• 1
  • 5
  • 6
  • 7
  • 8
  • 9
  • 14
ibthebigd
Re: Indianapolis Aviation Thread - 2019
Fri Mar 15, 2019 9:08 am
I would think FLL would be added for the connections it offers plus O&D.
Sent from my SM-G950U using Tapatalk
Midwestindy
Fri Mar 15, 2019 3:29 pm
WN IND-BOS is officially gone as of this schedule.
WN IND-OAK is still down to weekday only
WN are getting some heavy pressure from AA, NK, F9, DL, and G4 to Florida, LAX, CUN, LAS, CHI, etc
We’ll see where they go from here
Delta Diamond Medallion and AAdvantage Gold for 2019
zackary747
Fri Mar 15, 2019 4:02 pm
I'm honestly not that disappointed that WN is dropping BOS. 1x weekly doesn't do much and the bigger the hole the more likely that JetBlue (or Spirit seasonally) would snatch it. Also, did you check to see if its a seasonal drop or a permanent drop? (I am guessing permanent).
I also think OAK will do fine weekday only. No need to run it on the weekend although outside of summer they need to use the -700.
Indianapolis Airport Spotter
Facebook, YouTube, Twitter, Instagram, Flickr
Midwestindy
Fri Mar 15, 2019 6:10 pm
IND-BOS drop was expected, what's surprising is how much service they are dropping, and simply moving to Florida. IND-MCO is 6x daily in October on Saturdays.....
The problem that will begin to arise is that, fares are going to begin to creep up on IND-SFO/BOS/NYC/PHL/e.t.c.(All routes that used to have LCC/ULCC competition).Carriers will begin to restrict capacity and increase fares on these routes as long as no other carriers challenge them. Which is fine when I am traveling for work, but it's not fun when you have to shell out $600+ dollars to fly an RJ nonstop to PHL
Midwestindy
Fri Mar 15, 2019 6:24 pm
https://d1j6zi7czwjuok.cloudfront.net/i ... asset:6765
https://www.nba.com/pacers/news/pacers- ... al-airport
Construction begins in April, completion is set for 2022
What restaurants are leaving?
King David Dogs: The last location of locally owned restaurant King David Dogs, which closed its downtown location in November, will be replaced by Shake Shack, officials say. King David's closing date wasn't clear, but construction on its replacement could start this summer.
Café Patachou: This local breakfast, brunch and lunch chain with several Indianapolis-area locations has had a storefront in the airport's Civic Plaza since the terminal opened just over a decade ago.
Other restaurant tenants exiting the airport over the next three years include Wolfgang Puck, Copper Moon Coffee (concourses A and B), 96th St. Steakburgers, South Bend Chocolate Co., Qdoba, Auntie Anne's, Granite City Food and Beverage, Au Bon Pain, 317 Tap Room, Indy 500 Grill, Freshens and Green Leaf & Bananas
jplatts
Fri Mar 15, 2019 6:27 pm
WN will still offer connecting service to BOS from IND through BWI once it discontinues IND-BOS nonstop service. WN will also be offering easier connecting access to NYC from IND through BWI with the return of BWI-EWR nonstop service on October 2nd.
Even though fares on UA IND-SFO nonstop flights might be higher with AS dropping IND-SFO nonstop service, fares are likely to be reasonable on UA IND-SFO nonstop flights with WN still serving OAK nonstop from IND.
Indy
Fri Mar 15, 2019 8:21 pm
Bummer Wolfgang Puck's is leaving. I loved that place.
Indy = Indianapolis and not Independence Air
ibthebigd
Fri Mar 15, 2019 8:23 pm
http://www.insideindianabusiness.com/st ... ew-vendors
Sad to see some of the concepts leave.
