airbazar
Re: CLT new 12000ft runway canceled
Thu Feb 28, 2019 12:05 pm
MIflyer12 wrote:
airbazar wrote:
MIflyer12 wrote:
So, yeah, it gets down to FAA $. Why spend the extra $50-100 million for the extra 2,000 ft of runway which isn't likely to be used even four times a day - if ever in the next decade.
Personally I'm of the opinion that when it comes to infrastructure and especially airport infrastructure it's always better to over build. You take what you can get when you can get it because it's only a matter of time until the nimbys and environmentalists come calling and put a stop to any future expansion. Just look at MUC who chose to do the sensible thing and build only 2 runways because that was all that was needed at the time even tho they had approval for 3 runways. They are kicking themselves now for being sensible.
It's nice to spend other people's money. If AA was paying for it - say, through a per departure or per ton fee allocated across all CLT departures - do you think they'd want it?
And where does the "FAA money" come from? That's a very negative way to look at this and why infrastructure in this country is so poor. There is no planning for the future. It's all reactionary. We're always patching up infrastructure after it's fallen apart.
Super80Fan
Re: CLT new 12000ft runway shortened
Thu Feb 28, 2019 1:00 pm
What is with the obsession in this country with shortening runways? Scared of progress?
RIP McDonnell Douglas
RIP US Airways
Polot
Thu Feb 28, 2019 1:41 pm
It is because of progress that we don’t really need these super long runways in the first place.
SLCUT2777
Thu Feb 28, 2019 2:39 pm
Has DEN ever really needed 16,000' of runway? Does SLC really still need to expand one of their 12,000' runways to 15,000? While both are hot and high, the demand may not dictate the infrastructure investment...
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
TWFlyGuy
Thu Feb 28, 2019 3:15 pm
What I'm curious about is how, if at all, this changes the design. If you look at how they plan to taxi to the new runway, they were going to build elongated "U" shaped taxiways on the north & south ends apparently so they could continue to use the inner most runway while an aircraft taxied to the new runway. It will be interesting to see if the plan still works.
CV880
Thu Feb 28, 2019 7:51 pm
CLT replaced the entire length of 36C with new concrete a few years ago. They should have added 1k feet to the south end which they probably could have done. They also could use displaced thresholds for landing traffic on both ends & probably would have been able to max the strip out to 11500 or more with some preplanning. It's evident that the FAA is not willing to approve/finance new construction thats not absolutely necessary. The elongated taxiway proposal was a waste of funds.
mikejepp
Fri Mar 01, 2019 2:14 am
Heights wrote:
So if I’m understanding this, both CLT and RDU’s proposals to build a new 12,000 foot and 11,500 foot runway respectively have been shortened/modified?
Why?
Its strange.
Looks like the longest civilian runway in the Carolinas is the (fairly) new 11500ft runway at Kinston.
If Kinston, of all places, can get an 11500ft runway, you'd think CLT or RDU would be able to...
Aesma
Fri Mar 01, 2019 2:30 am
KarlB737 wrote:
ikolkyo wrote:
Where are they trying to fly for a 12,000ft runway to be necessary? Asia? Hell, Australia? Lol
Not that any current airlines serving CLT are using the A380 maybe the airport was looking down the road to future international possibilities. I state this fully realizing that A380 production will grind to a halt in the not to distant future. So in the interest of trying to at least speculate why CLT wanted this much concrete how much length is required for a fully loaded A380 to take off and to land with more than enough length. If there is any merit to my theory CLT could have expressed the need for 12,000 ft. prior to the decision by Airbus to call it quits on the A380
The A380 needs less runway than a 748. 10000ft is fine.
Moose135
Fri Mar 01, 2019 2:44 am
mikejepp wrote:
Its strange.
Kinston is a former military field - US Navy in WWII then the USAF in the 1950s.
mikejepp
Fri Mar 01, 2019 3:03 am
Moose135 wrote:
mikejepp wrote:
Its strange.
Their runway was 7500ft until the early 2000s and then extended an additional 4000 feet.
SonomaFlyer
Fri Mar 01, 2019 3:17 am
The altitude at DEN is fairly extreme for a major hub. That altitude really degrades take-off performance and toss in heat and the runway length actually isn't excessive. The number wasn't picked out of a hat. They had to account for long haul and ULH flights out of DEN at the height of summer heat.
rajincajun01
Fri Mar 01, 2019 7:46 am
This and DEN was an alternate for the Space Shuttle.
