sonicruiser
Snow at PHX?
Thu Feb 21, 2019 5:25 am
So LAS recently had some snow, but not enough to cause disruptions. Central/Southern AZ is scheduled to see more snow than NV tonight and that would likely result in delays which would be more impactful at PHX than LAS as the former is much bigger for connections. Will be interesting to see how AA handles this.
PlanesNTrains
Re: Snow at PHX?
Thu Feb 21, 2019 5:50 am
I live 20 minutes from PHX. Snow is not in the forecast for the metro area afaik.
-Dave
MAX’d out on MAX threads. If you are starting a thread, and it’s about the MAX - stop. There’s already a thread that covers it.
Raventech
Re: Snow at PHX?
Thu Feb 21, 2019 6:09 am
Correct, per winter storm warning snow level is about 3000 feet, and tempurature is suppose to remain above freezing so if it did come down as snow it will melt when it hits the ground.
mga707
Re: Snow at PHX?
Thu Feb 21, 2019 6:16 am
TUS is more likely to see snow than PHX. 2400' vs. 1100' elevation. We're hoping for it--if it's cold and wet it might as well snow. Last measurable snow at TUS was six years ago today--1 inch on 2/20/13.
Byrdluvs747
Re: Snow at PHX?
Thu Feb 21, 2019 6:27 am
I lived in PHX for 30 years, and in that time snow had only managed to reach the ground(and melt immediately) once back in 1990. You may see some snow in the higher elevations surrounding the valley, but basically never on a PHX runway.
For historical context, the last time there was measurable snow in PHX was back in the 1930's. I believe it was 1 inch.
The 747: The hands who designed it were guided by god.
mga707
Re: Snow at PHX?
Thu Feb 21, 2019 6:33 am
Confirming that the +/- 1300' elevation difference between PHX and TUS makes a big difference. Tucson's had around 20 instances of 1 inch or more snow recorded officially by the NWS or it's predecessor since 1937. Record was nearly 7 inches on December 8/9, 1971. Yes, that did shut down TUS.
slcdeltarumd11
Re: Snow at PHX?
Thu Feb 21, 2019 6:37 am
It's not going to snow in PHX , what you saw was for the mountains. Places in view of PHX will get good snow, but it's not gonna fall at the low elevation airport.
Also you need to remember somewhere like LAS is near places that get a lot of snow. Plows and salt trucks are plentiful nearby because of mountains. Nevada and Arizona have plenty of trucks and plows. If they really needed to treat the runway at LAS they would be able to. A place like MCO or TPA would be much more isolated if there was a freak snow event. They would be much further from plows or salt trucks etc etc.
Veigar
Re: Snow at PHX?
Thu Feb 21, 2019 9:51 am
Did LAS get any meaningful amounts of snow on its runway? Would make for some really cool photos.
jetwet1
Re: Snow at PHX?
Thu Feb 21, 2019 10:51 am
The first big wave came through the valley starting around 8pm, it didn't stick then, we had lite snow of and on all night, it's just started really snowing in my area again 2:50am.
Looks nice, but there are a lot of homes without power and the temp is dropping.
cledaybuck
Re: Snow at PHX?
Thu Feb 21, 2019 12:17 pm
Forecasted snowfall amounts across northern Arizona. https://www.weather.gov/fgz/
As we celebrate mediocrity, all the boys upstairs want to see, how much you'll pay for what you used to get for free.
sonicruiser
Re: Snow at PHX?
Thu Feb 21, 2019 11:34 pm
KICT
Re: Snow at PHX?
Fri Feb 22, 2019 12:13 am
KFLG getting snow is not noteworthy.
People are saying. Believe me.
ytib
Re: Snow at PHX?
Fri Feb 22, 2019 12:18 am
KFLG: 7000'
KPHX: 1086'
KTUS: 2643'
KLAS: 2181'
KABQ: 5312'
KSAF: 6348'
Airbus:318,319,320,321,332,333,388
Boeing:707,717,732,733,734,73Q,735,73G,738,7M8,739,752,753,742,74L,744,762,763,772,77L,77W,789
Misc:142,CN1,CR2,CR7,DC8,DH2,DH8,D8Q,D10,D95,EM2,ER3,ER4,E70,100,J31,M11,M83,M88,M90,SF3
Where is Neil
arcticcruiser
Re: Snow at PHX?
