enilria
OAG Changes 3/10/2019:Y4 New Routes;WN HNL-KOA/OGG;VC Trims;ET Adds ABJ-IAD;DL Ends DTW-GRU
Sun Mar 10, 2019 1:31 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
9X BNA-MEM MAY 0.9>2[1.0] JUN 0.8>2[1.0] JUL 0.9>3[1.0] AUG 0.8>2[1.3] SEP 0.9>2[1.3] OCT 0.9>3[1.2] NOV 0.8>2[1.1] DEC 0.9>2[1.1]
9X DSI-MEM APR 0>0.4[0.6] MAY 0>0.5[0.6] JUN 0>0.6[0.7] JUL 0>0.5[0.7] AUG 0>0.6[1.4] SEP 0>0.4[1.5] OCT 0>0.4[0.7]
*9X ELD-MEM MAY 0>0.8[0] JUN 0>0.8[0] JUL 0>0.9[0] AUG 0>0.8[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.8[0] DEC 0>0.9[0]
9X MGW-PIT MAY 3>5[3] JUN 3>4[3] JUL 3>5[3] AUG 3>4[3] SEP 3>4[3] OCT 3>5[3] NOV 3>4[3] DEC 3>4[3]
AA AMA-DFW JUN 8>7[7]
AA ASE-DFW DEC 1.0>2[2]
AA ASE-LAX DEC 0>0.9[0.8]
AA ASE-ORD DEC 0>0.9[0.8]
AA ASE-PHX DEC 0>0.5[0.4]
AA AVP-PHL JUN 4>3[4]
AA BDL-LAX JUN 1.0>0.6[1.0]
AA BDL-PHL JUN 6>5[6]
AA BIS-ORD JUN 0.8>0[1.0]
AA BOS-DFW JUN 9>7[7]
AA BOS-JFK JUN 5>0.8[5] JUL 5>4[5]
AA BOS-LGA JUL 12>11[11]
AA BRO-DFW JUN 4>3[4]
AA BTV-PHL JUN 5>4[5]
AA BWI-JFK JUN 2>1.2[1.8]
AA BWI-ORD JUN 5>4[4]
AA BZN-DFW DEC 1.0>1.5[1.4]
AA BZN-LAX DEC 0>0.5[0.4]
AA BZN-ORD DEC 0>0.5[0.4]
AA CAE-DCA JUN 3>4[3]
AA CLE-JFK JUN 2>1.2[3]
AA CLT-JFK JUN 6>7[6]
AA CLT-MSY JUN 7>6[7]
AA CLT-YYZ JUL 5>4[4] AUG 5>4[4] SEP 5>4[4] OCT 5>4[4] NOV 5>4[4] DEC 5>4[3]
AA CMH-ORD JUN 8>9[8]
AA CMH-PHL JUN 7>6[7]
AA DCA-YYZ JUN 3>1.8[3]
AA DFW-EGE DEC 1.0>1.9[2]
AA DFW-GRK JUN 7>8[7]
AA DFW-GUC DEC 0>0.9[0.8]
AA DFW-HDN DEC 0>0.9[0.8]
AA DFW-JAC DEC 1.0>1.4[1.4]
AA DFW-LGA JUN 12>13[11]
AA DFW-MTJ DEC 1.0>1.9[1.8]
AA DFW-RSW JUN 4>3[2]
AA DFW-SGF JUN 7>8[7]
AA DFW-SHV JUN 7>6[5]
AA DTW-PHL JUN 6>5[6]
AA EGE-JFK DEC 0>0.5[0.4]
AA EGE-LAX DEC 0>0.5[0.4]
AA EGE-MIA DEC 0>0.5[0.4]
AA EGE-ORD DEC 0>0.5[0.4]
AA EGE-PHX DEC 0>0.5[0.3]
AA ELP-LAX JUN 2>3[2]
AA FAT-LAX JUN 4>3[4]
AA FAT-PHX JUN 6>5[5]
*AA FLL-ORD JUN 1.0>0.2[2]
AA GYE-MIA JUN 2>1.3[2]
AA HDN-ORD DEC 0>0.5[0.4]
AA IAH-PHL JUN 4>3[3]
AA IND-LAX JUN 1.8>1.0[1.9]
AA IND-PHL JUN 6>5[6]
AA JAC-LAX DEC 0>0.5[0.4]
AA JAC-ORD DEC 0>0.5[0.4]
AA JFK-LAS JUN 3>1.6[3]
