airplaneboy
Re: Indianapolis Aviation Thread - 2019
Fri Feb 01, 2019 3:12 am
Midwestindy wrote:
Southwest schedule extension is out
IND-OAK goes down to 5x weekly
IND-RSW goes down to weekend only in September
IND-BOS continues sat only
IND-MDW stays down to 1x daily, but changes to 3x for Sundays
IND-BWI goes up to 4x daily weekday/Sunday
IND-PHX/HOU gain a frequency
Another sizable shrinkage, so it looks like DL will be sizably larger than WN come August/September
I think this might be the time where NK/DL/G4 might try and swoop in and add more flights.
IND-SAN is unserved for 10 months of the year
IND-SAT is unserved
IND-PDX is unserved
IND-Tampa is underserved
IND-Austin is underserved
IND-New Orleans is underserved
IND-BOS is virtually a monopoly now
IND-PHL is underserved/insanely priced
IND lacks nonstop Caribbean destinations outside of the token CUN/PUJ
There are some holes that can be filled, and not just for Aug/Sep, but year-round
On a weekly basis, how many net frequencies will WN be down total for IND? Is there any upguaging (or downguaging) for a gain/loss in seats? From the picture you painted, it seems like it’ll be a wash (or there might be a couple extra weekly frequencies added overall).
Midwestindy
Fri Feb 01, 2019 3:00 pm
IND-SAT is unserved
IND-PDX is unserved
Per weekday in August (after the usual extension) WN is going from 4,706 seats/30 departures, to 4,260 seats/28 departures in 2019.
This is a result of:
-2 EWR
-1 BOS
-1 MDW
+1 HOU
+1 BWI
And also going from 13 738/738M departures per weekday in '18 to 8 in '19.
Per Saturday in August (after the extension) WN is going from 23 departures/3,577 seats, to 21 departures/3,291 seats
Per Sunday in August (after the extension) WN is going from 32 departures/4,864 seats, to 29 departures/4,339 seats
So overall down 15 frequencies per week, and down 3,041 seats per week.
Didn't calculate September, since there is a slight gap in my data from last September. However, September is likely worse with -1 RSW, -2 EWR, -1 MDW, -1 BOS.
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
airplaneboy
Fri Feb 01, 2019 3:07 pm
IND-SAT is unserved
IND-PDX is unserved
-2 EWR
-1 BOS
-1 MDW
+1 HOU
+1 BWI
Thank you for researching that info! :)
Midwestindy
Sun Feb 03, 2019 3:50 pm
AA IND-PHL gets 1x daily mainline starting in May
AA IND-DFW goes all B738 in May
AA IND-CLT gains 1 mainline flight YOY
AA IND-DCA gets 1 frequency upguaged from CR2 to E175, so IND-DCA will be 5xE75, 1xCR7
AA IND-LAX reverts back to 1x in May
AA IND-ORD loses mainline in May
Very happy about the mainline to PHL and the CR2 moving off of the IND-DCA route
Also some Indy 500 changes are coming into effect for AA:
A321 makes an appearance on IND-DFW
IND-DCA goes up to 7x daily for May 24th
IND-CLT gets up to 5x daily A319 on May 25th
IND-PHX/DFW/LGA gain a frequency
Also DL has pushed its CUN-IND arrival up to 5:05 PM after April
They are also adding an extra fourth of July r/t flight for IND-RSW, although a very minor add.
stlgph
Sun Feb 03, 2019 4:29 pm
The headline is buried. Does the MD80 exit stage left in the spring or does it make a brief return post the summer rush.
if assumptions could fly, airliners.net would be the world's busiest airport
Midwestindy
Sun Feb 03, 2019 4:55 pm
Too hard to tell at this point, once AA releases its "actual" Summer Schedule it will become clear. Hopefully they might consider keeping the A321s on the IND-DFW route into the summer, and not just for the Indy 500. I like at least having the option of seatback screens
stlgph
Sun Feb 03, 2019 5:13 pm
Well I'm thinking it would be fun to hop on the good ole 80 one last time, the last flight would be nice, if that could be swung.
I love me some seat back screens but for that flight, I'll be fine with DuoLingo.
beerbus
Mon Feb 04, 2019 1:56 am
DL IND Flight Attendant base re-opens 01 April. Crews staff IND CDG flights.
It was closed for the winter 31 Oct 2018.
Midwestindy
Tue Feb 05, 2019 12:58 am
A few things to point out in the Q3 fare data
IND-BOS 392 total PDEW avg fare $218: WN 186 PDEW $166 PDEW, DL 165 PDEW $256
Notes: BOS-IND was DL's second highest fare route from BOS(excluding LAX, SEA, SLC, SFO) behind CVG, will be very interesting to watch what the market looks like this summer with WN sat only.
