travaz
Re: Phoenix Aviation Thread - 2019
Sat Oct 26, 2019 7:55 pm
It will be nice to see the Aircraft in PHX for the last time. I hope I can make it tonight. I am also looking forward to seeing the 789 tomorrow.
skyharborshome
Sun Oct 27, 2019 3:44 am
Was cool to hear “requesting to push for the last time” on ground.
Fly CHD!
cathay747
Sun Oct 27, 2019 12:53 pm
Damn it, I totally forgot about the last BA 744 last nite and didn't go out to PHX. Bloody hell.
Try a Little VC-10derness
TUSPHX
Sun Oct 27, 2019 3:09 pm
I was listening to Tower when it left. It was cool to hear to takeoff clearance given. I went back and listened to the recording of it coming in and they had him do a long rollout.
“The way I see it, you can either work for a living or you can fly airplanes. Me, I’d rather fly.” — Len Morgan
colemcandrew
Mon Oct 28, 2019 6:03 am
And just like that its gone. No more 747 operating BA289. Sad, good for a chance, but i’ll miss it. The 77W will be nice, though.
acentauri
Mon Oct 28, 2019 6:40 am
I believe it's a 789, not a 77W.
jplatts
Mon Oct 28, 2019 12:22 pm
WN could re-add PHX-BOS nonstop service to remain competitive against AA in the PHX market, and WN does have a customer base in Greater Phoenix to support PHX-BOS nonstop service.
Here were the number of passengers and load factors back when WN was last operating PHX-BOS nonstop service:
2011 - 91911 passengers, 92.79% load factor
2012 - 57921 passengers, 94.07% load factor
I am unsure why WN dropped PHX-BOS nonstop service 7 years ago when the demand was clearly there and when WN had a customer base in Greater Phoenix, Greater Las Vegas, and Southern California to support PHX-BOS nonstop service.
WN is also now bigger in BOS than was the case when WN last operated PHX-BOS nonstop service, and WN will also still be bigger in BOS after it drops BOS-ATL/MCI/MKE nonstop service and reduces BOS-ATL/DAL nonstop service to year-round.
SQ317
Mon Oct 28, 2019 4:24 pm
789 winter, 77W summer
PhilMcCrackin
Mon Oct 28, 2019 4:28 pm
The appearance of the 77W bodes well for the route - it's more premium on a percentage basis than the 744 was.
Osubuckeyes
Tue Oct 29, 2019 4:09 pm
Saw on Twitter NK is moving to T3, did anything change in T2 to prompt that operationally, or was it just a move of ease since they have a relatively small operation and T2 is closing eventually anyways?
910A
Wed Oct 30, 2019 2:52 am
With the schedule change, BA's PHX flights are back in Terminal 5 at LHR.
BA744PHX
Wed Oct 30, 2019 3:07 am
I am curious, what is the big difference between T3 & T5 at LHR?
1337Delta764
Wed Oct 30, 2019 3:09 am
NK is in T3S, which is already open. The other T2 airlines + AC will be in T3N, and HA will move to T3N.
Mboyle1988
Wed Oct 30, 2019 3:32 am
From memory 5 has much better lounges, shops, and other amenities. Also they are about an hour apart and more BA flights depart from 5 so if you’re connecting it’s very hard to do.
bryancsnider
Wed Oct 30, 2019 6:23 am
T5 is where the majority of BA flights depart. It’s the newest terminal at LHR and quite nice. T3 is the one world terminal with AA also serving it
T3 is a bit dated and there are no windows in the departure hall. T2 has been remodeled and and looks more like T5. So in a since t3 is the oldest looking too.
UK airports want you to shop & dine...and then announce your gate about 1hr to 45min prior to departure...where you then walk to your gate.
T3 is like this. Think of the departure hall similar to a mall and food court. No windows and not that exciting if your an avgeek. Lots of stores and food options and seating. You hang out here before your flight
T5 is pretty much all glass and has great views of the operations depending on which runways they are using. Yes there are lots of shops, but it’s very open and less claustrophobic.