AA JFK-ORD JUN 1.3>2[1.0]
AA JFK-ORF JUN 1.8>1.0[2]
AA JFK-RDU JUN 4>3[4]
AA JFK-SAN JUN 3>2[1.8]
AA JFK-SEA JUN 3>2[1.8]
AA JFK-YUL JUN 1.8>1.0[2]
AA LAS-MIA JUN 3>2[3]
AA LAX-MSY JUN 1.8>1.0[1.0]
AA LAX-MTJ DEC 0>0.5[0.4]
AA LAX-PHL JUN 6>7[6]
AA LAX-RDM JUN 1.1>1.7[1.0]
AA LAX-SAN JUN 6>5[6]
AA LAX-SFO JUN 11>8[10]
AA LAX-SJC JUN 6>5[5]
AA LAX-SLC JUN 4>3[3]
AA LGA-MSP JUN 2>1.8[3]
AA LGA-ORD JUL 14>13[13]
AA MDT-PHL JUN 6>5[5]
AA MEM-ORD JUN 6>5[4]
AA MHT-PHL JUN 6>5[6]
AA MRY-PHX JUN 3>4[3]
AA MSN-ORD JUN 7>6[5]
AA MSP-PHL JUN 4>3[4]
AA MSP-PHX JUN 4>3[4]
AA MTJ-ORD DEC 0>0.5[0.4]
AA MTJ-PHX DEC 0>0.5[0.4]
AA MYR-PHL JUN 3>2[2.0]
AA OAK-PHX JUN 5>3[4]
AA ORD-PHX JUN 9>8[9]
AA ORD-PIT JUN 6>7[6]
AA ORD-RSW JUN 1.9>1.1[1.4]
AA ORD-TVC JUN 6>5[4]
AA ORD-TYS JUN 3>4[4]
*AA ORH-PHL JUN 1.9>0.8[0]
AA PHL-PNS JUN 1.0>1.8[0.8]
AA PHL-PVD JUN 6>5[6]
AA PHL-PWM JUN 6>4[6]
AA PHL-RIC JUN 7>5[7]
AA PHL-SEA JUN 4>3[3]
AA PHL-STL JUN 5>4[5]
AA PHL-TPA JUN 5>6[5]
AA PHL-YOW JUN 3>2[3]
AA PHX-RNO JUN 4>5[4]
AA PHX-SBA JUN 5>4[5]
AA PHX-TUS JUN 6>7[6]
AC BDL-YUL APR 0.9>0.7[3]
AC SFO-YYZ JUN 6>5[6] JUL 6>5[6] AUG 6>5[6]
AM AUS-MEX DEC 0.7>0.9[0.9]
AM FAT-GDL DEC 0.7>0.9[0.9]
AM GDL-LAX JUN 1.3>1.6[2] JUL 1.3>1.8[2] AUG 1.3>1.6[2] DEC 1.3>1.7[2]
AM GDL-ORD JUN 1.0>1.6[1.9] JUL 1.0>2[1.8] AUG 1.0>1.6[1.9] DEC 1.0>1.6[1.5]
AM LAS-MEX DEC 1.3>1.6[1.9]
AM LAS-MTY DEC 0.3>0.6[0.5]
AM MCO-MEX DEC 1.3>2[2]
AM MCO-MTY DEC 0>0.2[0.1]
AM MEX-ORD DEC 2>3[3]
AM MEX-SFO DEC 2>3[3]
AV GUA-ORD MAY 1.0>0.4[0]
B6 BGI-FLL JUN 1.0>0.8[1.0] JUL 1.0>0.5[1.0] AUG 1.0>0.6[1.0] SEP 1.0>0.6[1.0] OCT 0.8>0.5[1.0]
B6 BGI-JFK JUL 2>1.7[2] OCT 1.8>1.4[1.7]
DI LGW-MIA DEC 0.6>1.0[0]
DL ASE-SLC SEP 2>1.0[2] OCT 2>1.0[2] NOV 1.9>0.7[2]
DL ATL-GSO OCT 8>9[8] NOV 7>8[8]
DL ATL-GSP OCT 8>9[8] NOV 7>8[8]
DL ATL-JAX AUG 13>12[13]
DL ATL-OAK SEP 1.0>0.7[0]
DL ATL-PAP JUL 0.7>1.0[1.0] AUG 0.7>1.0[1.0]
DL ATL-PIT NOV 7>8[8]
DL ATL-TUS OCT 2>3[1.8]
DL AUA-BOS DEC 0.1>0.3[0.1]
**DL DTW-GRU NOV 0.4>0[0.4] DEC 0.4>0[0.3]
DL EWR-SLC AUG 1.8>1.4[1.7]
*DL HNL-PDX DEC 0.4>0[0.4]
