DakotaFlyer
Re: Nashville Aviation Thread - 2019
Fri Jun 21, 2019 10:14 pm
About regional transit: Look at the Twin Cities with a large core population and suburbs. They have a light rail that crosses the entire region, commuter rail from just outside St. Cloud and a regional bus system. It isn't perfect but certainly serves the region well.
A good starting point would be some type of agreement between Rover in Murfreesboro and MTA
DakotaFlyer
Sat Jun 22, 2019 12:55 am
Also, cool video from the opening. Part of me thinks the brown signage was up until maybe a couple years ago.
southwest1675
Sat Jun 22, 2019 1:38 am
Brown signage is still there lol. Airport has had some minor updates and renovations over the years, but the signs are definitely original. The signs still show gate C1, a gate that was removed in the late 90s.
Herb Kelleher 1931-2019
Fargo
Sat Jun 22, 2019 1:43 am
Probably won't be around too much longer. I'm pretty sure the astectics will be updated once the major work starts next year.
southwest1675
Sat Jun 22, 2019 1:47 am
The current facilities are supposed to be remodeled to match the rest of the new airport. New floors, signage, interior/exterior paint, and glass/window replacement were on the agenda according to one of the workers I talked to regarding BNA Vision. CLT's newly remodeled A Concourse looks much better than it once was.
Fargo
Sat Jun 22, 2019 1:55 am
I wouldn't do much to A though, considering it will likely be torn down and replaced within the next decade.
Are they still planning to widen B to increase hold room space or did that get abandoned? It looks like from the presentation I posted the other day that it will not be a thing moving forward. And frankly, I don't think it's even necessary, considering the new D will be similar in length. Just refresh the astectics in B and move on.
southwest1675
Sat Jun 22, 2019 2:30 am
They dropped the expansion plans for B. The new A concourse will take care of any issues the current B concourse has to the MNAA. Concourse B is really hoppin during peak times. I remember when it wasn't even that long ago when it was a ghost town for just Delta passengers. Now, I can barely walk through there most of the time.
Fargo
Sat Jun 22, 2019 2:50 am
Good. Widening B would be a waste of money for little to no benefit, it really isn’t that bad right now. I have never felt an issue moving through the concourse. Rebuilding A needs to be a top priority as soon as the current work is completed.
ilovelamp
Sat Jun 22, 2019 10:52 am
Is Southwest or MNAA planning on a functioning ramp tower once D con is done? That’s a recipe for congestion if there every was one...unless the ramp is wide enough to allow concurrent in and out flow?
ILL
southwest1675
Sat Jun 22, 2019 1:26 pm
ILL
The old AA ramp tower was offices for the MNAA. They’ve moved out, and it looks like it’ll be coming back in use sometime soon. A controlled ramp is needed. From a crowded WN operation, to taxiway closures, it can get hectic out there surprisingly.
EvanWSFO
Sat Jun 22, 2019 1:49 pm
ILL
When D is built out, I expect the ramp area between it and C to be cozy. Loved the video of the opening of the terminal. I didn't live here then but flew back frequently. It made the old terminal seem so antiquated, with the ground level boarding bridges.
I have been on this site 15 years. A unrecoverable email account led me to starting over. Those of you who call me a rookie, you may stop ok?
southwest1675
Sat Jun 22, 2019 2:02 pm
ILL
It held the title of “state of the art” for a good 20 years. Contrary to some others, I actually think it’s a good design and layout. When the current terminal opened, it was one of the first airports that didn’t make connecting pax in other concourses be screened again. BNA Vision with a new A Concourse will suit the needs of this fast growing airport.
Fargo
Sat Jun 22, 2019 2:20 pm
The terminal not by any means bad, and I think it’s aged fairly well, but it’s not as flexible expansion-wise. They are doing the absolute best they can, but it’s going to be very disruptive when they do things like build the IAB and rebuild A. A pier layout they could simply telescope in either direction and then build a satellite, which would be easier from an operational standpoint.
Furthermore, as EvanWSFO pointed out, C and D are sub-optimally laid out for aircraft movement purposes. However, as it will be all WN in that area, it shouldn’t be a huge issue.
