1337Delta764
Future AA widebodies on SJU-MIA routes
Wed Jan 09, 2019 1:43 pm
I recently flew SJU-MIA on an AA 763 and I wonder once AA retires their 763s, what widebodies, if any, will AA use on the route. I thought about the 787, but one of the FAs thought it was more likely AA would use one the A330s instead. What does anyone here think?
x1234
Re: Future AA widebodies on SJU-MIA routes
Wed Jan 09, 2019 2:01 pm
The 787 is used at AA on its longest routes across the Atlantic and Pacific in order to decrease the fuel burn where it matters. The 763 is the cheapest oldest AA wide-body and burns a little more than the 787 but less than the A330. The A330 burns 10% less fuel than a 777. I'd say its going to stay a 763 until its retired then a A330 if AA has to move cargo from MIA to SJU (A330 can accommodate LD3 containers side by side like a 787/777).
jayunited
Wed Jan 09, 2019 2:02 pm
[photoid][/photoid]AA is using their 788s on their ORD-CUN route daily and 2x 788s on the weekend for the winter season. It's not hard to imagine AA placing a 787 or a A330 on MIA-SJU routes during winter season when there would be more slack in the schedule and demand is higher as people from cold weather states look to escape the cold. Perhaps during the summer months when demand isn't as high they may utilize their A321s as those wide bodies would then be needed to support a robust international schedule.
Tan Flyr
Wed Jan 09, 2019 2:35 pm
As a seasonable shipper of various very perishable commodities to SJU, we certainly hope that AA maintains some widebody connectivity at both MIA and PHL for perishable cargo to SJU.
The key is connectivity, as LD-3 of numerous perishable items originate from a number of areas. As long as there is a widebody daily from at least LAX to MIA, and better yet an A-330 from SFO and LAX to PHL to connect to a B787,or A330 of either type down to SJU we are quite happy. The only icing on the cake would be a widebody from SEA to MIA in the summer months for that connectivity.
Aeroflot001
Wed Jan 09, 2019 2:39 pm
Ah the Golden era of the A300 when non-reving on SJU-MIA was too easy, that was the true wide-body of that era without a doubt.
It is refreshing to see that at least a 763 is being used from time to time.
upperdeckfan
Wed Jan 09, 2019 3:01 pm
My bet is no more WB's on MIA-SJU after 763's are retired.
From a pax load standpoint there are better Caribbean routes to send either an A330 or a B788, already mentioned ORD-CUN is a good example. Winter traffic is a factor out of the likes of ORD or JFK but not out of MIA.
Cargo would be the driver for MIA-SJU to retain WB service
748,744,742,741,772,773,762,763,
764, 789, 732,733,735,737,738,739,
752, 722, 717,74M,DC10,DC9,M82,
M83, M87, M88,310,319,320,321,332,
333, 343, 346,359,388,L1011,CR2,
CR7, CR9,CRK, E175,E190,ATR42,
DSH8, CS1,CS3
Boof02671
Wed Jan 09, 2019 5:39 pm
A333s are being retired.
maps4ltd
Wed Jan 09, 2019 5:41 pm
As MIA is a 772 base, could SJU see 772s?
Maybe it will see A321NEOs, but I have a feeling the MAX virus may spread to San Juan.
Delta Gold Medallion
Cointrin330
Wed Jan 09, 2019 5:56 pm
Once the 767 is fully retired at AA, I can see the occasional rotation of a 772 from MIA in between long hauls but overall, the A321/738/78M will become the mainstay of what's left of AA's operation at SJU and specifically, on the MIA-SJU route. A330s will more likely be flying from PHL and CLT than MIA.
Boof02671
Wed Jan 09, 2019 5:57 pm
They run wide bodies for the cargo volume.
Bobloblaw
Wed Jan 09, 2019 6:19 pm
AA is using 787s on ORD-CUN because thanks to canceling PEK and PVG, they have nothing to do with about 4-5 788s in the winter. It is not the optimal plane for such a route.
Janj
Wed Jan 09, 2019 6:25 pm
PHL still sends A330s I believe, but it’s primarily for cargo. I don’t think CLT-SJU has seen the A330 in years, except maybe a couple one-offs. Most of that is funneled through Miami now, the five daily flights on a mix of widebodies and narrowbodies are a thing of the past at CLT.
INFINITI329
Wed Jan 09, 2019 8:07 pm
How much cargo can a containerized A321 theoretically carry? I think we'll see at least 1 or 2 widebodies on the mainland-SJU runs for the foreseeable future. The only other option is to hire a freighter to take the cargo for you but I assume it would still be cheaper to run your own metal. If the 797 comes to life this may be a role for it.
redwingspilot
Wed Jan 09, 2019 8:37 pm
PHL actually has the 767 on it right now for the foreseeable schedule.
rbavfan
Wed Jan 09, 2019 9:23 pm
They are holding off on that as they need WB capacity.