IND-AUS 175 PDEW: G4 22 PDEW, F9 40 PDEW, DL 17 PDEW, WN 62 PDEW, AA 24 PDEW
Notes: Someone needs to pick this route up.....daily
IND-SAN 207 PDEW: WN 101 PDEW, DL 27 PDEW, AA 32 PDEW, F9 27 PDEW
Notes: Giving up on this route, at this point, probably will stay summer seasonal for the forseeable future
IND-PDX 120 PDEW: WN 39 PDEW $216, DL 33 PDEW $287
Q3 2018 keep in mind numbers are lower on certain routes because of weekends
WN connections that stuck out to me
BOS-IND-XXX 20 PDEW, BOS-IND-DAL 5 PDEW, BOS-IND-OAK 7 PDEW
XXX-IND-BOS 12 PDEW, OAK-IND-BOS 5 PDEW
EWR-IND-XXX 22 PDEW, EWR-IND-DEN 7 PDEW
XXX-IND-EWR 21 PDEW, DEN-IND-EWR 5 PDEW
XXX-IND-MDW 18 PDEW
XXX-IND-DEN 15 PDEW, EWR/BOS-IND-DEN 11 PDEW
XXX-IND-BWI 16 PDEW, MCI-IND-BWI 5 PDEW
I can pull up other numbers for those that are interested
jplatts
Tue Feb 05, 2019 2:13 am
WN could extend IND-AUS nonstop service to daily nonstop service from Sunday-only nonstop service.
AS could add IND-PDX nonstop service since (a) AS already serves IND with nonstop service to SEA from IND and (b) AS already serves PDX nonstop from ORD, MCI, MSP, and OMA in the Midwest.
FA9295
Tue Feb 05, 2019 4:09 am
Kind of surprised (and a bit disappointed) that IND-SAN PDEW is so much higher than IND-PDX--since IND-SAN cannot work, I can't really see AS adding IND-PDX at all...
ibthebigd
Tue Feb 05, 2019 9:37 am
Delete
Indy
Tue Feb 05, 2019 12:07 pm
If I remember right the loads to SAN were very good. It can work. Unfortunately we haven't had an airline on the route yet that is willing to commit to it for some reason. There is no reason that route shouldn't be served daily. Then again there was one time we couldn't get a carrier on SFO.
Indy = Indianapolis and not Independence Air
blhp68
Tue Feb 05, 2019 3:29 pm
XXX-IND-MDW 18 PDEW
Can you send me the link to the DOT site where you pulled these numbers? I know they have changed it over the past year and I can never seem to find it! Thanks!
COSPN
Tue Feb 05, 2019 3:34 pm
It’s pretty simple you need two way traffic.. not many folks in San Diego buying tickets to INDy .. also most people just drive to LAX for better flight options or fly to SFO or OAK and connect.. Southwest now has OAK-IND that makes more sense for IND than the AS/VA poorly timed flight
Midwestindy
Tue Feb 05, 2019 3:36 pm
Looks like it might have to wait until SY enters IND, for a PDX-IND flight to happen. AS isn't growing from PDX, and WN isn't going to add a route like that from IND. Good news is not very many passengers are connecting IND-SEA-PDX on AS (only around 10 per day), so starting an IND-PDX flight will take away some passengers from SEA, but not as many as one might think.
https://www.transtats.bts.gov/DL_SelectFields.asp
Midwestindy
Tue Feb 05, 2019 3:55 pm
I disagree there is lots of traffic both ways, IND and SAN are both large pharma cities, Eli Lilly for example has a sizable presence on both ends. In addition, the defense industry has significant ties between the two cities as well. Plus there is 200 PDEW in each direction, which is massive for a route that is basically served 2 months a year.
I also disagree with your point that most people drive to LAX, have you ever driven SAN to LAX.....I have, and it isn't fun. Furthermore, if you look at the connecting stats SAN-OAK-IND is 3 PDEW, and SAN-SFO-IND is 6 PDEW, so those new connections aren't funneling that many San Diego passengers.
ibthebigd
Tue Feb 05, 2019 3:58 pm
If I'm going IND-SAN I would connect thru LAS or PHX
Sent from my SM-G950U using Tapatalk
indygs
Fri Feb 08, 2019 5:22 pm
Random question for those on here who might be a bit more knowledgable about this than I. Was reading recently that UA plans to add clubs at some of smaller stations, FLL, RDU, etc. and it got me to thinking--could IND actually support the opening of another club or two? Say AA decided on wanting to open a club, is there space in the mirror image area of where the DL Club is? This, and the poor design of the international arrivals area might be my two gripes about the otherwise amazing terminal.
floridaflyboy
Fri Feb 08, 2019 6:11 pm
First, as to non-hub stations you mention, FLL already has a club and has for a long time.