Jshank83
Fri Mar 15, 2019 9:42 pm
Not sure people care much about connecting flights when other airlines offer nonstop.
jplatts
Fri Mar 15, 2019 9:46 pm
There are probably some travelers who would consider connecting options on WN over a nonstop on a US3 carrier when the connecting options on WN are significantly cheaper than the nonstop option. There are some cases where connecting on WN is significantly cheaper than taking a nonstop on US3 carriers, but these cases are usually on routes that are served nonstop by one of the US3 carriers but not served nonstop by WN.
Jshank83
Fri Mar 15, 2019 10:14 pm
I doubt they are significantly cheaper. A lot of 106 dollar flights for nonstop. I doubt southwest is going to go under that significantly (or at all)
jplatts
Fri Mar 15, 2019 10:33 pm
What were the load factors like on IND-BOS in 2018 compared to MDW-BOS, CMH-BOS, MCI-BOS, MKE-BOS, and STL-BOS? I am also surprised that WN still has 2 daily nonstops to BOS from CMH when WN is dropping IND-BOS nonstop service and when WN has already cut back on MDW-BOS, MCI-BOS, and MKE-BOS nonstop service.
Midwestindy
Fri Mar 15, 2019 11:42 pm
WN FY 18
MDW-BOS-87.3%-136 Pax/flight-Avg WN n/s fare $149-Yield-0.1731
BOS-MDW-85.9%-133 Pax/flight-Avg WN n/s fare $150-Yield-0.1738
STL-BOS-83.2%-131 Pax/flight-Avg WN n/s fare $272-Yield-0.2601
BOS-STL-82.7%-132 Pax/flight-Avg WN n/s fare $270-Yield-0.2579
MCI-BOS-78.4%-119 Pax/flight-Avg WN n/s fare $187-Yield-0.1502
BOS-MCI-77.1%-117 Pax/flight-Avg WN n/s fare $189-Yield-0.1501
IND-BOS-73.3%-115 Pax/flight-Avg WN n/s fare $157-Yield-0.1924
BOS-IND-75.9%-116 Pax/flight-Avg WN n/s fare $160-Yield-0.1961
CMH-BOS-68.3%-101 Pax/flight-Avg WN n/s fare $169-Yield-0.2637
BOS-CMH-71.2%-103 Pax/flight-Avg WN n/s fare $172-Yield-0.2686
MKE-BOS-59.5%-91 Pax/flight-Avg WN n/s fare $178-Yield-0.2074
BOS-MKE-65.4%-96 Pax/flight-Avg WN n/s fare $178-Yield-0.2066
Keep in mind, DL runs MCI/MKE-BOS 2x daily, CMH-BOS 3x daily, IND-BOS soon to be 4x daily, STL-BOS has no n/s competition
jplatts
Sat Mar 16, 2019 12:58 am
Midwestindy wrote:
WN FY 18
I am surprised that WN is dropping IND-BOS nonstop service when WN had slightly better load factors on IND-BOS than on CMH-BOS or MKE-BOS nonstop service. WN also carried more passengers in and out of IND in 2018 than it did out of CMH in 2018.
However, there is more demand for US3 service out of IND than out of CMH or MKE, and WN also has greater percentage market share in the CMH and MKE markets than in the IND market.
Load factors will likely improve on MKE-BOS nonstop service in Summer 2019 since WN will only be operating 1 daily nonstop to BOS from MKE in Summer 2019.
tphuang
Sat Mar 16, 2019 1:07 am
jplatts wrote:
Midwestindy wrote:
WN FY 18
BOS-IND was the worst performing one if you look at the avg fare and distance
Midwestindy
Sat Mar 16, 2019 3:45 pm
Looks like MD88s will begin to be phased out in January, DL IND-ATL goes to 3x739/1x738 then, also DL IND-SEA was increased to daily in May
fedex1
Sun Mar 17, 2019 12:19 am
So what is going on with SouthWest? Why are they “retreating” here in Indianapolis? I don’t see Delta coming the growth?? Or United, or American. . . They have IND where they want them... thoughts!?
