calpsafltskeds wrote:788 going from almost a copy of 763 totals, to having Y within 10 of 772ER.
788 and 789 Y totals almost equal. 788 should be real low CASM, HNL-EWR/IAD?
I put together a table (below) of Polaris aircraft seats and totals along with a graph showing seats by class and total seats starting with lowest total seat aircraft.If image doesn't work, go to
http://www.internetservicepros.com/grap ... seats3.jpg
My guesses on seats.
788:
Zone 1 - Polaris vs Diamond, between Zone 1 and 2 -8 seats
Zone 2 Minimum 1 Row J removed, 3 Rows PE (+18), only 3 Rows E+ (-36), Y (+25) 6 due to galley removal
Zone 3 +9, 1 Row added, pitch 32 to 31 (5 E+ remain)
789:
Zone 1 Polaris vs Diamond, between Zone 1 and 2 no change
Zone 2 J may take more room, add 21PE, convert 56 E+ seats to 49Y to allow Polaris and PE
764: Add 18 PE, Lose 4J and 21E+/Y Total -8 seats
Zone 1 Lose 4 Polaris vs. Diamond
Zone 2 Add 18 PE, drop E+ to 34 from 35 inches. Probably convert 4 E+ rows to Y for PE spacing
Zone 3 No change already at 31 inch pitch
788:
789:
calpsafltskeds wrote:Distance from EWR has little affect on this. UA will never stop service to those airports from their hubs. Service at PHL is roughly the same at every hub in the USA which is dominated by one carrier and I would consider PHL a second tier hub - that being one carrier dominates the hub with other airlines either providing spokes to their own hubs or low-cost carriers trying to pull some O&D traffic by low fares. Most hubs I list below have significant O&D to UA hubs, so service is operated so the Mileage Plus members have service on UA to those large cities from their home airport.
I would guess the only reason UA doesn't fly PHL-EWR/IAD is the short driving distance for locals and connections don't pencil out vs. AA's non-stop service from PHL to just about anywhere.
There are really different markets/passengers on lets say a ORD-ATL service flown by UA, DL and low cost carriers. Most likely UA flies something like a DLH-ORD-ATL passenger plus ORD based ATL passengers while DL flies a Montgomery AL-ATL-ORD passenger plus ATL based ORD passengers - low cost carrier fights it out to gain ATL-ORD passengers who don't care about mileage programs.
If you did the same analysis for Colorado you'd find UA in roughly the same position as American in PA.
For the same reasons UA will never pull services from MSP/SLC/LAX/SEA/PDX/PHX/DFW/MIA/FLL/ATL/CLT/BOS/BWI/BNA/MEM/STL/MCI/CLE/DTW/MSP and maybe a couple more airport that all are hubs or large focus cities for one or more airlines.
UA is the most hub centric carrier in the US. I would hope when UA picks up more aircraft that they would start connecting large cities to large cities that are not UA hubs, but where UA has a decent market share overall. Markets like MCO-BOS. UA does operate in 9 of the top 10 markets - the one missing is MCO-ATL and DL is dominant and its a shorter haul.
788:
789:
jayunited wrote:CALTECH wrote:"•In July, expect to cancel approximately 40-45 flights a day, or roughly 1,290 flights for the month
•In August, expect to cancel approximately 60 flights a day, or roughly 1,900 flights for the month
•In September, expect to cancel approximately 70 flights a day, or roughly 2,100 flights for the month
•In October, expect to cancel approximately 95 flights a day, or roughly 2,900 flights for the month "
Yeah I saw that on Flying Together but what I'm not sure of is the exact number of MAX9s that are supposed to be in the fleet by November 2019, and how many are supposed to be in the fleet by spring 2020. I can do some research when I get to work tomorrow but thats what I was unsure of off the top of my head.