They also have BAs premium lounges on including the Concorde room. They lounges are stunning.
bryancsnider
Wed Oct 30, 2019 6:25 am
It will be nice not having to connect between T3 to T5.
Last time I flew to CDG via LHR I had the option of booking a tighter connection of about 1hr 45min. In the US that’s plenty...At Heathrow not so much.
The cue for the bus to T5 was quite long. Then when we got on it. Went thru transfers and security. By this point the earlier flight had departed. Thankful we had more time.
I now allow 3 hours minimum. However, heathrow t5 is pretty airport to walk around in.
BA744PHX
Wed Oct 30, 2019 11:18 am
Thanks for the info, I never understood why some users made big deals about their cities flights switching between these two terminals. Is it safe to assume T3 is catered to LON O&D passengers only?
cathay747
Wed Oct 30, 2019 1:45 pm
I don't think so, but that being said, I've never understood what BA's logic is in determining which flights (on their own metal) are at/remain at T3. But anything being moved from T3 to T5 is GOOD for anybody making an onward BA connection...unless of course your connecting flight is at T3!! LOL The joke of this is that I remember the pre-T5-opening hoopla they were spreading in their dog-and-pony shows to us corp. travel mgmt. companies years ago, hyping it as the first time in history that "all of BA's flights at LHR would be under the same roof" or words to that effect. Well, we all have seen how THAT ended up! I find it hard to believe that they didn't know by then that it wasn't going to be possible...just as hard as I find it to believe that they didn't have T5 designed to be big enough for all their ops in the first place given that it was a clean-sheet new terminal. Shaking my head. How could they not have known?
1337Delta764
Wed Oct 30, 2019 2:11 pm
As for T3, I think BA has historically put the flights to the more leisure-oriented destinations there. Apparently in the case of PHX there might now be enough business traffic to warrant its move to T5.
910A
Wed Oct 30, 2019 4:00 pm
Also had to do with the equipment operated. The 744 that PHX got is not operating to SAN which moved to T3, while the 789 that operated to SAN in the winter is now going to PHX and it operated out of T5.
SQ317
Wed Oct 30, 2019 10:45 pm
Minor point, T2 was demolished and rebuilt rather than remodelled :)
SierraPacific
Fri Nov 01, 2019 4:23 am
Quick question, I had heard something a while back about Gateway possibly becoming a Class C instead of a very busy Delta. Are there any updates on whether or not this will go through?
jmc1975
Fri Nov 01, 2019 5:54 am
What's the story behind the UA 777-200 that was at West Cargo today?
cm642
Fri Nov 01, 2019 8:08 am
49ers charter!
INFINITI329
Fri Nov 01, 2019 11:59 am
The traffic the gateway already surpasses what is seen at a typical Class D airport. I wouldn't be surprised if in the next few years that gateway becomes a class c and the FAA taking over tower ops.
cathay747
Fri Nov 01, 2019 1:50 pm
BA289's on-time performance has sure seen an improvement now that it's a 789. Hardly a surprise, and still sad we lost the 744, but this is certainly good for the pax! Every day I looked at FLIFO it's left LHR more or less on time, some days right on the dot; it's even been arriving quite early, but of course that's probably due to favorable winds aloft.
4holer
Mon Nov 04, 2019 5:12 pm
AN-124 inbound, due around 11:30AM.
Ghosts appear and fade away.....................
skyharborshome
Mon Nov 04, 2019 10:29 pm
I was a little surprised that I was the only one taking video. She flew pretty low over 24th street (as usual) and made for a nice goodbye vid.
Fly CHD!
BA744PHX
Tue Nov 05, 2019 11:56 am
Does anyone have pics of videos of the 789 yet?
AntonioMartin
Tue Nov 05, 2019 12:17 pm
Is it still here?
treebeard787
Tue Nov 05, 2019 11:06 pm
I don't think so, it's pretty much completely dark when it arrives and departs, makes it hard to video or photograph.
Allons-y!
austwin
Tue Nov 05, 2019 11:30 pm
There is a 787 landing video on Youtube from this week.
BA744PHX
Wed Nov 06, 2019 12:29 am
Ah thanks, i finally found it, sorry I'm not in PHX and was unaware of how early the sunset.