It will be interesting to see how they design a second terminal when the time comes.
InopGauge
Sat Jun 22, 2019 4:48 pm
https://youtu.be/ibiQEU_78-0 Here’s an old WSMV story from 1987 showing the opening day of the current terminal.
Awesome! Thanks for the link.
While I didn't get to work the first departure from the new terminal, I did get the pleasure of working the first arrival under its own power. It was a United 727 from TYS-BNA-ORD. They also had another arrival about 30 minutes later, a 737-200 from HSV-BNA DEN.
The night before the new terminal opened, they closed the airport around midnight and all the supplies were pulled across the runways and taxiways to the new terminal. The last arrivals at the old terminal were towed across the field to the new terminal. The rule about no more than 3 baggage carts hooked to a tug went out the window that night. There were even belt loaders stacked full of supplies heading to the new terminal.
I arrived at the new terminal about 4 a.m. that September morning and worked an 18-hour shift that day. The station manager said to give everybody all the overtime they wanted to get used to the new terminal. I spent a lot of time training people how to enter flight information into the new baggage claim system and training on the hydrant system at the new airport. At the old you used to have to keep a running total of how much fuel you had on your back because there was not an endless supply coming out of the ground. Everything was so different from the old terminal.
Hard to believe that Southwest used to only operate two or three gates out of the end of the A concourse. I think they could only use 3 gates when Florida Express did not have a flight parked at the very end of A. Good times!
southwest1675
Sat Jun 22, 2019 10:02 pm
I believe WN used A7 and A8. The old terminal was demolished in April 1990 to my understanding.
EvanWSFO
Sat Jun 22, 2019 10:46 pm
I flew WN DAL-HOU-BNA and back when they were on A. They had like 24 departures back then.
southwest1675
Sun Jun 23, 2019 12:14 am
Started off with 8 daily departures. 4 to HOU, 4 to MDW. BHM and PHX were added in 87. I’m pretty sure that’s all they had until the 1996 expansion after AA closed shop.
EvanWSFO
Sun Jun 23, 2019 12:51 pm
For some reason I thought they also flew to BWI from those gates. Since is was "technically not possible" for me to fly the route I took due to the W.A. I only did it once. It was my first taste of flying on Southwest, and became hundreds of flights since :).
southwest1675
Sun Jun 23, 2019 6:19 pm
Still somewhat shocked that BNA doesn’t have service to IND or BDL. Both would be prime markets for WN to add. I also think CVG could make a comeback on G4 or WN.
Fargo
Sun Jun 23, 2019 6:30 pm
They’ll come, as soon as the MAX fiasco is resolved and WN can start serious growth again.
southwest1675
Mon Jun 24, 2019 5:27 pm
With B6 apparently making many cuts, I wonder if BNA might be getting that rumored JFK service since slots have opened up.
HeyHey
Tue Jun 25, 2019 10:30 pm
Did BNA lose its F9 flight to VPS? That route was added in summer 2018, but I no longer see it on the allegiant website when I was looking for prices to fly to Destin. I hadn't seen any mention of it on here, so I'm afraid it may have gotten axed.
Frank11
Tue Jun 25, 2019 10:42 pm
Anyone have any initial performance numbers for the SY PDX service? I am glad PDX-BNA finally happened now I just hope it performs well and stays!
Fargo
Tue Jun 25, 2019 10:50 pm
Not sure, but I expect WN to launch this route sooner or later.
TYSflyer
Tue Jun 25, 2019 10:52 pm
Yes, it was quietly removed. My thought was it was probably hard for it to compete against nearby WN service to ECP and PNS.
Fargo
Tue Jun 25, 2019 10:53 pm
Mitsubishi is moving its North American HQ to Franklin from California.
https://www.wkrn.com/top-stories/mitsubishi-motors-to-move-north-american-headquarters-to-franklin/
This further bolsters the case for a TYO flight down the road.
Cubsrule
Tue Jun 25, 2019 11:09 pm
Don’t overestimate the size of Mitsubishi. This is probably something like a 5 PDEW boost, if that.
Fargo
Tue Jun 25, 2019 11:13 pm
I know, but the point is every little bit helps.