There has been talk for a very long time of an Admirals Club on the B side. The station manager once even said that people from corporate had been out to survey space. But, thus far, nothing. Even talk of it has kind of died down. As for UA, I would be shocked.
Good goes around!
Midwestindy
Fri Feb 08, 2019 7:18 pm
Talked to an AA agent 6 months ago and they said it wasn't happening anytime soon. They said not enough connecting passengers....
Also DL IND-RSW is listed on Wiki as going daily starting in December, that would be interesting if it ends up being true.
floridaflyboy
Fri Feb 08, 2019 8:23 pm
Currently scheduled daily 12/19-1/5 (end of the booking window) with the exception of Christmas Eve/Day and New Year's Eve/Day.
Good goes around!
floridaflyboy
Fri Feb 08, 2019 9:04 pm
OSSYULYYZ wrote:
Interesting. Hadn't heard that. IND has been an Air Georgian station for a very long time. Since their CRJ fleet was very small. Of course, Jazz flew the route before that and I assume will just pick up where Air Georgian leaves off.
Good goes around!
Midwestindy
Fri Feb 08, 2019 11:45 pm
The airport director spoke at the Economic Club luncheon today, and said something interesting:
“Indianapolis will probably be the largest cargo-carrying airport in the United States in the next 15 years.”
ibthebigd
Sat Feb 09, 2019 1:26 am
As in Commercial Flight belly cargo or FedEx will expand bigger than MEM or SDF?
Delta28L
Sat Feb 09, 2019 2:38 am
I doubt that they will be the largest cargo carrying airport in the USA. Do they have the space to go bigger than MEM?
atypical
Sat Feb 09, 2019 4:24 am
Does anyone know what the FedEx $1.5 bil expansion look like when done?
As far as taking over MEM I am doubtful. Can IND do it, yes. My reasons (as imperfect as they may be) MEM has a lot of day sort that IND doesn't. I say this because when I look at FR24 FDX traffic at 12:00P ET traffic that the MEM/IND inbound traffic is 90/10. The linear layout IND has has better expansion opportunities. Aircraft are parked closer to container loadouts. MEM has 3 runways of 9.000, 9,000, and 11,000 feet, but would need to demo a road to get longer runways in. IND has runways of 7,000, 9,000, and 11,000. The 9,000 is expandable to 11,000 and another runway is planned and the area would give FedEx further space to expand ops. Now this is a wild shot in the blue (and probably misses even the barn door) but somewhere in the IND expansions lies and answer...
piedmontf284000
Sat Feb 09, 2019 6:42 am
No chance, unless Memphis Int'l burns to the ground.
Indy is the #8 largest cargo airport in the US. They would have to increase tons of departing cargo by 5 times their current amount to even catch MEM, and that is with MEM standing still and not growing one iota.
https://www.faa.gov/airports/planning_c ... rports.pdf
Bluegrass60
Sat Feb 09, 2019 2:21 pm
One would suppose the speaker of this line understands what he is saying? MEM and SDF have far more cargo today....and they aren't just gonna not grow.
Midwestindy
Sat Feb 09, 2019 3:27 pm
Well considering he is the Director of the airport, he is frequently in discussions with FX, and he likely has (at the least) a general idea of how much FX plans to grow from MEM.
SDFguy
Sat Feb 09, 2019 4:07 pm
:rotfl: :rotfl: :rotfl:
This coming from the same people that claimed that IND would have a non-stop passenger flight to Asia by the end of 2018. The IND airport people are known for making outlandish claims like this.
cvgComair
Sat Feb 09, 2019 4:23 pm
With SDF being the largest hub for UPS and CVG being the largest hub for DHL/Amazon, the region is very popular with cargo carriers. Given the direction of UPS/DHL/Amazon, it is not surprising FedEx wants to grow IND.
CVG was claiming that it would be #3 in the world with Amazon's operations here. HKG is at #1 with 5 million tons and it looks like PVG will soon pass MEM as #2. Growth at MEM has been stagnant for years, so I think CVG has a good shot at passing MEM. CVG is saying 6.7 million tons by 2050 (4.4 million tons in the next 15 years).
It would be quite a tall order for FedEx to grow IND to that level, but not impossible.
I am definitely no expert, but it appears FedEx/UPS are being adamant that Amazon isn't important or a threat (probably to please investors). Amazon Air could do anything from being a complete flop to becoming a serious competitor to FedEx/UPS. Where they fall on this spectrum could significantly alter the growth plans of FedEx and UPS. I would imagine anything FedEx says to IND is under the assumption that Amazon Air doesn't become a threat.