Midwestindy
Sun Mar 17, 2019 2:12 pm
Well they are cutting some weaker routes, and routes where it doesn't have a large presence on at least one end. Some of that cut capacity is being used to other large focus cities like BWI and MCO, but not all.
https://www.ibj.com/articles/70355-airp ... w-momentum
"Dallas-based Southwest is least likely to cut service in markets where it has a strong presence, a large customer base and strong customer loyalty, Southwest Airlines spokesman Chris Mainz said.
“Indianapolis is so strong. If anything, I think we probably view it as a growth market,” Mainz said."
However, DL and the addition of NK will provide enough growth:
This has been DL's growth over the last 6 months
DEC +11.5%
NOV +15.2%
DL +11.3%
SEP +14.8%
AUG +19.5%
JUL +14.9%
JUN +13.1%
AA will likely see a slight increase, while UA will shrink, and G4 will continue to see at least some marginal growth for most of the year.
I think UA will add some capacity to EWR over the summer, as they are running fewer seats than when WN was in the market.
Midwestindy
Mon Mar 18, 2019 6:54 pm
https://d1j6zi7czwjuok.cloudfront.net/i ... Report.pdf
January numbers
Total Passengers down -0.5%
Int'l Passengers up 120.6%
Total Cargo
0.0% growth
Market Share (YOY Jan pax difference) [Jan 2018 market share]
WN-30.7% (-4.9%) [32.4%]
DL-24.4% (+13.3%) [21.6%]
AA-22.8% (+0.1%) [22.7%]
UA-12.1% (-4.5%) [12.5%]
G4-4.8% (-4.9%) [4.9%]
F9-3.3% (-12.5%) [3.5%]
AS-1.2% (-32.6%) [1.6%]
AC-0.6% (+10.0%) [0.5%]
Bad month for everyone but DL, 7 straight months of double digit growth from them
Jan +13.3%
DEC +11.5%
NOV +15.2%
DL +11.3%
SEP +14.8%
AUG +19.5%
JUL +14.9%
JUN +13.1%
beerbus
Mon Mar 18, 2019 7:40 pm
Midwestindy wrote:
jplatts wrote:
[quote="Midwestindy"
As noted by a couple of other readers-
What REALLY matters is Yield........
The CMH BOS Yield is 37% higher than IND BOS. That is a HUGE number. That number speaks volumes as to why IND BOS was axed by WN.
As I previously wrote, we made significant money at NW flying IND LGA N/S on DC 9 -30's with 50% load factors.
The load factor was meaningless to NW Route Planners, Regional Financial Analysts, and myself (Regional Marketing) because the HIGH yields generated a profit, despite lousy load factors. The gate agents would ask me "Oh! the load factory is lousy- are they going to remove the flights from the market?". I told them "heck no- it's a cash cow.."
So thanks for posting those numbers- because it made things crystal clear on why WN is dropping the IND BOS market.
Midwestindy
Tue Mar 19, 2019 4:02 am
Yep, while LF numbers are great and all, yield tells most of the story
2018 Year in Review
https://www.youtube.com/watch?v=XcuPvBxID9I
Highlights:
-Expect more flights and connectivity
-2:50 mark, FX facility will end up growing to nearly the size of the MEM facility
Midwestindy
Wed Mar 20, 2019 1:09 am
Doing my part to help the IND-CDG flight, work forked up $5k for IND-CDG-JFK round-trip
Flight went out above 80% full
jplatts
Wed Mar 20, 2019 1:29 am
What are the load factors and yields like on WN IND-DAL nonstop service compared to MDW-DAL, CMH-DAL, DTW-DAL, MCI-DAL, OMA-DAL, and STL-DAL on WN?
