dcajet
Question about LH's 748 fleet
Wed Jan 02, 2019 10:38 pm
LH has two seat configurations for the 748 fleet:
1. 8F/92C/32Y+/208Y
2. 8F/80C/32Y+/244Y
How do these two configs break down by registration #?
na
Re: Question about LH's 748 fleet
Wed Jan 02, 2019 10:57 pm
1. 8F/92C/32Y+/208Y
2. 8F/80C/32Y+/244Y
They are not fix but can change from season to season. My last flights on LH 748s were in November and I can tell you that D-ABYM and D-ABYQ are in the configuration with the smaller Business class.
conaly
Wed Jan 02, 2019 11:19 pm
Does LH use any B748 with the first mentioned layout at all? I've now had four flights on LH B748:
D-ABYP (Oct 2017 HND-FRA)
D-ABYQ (Aug 2018 FRA-GRU)
D-ABYJ (Aug 2018 GRU-FRA)
D-ABYL (Sep 2018 HND-FRA)
All of them had the second mentioned layout (not 100% sure about the 2017 flight though). And my next 748-flight to HND scheduled for next week also has the same layout. I've checked the schedules for the next few days where LH uses the 748. All possible seat reservations showed layout 2. So I guess currently all 748s are equipped with the second mentioned layout.
Airports 2019: ADB, ALG, AMD, ATL, BOS, CTS, DEL, DTW, DUS, EWR, FRA, FUK, HAM, HIJ, HND, IST, JFK, MUC, NGO, NUE, OKA, PHL, SIN, STN, YYZ
Planned 2019: BOG, CDG, FRA, MUC, NUE, ZRH
Swadian
Wed Jan 02, 2019 11:44 pm
LH only flies the version with 80J and a total of 364 seats. Source: https://www.lufthansagroup.com/en/compa ... tners.html.
The other version doesn't exist.
dcajet
Thu Jan 03, 2019 12:25 am
It did exist until not that long ago.
Question: why then do stations like EZE (the longest non stop route for LH) only see the more recent delivered ones? Say, from D-ABYL to D-ABYU? Is there a reason for that? I thought it could be the configuration, but seeing there is only one 748 config now.... Is it a matter of aircraft capability?
lhrsfosyd
Thu Jan 03, 2019 12:31 am
Perhaps later deliveries are lighter and burn less fuel so are scheduled on the longest routes?
dcajet
Thu Jan 03, 2019 12:41 am
I seem to remember that the first ones delivered by Boeing did not meet range specs. But I thought this was resolved.
LH707330
Thu Jan 03, 2019 2:11 am
Some of the early ones were overweight and didn't have the stab tank active, which limited the range. Between a couple tonnes of weight saving and the stab tanks (YL onward, IIRC), the newer ones have a couple hundred extra nm of range.
dcajet
Thu Jan 03, 2019 4:09 am
Thanks. That must be the reason. D-ABYA made an appearance around the time the new livery was introduced, but never before or since that trip. Must have been LH was showing off the new colors around the network.