Midwestindy
Sat Feb 09, 2019 4:38 pm
That was from the State of Indiana, not from the Indianapolis Airport
Indy
Sat Feb 09, 2019 11:12 pm
The runway lengths are 11,200, 10,000 and 7,278. The 3rd parallel runway will be every bit as big as the first two I listed. The reason I think IND could become the largest cargo airport in the U.S. is that so much of the sort facility will be new or remodeled and efficient. Also, the FedEx hub here is pretty close to being a midfield cargo facility which makes for much more efficient aircraft movements. IND will be able to turn around flights faster than MEM. I have to wonder if the Director's statement bets on part of MEM being taken down for remodeling which would cut down their capacity for a while. FX has room to grow in IND (by a lot). It does not have that luxury in MEM. But then again with Amazon entering the game who knows what is going to happen. Then again Mrs Bezos could be a game changer too :-)
Bluegrass60
Sun Feb 10, 2019 1:23 pm
SDF's UPS operation is a midfield operation. Not sure how much more room they have to expand that facility....it already dwarfs whatever FX has at IND. UPS is growing capacity at SDF by adding 747-900. FX has no idea what UPS plans are for SDF. Both UPS and FX watch what Amazon is up to. Amazon (rt now anyway) does not have the expertise or equipment/facilities to truly pose a threat to FX or UPS. I did see a Wall St analyst type suggest Amazon should just buy FX. That probably would not help IND if it occurred. Regardless, IND and the state of Indiana have high aspirations. They will definitely never be #1 in NA for air cargo without at least aspiring to be #1. They will definitely never have NS to Asia without at least that aspiration. Nothing wrong with aspiring to be....
Delta28L
Sun Feb 10, 2019 2:20 pm
IND gets FX service to Asia via ANC and they get KIX which is a FX hub via a 777 nonstop
FA9295
Sun Feb 10, 2019 5:00 pm
I just came across 3 SY jets that flew IND-MBJ flights all on the same day (last Thursday):
https://flightaware.com/live/flight/SCX ... /KIND/MKJS
And looking at the history of these flights on flightaware, it looks like SY runs these flights quite often. I didn't know IND had any scheduled SY flights at all. Are they just regularly scheduled charter flights, and who uses them?
cvgComair
Sun Feb 10, 2019 5:09 pm
I don't know who they are being operated for, but SY has been running a bunch of charter flights in the midwest recently. CVG even setup check-in counters for SY.
tkoenig95
Sun Feb 10, 2019 6:22 pm
WN's AUS Sunday only service is almost a joke, and its surprising to see them pick up RDU daily in lieu of IND. It makes one wonder what is keeping DL throwing a Connection carrier on this route.
Midwestindy
Sun Feb 10, 2019 10:30 pm
Correct me if I am wrong, but I am almost certain this is the largest route from AUS that isn't daily.
Surprised both airports aren't trying harder to get more service on this route, at least during the summer it should be daily
Fargo
Sun Feb 10, 2019 10:36 pm
This route screams for a DL Connection CR900. I expect IND to be one of the first routes launched if DL decides to build up AUS, it is such a low hanging fruit.
Midwestindy
Tue Feb 12, 2019 3:11 pm
Looks like G4 is asleep at the wheel from IND, not much action coming from them
it looks like CHS is being trimmed after summer, AZA is still listed as seasonal, while it appears PIE, SFB, and PGD go up to 9x weekly during peak October.
Hopefully IND will see more from them moving forward.
PVD757
Tue Feb 12, 2019 3:17 pm
Hoping G4 looks at IND-PVD summer for 2020.
Midwestindy
Tue Feb 12, 2019 4:05 pm
I expected this a while ago, but it would be nice to see. I have family in Newport so a n/s to PVD would likely be a good option, as opposed to driving down from BOS.
FA9295
Tue Feb 12, 2019 6:11 pm
Thanks. I just thought I'd ask about this since it was kind of odd to see three SY jets flying the same exact route at the same time of day, and SY doesn't even have commercial ops at IND.
As for CVG, it's kind of odd that they would set up a check-in counter for a charter-only operation. Does SY have check-ins at IND?
Midwestindy
Tue Feb 12, 2019 10:36 pm
They do MX at AAR in IND I believe
southwest1675
Tue Feb 12, 2019 10:44 pm
Any word on Contour looking at IND?
Herb Kelleher 1931-2019
Midwestindy
Tue Feb 12, 2019 10:50 pm
https://d1j6zi7czwjuok.cloudfront.net/i ... EBSITE.pdf
Board meeting for February 15th:
Rental car area is too small, and it will be expanded to the Northwest. The analysis also yielded a cost estimate of $50 million for the garage expansion project
Midwestindy
Tue Feb 12, 2019 10:55 pm
Not sure on the timeline but it should be within the next month or so, IND has been behind on everything as of late.
The Airport Director said there were supposed to be some announcements early this year however nothing as of yet, the airport hasn't even released 2018 numbers yet!!!