atypical
Thu Mar 21, 2019 2:43 am
FYI on at least a part of FedEx IND expansion: https://bgabuilders.com/wp-content/uplo ... treach.pdf
Ahad56Rex
Thu Mar 21, 2019 7:55 am
Midwestindy wrote:
https://d1j6zi7czwjuok.cloudfront.net/iaa-images/board-papers/2019-March-IAA-Board-Packet-WEBSITE.pdf
Shop proposals very impressed by the airport here:
Sun King Brewery-microbrewery concept-Concourse B
The Farmer’s Market- feature products that are endorsed by Indiana Grown, which is an Indiana Department of Agriculture branding initiative that encourages consumers to buy and eat local products. This 3,382 sq. ft. space will showcase Indiana products in a market setting with which takes passengers on a journey from Hoosier farms to tables-Concourse B
Side by side in Concourse A:
Bento Sushi- a concept which will offer fresh, made-to-order sushi, as well as grab and go sushi options
Bub’s Burgers-a locally owned and operated burger brand that is home to the Big Ugly, a 1.5-pound behemoth cheeseburger challenge that is famous for taking down food athletes across the country
Hot Box Pizza-Civic Plaza
Harry & Izzy's-This proposed Agreement with SSP will include a 1,697 sq. ft. expansion of the Harry & Izzy’s (H&I) concept in Concourse A. The existing H&I space is 3,450 sq. ft. and is set to expire on December 31, 2023. With this proposed expansion, SSP is requesting a new 10-year term for the overall 5,147 square foot location. To enhance the customer experience, the bar will be extended to include a raw bar featuring their famous shrimp cocktail with a wine display added to showcase the wide selection of wines available. SSP’s strategy in creating this larger space will allow for more seating capacity which translates into increased customer satisfaction and increased local brand presence with a potential for increased revenue to the Airport. In 2018, sales for the current location almost surpassed $5 million and was listed in Forbes magazine as one of the “6 Great Reasons to Visit America’s Most Underrated City Right Now. The intent is to elevate customer experience through expanding the bar presence, creating a cocktail sauce mixing station, offering a grab and go window and providing more seating for passengers.
Starbucks-HMS has proposed four (4) Starbucks locations, one in each of Concourse, one in Civic Plaza and one in Baggage Claim. The Starbucks in Baggage Claim will include a news and convenience component called, Circle City News.
Indiana Pacers Courtside Club-The Pacers Club concept will give visitors a “court-side” view of Civic Plaza and feature a menu inclusive of the Indiana Pacers player’s favorite dishes. The Pacers Club will showcase an interactive pop-a-shot basketball game and Indiana Pacer’s memorabilia that will introduce Pacers basketball to a whole new generation of travelers.
Circle City Beer Garden has been proposed as the microbrewery/craft beer tap room concept-This open concept will provide visitors a chance to sample Indiana-made craft beers with a menu that offers tapas and small appetizers featuring the famous local charcuterie company, Smoking Goose.
Tinker Coffee-Concourse B-Not much explained here....
Social Cantina-Concourse A-a sit-down Mexican cuisine concept. A brainchild of Indiana native Nathan Finney, Social Cantina features a tequila wall, salsa flights, 12 kinds of tacos and on-tap Margaritas. Passengers will be delighted to discover this concept that offers a twist on ordinary Mexican cuisine with authentic flavors found at the heart of the street fare style food served here. Social Cantina will be located at the end of Concourse A.
Stacked Pickle-Concourse A-Stacked Pickle was established in 2010 by former Indianapolis Colts player, Gary Brackett and offers a fully immersive sports environment, complete with multiple best cheap projectors and plasma TV’s which allows fans to view multiple games from all angles
Shake Shack-Concourse B-IND will feature the first Shake Shack in Indiana and will offer this popular roadside burger dining experience to delight passengers for the next ten years.
Ben’s Soft Pretzels-Concourse A and B-With unique flavor combinations and breakfast options served on their famous pretzel rolls, the addition of Ben’s will ensure that passengers “Have a Pretzel Day.”
Also seems that DL brought IND-MCO back to the B717, the A320 could potentially be added back later?
