jbmitt
Re: Denver Aviation Thread - 2019
Sun Apr 21, 2019 11:38 pm
Fargo wrote:
jetmatt777 wrote:
intotheair wrote:
Is it true that UA is going to use the high number regional gates in A this summer in addition to the CUTE gates in A and C? I noticed the signs in the trains have been updated to list UA in all three concourses. So crazy when you think about how big of an operation that will be!
UAX will operate on 9 A-con Gates in addition to the mainline on the peak banks using the CUTE gates.
Dang, UA spread out amongst 3 concourses, gonna be quite hectic!
What’s the long term plan for how UA, WN and F9 will be spread out? Since they are the “hub” carriers, they will require the most gates. How many
gates will each have after the expansion is done and will UA go back to just B, or will they still need A and C as well?
UA has been on all three concourses for a while. The only things new will be more regional activity on A. Typically, A is for inbound/outbound international flights. I've had several domestic flights in and out that start/end as international flights. I haven't seen them tow planes too often. B is for the usual UA/UAX operations. C has been used a lot more, especially with B gates getting concrete/apron work done.
Frontier14
Sun Apr 21, 2019 11:53 pm
ytib wrote:
Latest on the terminal construction and the concrete issues: https://www.denverpost.com/2019/04/20/d ... ete-delay/
"May 2023 is the most recent projection made by Great Hall Partners for completion of the final phase of the $650 million-plus project, as disclosed this week in a monthly project report for bondholders.
That would be 18 months beyond the original target of November 2021. And the estimate has grown from a forecasted 10-month project delay in February."
What can one say, it is Denver International and the City of Denver again failing the pax and the airlines because of lack of oversight of contractors etc......The shoddy original concrete work was apparently done on the then Mayor Pena's watch. I cannot remember who the general contractor was, but it was one of the bigger names at the time (early 1990s). There was the billion dollar bust on the baggage handling system that was built, but was functionally unusable. You bet the traveling pax paid for that screw up.
Now we have reported a million dollar esoteric colored light sign at the entrance to Denver International that has gone on the fritz, just months after being installed. The article reports there are going to be significantly more costs to the traveling public because of the latest discovery related to the concrete. Perhaps, one could say well at least they caught it early before completing everything, and then have it collapse.
But wait, one of the so called travel industry watchers has just determined that DIA (Denver International Airport) is the best in class airport. Perhaps the current airport director can freeze salaries and reduce the airports marketing budget to help with some of the cost overruns that are being projected.
Frontier 14
jetmatt777
Mon Apr 22, 2019 12:14 am
Here is the current state of the basement beneath Concourses A and B. It's pretty disgusting and in amazing disrepair.
Support column sinking into the ground. This particular one has sunk nearly 3 inches. Fairly common sight.
Hallway to an old lockeroom under B28.
Stalagmites (or something) forming as water penetrates the walls of the basement.
Water flooding the basement. In the second image you can actually see it pouring in from the ceiling.
Water intrusion again. Something growing on the air handler units. Probably not great to be breathing in whatever it is.
The airport is a mess.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
trexel94
Wed May 15, 2019 1:52 am
Edelweiss will re-start seasonal DEN flights this month with the A340-300 instead of the A333 per CAPA. I'm not sure why they've switched the aircraft but it will be nice to see the A343 again.
https://centreforaviation.com/news/edel ... 020-903009
diatraveler
Wed May 15, 2019 2:18 am
Article says 2020 for the aircraft switch.
fry530
Wed May 15, 2019 2:39 am
Nice! Looks like it will be 2020 that we see the A340, but it's great to see it coming back next year as well with a capacity increase none the less! Clearly Denver is working for Edelweiss!
319 320 32N 321 332 333 722 733 735 73G 738 739 744 752 763 772 77W CR2 CR7 Q400 E145 E170 DC10 MD80
AA BA BD CO DL EI F9 HP NW NZ UA U2 WN Y4
trexel94
Wed May 15, 2019 3:30 am
Indeed! When was the last time we've seen an A343 touch down at DEN? Fun fact is that WK's A333s actually seat one more passenger than their A343s.
intotheair
Wed May 15, 2019 9:05 am
On a regular basis? Probably when LH first tried DEN-MUC in 2007. MUC was with the A343 while FRA got the A346.