DL IND-JFK NOV 1.8>3[2]
DL JAC-SLC SEP 3>4[3]
DL LEX-MSP MAY 0.9>0.6[1.0]
DL LGA-ORD DEC 10>9[10]
DL MSP-OKC DEC 2>1.5[1.6]
DL OKC-SLC DEC 2>2.0[1.9]
DL PHL-SLC OCT 1.4>1.8[0.8] NOV 1.4>1.8[0.8]
EI deferred the YUL start and reduced JUL ops
EI DUB-MSP JUL 1.0>0.7[0]
EI DUB-PHL JUL 1.0>0.7[1.0]
EI JFK-SNN JUL 0.8>0.5[0.8]
*ET ABJ-IAD JUN 0>0.3[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0] NOV 0>0.4[0] DEC 0>0.5[0]
G4 BLI-OAK JUN 0.7>1.0[0.7] JUL 0.7>1.0[0.7]
G4 LAS-OAK JUN 1.0>1.3[1.0] JUL 1.0>1.2[1.0]
HA HNL-ITO SEP 15>14[14] OCT 15>14[15]
HA HNL-KOA SEP 20>19[19] OCT 20>18[20]
HA HNL-OGG OCT 26>27[28]
*HA HNL-SFO OCT 1.0>1.5[1.0] NOV 1.0>2[1.0] DEC 1.0>2[1.4]
HA KOA-LIH NOV 1.4>1.0[1.4] DEC 1.4>1.0[1.5]
HA OGG-SFO OCT 0.8>1.0[1.0]
HX HKG-LAX SEP 1.0>0.6[1.0] OCT 1.0>0.6[1.0]
KG DEN-RIW JUL 0>1.6[2] AUG 0>1.6[1.9] SEP 0>1.6[1.8] OCT 0>1.6[1.9]
KG DEN-SHR JUL 0>0.8[1.0] AUG 0>0.8[1.0] SEP 0>0.8[1.0] OCT 0>0.8[1.0]
KG RIW-SHR JUL 0>1.6[0.6] AUG 0>1.6[0.9] SEP 0>1.6[0.8] OCT 0>1.6[0.9]
KS AKN-ANC APR 0.6>0.9[2]
KS AKN-DLG APR 0.6>0.9[0]
KS ANC-DLG APR 0.6>0.9[3]
KS ANC-SNP APR 0.4>0[0.4] MAY 0.5>0[0.5] JUN 0.4>0[0.5] JUL 0.4>0[0.3] AUG 0.4>0[0.4] SEP 0.4>0[0.5] OCT 0.4>0[0.3] NOV 0.4>0[0.4] DEC 0.4>0[0.4]
*LF BKW-CLT APR 0.9>1.7[0] MAY 0>1.7[0] JUN 0>1.7[0] JUL 0>1.7[0] AUG 0>1.7[0] SEP 0>1.7[0] OCT 0>0.8[0]
*LF BKW-PKB APR 0.9>1.7[0] MAY 0>1.7[0] JUN 0>1.7[0] JUL 0>1.7[0] AUG 0>1.7[0] SEP 0>1.7[0] OCT 0>0.8[0]*
Q6 IAD-SAL DEC 0>0.6[0.5]
Q6 JFK-SAL DEC 0>0.4[0.5]
SY MSP-MYR JUN 0.0>0.3[0.1]
UA BOS-EWR JUL 11>10[10]
UA BWI-DEN AUG 3>2[2]
UA BZN-DEN JUL 5>4[5]
UA BZN-IAH JUN 0.4>0.6[0.0] JUL 1.0>1.3[0.3] AUG 0.6>0.8[0.3]
UA BZN-SFO JUL 1.0>1.3[2]
UA CLE-LAX AUG 2>1.8[1.7]
UA CLL-IAH JUL 3>2[3]
UA CMH-EWR JUL 8>7[7]
UA CVG-EWR JUL 6>5[6] AUG 6>5[6]
UA DCA-EWR JUL 8>7[7]
UA DEN-ELP JUL 4>3[4]
UA DEN-FAT JUL 4>3[4]
UA DEN-MCI JUL 6>4[6] AUG 6>5[6]
UA DEN-MKE AUG 3>2[2.0]
UA DEN-MSN AUG 3>2[2.0]
UA DEN-TPA AUG 2>3[2]
UA DEN-TUL JUL 5>4[4]
UA ECP-IAH JUL 3>2[2] AUG 3>2[2]
UA EWR-NAP OCT 0.1>0.6[0]