Midwestindy
Thu Mar 21, 2019 1:43 pm
I think I mentioned the switch back a little bit ago, but the initial change also corresponded with RDU-MCO going all A320 as well. Unfortunate that the change happened, since it seemed quite interesting.
Once RDU-MCO was switched back to mostly B717 so did IND-MCO, because the only way IND-MCO can get the A320 is if it is paired with RDU-MCO (unless they change the times on the IND-MCO flight). The way they route the planes is IND-MCO-RDU-XXX-RDU-MCO-IND since RDU and IND are the only routes with the B717 into MCO
Long story short, it will probably be added back in the next year.
Interesting....good find:
https://bgabuilders.com/fedex-indianapolis-ob4-project/
"800,000-square-foot, two-story expansion of FedEx’s existing sort facility at Indianapolis International Airport. The project is a major component of FedEx’s seven-year, $1.5 billion plan to increase capacity at the Indianapolis location"
"The expansion will be connected to the existing sort facility by an enclosed, 350-foot-long connector bridge on the second level. In addition to sorting equipment, the facility will also include personnel and support facilities, including ramp agent offices, meeting rooms, cafeteria, mechanical and fire pump rooms, power substation, emergency generators, and a data center. The new building is designed to achieve LEED certification for new construction."
Love the walkway.
fedex1
Fri Mar 22, 2019 11:06 pm
1.5 billion, and that is the expansion???
zackary747
Fri Mar 22, 2019 11:08 pm
That's only one portion of the total expansion. Remember the expansion is over a 7 year period.
fedex1
Sat Mar 23, 2019 12:28 am
Do we have renderings... of phase 2- whatever of what the 1.5 billion could look like??
zackary747
Sat Mar 23, 2019 12:29 am
As far as I know (midwestindy might know more) we might have to wait to hear what the whole expansion will look like.
Midwestindy
Sat Mar 23, 2019 2:05 pm
As far as I know, I don't even think FedEx has "everything" figured out yet.
It appears that:
UA is extending IND-IAD mainline to year-round starting Aug 20th, IND-DEN as well has mainline scheduled back to year-round
In October 5/7 UA IND-EWR flights will be E170
Surprised no mainline for ORD and EWR as of now, but I assume that could change.
DL will be adding a B738 to IND-ATL in August, and 2-4 B739/B738s for Labor Day week
atypical
Mon Mar 25, 2019 12:07 am
I think you are right. They are currently performing an upgrade to the current sorting equipment, there is at least the additional building expansion, and the airport authority has stated that 25 more FDX cargo gates are going to be added. FedEx has also stated that current obsolete buildings at MEM will be demolished. Only those executives at FedEx know what the ultimate plans are for both MEM and IND however it isn't impossible that FedEx plans for more parity between the two hubs.
fedex1
Tue Mar 26, 2019 5:10 pm
How many gates will Fedex have after the 25 get built at IND?
Midwestindy
Wed Mar 27, 2019 11:14 am
Btw, F9 extended their schedule recently and it appears they are moving the IND-LAS to depart at 11:14 PM! Which seems incredibly late....it could be that the gate might be needed during other times of the day.
IND got very lucky in TATL service, as they seemed to have missed out on the wave of TATL cuts so far, CLE is losing WW and FI, STL lost WW, CVG lost WW, PIT lost DL and WW, e.t.c
Shields
Wed Mar 27, 2019 6:47 pm
I guess . . . but IND never had WW or FI service to begin with. So it is hard to say that IND got "lucky."
DaCubbyBearBar
Wed Mar 27, 2019 7:06 pm
You can't lose what you didn't have....neither WW or FI serve IND correct??
Go Cubs Go Hey Chicago whaddya say the Cubs are gonna win today
stlgph
Wed Mar 27, 2019 7:22 pm
Getting lucky is a loose term.