A319 A320 A321 A330 B1900 B717 B727 B737 B757 B767 B777 B787 C172 C402 CR2 CR7 CRJ9 DH8 E120 ERJ135 ERJ145 E170/175/190 L1011 MD80 MD90 SF340
rajincajun01
Fri Mar 01, 2019 7:47 am
mikejepp wrote:
Moose135 wrote:
mikejepp wrote:
Its strange.
The extension was part of the attempt to lure FedEx for their mid-Atlantic hub if I remember correctly. It ultimately went to GSO...sort of.
Chapmads
Fri Mar 01, 2019 11:50 am
Here’s my question then. I’m in alignment with the understanding that the 12,000 foot runway was to open up the possibility of and accommodate Asia flights one day. If it’s deemed that 12k feet isn’t necessary or pragmatic, I get that. However, why build the runway at all? The plan is/was to put it in between two of the existing parallel runways. In doing so, what do you gain by putting another 10,000 foot runway?
The current 3 parallels are spaced for 3 simultaneous landings. The 4th runway doesn’t change that. I guess it could conceivably help with offsetting inbound/departure traffic, but it seems to me there are bigger needs (taxi space, gates, etc.) that would be a better use of funds than building a new runway that doesn’t have a unique characteristic.
wjcandee
Fri Mar 01, 2019 12:03 pm
Absolutely. "If you build it they will come." And then they will block you from doing anything more.
cat3appr50
Sat Mar 02, 2019 6:56 pm
Not sure why there would be flights from KCLT to such remote locations in the near future, whether with a 10,000’ runway or 12,000’ runway. But in any event, taking a quick technical look at a hypothetical flight from say KCLT to RKSI with a B777F at an estimated flight time of around 14.5-15 hours, with typical route waypoints, winds aloft input, calculated payload, ZFW, and total block fuel, TO Thrust no Derate, for an assumed February winter flight (12C OAT) etc. ….based on a nominal 10,000’ runway (KCLT current runway 18C length), the maximum takeoff weight would be around 725,000 lbs. (around 95% of max. t’off wt.) to arrive at a conservative (code “field”) takeoff margin of around 500 ft.
Assuming a takeoff on the same runway only in summer at 35C OAT, the maximum takeoff weight would be around 693,000 lbs. (around 90% of max. t’off wt) to arrive at a conservative (code “field”) takeoff margin of around 500 ft. So, a 10,000’ runway could accommodate that hypothetical flight, but with a significantly reduced payload in summer.
Q
Sun Mar 03, 2019 2:00 am
When I was a young kid I flew CHA-CLT-LGA on Eastern 727. I was on 727 gate at the old terminal before a new terminal in several years later. The old terminal had at least 10 gates. Not too sure that I don't know of it.
Q
XT6Wagon
Sun Mar 03, 2019 2:12 am
Well, 10K ft with 1K ft of paved "over run" area at each end would have been sweet. Then anything really needing 12K could have backed up to get it. So shorter taxiways, but full length on the runway.
admanager
Sun Mar 03, 2019 3:28 am
Global Trans Park. (Son of Mirabel)
http://www.wilsontimes.com/stories/our- ... yers,93435
GTP as a source of pride, but to eastern North Carolina and the state as a whole, it's a blunder, a boondoggle, an albatross around our collective necks.
Since 1992, the Global TransPark's jet-engine hype has sucked in between $200 million and $300 million in taxpayer money, the John Locke Foundation's Carolina Journal reported, and the state-owned industrial park has provided precious little return on that investment.
afcjets
Sun Mar 03, 2019 6:48 am
Q
The new (current) terminal opened 5/2/82. 36L/18R (renamed 36C/18C) opened 6/20/79. The old terminal had about 15 gates. Here is a pic of it in 1971 showing all the gates before Eastern expanded their main concourse by two gates in 1973.
https://dilemmaxdotnet.files.wordpress. ... t_1971.jpg
CLTRampRat
Sun Mar 03, 2019 2:08 pm
The 12000 for runway was supposed to be used by the American 737s who, when using 36C, use the hill on the side of Old Dowd Road to force themselves into the air.
Moose135
Sun Mar 03, 2019 5:52 pm
Ain't that the truth! I've seen some of those go by at eye level from the overlook...
CLTRampRat
Sun Mar 03, 2019 6:03 pm
Yet the Southwest 737s of all variations are off by the diagonal runway and vertical.
