asuflyer
Air China 983 PEK-LAX Diversion to Anadyr
Tue Mar 05, 2019 12:42 am
An Air China 77W B-2040 operating CA983 from PEK to LAX diverted to Anadyr DYR in the Russian Far East due to a cargo fire indication. The evacuation proved dangerous and did not go as planned as the slides were blown out of position from the aircraft due to high wind gusts. The pax have been unable to leave the airport since the diversion.
Sources
https://vk.com/dyr.aero?z=photo-5000296 ... 02967_4023
https://twitter.com/zuzu2007/status/1102686520924766208
LAX772LR
Re: Air China 983 PEK-LAX Diversion to Anadyr
Tue Mar 05, 2019 3:22 am
Had to be pretty scary, not to mention so limiting! :eek:
GEUltraFan9XGTF
Tue Mar 05, 2019 3:27 am
I guess slides aren't tested in wind storms?
© 2019. All statements are my own. The use of my statements, including by journalists, YouTube vloggers like "DJ's Aviation", etc. without my written consent is strictly prohibited.
YoungDon
Tue Mar 05, 2019 3:28 am
Well on the bright side, it's pretty warm in Anadyr today, almost above the freezing mark, and hopefully no injuries? Could have been worse...
Will be interesting to learn if there was an actual cargo fire or if it was a faulty indication.
ferminbrif
Tue Mar 05, 2019 3:40 am
Will be interesting to learn if there was an actual cargo fire or if it was a faulty indication.[/quote]
I guess it was a faulty indicator. Otherwise, the fire would have come out somewhere …..
eamondzhang
Tue Mar 05, 2019 4:08 am
Saw video during evac - itself is fine, wind only picks up after evacuation.
Apparently only 183 pax onboard which also helps.
Michael
c933103
Tue Mar 05, 2019 5:38 am
CA say there's no trace of fire in the cargo bay so most likely faulty indicator
When no other countries around the world is going to militarily stop China and its subordinate fom abusing its citizens within its national boundary, it is unreasonable to expect those abuse can be countered with purely peaceful means.
c933103
Tue Mar 05, 2019 5:39 am
Michael
Chinese report say 188 passengers
eamondzhang
Tue Mar 05, 2019 6:08 am
Michael
Actually just pulled the report and neither of us are correct - F3 C26 Y157 total 186 is the final number.
Michaele
LAX772LR
Tue Mar 05, 2019 6:12 am
If nothing else, it should call into question whether any such testing is adequate under current required minima...
...too bad we all know that absolutely nothing will be done about this until (and since no) lives lost. :(
DarkSnowyNight
Tue Mar 05, 2019 6:28 am
In all fairness though, that'll be a while. The 77W is a pretty Life Insurance friendly plane.
"Ya Can't Win, Rocky! There's no Oxygen on Mars!"
"Yeah? That means there's no Oxygen for him Neither..."
LAX772LR
Tue Mar 05, 2019 6:52 am
*gasp* :eek:
Hush yo mouf boy!
MH may no longer have 777s, but KE/OZ/CI/GA are still out there.
AA737-823
Tue Mar 05, 2019 6:53 am
Come on, let's be practical for JUST an a.net moment.
What do you want them to do, inflate them with gaseous lead???
That slide has to go from fitting inside a glorified shoebox to being a GIGANTIC toboggan in about ten seconds flat.
It isn't intended to be a pleasurable journey from top to bottom.
Francoflier
Tue Mar 05, 2019 7:07 am
A prompt diversion is warranted in case of a fire indication. Without an actual indication, however (such as smoke, smell or high cargo compartment temps), evacuation might not be the best idea.
strfyr51
Tue Mar 05, 2019 8:09 am
There's no way in Hades the crew can tell what the situation was in the cargo bay so they did the prudent thing as if there was a real fire. Once the passenger got on the slides I'd bet good money they would have gone to the ground anchored by passenger weight. As it is? they'll be ot of service until all the slides are replaced so I'd look for a rescue airplane and that airplane to be Maintenance ferried back to a hub for new slides. I've seen this problem before anc we never found the problem so we precautionarily replaced all the fwd cargo bay sensors and returned the airplane to service with all new slides.
LAX772LR
Tue Mar 05, 2019 8:22 am
None of which has much of anything to do with the actual question posed; but would score this a 6 out of 10 for pointless bloviation. :roll:
chonetsao
Tue Mar 05, 2019 8:33 am
I would not mind to be in that airport for once!!
jayunited
Tue Mar 05, 2019 12:47 pm
Below is a copy and paste from Air & Space Smithsonian which states slides are tested in winds up to 25 knots. Should that threshold be raises another 25-30 knots I don't know but for now the FAA and their equivalents around the world seem to be okay with the current testing standards.