mmahpeel wrote:Some interesting configuration changes for the 787-8 and -9 directly resulting from the Polaris and premium Y installations -
787-8 will be 28/21/194 (from 36/183, an increase in density resulting in part from the removal of the galley complex at door 3)
787-9 will be 48/21/188 (from 48/204, some lavatory and galley changes in the back cabin)
mmahpeel wrote:787-9 - 37 (reduction from 88 in current config)
codc10 wrote:mmahpeel wrote:787-9 - 37 (reduction from 88 in current config)
IMO, this is a MASSIVE, MASSIVE downgrade, considering that the 789s fly United's longest routes. Premium Economy (21) plus E+ is only 58 seats on this airplane, meaning 12 Economy pax, most likely Premier members, will be forced into standard Y seats for 15+ hour flights. Not a good thing.
calpsafltskeds wrote:codc10 wrote:mmahpeel wrote:787-9 - 37 (reduction from 88 in current config)
30 pax, not 12. 21PE +37E+=58. 88- 58 =30 fewer premium economy seats.
Maybe UA will offer lower cost upgrades to E+ to get more cash from FF members. Not saying its right, but UA must be looking at how many E+ seats are needed for paying passengers and how many they need above that to do more limited upgrades.
calpsafltskeds wrote:UPDATING POST due someone posting E+ seating on 788/789.
I'm not disagreeing with anyone, just pointing out that UA has dropped total Premium Y seating when Polaris is added. I was just estimating what it looked like could fit and trading E+ seats for Y seats is one way to pick up 3 or 4 inches per row. With PE, obviously you'd expect at least an equal amount of E+ would go. I sure hope UA finds a way to keep as much E+ seating as possible, but unless Y goes from 31 to 30 inches, I believe there will be a cut in the total of seats of PE +E+ vs. previous E+. Newer configurations are in the 12 to 17% E+ percentage.
The below list shows non-Polaris and Polaris sorted by highest premium Y seating. According to my chart, Excluding the 76L, E+ and PE totals range have been shrinking from 32 to 34% on current 787s to the low to mid 20% range. I've included the real possibility that E+ will get one more row on 787 aircraft than I estimated - I hope this happens w/o cutting Y to 30 inches.
76L: 28.8% E+/11% PE = 39.2%, this is a special config I'm not including as it will be used on premium routes.
Un-reconfigured aircraft have high E+ totals, expect E+/PE totals to drop when Polaris added
789: Current 34.9% E+, Going to 14.4% E+/8.2%PE, Total 22.6%
788: Current 32.0% E+, Going to 14.0% E+/8.6%PE, Total 22.6%
764: Current 29.2% E+, Proposed going to something like 15.1% E+/7.8%PE, Total 22.9%
Polaris reconfigured/Polaris deliveries have lower E+/PE totals.
772: 12.5% E+/8.7% PE, Total 25.4%
77W: 17.7% E+/6.9% PE, Total 24.6%
763: 21.5% E+, no PE
78X: 14.2% E+/6.6% PE, Total 20.8%
It appears to me that UA will choose less premium routes for the 788 and 78X fleet, thus E+/PE totals can be lower as well.
calpsafltskeds wrote:73Gs could be WestJet, SAS or China Southern or China Eastern. Only airlines with big enough fleet except Southwest and UA won't buy aircraft with that many cycles.
Doubt WestJet as they have MAX issues as does China Southern. SAS doesn't show MAX aircraft in fleet.
Boeing12345 wrote:calpsafltskeds wrote:73Gs could be WestJet, SAS or China Southern or China Eastern. Only airlines with big enough fleet except Southwest and UA won't buy aircraft with that many cycles.
I was shocked about a month or so ago when I heard this internally. These aircraft are coming from another US operator that inherited them thru a merger. The reason I'm shocked is because this operator has the most 737-8's parked in the USA.
strfyr51 wrote:UA has never had more than a few gates on the D concourse. and with Hubs at EWR and IAD? I do not see why they would. PHL is a good station for UAL but they don't seem to have the interest in making it much bigger and Haven't since 1984 when I hired in at UAL. and PHL is my home town..
n471wn wrote:I do not believe these birds are coming from WN. On another UA thread an individual says they are coming from COPA
codc10 wrote:n471wn wrote:I do not believe these birds are coming from WN. On another UA thread an individual says they are coming from COPA
Copa is down to 9 73Gs, though. Reportedly 2 are sourced from Bangladesh, so there's still a gap.
jayunited wrote:It saddens me to see economy plus being gutted. I get if we add P.E. seats with the economy plus seats the drop off isn't that drastic but considering some of the long haul flights UA utilizes the 789s on I was hoping for a larger E+ cabin, to go from 88 to 32 seats is a bit disappointing considering the seat count in regular economy will go up.
