FTMCPIUS
Re: Chicago Aviation Thread - 2019
Wed Jul 10, 2019 9:20 pm
airstatdfw wrote:
FTMCPIUS wrote:
airstatdfw wrote:
More has to do with security, you can keep planes on the south side moving while the north side is working AF 1 or AF 2. But 9R and 22L have both had B747 Dept and 22L even has had the A380 Dept. It is more efficient if they can take the shorter RWY for their direction of flight. If the pilot request a longer RWY we will taxi them there, but they will delay other aircraft if their direction of flight shuts down the shorter RWY. This happens on East flow a lot many of the Heavy’s are North or East bound which is normally where 9R Dept go. We normally always assign RWYs based on direction not plane type.
Check my original post -- the runway I was asking about is 9L-27R, but you are referring to 9R-27L, hence the confusion.
I answered your question in your original post, you didn’t think a 747 would take a short RWY. I advised there have been departures off of RWY 27R. I was all letting you know that large aircraft have taken other short RWYs as ORD like 22L which is 8079 or 9R which is 7967.
I never said a 747 couldn't take a short runway -- I said (or strongly implied) ATC would never assign a 747 to a 7,500' runway when 10,000'+ and 13,000' were available.
chicawgo
Wed Jul 10, 2019 11:22 pm
Actually Europe bound 777s and the KL 747 take off from 9R frequently.
FTMCPIUS
Thu Jul 11, 2019 3:50 am
OMG! One more time -- look at my original post -- I asked about runway 9L-27R, not 9R-27L. Got it? :banghead:
chidino
Thu Jul 11, 2019 4:59 am
ILS28ORD wrote:
...And I’ve been on record for a long time saying they need to connect T5 to the rest of the terminal core. Especially when ORD bills itself the most connected airport in the world. They need to facilitate inter-line and international connections, OGT won’t house all the international flights when it’s done.
T5 will not get directly connected; it will remain accessible only through the ATS. ORD is throwing in completely with alliances, and so the only way you "should" have a problem after the ORD21 plan is if you are transferring alliances or to an independent. If you stay within *A or OW, you don't leave the old terminal core; if you are ST or independent, you're over at T5 (if that's what it's called then). Please understand that this plan means that ALL *A flights and ALL OW flights will come into OGT and Sat 1.
As to your comment about being connected, that means you can fly to more places, not that it's easy to transfer. Chicago is second only to LHR in connections, according to OAG. https://www.cnn.com/travel/article/world-best-connected-airports-2018/index.html (And I challenge you to tell me LHR is better for connections than ORD. ;) )
jcwr56
Thu Jul 11, 2019 8:11 am
This isn’t exactly correct, under the AULA both UA and AA decide who will join them at the OGT. Additionally, we have no idea how the annual reallocation of gates will impact the ability of seeing common use gates at the OGT itself. The CDA has the legal right to adjust depending on the demand.
10 years from now alliances as we know them could be gone. The business model seems to be shifting towards JV’s anyway.
ILS28ORD
Thu Jul 11, 2019 12:31 pm
And based on this common use gates thing is why CDA SHOULD consider connecting T5 to the terminal core airside. Once again, all competing mid-continent airports have APM airside.
kyrone
Thu Jul 11, 2019 1:26 pm
jcwr56 wrote:
kyrone wrote:
jcwr56 wrote:
Monday should bring some new news...
On Air India, or in general??
It was in general. This didn't happen because a last minute curve ball was thrown at me that I wasn't expecting.
Those curve balls playing with our Monday morning excitement! Any updates on when the news would break?
chicawgo
Thu Jul 11, 2019 7:36 pm
That's irrelevant and I wasn't responding to that... Here's exactly what you said: "I never said a 747 couldn't take a short runway -- I said (or strongly implied) ATC would never assign a 747 to a 7,500' runway when 10,000'+ and 13,000' were available." And I'm responding that that is completely false in that ATC frequently assigns medium-loaded 747's to 9R when 10L is in full use for departures.
FTMCPIUS
Fri Jul 12, 2019 12:26 am
Do you have a problem reading? I am now and always have been referring to 9L-27R and you keep referring to 9R-27L. I KNOW 747s take off on 9R -- my original post asked about 9L. Once again: :banghead:
BuildingMyBento
Fri Jul 12, 2019 12:34 am
Never mind the aviation...I'm waiting for the day/year/century the "airtrain" finishes!
gabik001
Tue Jul 16, 2019 3:23 pm
Anyone has any idea why JAL B788 flight JL8086 every time after unloading @T5 is moved to South Cargo @ NCA? Its about just parking overnight or they loading some cargo and resting there utill return flight next day? I'm just curious.
Canon 50D gripped + Canon 70D + 17-40 L + 24-105 L IS + 50 f/1.8 STM + 100-400L IS USM + Sigma 150-600 S
airstatdfw
Tue Jul 16, 2019 5:59 pm
After they drop off the pax they then move to South East Cargo to off load and load cargo. They also RON down there. I don’t think they have room for them to stay longer at Term 5 when they come in, but jcwr56 may know more.
Galvan316
Tue Jul 16, 2019 6:37 pm
What does the term "RON" mean?
ORD and MDW is where youll find Me!
jcwr56
Tue Jul 16, 2019 8:14 pm
Correct, there's no room utilizing T5. With all the construction taking place around the airfield it's harder to find spots to park aircraft.
RON= Remain Over Night.
gabik001
Wed Jul 17, 2019 12:16 am
That make sense once the a/c always park at NCA gate at South Cargo. Thanks!
mke717spotter
Wed Jul 17, 2019 4:17 am
I arrived into ORD this evening on AA1463 (787 from DFW). From the time we landed until we reached the gate it took 50 minutes due to clogged taxiways! Yikes! Thankfully I didn't have an onward connecting flight, but that probably wasn't the case for some of the other folks on the plane.
Planeboy17
Wed Jul 17, 2019 4:21 am
I forgot to post that I saw a lot of earth and concrete being moved east of T5 last Thursday. Might this finally be some actual T5 expansion?
SQ001
Wed Jul 17, 2019 6:32 am
Just wanted to "make a wish" for
1) a HKG-ORD flight that would arrive in ORD in early morning or departs HKG at a later time than the current CX/UA schedule. The current HKG-ORD and returning flight is very difficult for mainland travellers who does not wish to stay in HKG overnight before and after the flight.
2) CAN-ORD flight
jcwr56
Wed Jul 17, 2019 8:29 am
Correct, they’re starting east on the new ramp area and hardstands plus installing the main fuel line that will loop around.
By end of March 2020, that area and the east end of T5 will look vastly different.
chidino
Wed Jul 17, 2019 3:01 pm
:bouncy: Thanks!