In the more recent run of DEN-MUC, it’s been either a 333, 346, or 359. FRA has pretty consistently been on the 744 in the last ~8 or so years.
300 319 320 321 332 333 345 346 380 717 733 734 735 73G 738 739 744 752 753 762 763 772 77W 788 789 CR2 CR7 CR9 Q400 E175 DC10 MD82 MD90
AA AF AS AY AZ B6 BA BR DL F9 FI GA HA KF LH MI QX SK SN SQ UA US VY WN
wnflyguy
Wed May 15, 2019 6:52 pm
WN to build a 100 million dollar 3 aircraft bay hanger in DEN.
DEN will soon be come its Largest station with Flights and Gates.
Flyguy
my post are my opinion only and not those of southwest airlines and or airtran airlines.
airfrnt
Wed May 15, 2019 7:46 pm
Flyguy
Huge win for the Airport. It's been a open secret that both UA and WN are planning extremely aggressive expansions at the Airport, with Denver slated toeasily be southwest's largest city.
More here https://www.denverpost.com/2019/05/15/southwest-airlines-hangar-denver-airport-dia/ - Above and beyond the Hangers:
Southwest also hopes to take advantage of concourse expansion project underway at DIA that will add 39 gates to the airport. The airline currently leases 24 gates in Concourse C, which will get 16 new gates as part of the project. Southwest wants all of those, a sentiment Kelly said he has shared with the airport, the mayor, the governor and anybody “who will listen to us.”
That's a 66% increase in their footprint at Denver. Some of their gates are definitely crammed together, so I don't think it's a increase of 66% in their flights.
I'm kind of surprised that neither UA nor F9 were interested in selling off their hangers. Rumor has been for a while that they were not completely happy with the arrangements around the hangers.
CALMSP
Wed May 15, 2019 7:48 pm
Flyguy
F9 maybe, but UA selling off their hangar should not come as a surprise to anyone.
msp747
Wed May 15, 2019 10:28 pm
CALMSP wrote:
Flyguy
I assume you mean UA NOT selling their hangar.
I was obviously wrong, but I thought F9 had been trying to sell that hangar. Other than the occasional Airbus parked outside, it does not appear that it is used. Guess I'm just there at the wrong time.
Anyone have any idea where this new Southwest hangar is going to be built? I didn't see a location in the article. With Concourses A, B, and C just about built out, I'm sure they wouldn't want to put it where it would interfere with a future Concourse D. Maybe alongside the current UA facility?
guppyflyer
Thu May 16, 2019 5:09 am
It will be north of the F9 hangar by 1000' or so.
wnflyguy
Thu May 16, 2019 2:28 pm
Sounds like WN will increase it's gates to 37 and have around 48 RON aircraft.
Once the 16 other gates are opened almost every WN cities will have a Daily or weekend only DEN nonstop with the exception of probably LIH,ITO,PLS and NAS.
Flyguy
jplatts
Thu May 16, 2019 5:06 pm
While I agree that WN is likely to add some new domestic nonstop routes out of DEN such as DEN-BHM, DEN-CLT, DEN-DSM, and DEN-ICT, there are some domestic destinations such as CRP, GSP, HRL, ITO, HNL, ISP, OGG, KOA, LIH, MHT, RIC, and DCA that are unlikely to see nonstop service out of DEN on WN anytime soon.
I agree that WN bringing back DEN-PVD nonstop service might happen since DEN is one of the top destinations traveled to from PVD that isn't currently served nonstop from PVD on WN and since there is a significant amount of passengers connecting to destinations west of the Rockies from PVD.
WN is unlikely to add nonstop service to Caribbean or Central American destinations out of DEN as most of the Central American and Caribbean destinations served by WN aren't currently served nonstop from DEN on any airline.
mkorpal333
Thu May 16, 2019 5:29 pm
Too bad it's totally useless for anyone living in Denver.
STT757
Thu May 16, 2019 8:47 pm
Flyguy
Probably not ISP either.
Sent from my iPhone using Tapatalk Pro
CALMSP
Thu May 16, 2019 9:07 pm
?? not sure what you mean here.