HeyHey
Wed Jun 26, 2019 12:05 am
Oops. Meant G4.
EvanWSFO
Wed Jun 26, 2019 1:02 pm
The same comments were made about Nissan in Franklin. There are a number of Japanese OEM's in middle TN that feed the Nissan plant. Having a consulate here helps. I doubt a flight would start daily, but there have been crazier things happen in the industry in the last few years.
Cubsrule
Wed Jun 26, 2019 1:35 pm
No. The Nissan demand is many times the size of what Mitsubishi demand will be. Mitsubishi is only 200 jobs and no manufacturing or engineering. It's a positive announcement for sure but not a game changer as far as Japan demand or a TYO flight.
CLJFlyer
Wed Jun 26, 2019 1:40 pm
If anything, a flight to Mexico City would help. I know a handful of companies just in the Franklin area that have large manufacturing presence in Mexico. I know co-workers that on a weekly basis travel down to Mexico City for work.
EvanWSFO
Wed Jun 26, 2019 1:52 pm
WN hasn't been able to make MEX work from several cities. Perhaps Volaris might, just not sure what the yield is on flights to non-tourist destinations as opposed to VFR traffic.
dfdubflyer
Wed Jun 26, 2019 2:00 pm
The AM/DL JV would likely be the ones with the BNA POS to make it work as I think the demand would be more southbound than northbound
Cubsrule
Wed Jun 26, 2019 2:05 pm
The trouble is that Mexico City =/= Mexican manufacturing. Nissan has a large presence in Aguascalientes, which is fairly close to MEX in the grand scheme of things, but it makes much more sense to do BNA-AGU over DFW or IAH than over a Mexican airport.
southwest1675
Thu Jun 27, 2019 5:21 am
https://www.chicagotribune.com/news/ct- ... story.html An old article from 1985 announcing AA to build a hub in Nashville. Sounds like they had the right idea, just 20 years too early....
TangoCharlie123
Thu Jun 27, 2019 5:49 pm
https://www.bizjournals.com/nashville/n ... ubled.html
BNA’s economic impact was $7.1 Billion in 2018 more than double what it was in 2012 ($3.5 Billion).
HeyHey
Fri Jun 28, 2019 12:48 am
I know diversions aren't all that uncommon at BNA, but the number of airports that took BNA's diversions tonight seemed impressive. SDF, EVV, LEX, TYS, MEM, HSV, and BHM all took diversions from BNA. Does anyone know why they would choose a place like EVV over SDF or fly all the way to BHM instead of landing at HSV?
runner13
Fri Jun 28, 2019 2:02 am
The dispatchers and Captain’s both agree on the diversion airports. I was off work today but these storms were predicted at around the time they happened. So I’m going to assume multiple convective sigmets were forecasted for the area and the dispatchers knew ahead of time to plan for diversions and that’s what they decided was the best place. Looking at flightaware they didn’t take arrivals for an hour during a usually heavy arrival time. That’s why there were so many. I know up in Hendersonville it was pretty rough for a while. I watched several of the diversions holding over my house for a while. It was pretty impressive to watch in front of that huge line of storms heading up from the south.
Cubsrule
Fri Jun 28, 2019 2:30 am
I think DL may have had a gate or staff availability issue at SDF. 2599 looks like they thought about SDF before going to LEX.
antoniemey
Sat Jun 29, 2019 2:29 am
They definitely operated out of that area. On my Instagram feed somewhere there's a photo of their sticker on the door to the A7 stairwell. It had survived underneath a CO logo sign. The double-sided tape on the CO sign gave way, and the Southwest sticker was still in pretty good shape underneath it.
Make something Idiot-proof, and the Universe will make a more inept idiot.
jplatts
Sun Jun 30, 2019 11:38 am
While CVG is closer to BNA than most of the destinations that currently have nonstop service from BNA on WN, WN might be able to make BNA-CVG nonstop service work since
(a) there are some WN nonstop routes shorter than or similar in distance to BNA-CVG that have a significant amount of O&D traffic such as ATL-BNA, AUS-DAL, BWI-ISP, BUR-LAS, MDW-DTW, FLL-MCO, FLL-TPA, FLL-TPA, MCI-STL, LAS-LGB, LAS-LAX, LAS-ONT, LAS-SNA, OAK-RNO, and RNO-SJC,
and
(b) WN would be able to offer 1-stop connecting service to Southern California, Texas, MSY, Florida, ATL, North Carolina, and CHS from CVG through BNA if WN adds BNA-CVG nonstop service.
