evank516 wrote:Delta only has 10 737-700s in their fleet. They're pretty heavily used on routes already, and they're about to be used on one more when they resume ATL-BUR. This adds to the list of routes such as ATL-EYW and ATL-TGU where they're needed for safe operations. Not sure they have that much flexibility to operate ATL-SNA at the current level of frequency in addition to the others.
I'd say lets see how many A220s are in the fleet by the time the 757s make their exit. They will most likely have a base in ATL by that point in time.
IADCA wrote:evank516 wrote:Delta only has 10 737-700s in their fleet. They're pretty heavily used on routes already, and they're about to be used on one more when they resume ATL-BUR. This adds to the list of routes such as ATL-EYW and ATL-TGU where they're needed for safe operations. Not sure they have that much flexibility to operate ATL-SNA at the current level of frequency in addition to the others.
They also have 50-something A319s that can replicate a lot of what the 737-700s do, freeing them up for routes that truly need the capability, as well as a pile of 737-800s.
PlnCrzyMikey wrote:Isn't EYW the shortest commercial (jet) runway in the US? DL is currently serving it with the 73G to ATL 3X daily (and 2X additional with CR7).
PlnCrzyMikey wrote:I am not surprised that the 73G outperforms the CR7. The few times that I have flown the CR7 (short hauls) it did not impress me as a performer. Never flown on a 73G; lots of rides on the 738 (ok but nothing spectacular) and 739ER (are we gonna make it before the runway ends in PHX?).
However, a 757 in/out of SNA is an experience. Fun factor to the max if one is into that kind of thing.
PlnCrzyMikey wrote:So, A220 eventually for SNA-ATL? Maybe, if the later deliveries do not have the range restriction (or is that gone?).
DylanHarvey wrote:PlnCrzyMikey wrote:I am not surprised that the 73G outperforms the CR7. The few times that I have flown the CR7 (short hauls) it did not impress me as a performer. Never flown on a 73G; lots of rides on the 738 (ok but nothing spectacular) and 739ER (are we gonna make it before the runway ends in PHX?).
The CR7 is actually a high performance aircraft. Flies into ASE, very good thrust to weight ratio.
evank516 wrote:DylanHarvey wrote:PlnCrzyMikey wrote:I am not surprised that the 73G outperforms the CR7. The few times that I have flown the CR7 (short hauls) it did not impress me as a performer. Never flown on a 73G; lots of rides on the 738 (ok but nothing spectacular) and 739ER (are we gonna make it before the runway ends in PHX?).
I don't really know what 8,006 feet of runway (looks like there's 1,000 feet less available for runway 15 ops though) at high altitudes would translate to at sea level, but the runway still has a good amount of length compared to a 4,801 foot runway in EYW. Are most take offs on runway 15 or 33 at ASE?
Varsity1 wrote:evank516 wrote:DylanHarvey wrote:The CR7 is actually a high performance aircraft. Flies into ASE, very good thrust to weight ratio.
ASE is the most demanding performance commercial airport in the United States. You can only land 15 and only depart 33 (one way in, one way out). A single engine go around passed the missed approach point is not certain in a part-25 aircraft. The climb gradient is also a major issue on departure. It has a 99ft wingspan limitation, but even if it didn't, I doubt anything but an empty 73G or 319 could get in and out legally.
PlnCrzyMikey wrote:Looking for thoughts on which aircraft type in the fleet is most likely to take over this route once the 757 is phased out in the coming years. I do not see the 739 or 321 having adequate runway performance/range at high payload weights. For a short time the 73G did the route for DAL, and UAL uses it between KSNA and KEWR so it apparently has the range/performance. Will DAL abandon the route once the 757 is retired or down gauge it, and if so, which aircraft?
Opinions?
My question was more geared towards what a runway the same length at ASE at its elevation would translate to at sea level, if there is such a way to calculate?
N292UX wrote:Doesn't FedEx fly the A300 to SNA? If that's the case without restrictions, I'm sure they'd use the 739/A321 if they can land there. If not, I know AA/UA both use the 738 into SNA. That'd be my guess.
PlnCrzyMikey wrote:6-8 years out? am skeptical about them being around this long, unless you consider the latest acquisitions by DAL of 757s. They have 5 of the newest 757-200 aircraft built; the former Shanghai birds, which are approx. 15 yrs old.
BoeingGuy wrote:N292UX wrote:Doesn't FedEx fly the A300 to SNA? If that's the case without restrictions, I'm sure they'd use the 739/A321 if they can land there. If not, I know AA/UA both use the 738 into SNA. That'd be my guess.
Yes. A 777 could takeoff from SNA if it had minimal fuel and cargo. This issue is the short runway combined with a longer stage length to ATL.
The 737-800 routes you mention are shorter routes than ATL.
A few people mentioned that UA has used the 738 to EWR. I didn’t think a 737-800 could do SNA-EWR without weight restrictions.
PlnCrzyMikey wrote:The FDX A300 (used to be 310) always had me puzzled...how light do they load it to get it out of there? Not much fuel (goes to MEM) but also weight-limited as well? I also have heard (never saw it) that the 767-200 was considered for service there at one time (UAL?)
PlnCrzyMikey wrote:interesting that some of the refurbs were not fitted with winglets (domestic config) or even had them removed (???). Also appears that a lot of the older frames got converted to the sports charter configuration (your namesake for one, which according to planespotters.net is Delta's oldest 757 that is still in service).