UA EWR-PHX AUG 3>2[2]
UA EWR-PIT JUL 8>7[7]
UA EWR-RDU JUL 9>8[8]
UA IAD-TYS APR 3>2[3]
UA IAH-JAN JUL 6>5[5]
UA IAH-MKE JUL 3>1.8[1.9] AUG 3>2[1.9]
UA IAH-MLU JUL 3>1.9[3] AUG 2>1.9[3]
UA IAH-RNO OCT 0.4>1.0[0.3] NOV 0.3>1.0[0.3] DEC 0.3>1.0[0.7]
UA IAH-SDF JUL 4>3[3]
UA IAH-TUS JUL 3>2[2] AUG 3>2[2]
UA IND-SFO JUL 1.9>1.5[1.6]
UA JAC-SFO JUL 1.3>1.0[1.0]
UA LAS-LAX SEP 5>6[4]
UA LAX-MCO SEP 2>1.0[1.8]
UA LAX-MSO JUN 0.8>0.5[0.8]
UA LAX-SBA SEP 3>4[4]
UA MCO-SFO SEP 3>2[3]
UA MYR-ORD JUL 1.0>1.3[0.3] AUG 0.6>0.8[0.2]
UA OKC-ORD JUL 4>3[3]
UA ORD-PIA SEP 5>4[4] OCT 5>4[4] NOV 5>4[4]
UA ORD-TYS JUL 5>4[4]
UA ORD-YWG JUL 3>2[3] AUG 3>2[3]
UA SEA-SFO AUG 13>14[11]
UA SFO-SLC SEP 4>5[4]
*VC AUS-TUS JUN 0.3>0[0.4] JUL 0.3>0[0.4] AUG 0.3>0[0.5] SEP 0.3>0[0.4] OCT 0.3>0[0.4]
*VC BTR-SFB APR 0.3>0[0] MAY 0.3>0[0] SEP 0.3>0.0[0.2] OCT 0.3>0[0.3]
*VC CAE-SFB APR 0.6>0.2[0] MAY 0.6>0.3[0] JUN 0.6>0.3[0] JUL 0.6>0.3[0] AUG 0.6>0.3[0] SEP 0.6>0.3[0]
*VC MGM-SFB APR 0.3>0[0] MAY 0.3>0[0.3]
I hadn't seen the intra-Hawaii frequency
*WN HNL-KOA MAY 0>3[0] JUN 0>4[0] JUL 0>4[0] AUG 0>4[0] SEP 0>4[0]
*WN HNL-OAK APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0]
*WN HNL-OGG APR 0>0.4[0] MAY 0>4[0] JUN 0>4[0] JUL 0>4[0] AUG 0>4[0] SEP 0>4[0]
*WN HNL-SJC MAY 0>0.9[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
*WN OAK-OGG APR 0>1.5[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0]
*WN OGG-SJC MAY 0>0.2[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
*Y4 ABQ-CUU JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0]
Y4 ABQ-GDL APR 0.3>0.1[0] MAY 0.3>0.1[0] JUN 0.3>0.0[0] JUL 0.3>0[0] AUG 0.3>0[0] SEP 0.3>0[0] OCT 0.2>0[0]
Y4 AGU-LAX DEC 0>0.4[0.5]
*Y4 AGU-MDW JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.4[0] DEC 0>0.5[0]
*Y4 BJX-FAT NOV 0>0.3[0] DEC 0>0.3[0]
Y4 BJX-MDW DEC 0>0.5[0.6]
Y4 BJX-OAK OCT 0.4>0.6[0.3] NOV 0>0.6[0.3] DEC 0>0.6[0.3]
Y4 DEN-GDL APR 0.4>0.6[0.4] JUL 0.5>0.7[0.5] AUG 0.4>0.6[0.4] DEC 0>0.4[0.6]
Y4 DEN-MEX APR 0.4>0.7[0.4] JUL 0.4>1.0[0.7] AUG 0.4>0.8[0.7] NOV 0>0.4[0.1] DEC 0>0.5[0.7]