Fri Feb 22, 2019 12:21 am
Does´nt take much does it?
mga707
Re: Snow at PHX?
Fri Feb 22, 2019 3:31 am
Snow is now out of the forecast for all lower elevation areas of southern Arizona. Just rain. I was hoping to wake up to white stuff, but 'tis not to be. Have to go up to Mt. Lemmon (9000').
EA CO AS
Re: Snow at PHX?
Fri Feb 22, 2019 3:56 am
It is when it's the largest single day of snowfall in history for them:
https://twitter.com/NWSFlagstaff/status ... 7309088769
Regarding PHX, the airport is at a fairly low elevation so snow seldom occurs, and when it does, it won't stick. My house backs up against the McDowell Mountains at a higher elevation, and we may see snow flurries at one point but it won't stick either, although it may up on the mountains.
amcnd
Re: Snow at PHX?
Fri Feb 22, 2019 4:57 am
I saw snow in PHX this winter. The local church trucked it in. was pretty cool to see all the kids playing on it..
jetwet1
Re: Snow at PHX?
Fri Feb 22, 2019 8:01 am
Especially out here, driving to fast, using power poles to help stop, our cul-de-sac had no power for most of last night, thankfully we have our powerwalls plus a log fireplace, so we were good, most of the homes in this area have firplaces so they at least had heat.
Adipocere
Re: Snow at PHX?
Fri Feb 22, 2019 9:18 am
ytib wrote:
KFLG: 7000'
KPHX: 1086'
KTUS: 2643'
KLAS: 2181'
KABQ: 5312'
KSAF: 6348'
Wow did not realize PHX is actually a 1000 feet up. I thought it would be closer to the SoCal hot cities at or even below sea level (Thermal, Yuma etc). It’s actually surprising that PHX gets as hellishly hot as it does being a 1000 feet up.
Veigar
Re: Snow at PHX?
Fri Feb 22, 2019 9:20 am
Annnnd there goes the snow. Won't be seeing that in Vegas again for another 15 years give or take.
barney captain
Re: Snow at PHX?
Fri Feb 22, 2019 10:20 am
Do we really need 3 separate threads on something that isn't happening?
Southeast Of Disorder
mga707
Re: Snow at PHX?
Fri Feb 22, 2019 4:37 pm
Should have known. Measurable snow this morning in Tucson. Still snowing as of 0930, over an inch at my house which is 10 miles east of TUS and a little higher.
airzona11
Re: Snow at PHX?
Fri Feb 22, 2019 6:50 pm
TUS getting some good snow. University of Arizona campus getting a good dusting as well. Great scene on the mountains North and East of PHX.
UpNAWAy
Re: Snow at PHX?
Fri Feb 22, 2019 6:55 pm
Breaking a 100 year old records is, as is getting 36 inches in 24 hours...
ikramerica
Re: Snow at PHX?
Fri Feb 22, 2019 7:18 pm
That is a very cold storm. We had it in socal near BUR yesterday and during the day! we had flurries at 1000’ feet. It was a snow hail, round like hail but soft and white and not. dense. If you gathered it together in your hand it formed slush balls.
sonicruiser
Re: Snow at PHX?
Fri Feb 22, 2019 9:18 pm
Not everyday you see snow covered cactus...
Pics courtesy of TUS Twitter: https://twitter.com/TucsonAirport
AAtakeMeAway
Re: Snow at PHX?
Fri Feb 22, 2019 10:05 pm
OK just please don't start another thread "Snow in TUS" .
jetmechanicdave
Re: Snow at PHX?
Sat Feb 23, 2019 1:05 am
Exactly lol
Aircraft Mechanic and Airliners.net Forum Moderator
Byrdluvs747
Re: Snow at PHX?
Sat Feb 23, 2019 1:20 am
For those outside of AZ, yes. Its not a strange sight to natives and residents.
wetpantsmcgee
Re: Snow at PHX?
Sat Feb 23, 2019 1:48 am
There's a dusting on the foothills behind Scottsdale, I'd say the snow level almost got down to 2000'. Weird sight to see taking the kids to school.