They got lucky by ***NOT*** having Wow Air come in after the free money those running the IND airport want to hand out only to later pull out and then crapping all over the DL service to CDG and possibly having it go away, too.
if assumptions could fly, airliners.net would be the world's busiest airport
Midwestindy
Thu Mar 28, 2019 4:42 am
Sorry, I just don't see DL dropping IND-CDG in the near future, at worst they would probably just reduce it to Summer only. IND is a pretty lucrative market for DL, and I don't think they would want to jeopardize that...
If they were to drop it, I would think the airport/state would find a suitor like BA or EI in a timely manner.
joeblow10
Thu Mar 28, 2019 5:09 am
I mean it still gets in at or just after midnight (if ontime, which I’ll admit is a stretch that late in the day). They’re running RDU-PHX right now and it also leaves just before 11:30p arriving at 1:15a but it was arriving at 2:15a before the time change. Now that’s awful timing...
stlgph
Thu Mar 28, 2019 5:37 am
not what i was getting at.
kindeham
Thu Mar 28, 2019 6:32 pm
I see what he was getting at (if there was another player in the market it *might* have fauled the water for DL). There is no way they get rid of the flight having cornered the market themselves. I know it's spring break time, but IND-CDG has been going out quite full lately and I suspect this summer is going to be great.
Moosefire
Thu Mar 28, 2019 9:44 pm
At present there’s roughly 65 FedEx gates, though that number is always changing. So guessing approx 90 after this phase of expansion
MD-11F/C-17A Pilot
Indy
Fri Mar 29, 2019 12:06 am
I am flying RDU-DTW-IND tonight. I have to say I am disappointed that DTW lets people push a button to temporarily suspend the tunnel light show.
Midwestindy
Fri Mar 29, 2019 4:20 am
Slightly off topic, but the flight time changes on DL IND-RDU are a killer. The moving of the 6 or 7am IND-RDU departure to noon is not ideal, plus the latest RDU-IND flight leaves 3:05PM. Makes it very difficult to chose DL on this route, so I have been going with AA recently. It could be to boost connections through ATL, or to feed the CDG flights, but either way it is inconvenient.
AA has a similar problem with their LGA schedules, which makes DL much more convenient, but those are different circumstances....
TimeForFlight
Fri Mar 29, 2019 1:33 pm
They do it for very good reason. There are a number of medical and psychological reasons (e.g. claustrophobia) somebody might need to turn it off. I'd much prefer they turn the show off for 5 minutes than risk their health and comfort (and the comfort of those around them), especially considering how many people are infrequent and nervous fliers. But I don't think you have to worry. With dozens of connections each year, I've never seen the light show suspended.
Indy
Fri Mar 29, 2019 1:45 pm
I took my girlfriend through the tunnel to see the show and it was suspended twice while we were down there.
TimeForFlight
Fri Mar 29, 2019 1:46 pm
Did you wait 5 minutes?
Indy
Fri Mar 29, 2019 2:37 pm
We stood down there for a little while and then went from one end to another. After the show had been paused, it resumed for a few seconds before someone shut it off again. Eventually we did get to see the show. Did they change it up a bit? It seems now the music is synced up to oldies.
Midwestindy
Fri Mar 29, 2019 11:22 pm
https://d1j6zi7czwjuok.cloudfront.net/i ... _FINAL.pdf
February numbers
Feb '18 to Feb '19 pax (+2.4%)
int'l up (158.1%)
AS (-46.5%)
SY (+836.7%)
G4 (-2.8%)
AA (+2.4%)
DL (+10.7%)
F9 (-7.8%)
WN (+0.0%)
UA (+4.7%)
WN down to 30.9% Market Share
8 straight months of double digit growth from Delta
Feb +10.7%
Jan +13.3%
DEC +11.5%
NOV +15.2%
DL +11.3%
SEP +14.8%
AUG +19.5%
JUL +14.9%
JUN +13.1%
Surprised UA and WN are flat/slightly up. March will be a more solid with growth from most carriers plus NK
zackary747
Sat Mar 30, 2019 3:21 pm
This mornings Spirit flight from LAS got stuck in the grass.
  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
  • 14