Y4 DFW-DGO JUN 0>0.2[0] JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0]
Y4 DFW-GDL NOV 0>0.6[0.4] DEC 0>0.6[0.7]
Y4 DGO-LAX NOV 0>0.3[0.1] DEC 0>0.3[0.2]
Y4 FAT-GDL JUL 1.0>1.5[1.0] AUG 1.0>1.3[0.9] NOV 0>1.0[0.9] DEC 0>1.0[1.4]
Y4 FAT-MLM NOV 0>0.4[0.3] DEC 0>0.5[0.3]
Y4 GDL-IAH JUL 0.6>0.9[0.5] AUG 0.6>0.8[0.4] DEC 0>0.5[0.7]
Y4 GDL-JFK APR 0.3>0.6[0.3] MAY 0.3>0.6[0.3] JUN 0.3>0.6[0.3] JUL 0.3>0.6[0.3] AUG 0.3>0.6[0.3] SEP 0.3>0.6[0.3] OCT 0.2>0.5[0.3] NOV 0>0.6[0.3] DEC 0>0.5[0.3]
Y4 GDL-MCO DEC 0>0.3[0.4]
Y4 GDL-MIA DEC 0>0.3[0.4]
Y4 GDL-ORD NOV 0>0.4[0.3] DEC 0>0.5[0.4]
Y4 GDL-PDX NOV 0>0.9[0.6] DEC 0>0.9[0.7]
Y4 GDL-PHX DEC 0>0.5[0.6]
Y4 GDL-SEA JUN 0.6>0.9[0.5] JUL 0.5>1.0[0.7] AUG 0.6>0.9[0.6] OCT 0.5>0.7[0.4] NOV 0>0.8[0.5] DEC 0>0.9[0.7]
Y4 GDL-SJC APR 1.0>1.3[0.7] MAY 1.0>1.2[0.7] JUN 1.0>1.3[0.7] JUL 1.0>1.4[0.8] AUG 1.0>1.4[0.8] SEP 1.0>1.3[0.7] OCT 0.8>1.3[0.7] NOV 0>1.3[0.8] DEC 0>1.3[0.9]
Y4 GDL-SMF JUL 1.0>1.3[0.9] NOV 0>1.0[0.9] DEC 0>1.0[1.1]
Y4 LAS-MEX APR 0>1.0[0.9] MAY 0>1.0[0.8] JUN 0>1.0[0.9] JUL 0>1.0[0.8] AUG 0>1.0[0.9] OCT 0>1.0[0.8] NOV 0>1.0[0.9] DEC 0>1.0[0.9]
Y4 LAX-MEX APR 0.2>1.6[2] MAY 0.2>1.3[1.0] JUN 0.1>1.5[1.0] JUL 0.2>1.9[1.0] AUG 0.1>1.7[1.0] SEP 0.1>1.3[1.0] OCT 0.1>1.3[1.0] NOV 0>1.3[1.1] DEC 0>1.3[1.0]
Y4 LAX-OAX NOV 0>0.4[0.3] DEC 0>0.4[0.3]
Y4 MCO-MEX NOV 0>0.4[0.7] DEC 0>0.4[0.7]
Y4 MDW-QRO JUL 0.3>0[0.3] AUG 0.3>0[0.3] SEP 0.3>0[0.3] OCT 0.2>0[0.3]
Y4 MDW-ZCL NOV 0>0.6[0.4] DEC 0>0.5[0.4]
Y4 MEX-MIA NOV 0>0.6[1.0] DEC 0>0.6[1.0]
*Y4 MEX-OAK JUL 0.6>1.0[0.6] AUG 0.5>0.8[0.6] NOV 0>0.6[0] DEC 0>0.6[0]
Y4 MLM-OAK OCT 0.5>0.7[0.6] DEC 0>0.6[0.7]
Y4 MLM-SJC NOV 0>0.4[0.3] DEC 0>0.4[0.3]
*Y4 MTY-SAT NOV 0>0.4[0] DEC 0>0.5[0]
*Y4 ORD-QRO JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0]
*Y4 PHX-PVR JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0]
jfklganyc
Re: OAG Changes 3/10/2019:Y4 New Routes;WN HNL-KOA/OGG;VC Trims;ET Adds ABJ-IAD;DL Ends DTW-GRU
Sun Mar 10, 2019 1:44 pm
You have to wonder how much longer AA can hang on to the hublet at JFK.