DEN1895
Thu May 16, 2019 9:17 pm
Flyguy
I don't think that Southwest will be getting that many gates on C, there is a good chance that Delta will move back to C to make room for Frontier to expand on A. Delta has 6 gates now, but wants 7 or 8, leaving WN with 8 new gates and they could also take over the common use gate (C38) when construction is done on B and United moves back. This would bring them at least up to 32 which is what they have at Midway and BWI. Spirit also wants more gates but I am not sure if they will have any extra on C.
mkorpal333
Thu May 16, 2019 10:03 pm
I totally goofed and forgot about booking with Swiss. My bad.
Rdh3e
Fri May 17, 2019 2:53 am
For anyone interested, this is what this July is shaping up to look like:
Number of departures:
AL….Deps….YOY….YOY %
UA….496.......37...........+7%
WN....216.........9...........+4%
F9........85.......18.........+21%
Number of seats:
AL….Seats….YOY….YOY %
UA….52,310…4,080….+8%
WN…32,864….985…...+3%
F9…..15,730...3,289....+21%
Number of destinations:
AL….Dest….YOY….YOY %
UA….163.........19.......+12%
WN….68…........5….....+7%
F9…...97.....….21…...+22%
jhsusman
Sat May 18, 2019 6:12 pm
Does anyone know how many different destinations (domestic & intl) Denver will serve this summer? DEN has to have one of the biggest (if not the biggest) domestic networks in the U.S. . .
Beechtobus
Sat May 18, 2019 7:39 pm
Good question. I know in recent years Denver has on and off beaten ATL in number of domestic destinations served nonstop. I’m not sure if DEN is currently on top (thought I’m guessing they are with the many recent unbefore seen UA and F9 adds).
http://Www.flydenver.com/about/press_ki ... stinations has some pretty good info on Denver service statistics.
Delta28L
Sun May 19, 2019 12:44 am
Domestically I think DEN would win. Internationally DEN doesn’t even come close to ATL. Combined totals and I think ATL beats out DEN.
Frontier14
Sun May 19, 2019 2:08 am
:checkmark: :checkmark: :checkmark:
Frontier 14
DEN1895
Sun May 19, 2019 2:06 pm
After doing some research, here is how the destinations break down for DEN and the other large hubs.
........Total......Domestic.....International
DEN 214........188................26
ATL 247........168................79
ORD 261........186................75
DFW 249........186................63
So DEN does have the most domestic destinations, but can't compete with international.
jadedchameleon
Wed Jun 26, 2019 4:36 am
Didn't even know this was a thing until today when I arrived at these gates on a SKW CR2. I was pretty confused to arrive in A on United. We were late and so there were lots of panicked folks trying to make their way to B. Doesn't really seem like a good long term solution....
jetmatt777
Wed Jun 26, 2019 2:41 pm
Well we are down 12 gates on B con right now for construction. It’s not a long term solution. I hear they may try and setup a van/shuttle service to help with connections. We are doing more gate holds for connections from A.
Frontier14
Thu Jun 27, 2019 9:14 pm
As others have said it is a temporary fix for Skywest's CRJs. Frontier has been using several of the gates off and on since it was opened. Pretty plain Jane, but still nicer than UAs commuter gates on concourse B.
Frontier 14
Frontier14
Fri Jul 05, 2019 3:54 pm
Does anyone know if UA has shifted some of their regional jet arrivals and departures over to the A concourse yet?
Frontier 14
diatraveler
Fri Jul 05, 2019 4:27 pm
Frontier 14
They have been using the A Gates (A71 - A87) now for about a month. A combination of CRJ200's and E175's.
diatraveler
Fri Jul 05, 2019 4:30 pm
Flyguy
I don't think Delta will leave the A concourse in the future. They just built a very nice Sky Club Lounge on A. They also utilize gate A31 for wide body flights to Atlanta over the Christmas busy season. From what I am hearing, both Delta and United are jockeying for the new A gates.
jetmatt777
Fri Jul 05, 2019 4:42 pm
Frontier 14
Didn’t you just answer this question in the post above this?
