they aren’t happening this year. They would’ve been making a big deal about it already if they had been happening. Money probably went towards the terminal improvement program and to BA
F9LASDEN
Mon Jul 29, 2019 8:04 pm
“777” to indicate a jackpot on a slot machine...F9777 is DEN-LAS, NK777 is FLL-LAS, and AA777 is PHX-LAS-PHX
Pittsburgher
Mon Jul 29, 2019 10:44 pm
Hawaii Five-0 - HA50 HNL-JFK is a neat one
Runway28L
Mon Jul 29, 2019 11:31 pm
There appears to be two UPS MD-11s scheduled to arrive at PIT tonight. 5X9758 from DEN and 5X9505 from SAT.
https://www.flightradar24.com/data/flights/5X9758
https://www.flightradar24.com/data/flights/5X9505
steeler83
Mon Jul 29, 2019 11:46 pm
Book it, Dano!!
I like how AA1776 is used for PHL-BOS. Way to keep it revolutionary! Do they (or anyone else) have a 1773 flight out of BOS?
About tje China charters, I wasn't getting my hopes up anyway that they'd be back. All parties are happy with BA and Condor service. Let's see how long we can keep them around. As has been mentioned, Condor wants to expand services.
Do not bring stranger girt into your room. The stranger girt is dangerous, it will hurt your life.
flyPIT
Tue Jul 30, 2019 7:12 pm
"With some major wins in the bank, Pittsburgh Airport takes its next growth steps forward"
https://www.freightwaves.com/news/with-a-couple-major-wins-in-the-bank-pittsburgh-airport-takes-its-next-growth-steps-forward
Excellent article.
FLYi
flyPIT
Tue Jul 30, 2019 8:36 pm
Pittsburgh is finally getting an Amazon fulfillment center. It seems like we were the only metro area without one. !,000,000 sq. ft and 800 jobs at the Westport business park just a few miles from PIT. So what does this mean for PIT, as far as the possibility of being added by Prime Air? They are adding more 737s so I think it is a good possibility now, as is the need to think about expanding the cargo facilities at PIT.
https://pittsburgh.cbslocal.com/2019/07/30/allegheny-county-findlay-township-amazon-fulfillment-center/
In other economic news, Pittsburgh looks to gain its 9th Fortune 500 headquarters with the merger of Mylan and Upjohn, which will be combined as a new company spun off from Pfizer. Mylan is currently run from their Pittsburgh location but we lost the F500 HQ designation when they opened an office in the Netherlands a few years ago as part of a tax inversion scheme.
"The new company will be incorporated in Delaware and run operations in Pittsburgh, Shanghai and Hyderabad, India.
The new company will be domiciled in the United States, unlike Mylan, which is domiciled in the Netherlands with its headquarters in Pittsburgh.
https://pittsburgh.cbslocal.com/2019/07/29/pfizer-buying-mylan-pharmaceutical-companies/
Also, the region's second cracker plant looks to be moving forward, although no final decision to go forward has been made official. Having said that site prep has begun. This will a $10 billion project near Wheeling, WV, about an hour from PIT.
http://www.theintelligencer.net/news/top-headlines/2019/07/funding-provided-for-belmont-county-cracker-plant-site-preparation/
FLYi
JamesRenard
Wed Jul 31, 2019 1:29 am
I had a look at Google Flights to see if there'd been any changes.
I saw that AA has once again extended mainline service on the PIT-LGA and PIT-DCA routes, with E190 flights operating up until 11/1 and 11/2 respectively.
I did a search for PIT-SJU and... nothing. Google doesn't have anything, and G4's website only shows DAB and SFB as nonstop destinations from SJU. I don't know if they just haven't loaded the winter seasonal services yet, or if they're cutting the service altogether (along with CVG-SJU and RDU-SJU).
ConcourseZ
Wed Jul 31, 2019 12:41 pm
Can confirm the 911th has all eight ships. Four are here and four at March AFB. All eight will be here once the new ramp is completed.
steeler83
Wed Jul 31, 2019 12:50 pm
Excellent article.
I agree, excellent article indeed. I also think that the ACAA et al need to focus on expanding the cargo space. With EFL coming in, Amazon setting up a fulfillment center, and not one but another cracker facility setting up shop not far from PIT, things could get rather interesting within the next several years. The time to move forward with this cargo expansion proposal is now; not in a few years or so from now...