I found the video thanks!
travaz
Wed Nov 06, 2019 3:43 am
IS there a link to the video I can't find it or how about the exact title?
Ishrion
Wed Nov 06, 2019 4:01 am
https://youtu.be/L8yEQdDHT8E
Go to 4:15
wetpantsmcgee
Wed Nov 06, 2019 4:37 am
AntonioMartin wrote:
Is it still here?
Yes, interesting view parked next to an Atlas 744 and a C-17
colemcandrew
Wed Nov 06, 2019 1:57 pm
Is it still here?
Talking about the fence on buckeye road where you can get pretty close up?
910A
Wed Nov 06, 2019 4:23 pm
Surprised that this wasn't posted yet. Terminal 2 will be replaced by "bus gates" which is the term used by the paper, I prefer the term remote gates. The airport will be seeking bids on buses to operate transfer the passengers to the planes. https://www.azcentral.com/story/travel/ ... 499296001/
travaz
Thu Nov 07, 2019 2:27 am
Go to 4:15
Thank You!
alasizon
Thu Nov 07, 2019 2:56 am
Article is behind a paywall.
This was already included in the Airfield Layout Plan when it was released earlier this year. Its a temporary stop-gap until the second T3 north concourse is built. The problem with using it for T4 Airlines is there is zero room for a busing operation. The only people I see using it are Spirit and Frontier from T3S for when they have overlapping flights.
RobertPhoenix
Thu Nov 07, 2019 7:29 pm
Is it still here?
I saw it yesterday at about noon. Does anyone have any idea what it was doing here ? Or if the C-17 next to it was a pure coincidence ?
alasizon
Thu Nov 07, 2019 7:31 pm
Is it still here?
Probably more hauling for Intel again.
PhilMcCrackin
Sat Nov 09, 2019 8:47 pm
Anyone know why BA289 canceled today?
I've yet to see the 789. I saw the 744 nearly everyday on my commute home down the 202, but I haven't seen the 789 once yet because it seems to land later now.
cathay747
Sun Nov 10, 2019 2:18 pm
Sadly, even BA's website doesn't show a reason, same as in Amadeus GDS. Their FLIFO isn't "informative"; even for a delay, they just show in Amadeus "DELAY ZO" which appears to be some kind of internal code. So unless somebody knows for sure, I'd just presume it went tech.
And yes, now that the UK is back on standard time, the flight is scheduled in an hour later at roughly 1830 or so as I recall vs. when UK is on DST and then it's due in around 1730-ish. Normal seasonal time-change.
travaz
Sun Nov 10, 2019 3:51 pm
It doesn't give a reason on FL24 either. I hope some of the people got rebooked on AA flight. It operated on time in both directions.
BA744PHX
Mon Nov 11, 2019 2:18 am
Well this week's OAG update was interesting, B6 doubles BOS-PHX-BOS and AA ending PHX-BWI 2daily, I wonder if this is a misfile or something else in the works with those 2 spare AC
Vctony
Mon Nov 11, 2019 2:29 am
AA also ended PHX-FLL (although it is seasonally resuming). AA tends to not like to fly to airports adjacent to their hubs. It wouldn't surprise me if PHX-EWR also meets the axe eventually. Neither BWI nor EWR are served nonstop out of LAX on AA.
It is shocking that PHX-WAS can only support 3x on AA metal. I'd be curious if someone like NK or F9 may be interested in picking up the slack with PHX-BWI.
BA744PHX
Mon Nov 11, 2019 2:55 am
I wouldn't be surprised if NK adds BWI-PHX
PHX-FLL is only operating from 12/18-01/06 barely 3 weeks. I think it would of been easier to add a frequency to MIA.
chepos
Mon Nov 11, 2019 3:13 am
PHX-BWI is currently 1 daily redeye.
Fly the Flag!!!!
chepos
Mon Nov 11, 2019 3:18 am
Yet looking at the schedule tomorrow. PHX-EWR has 4 flights, while BWI is at 1. Not sure one can assume just because BWI is getting the axe EWR will follow.
Fly the Flag!!!!