VC10er wrote:QUESTION: on a 777, is E+ also 10 abreast or did they keep 9 abreast?
VC10er wrote:It is disappointing to see E+ being dramatically reduced, however I have wondered how much UA makes from buy ups to E+? As a United GS flier, I just booked a domestic trip for me and 2 friends. The rep on the phone said that I can bring up to 8 guests into E+ (I was astonished!)
So, I’m assuming now a much smaller percentage of pax who have paid for E+.
As for international WBs I don’t know how much it generally costs to by up to E+. But, with UA trying to become a truly premium airline, aside from 4-5 inches of room does an international E+ get? (Or on very long NB flights?)
If United were to actually make E+ even a bit better with amenities such as:
Hot Towels
Champagne
Eye Shades
Ear Plugs
Dental kit
Better pillows and blankets
(Maybe even chocolate or Stroopwaffles
Perhaps UA could actually charge a little bit more for E+ and create some level of excitement over making E+ “sleep friendly” also, vs many who buy up because they are over 6.2 ft tall.
I think word of mouth about how great E+ is - (over and above 4-5 inches of legroom) would do wonders for the main cabin reputation on UA.
intotheair wrote:This is one place where I think DL really has a better product. DL in my experience charges a little bit less for Comfort+ compared to UA, and in addition to the extra legroom, C+ also includes priority boarding, premium snacks, free adult beverages on all flights, and a mileage bonus.
Oh, and let's also not forget that UA now has "Preferred Seating," which is a fee to choose a seat closer to the front of the E- cabin.
notconcerned wrote:The value proposition is different for DL because DM/Plat/Gold still have to upgrade to Y+ (either after ticketing or at T-72), so DL is probably selling more Y+ seats (and wants to sell them) at the expense of Gold/Silver elites who can't select them until their upgrade clears. UA provides E+ mainly as a benefit to 1K/Plat/Gold elites since they can select a E+ at booking.
KVH68 wrote:A United maintenance manager told a group of people that the 737s we are buying are coming from Southwest.
GmoneyCO wrote:Southwest announced plans to retire 20 of the "oldest" 737-700s starting in 2019 during the FY18 earnings release in February. At least some part of this was in motion before the MAX grounding happened and WN may not have wanted to pay what it was going to cost to extend the leases post-grounding thinking the MAX grounding wasn't going to be as long as it has been and will likely be.
That said, most of the frames leased from GECAS don't fall into the "oldest" category. Most are in the 13/14/15 year range and are under the average age of WN's 73G fleet of 15.1 years. Will be interesting. With the deal now public, maybe we'll see a table with former tail & serial numbers come along before long.
jetblastdubai wrote:notconcerned wrote:The value proposition is different for DL because DM/Plat/Gold still have to upgrade to Y+ (either after ticketing or at T-72), so DL is probably selling more Y+ seats (and wants to sell them) at the expense of Gold/Silver elites who can't select them until their upgrade clears. UA provides E+ mainly as a benefit to 1K/Plat/Gold elites since they can select a E+ at booking.
This is why it's so important to keep your status with UA. I can't imagine flying more than an hour or so in anything less than E+. In the past I made sure to take a couple mileage runs towards the end of the year if I was going to be a bit short of my 1P status. Luckily I was able to do most of these before the new mileage calculations kicked in and you earned mileage based on your ticket price. Once I hit 1 million miles and therefore earned Gold status for life the mileage runs stopped. I did some absolutely idiotic day trips or Int'l 2-day trips in my younger days that even made the agents laugh.
The power of FF programs keeping passengers loyal is pretty powerful IMO.