Frontier14
Fri Jul 05, 2019 9:12 pm
jetmatt777 wrote:
Frontier 14
Knew it was the plan, but was uncertain if UA had implemented it. :scratchchin:
Frontier 14
keithvh2001
Sat Jul 06, 2019 3:41 am
Living in Denver --- it was a fairly big news story when Denver passed the 200 destination number back in early 2018. It was the first time Denver had ever reached that number.
Being at 214 is pretty impressive, considering the 200 mark was passed only ~ 18 months ago.
It's not an inclusive list --- but off the top of my head, I think that Tyler (TX), Burlington (VT), Arcata, Everett, Flagstaff, Greenville (SC), Fort Walton Beach, Brownsville, Santa Rosa, Fairbanks and Grand Cayman are among the new routes over the last 18 months. Nothing on that list is extraordinarily sexy, and a few of them (Tyler, Burlington, Fort Walton Beach, Brownsville) are seasonal. But they are all decent adds and they go literally every direction: north, south, east and west. The overall Denver network is impressive.
Fargo
Sat Jul 20, 2019 4:37 pm
Where exactly is the new WN hangar going?
CALMSP
Sat Jul 20, 2019 4:57 pm
NE corner, access near 114th & Queensburg
DEN1895
Sat Aug 10, 2019 4:05 am
Today DEN posted the traffic stats for the first half of 2019, here is a quick breakdown of the YTD stats:
Overall Passenger Count: 32.7 mil (up 2 mil form last year) 6.1% increase
Operations: 4.5% increase, with 30 new routes added (14 new cities)
International traffic: 5.5% increase
Change per airline:
UA +11.2%
WN -0.7%
F9 +10%
AA -1.7%
DL +4.7%
Cargo is doing well this year with a 11.6% increase.
The rate of passenger growth has accelerated from last year, the first 6 months of 2018 saw a 4.2% increase.
Rdh3e
Sat Aug 10, 2019 12:13 pm
Change per airline:
UA +11.2%
WN -0.7%
F9 +10%
AA -1.7%
DL +4.7%
It looks like capacity growth at the airport is accelerating in the second half as well, about 10% compared to about 7% in the first half. If loads generally hold up that would put DEN somewhere around the 69M passenger mark for the year.
mcg
Sat Aug 10, 2019 12:16 pm
And the Great Hall project doesn't seem to be going well: https://www.denverpost.com/2019/08/09/d ... ferrovial/
jhsusman
Sat Aug 10, 2019 1:09 pm
What ever happened to the rumored Aer Lingus flight to Dublin? Any chance DEN gets more new international service soon?
DEN1895
Thu Sep 12, 2019 1:38 am
Today DEN posted the traffic stats for July:
Overall Passenger Count: 6.7 million,10% increase
Operations: 8.4% increase
International traffic: 11% increase
Change per airline:
UA +12.3%
WN +2.6%
F9 +26.6%
AA -3.8%
DL +5.6%
Cargo had a 11.6% increase in July.
Just over half way through the year, the airport has seen nearly 2.5 million more passengers.
DEN1895
Fri Sep 13, 2019 4:39 pm
In the past month there have been a few articles, one from each of the major carriers at DEN about their future of the airport:
UA: https://skift.com/2019/09/12/united-airlines-plays-up-its-denver-advantage-as-global-routes-suffer/
-Shows that Denver has become one of the highest margin hubs
-New Frankfurt flight one of the five most profitable international routes over the summer
-Predicted that Denver could have between 500 and 720 daily flights in the future
WN: https://www.dallasnews.com/business/airlines/2019/08/15/southwest-airlines-hopes-to-make-denver-its-busiest-airport-with-100-new-flights/
-WN wants the 16 new gates on C concourse along with the 25 they already have
-WN wants DEN to be their largest station passing Midway
-With the new gates an estimated 100 flights a day would be added to DEN, bringing the total to 325 (Midway has 265)
F9: https://www.bizjournals.com/denver/news/2019/08/29/frontier-ceo-green-campaign-ipo-flight-frequency.html
-Major focus in the coming years at DEN will be frequency increases as they already fly to 100 destinations
-Will try to get as many gates as possible, they currently only have 9 making growth difficult