JFK BOS dropping down to .8 for June. Geez
FlyPNS1
Sun Mar 10, 2019 1:49 pm
AA adding a 2nd daily flight on PHL-PNS....I’d like to say it’s because the route is doing so well, but suspect F9 launching PNS-PHL in May has something to do with it.
Thanks as always for doing these reports!
303dk
Sun Mar 10, 2019 1:52 pm
Not sure why they that at all. Connections go to PHL and O/D to LGA
Bobloblaw
Sun Mar 10, 2019 1:53 pm
Look at July.
Scarebus34
Sun Mar 10, 2019 1:56 pm
AA continues to trim JFK. What a sad state of affairs compared to what it used to be.
Bigant0408
Sun Mar 10, 2019 1:57 pm
Always look forward to your Sunday post. I know it takes a lot of effort to collect this data. I see delta going almost 2X daily on PHL-SLC route which I assume is because AA quietly ended there seasonal route as I can’t find any bookings for non stop on AA website. Good for Delta
The man who sleeps on the floor doesn’t fall out of bed
UpNAWAy
Sun Mar 10, 2019 2:31 pm
If you notice the plan is obvious. They are increasing beyond perimeter (LGA) JFK flying and reducing the short routes.
whywhyzee
Sun Mar 10, 2019 2:40 pm
YYZ-CDG is still showing 5x daily in the booking engine.
slcdeltarumd11
Sun Mar 10, 2019 2:45 pm
Jeesh YUL is down to 1x daily. I remember that being as high as 4-5x daily. AA is really on slash at JFK.
Still my favorite terminal at JFK and their frequency to LA is excellent.
crescent
It's to feed the overseas JFK flights to Europe and LatAm
303dk
Sun Mar 10, 2019 2:58 pm
AA has been vocal that the Europe connections would be focused out of PHL. LATAM connections have always been via MIA.
Dominion301
Sun Mar 10, 2019 2:59 pm
In the context of this thread, I don’t follow you.
Rdh3e
Sun Mar 10, 2019 3:29 pm
Appears to mean CLT instead of CDG.
klm617
Sun Mar 10, 2019 3:34 pm
Another big hit for Detroit losing GRU. At this point anything Delta adds at Detroit is pretty much meaningless are far as growth goes because every add gets washed away by an equal cancelation or reduction in service.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
transportgeek
Sun Mar 10, 2019 3:40 pm
Except they are showing reductions in beyond the LGA perimeter flying in this change, showing reductions to LAS, SAN and SEA
IPFreely
Sun Mar 10, 2019 3:45 pm
DTW-GRU is less than 200 miles shorter than DTW-ATL-GRU. Most DTW-based passengers will fly this connection and most passengers who were connecting XXX-GRU-DTW will now connect XXX-ATL-GRU. This will only cost DL a few pax at most. And it helps keep profit in ATL and helps ATL stay competitive in the race to the annual most flights/most passengers title. Eliminating a long haul flight while losing only a few pax and boosting ATL is a win/win move.
jfern022
[url][/url]
Thank god you don't work in Network Planning or RM at Delta.