Designing evacuation slides has grown more complex as the FAA has tightened performance standards. In the early 1960s, slides had to deploy in 25 seconds in non-extreme weather: no wind and medium-range temperatures. Today’s slides must deploy in six seconds in temperatures ranging from –65 to 160 degrees Fahrenheit and unfurl in winds up to 25 knots (28.7 mph). Airlines impose further challenges: Slides must be light and compact enough to fit inside an aircraft door or below the door sill or emergency exit window. So each slide is uniquely developed for its location on an aircraft model.
https://www.airspacemag.com/flight-toda ... -22196601/
GEUltraFan9XGTF
Tue Mar 05, 2019 1:14 pm
So the answer is, yes, they are. Just not Putin's Mother Russia Siberian winds.
RJLover
Tue Mar 05, 2019 1:25 pm
How do people get from the town of Anadyr over to the airport? Is there a ferry?
Last Flight(s): YHZ-YYZ // YYZ-YHZ Next Flight(s):
STLflyer
Tue Mar 05, 2019 1:36 pm
https://en.wikipedia.org/wiki/Ugolny_Airport
The airport is located on the opposite site of the Anadyr River compared to the city. Transport by summer is by boat, by winter by a road on the ice, and for a period in spring and fall, only helicopter. The helicopter ticket was (in 2015) 3,680 rubles ($60).
gia777
Tue Mar 05, 2019 4:06 pm
i wonder if it's really a fire in the cargo, any plane could still land safely.....I just cannot recall when was the last time a plane with real fire in cargo landed safely....
GIA777 :coffee:
jetblastdubai
Tue Mar 05, 2019 9:55 pm
This link has some more video that's pretty telling of the condition during the evacuation.
https://www.dailymail.co.uk/news/articl ... nding.html
You have to sorta feel sorry for these passengers that were obviously not prepared to exit in the cold, windy conditions. Lots of people in with no coats tromping through the snow.
Every zoo is a petting zoo......if you're a man!
MADPYRO
Tue Mar 05, 2019 10:09 pm
*gasp* :eek:
Hush yo mouf boy!
And all of those that had incidents were 77E's.... (apart from the KE and SQ engine fires, and even then, only the SQ one was a 77W)
A319/A320/A321/A388/B737/B738/B744/B752/B772/E190/F70
buzzard302
Tue Mar 05, 2019 10:14 pm
I've always wondered why there are not cameras in the cargo spaces so that the pilots can cross reference a fire indication with a visual confirmation.
Tue Mar 05, 2019 10:57 pm
They can call UNITED and ask for assistance... :duck:
YoungDon
Tue Mar 05, 2019 11:06 pm
It's not a good situation at all. Large jets have cargo fire suppression systems, but I can't attest to how well they work. Perhaps someone else can, but a cargo fire is one of the last emergencies I'd want to deal with, particularly on an overwater sector.
747megatop
Tue Mar 05, 2019 11:21 pm
Sources
I think regulators are going to (and should) look into this. What is this was an actual fire situation requiring passengers to evacuate asap but could not do so because of the slides blown out of position?
B1168
Tue Mar 05, 2019 11:41 pm
No, they can’t. I highly doubt if they even offer service in ANC, and even if they do, it remain doubtful if they have any plane ready to go there. If they can’t get that there, they’t better ask PEK to utilize the standby instead——better than SFO anyway.
LDRA
Wed Mar 06, 2019 1:38 am
188 pax on a 77W though...
9w748capt
Wed Mar 06, 2019 2:26 am
And? What's your point?
LDRA
Wed Mar 06, 2019 2:28 am
Load factor
eamondzhang
Wed Mar 06, 2019 2:32 am
It's middle of the lowest time of the year - not uncommon to see light loadings.
At least an SQ A333 made an emergency landing in BKK with smokes coming out of rear cargo hold (and I assume there'a real fire): http://avherald.com/h?article=4613943a&opt=0
Granted it's a couple years ago but still.
Michael
9w748capt
Wed Mar 06, 2019 2:35 am
LDRA wrote:
Load factor
LOL? So are airlines supposed to cancel flights every time they're not full?
carlokiii
Wed Mar 06, 2019 4:10 am
Just an update of the situation for the CA983 (04-Mar), and consequent CA984 (05-Mar):
The rescue aircraft (B-1266) landed in Anadyr 12 hours after the emergency landing.
Source
The ferry flight CA9983 to LAX took off from DYR 8 hours after, or roughly 20 hours after the emergency landing.
Source
And landed in LAX at around 9PM, a delay of 20 hours from original schedule.
The consequent CA984 flight is currently en route to Beijing on B-1266 as CA9984, with a delay of 15 hours from original schedule.
DarkSnowyNight
Wed Mar 06, 2019 6:10 am
Wouldn't be very practical. The cans belowdecks occupy approx 100% of the available space. You really wouldn't see anything.
