osiris30 wrote:So far, based on DATA and not SPECULATION the Max hasn't had two crashes for the same reason either. Additionally, the ET flight looks VERY different on FR data and MAY have a different root cause.
Just remind me; what was it Canada said? Something about significant data from satellites and not just FR24?
As it happens, after a shaky start, as each day passes I am beginning to appreciate your pro-Boeing contributions more than the perpetual smokescreens thrown up by some others on these forums. You show intelligence, and reasonableness, and that is quite enough of me blowing smoke up your exhaust pipe.
Could it be that these HUGE differences that you perceive from FR24 data are down to ADD being at 7,200ft?
Until you identify these {insert adjective of choice} differences, I am more inclined to believe the Canadian Transportation Minister Marc Garneau who spoke only of similarities.
I accept you are right that there is a possibility the two crashes are from different root causes, maybe with a common helping of pilot error - not because it was LionAir, or ET, but because pilot error is the #1 cause of crashes worldwide, yeah, even in America.
If that turns out to be the case, then so be it, but at least this whole debacle has highlighted a number of
other issues that really needed to be dragged into the light.
And it could even turn out that correcting the flaws in MCAS is the very least of Boeing's worries.