On the other hand, CVG-BNA is shorter than any existing G4 nonstop routes, even though G4's LAS-LAX and LAS-AZA nonstop routes are slightly longer than BNA-CVG. G4 also only operates nonstop flights, and G4 would have to make CVG-BNA nonstop service work on O&D alone.
WN would probably do better than G4 would on CVG-BNA nonstop service since WN would have some connecting traffic to Southern California, Texas, and Florida on its CVG-BNA nonstop flights in addition to O&D if WN adds CVG-BNA nonstop service whereas G4 would only be carrying non-connecting passengers between CVG and BNA if G4 adds CVG-BNA nonstop service. WN also has much stronger brand loyalty than G4 does in Nashville, Southern California, and Texas.
AVLAirlineFreq
Sun Jun 30, 2019 1:22 pm
CVG-BNA is less than a 4 hour drive. I can't imagine a point-to-point leisure-oriented carrier like G4 adding the route.
jplatts
Sun Jun 30, 2019 2:03 pm
I agree with your point, especially since G4 would have to make CVG-BNA work on O&D alone. On the other hand, I had mentioned that WN might be able to make CVG-BNA nonstop service work as there would be some passengers connecting to Southern California, Texas, and Florida from CVG through BNA if WN adds CVG-BNA nonstop service.
Fargo
Thu Jul 04, 2019 1:28 am
WKRN had a several part series the other day with Doug Kreulen on the BNA Vision work and projects beyond.
https://www.wkrn.com/news/nashville-2019/behind-the-scenes-at-nashville-international-airport/
The last video is an interesting one. It is about the proposed runway extension and towards the middle, it talks about potential new intercontinental destinations. For Asia, Doug talks about Tokyo first, but he also mentions Seoul as a possibility. That surprised me, how many ties to Korea does Nashville/Tennessee have?
As much as ICN is more convenient for connections as opposed to HND/NRT, I don't see that happening for quite a number of years. Just landing a Tokyo flight is going to take some time IMO, and may not happen until 2L is extended.
I really hope they are considering expediting the runway extension.
gsg013
Sat Jul 06, 2019 12:14 am
I havent heard about an ICN flight but it would make sense for DL/Korean Airlines through their JV with their recent strategy of connecting asian pax through ICN instead of tokyo.
Fargo
Sat Jul 06, 2019 1:00 am
I have a hard time seeing KE here before the 2030’s at the soonest. Nashville-Asia nonstop is an unproven market and it’s not as simple as Europe. The focus needs to be getting JL to NRT/HND and if that does well, KE to ICN can be seriously looked at.
southwest1675
Sat Jul 06, 2019 5:54 am
Supposedly BNA was courting Europe/London service for over 10 years. I could only imagine how long it could take to recruit an Asia flight.
Midwestindy
Sat Jul 06, 2019 9:50 am
I'm pretty sure BNA has been courting Asia since a bit before the London flight was announced. I remember reading an article at least from 2013 about it.
Here's what's going to happen though, I think it is going to play out like this. You are going to see AUS, RDU, BNA, IND, CMH, or some other mid-sized airport get a non-stop TPAC first, and the rest will follow in succession 1-3 years later.
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
Fargo
Sat Jul 06, 2019 12:52 pm
Unlike Europe, I don’t think there will be as many mid-sized markets landing Asia service. IMO, as of right now, the only markets that have a strong enough case are AUS, RDU, BNA and IND. Other airports in that category don’t have strong enough economies.
AUS will likely be first, considering their airport director hinted it could within the next two years. I think the only thing standing in the way of BNA getting a JL 788 to NRT/HND is the lack of a long enough N/S runway. Since IND has the proper infrastructure and incentive $ in place, perhaps JL isn’t too far off there. RDU wants China so that will take a bit.