Jo8338
Sun Mar 10, 2019 3:47 pm
I don’t understand the logic of AA cutting FLL -ORD since people can connect in ORD just as easily as CLT or PHl.
FATFlyer
Sun Mar 10, 2019 3:48 pm
FAT-PHX is gaining an A319 but reducing RJ frequency.
FAT-DEN may be due to FAT-ORD going mainline.
FAT-BJX is new, it has been discussed as a rumor on the Fresno Aviation thread.
The small FAT FIS facility is going to be busy and crowded for the next few years with all of that international service. The new FIS cannot be built soon enough.
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
TYSflyer
Sun Mar 10, 2019 4:04 pm
Thanks as always for your thread!
Didn’t show up on your thread as no frequency change, but with AA schedule update last night TYS-DFW gained a mainline flight starting in June on an A319. First AA mainline in TYS since shortly after 9/11. I figured it was about due as AA will be operating 26 daily weekday departures from TYS this summer. Prior to this addition, it had to be one of the larger stations without any mainline service.
msiebert09
Sun Mar 10, 2019 4:18 pm
Thank you again for your post! Always a pleasure to read my Sunday Airline Route Changes!
whywhyzee
Sun Mar 10, 2019 4:39 pm
Damn, I wrote that this morning, my phone's autocorrect doesn't recognize airport codes. It was supposed to be CLT, it corrected to a recent search from my phone. Apologies.
MIflyer12
Sun Mar 10, 2019 4:40 pm
Blame Ford, FCA and GM for shrinking their Brazilian operations. You can't fly (profitably) without demand. As for lack of Delta love for DTW, let's turn back the block 12 years to the NW era. How many flights - from all hubs - did NW have to South America? Not a single one.
bluefltspecial
Sun Mar 10, 2019 4:43 pm
As has been mentioned by others, this is another chop to JFK which we've continued to see.
My question is, what happens to those slots. Is it use them or lose them, or is there a timeline on it?
They just announced an expansion so BA and a few others can move in... seems odd, no?
Save a horse, ride a Fly-boy....
PHLspecial
Sun Mar 10, 2019 4:57 pm
I thought Delta would have dropped this route because of AA strong hold on PHL. Happy to see Delta holding on against AA.
303dk
Sun Mar 10, 2019 5:02 pm
If you do some dummy bookings, you'll see that AA commands higher fares for a one stop to LGA vs a nonstop to JFK. They're chasing the $
chrisinbrasil
Sun Mar 10, 2019 5:26 pm
When living in Porto Alegre, I was sad AA dropped flights from POA-MIA. Now, seeing GRU-DTW cut, is this about the Brazilian economy still?
Southern, Eastern, Delta, Northwest, United, American, Varig, Vasp, TransBrasil, Tam, Gol, British, Lufthansa, KLM, Aero, Brussels, Air Canada
LotsaRunway
Sun Mar 10, 2019 5:36 pm
Seems like a fairly substantial AA trimming of frequencies at PHL pretty close in (June). Is there a logistical issue, upgauging, or lower than expected bookings/capacity trim?
C010T3
Sun Mar 10, 2019 5:37 pm
No, G3, AD and O6 have inundated the market with capacity. DL’s weakest link is now understandably being cut. Their focus has also shifted to investing long-term in the development of JFK-GIG.
Bigant0408
Sun Mar 10, 2019 5:41 pm
I thought so too. But IMO the AA route was a early morning departure at like 6:30am so probably hard to gain connections that way. But overall good Delta taking advantage of a dropped out just like LH on Frankfurt
UALifer
Sun Mar 10, 2019 6:10 pm
Look at July.
Looks like from June 6 - July 6, AA operates a single BOS-JFK flight on Wednesdays and Thursdays only.
Back to 5/day starting July 7th... weird. Could this be another impending route cancelation, similar to JFK-MCO a few weeks back?
Beechtobus
Sun Mar 10, 2019 6:28 pm
I nonrev on this route fairly regularly and I have yet to not have to sit in the cockpit jump seat (every pax seat full). I imagine AAs add is a bit of both the routes success and F9 jumping on the route.
flyfresno
Sun Mar 10, 2019 6:32 pm
I would say that FAT-LAX on AA is the biggest loss here, as it means the last flight will depart at 3:56 and arrive at 5:17, more than 3 hours earlier than right now. While PHX has red-eye connections too, this means anyone taking a red eye from LAX (including TPAC) will have a significantly longer wait. DEN seems strange: no more mid-day flight? Did this just open a hole up for something else?