Boof02671
Wed Jan 09, 2019 9:42 pm
2020
Cointrin330
Wed Jan 09, 2019 9:53 pm
What is left of the 767 fleet is based in MIA and PHL to isolate the aircraft and minimize operational disruptions across the network. The last 2 767's flying out of JFK to Europe (CDG and MAD) are being replaced with the 777-200ER this Spring. A lot of 767 flying out of PHL to Europe will eventually (but very slowly) transition to the 787. This is happening starting in November 2019 with ZRH going to the 787. The 767's do not have a great dispatch reliability and the product is becoming uncompetitive. AA has minimal competition from PHL to Europe (with just LH and BA, whom they partner with) so they can put the 767 on routes from there comfortably.
MIflyer12
Wed Jan 09, 2019 11:25 pm
INFINITI329 wrote:
How much cargo can a containerized A321 theoretically carry? I think we'll see at least 1 or 2 widebodies on the mainland-SJU runs for the foreseeable future. The only other option is to hire a freighter to take the cargo for you...
AA could simply run less cargo to SJU. See, wasn't that easy! If cargo rates don't cover the costs (direct and opportunity) then AA won't run 'new' widebody aircraft to SJU.
RichardWelling
Thu Jan 10, 2019 12:34 am
And its all pharma traffic.
INFINITI329
Thu Jan 10, 2019 12:53 am
Which equals lost revenue...and handing over that revenue to your competitors isnt really good for your books
Boof02671
Thu Jan 10, 2019 12:56 am
It’s more than that.
compensateme
Thu Jan 10, 2019 1:02 am
US ran a 332/333 PHL-SJU for years, and according to what I’ve read on a.net, it printed money. My bet is that AA will restore such service, and launch & rotate the aircraft through MIA as well.
We don’t care what your next flight is.
c933103
Thu Jan 10, 2019 1:07 am
797 will most likely have less cargo capacity than typical widebodies and closer to narrowbody in term of cargo capacity, unless Boeing designed to make the aircraft suit Asian operators better
It's pointless to attempt winning internet debate. 求同存異. よく見て・よく聞いて・よく考える
(≧▽≦) Nyan! Nyan! Nyan! Nyan! Nyan! Nyan! Nyan! Nyan!
(≧▽≦) Meow Meow Meow! Meow Meow Meow Meow!
Tan Flyr
Fri Jan 11, 2019 12:43 am
Yes it is...how do you think highly perishable foods /herbs/ fruits/berries get to Puerto Rico? yes some by vessel, but a lot arrives by air. When you are trying to rebuild your tourism industry after an event like Hurricane Maria, you have to pull out the stops to entice vacationers to choose Puerto Rico over other Caribbean options.
Trust me, the Food Service / Perishable wholesalers on the island have made their needs known. ( as have the retailers) Hopefully AA will maintain at least 1 WB from MIA and 1 from PHL for the foreseeable future.
RichardWelling
Fri Jan 11, 2019 1:18 am
I am talking about SJU-MIA, that lane is all pharma. For the MIA-SJU sector its various commodities.
jayunited
Fri Jan 11, 2019 2:33 am
Actually it isn't.
UA was running multiple 739ERs on our EWR-SJU-EWR route untill we secure a huge lucrative cargo pharma contract which required a widebody. For a while UA was utilizing a domestic 772 nowdays its a 764 and a 739ER (and the widebody service continued despite the devastating effects hurricane Maria had on the island on on tourism) The only reason the 764 is on EWR-SJU-EWR routes is do to our pharma contracts, UA has stated as much on Flying Together. The pharmaceuticals business in Puerto Rico is going strong these companies have a space block agreement with UA. It is such a lucrative business that UA if it comes down to it and a 764 is down for maintenance UA will delay an evening flight to Europe several hours just so they can run the 764 on a round trip EWR-SJU-EWR instead of canceling and the reason for this is because of the cargo. A cancellation would cost UA hundreds of thousands of dollar just in the cargo alone because of the space block agreement and the fact that that cargo has to be at its intended destination within a certain amount of time if not it no longer viable. If the 764 cancels this flight is so important we hear about it immediately here at Willis Tower that is how high on the priority list this flight is. So if UA's cargo contract pays enough for UA to upguage EWR-SJU to a widebody and its important enough for UA to delay an afternoon European flight to cover EWR-SJU-EWR, I have no doubt that AA if they have pharma contracts are making a killing as well.
chepos
Fri Jan 11, 2019 2:58 am
I believe AA moves a lot of cargo on the PHL-SJU segment, back when the 333 (LUS days) operated on the route the belly was always jam packed. The flight had it’s share relaiability issues at times which would trickle on to the European departure bank. I recall the flight always having drama and very colorful passengers.
Fly the Flag!!!!
alasizon
Fri Jan 11, 2019 3:37 am
Prior to the hurricane damage, there was also a decent amount of floral products on the SJU-MIA leg (connecting all over the place in small shipments). I haven't seen much since then but that doesn't rule it out.
