stant62
FedEx and UPS 757s
Wed Jan 23, 2019 2:36 pm
Curious about FedEx and UPS' 757 fleets. Are they all RB211-powered? It appears there are 194 active 757s between the two companies and I'm not sure whether they were engine agnostic when the respective fleets were being ramped up.
Newark727
Re: FedEx and UPS 757s
Wed Jan 23, 2019 2:40 pm
No, FedEx's fleet has some PW-powered former United airplanes and UPS got both engine types for some reason.
stant62
Wed Jan 23, 2019 2:42 pm
Thank you for the quick response - do you happen to know exactly how many RR-powered 757s UPS and FedEx have?
NameOmitted
Wed Jan 23, 2019 2:55 pm
Can a pilot who flies a mixed fleet tell the difference between engine types by aircraft performance?
MIflyer12
Wed Jan 23, 2019 3:07 pm
planespotters.net is a useful tool.
dcs921
UPS has 35 with PW2000 and 40 with RR RB211. All 75 of them are factory built freighters.
stant62
Wed Jan 23, 2019 3:20 pm
It absolutely is but I'm not aware I can sort by engine type which is the information I'm looking for.
UPS757Pilot
Wed Jan 23, 2019 3:30 pm
N401UP - N435UP are PW2040
N436UP - N475UP are RB211
As for flying characteristics, both engines provide more than enough thrust, especially as we tend to operate the airplane far below its maximum takeoff weight. The RB211s have a thrust reduction mode after takeoff, I believe for noise. The PW2040s have a more effective thrust reverser due to the larger fan section. There are some systems differences as well, but performance-wise very similar.
Both are great engines.
UA777FO
Wed Jan 23, 2019 3:45 pm
The only difference I remember is different numbers to look at during engine start other then that can’t really tell the difference in flight characteristics.
Scorpio
Wed Jan 23, 2019 4:03 pm
FriscoHeavy wrote:
The 757 was never built in the factory as a freighter.
Yes it was. All UPS 757 were built new, as freighters.
Moosefire
Wed Jan 23, 2019 4:05 pm
FriscoHeavy wrote:
Factory built freighters? The 757 was never built in the factory as a freighter. They've all been converted from passenger use.
Incorrect
MD-11F/C-17A Pilot
UA444
Wed Jan 23, 2019 4:27 pm
They have more Pratt 757s than just the -222
Erau82
Wed Jan 23, 2019 4:30 pm
UPS and Boeing developed the -200PF freighter version starting with MSN 23723 (LN 139) which was delivered to UPS in 1987. Boeing assigned 757-24APF to this delivered configuration.
CriticalPoint
Wed Jan 23, 2019 4:32 pm
The RR engines started a lot faster than the Pratt’s......that’s about the only difference I ever noticed.
113312
Wed Jan 23, 2019 4:51 pm
The UPS B757 package freighter had a special L-1 entry door.[#] ]
The FedEx fleet is all conversions from passenger versions. They all have the standard L-1 door
B757Forever
Wed Jan 23, 2019 5:06 pm
The Precision conversion takes a pax aircraft and installs the small crew entry door as well.
http://www.precisionaircraft.com/conversions/
The Rolls Royce Dart. Noise = Shaft Horsepower.
SXDFC
Wed Jan 23, 2019 6:06 pm
Why is there a smaller L1 door on the package freighters?
airzona11
Wed Jan 23, 2019 6:08 pm
Only need to get the pilots in and out.
SteelChair
Wed Jan 23, 2019 6:15 pm
IIRC, the PW engine weighs a little bit less and burns a little bit less fuel, but is more unreliable. The RR engine weitghs a little bit more and burns a little bit more fuel, but is an order of magnitude more reliable. This is all second hand information from reading and talking to people in the industry.
N747PA
Wed Jan 23, 2019 6:23 pm
More space on the Main Deck with that door.
DualQual
Wed Jan 23, 2019 6:25 pm
RR Engines start faster vs the PWs. PW thrust reversers will stop you much faster due to the larger fan. On the EICAS there is an N3 display for the RR airplanes.
Systems wise there are some differences for engine anti ice valve location, fuel feed (RR has some hydro mechanical feed that is electronically refined vs PW which is all electronic magic), engine limiter (again due to hydro mechanical vice electronic), and the RR airplanes have a rich position on the fuel switches while the PW only have run and off.
Cold WX ops on each engine have some slight differences for run up requirements as well.
There's no known cure for stupid
HPRamper
Wed Jan 23, 2019 7:06 pm
The FedEx 757s are split roughly equally, there are 119 total in the fleet. It does not lean heavily either way.
hongkongflyer
Thu Jan 24, 2019 1:58 am
and possibly lighter
dawej
Thu Jan 24, 2019 2:34 am
I work closely with UPS and have asked about the engine options. Word is Rolls Royce option was a internal political move as they started to grow their Europe Ops.
DL757NYC
Thu Jan 24, 2019 2:39 am
Since they spent their whole life as freighters they have relatively low cycles/hours on them despite their age
twaconnie
Thu Jan 24, 2019 7:03 pm
Do UPS and FEDEX have their own in house maintenance?
flyingclrs727
Thu Jan 24, 2019 8:09 pm
The Precision conversion allows one whole additional pallet position than the BCF. It gives the same 15 full positions as the Boeing factory built freighters rather than 14.5 per Precision's website.
Avi8r747
Fri Jan 25, 2019 12:38 am
I recall during taxi, I would need to use the breaks with Pratt’s, and power with the rolls. Rolls started quicker, but Pratt’s had more power. Loved flying both of them. One of my favorite machines I’ve flown by far
musman9853
Fri Jan 25, 2019 12:58 am
with the fleet size they have, i'm almost positive they do. they're also apparently hiring new mechanics
Welcome to the City Beautiful.
UPS757Pilot
Fri Jan 25, 2019 5:28 am
Yes as do most airlines but heavy maintenance is outsourced on all fleets at UPS.