Midwestindy
Sun Mar 10, 2019 6:33 pm
UALifer wrote:
Look at July.
July schedule is a placeholder, at this point anything could be cut(except the hub flying)
Some upguaging, IND-PHL is getting mainline and BDL-PHL is getting more mainline.
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
Dominion301
Sun Mar 10, 2019 6:48 pm
Ah totally understood. This pretty much reversed last week’s addition.
DanDun
Sun Mar 10, 2019 7:02 pm
I believe JFK might be doing runway work in June, perhaps that’s why AA cut some frequencies, it’s odd that the BOS and SAN flights come back in July.
777Mech
Sun Mar 10, 2019 7:08 pm
You can't be throwing facts at him, he can't take it. It's the big evil Delta thay's just has it out for DTW.
N649DL
Sun Mar 10, 2019 7:31 pm
I recall that DTW-GRU was launched during the recession for the big 3 automakers and other corporate contracts. Perhaps a few dropped since then and affect yield on the route.
jplatts
Sun Mar 10, 2019 7:57 pm
AA has a hub at MIA, and AA already has 8 daily nonstops to MIA from ORD. AA also has nonstop service to MIA but not to FLL from its LAX and PHX hubs.
tphuang
Sun Mar 10, 2019 8:21 pm
AA's JFK regional operation's day looks to be numbered. Also, this is just the usual tweaking AA does to finalize schedule. Anything later is still up in the air.
Jo8338
Sun Mar 10, 2019 8:23 pm
Understood but most people that live in Broward and Palm Beach County don’t want to go to MIA.
UALifer
Sun Mar 10, 2019 8:27 pm
Midwestindy wrote:
UALifer wrote:
Bobloblaw wrote:
Look at July.
I’m more confused why they are choosing to fly Wednesday/Thursday only for June. Might as well not fly it at all. And even if you were only to fly it two days, why Wednesday?
C010T3
Sun Mar 10, 2019 8:29 pm
Ford has recently announced the closing of a plant in São Paulo.
EvanWSFO
Sun Mar 10, 2019 8:30 pm
Poor DTW. Just 500ish flights a day by a single airline. How dare they?
I have been on this site 15 years. A unrecoverable email account led me to starting over. Those of you who call me a rookie, you may stop ok?
sldispatcher
Sun Mar 10, 2019 8:39 pm
Thanks as always for this report. The responsible trimming by AA at JFK is similar to what we have seen other airlines do. AA is just feeling some of the same pressure in JFK that Delta felt at DFW. Instead of picking battles, they are picking profits. The horror!! Let's face it, no one airline can be all things to all people in all locations.
Those of us out here in "Spokelandia" deal with connections and high prices almost every trip. We don't get flights to every hub with each carrier. Often, our direction of travel may determine the airline choice unless we really just want to be loyal to one carrier and eat the extra time. However, our lives are happy and productive.
N649DL
Sun Mar 10, 2019 8:44 pm
Those jobs coming back to America or is this as a result of modifying their product line?
C010T3
Sun Mar 10, 2019 8:51 pm
Considering how Brazil is not a big car/truck importer due to how the market is organised, the production takes place mostly within the country. The fact that they are reducing their presence is a capitulation.
Delta’s move makes all the sense. American automakers are losing their importance in Brazil. If Peugeot launches Opel in Brazil, then GM could also start saying goodbye, considering how the Chevrolet cars that used to be sold in Brazil were all derived from European models.
MIAFLLPBIFlyer
Sun Mar 10, 2019 9:07 pm
AA's continued FLL cuts either mean FF members have to drive to Miami or will just seek other options. If someone in southern Palm Beach or northern Broward isn't an AA frequent flier, they can fly UA to ORD and not shed a tear. But I believe AA's FF base is large enough that they might be making a mistake cutting FLL to a bare bone spoke as has happened since the merger.
enilria
Sun Mar 10, 2019 9:30 pm
Thanks to everybody for the kind words. :)