Runway28L
Wed Jul 31, 2019 2:13 pm
Tail numbers for the last three at March? I know 89-1189 is one of them.
The left side doors on the new hangar appear to have been completed. The right side doors are almost finished.
Delta28L
Wed Jul 31, 2019 2:17 pm
The company that amazon leases 737Fs from ordered 15 more 737Fs during the Paris air show earlier this summer. I would not be surprised to see a prime plane in Pittsburgh once the new fulfillment center is opened.
Runway28L
Wed Jul 31, 2019 2:38 pm
June data for British Airways is out.
214 seats per flight > 17 flights each way > 3,638 monthly seats one way > 7,276 total monthly seats (1 flight cancellation during the month of June)
PITTSBURGH 6,313 total 6,313 scheduled
86.8% LF both ways combined.
For only it's third month, that's pretty darn good.
Runway28L
Wed Jul 31, 2019 8:28 pm
Multiple diversions piling up.
AA433 A321 SAN-PHL
UA247 B752 LAX-EWR
DL3015 A221 IAH-LGA
WN120 B738 BNA-EWR
WN2023 B737 MDW-LGA
DL2221 B712 ORD-LGA
AS512 B739 LAX-EWR
AA1187 A321 DFW-LGA
AA4636 E75L STL-LGA
DL6081 had to also return to PIT.
ConcourseZ
Wed Jul 31, 2019 9:16 pm
DL3015 A221 IAH-LGA diversion into PIT marks the first look here at the A220-100.
Gsasala
Wed Jul 31, 2019 11:29 pm
Technically Delta did fly one to PIT but it was a touch and go
Runway28L
Sat Aug 03, 2019 2:47 am
Air Force One will be visiting PIT next Thursday.
Delta28L
Sat Aug 03, 2019 12:34 pm
Trump is going up to beaver to tour the cracker plant. And probably make it into a campaign stop for re-election.
Does anyone know the ETA of Air Force one?
ctrabs0114
Sun Aug 04, 2019 2:24 pm
FWIW, I've been seeing the A221 regularly at DFW (mostly on LGA, DTW, SLC) and flew on one a few months ago on DFW-SLC. If/when the 221 comes to PIT on a regular basis (I'd guess DL would use them on DTW-PIT and maybe MSP-PIT - I don't think DL will be basing any 221s out of ATL for the forseeable future) if that were to happen), you'll be in for a treat. As a regular WN flyer and an occasional AA flyer, the DL A221 blows any other narrowbody away. DL's 221s have larger IFE screens and better seats.
That tends to speak volumes that the only time PIT gets to see some interesting planes (BA 788 and QR 777F notwithstanding) on site is when there are diversions or charters.
Runway28L
Sun Aug 04, 2019 5:14 pm
NK is now upping the second PIT-FLL flight from Mon/Fri-only to daily, so the route will now run 2x daily seven days a week for this upcoming winter. PIT-MCO is also picking up a second flight that runs on certain days.
Also, AS is switching SEA-PIT from a B739 to an Airbus effective 11/5/19. Unsure if it’s an A319 or A320.
krod031
Sun Aug 04, 2019 5:35 pm
Looking at the seat map and the configuration, With 33 rows, it might be a 321....
Delta28L
Sun Aug 04, 2019 8:33 pm
It’s a 321NEO
Runway28L
Sun Aug 04, 2019 10:04 pm
It’s a 321NEO
Just looked at the seat map. It appears to actually be an A320. Shows Rows 16 and 17 as overwing exits and 33 rows.
The A21N has 39 rows total.
flyPIT
Sun Aug 04, 2019 10:42 pm
Here's a new rendering from the PIT website of the TMP:
FLYi
steeler83
Mon Aug 05, 2019 3:10 am
And we already know how Condor is doing. Great to see both BA and Condor succeeding on LHR-PIT and FRA-PIT respectively.
Gsasala
Mon Aug 05, 2019 2:22 pm
This should help NK's issue of overselling tickets, because every single time I've flown on that route it's been either 100% full or oversold. This should allow them to just people on the next instead of having to pay for them to fly on another airline
