AA300B
AA 767 Replacement: MIA - Latin America Market
Tue Mar 12, 2019 10:51 am
It is no news to us that AA has announced their ageing 767s by the year 2020. being less than two years from this new era it would be very interesting to know the plans they have in mind for the affected market, specially out of MIA where several Latin American markets are served with this type.
The new AA has a gap between the A321N and the B788, only the first being based in MIA at the time. While both would be potential replacements for the 767, they have considerable differences in cargo capability.
These following markets currently served by the 767 have significant cargo importance for AA:
    Belo Horizonte
    Guayaquil
    Lima
    Montevideo
Maybe an insider can give us their feedback on the strategy planned for the MIA base with regards to this long anticipated replacement.
Cheers !
E145, E170, E190, A310, A300, A319, A320, A321, A330, A340, A380, 717 727, 737, 747, 757, 767, 777, 77W, 787
ac33e
Re: AA 767 Replacement: MIA - Latin America Market
Tue Mar 12, 2019 11:21 am
It seems like the 209 seat 767s can be replaced by 788s or 332s, whichever is available. Of course this would increase both passenger and cargo capacity, however most North American airlines have considerably upgauged their widebody fleet come the 787.
ctrabs0114
Tue Mar 12, 2019 11:26 am
For some reason, I was under the impression that some of the next batch of 788s were going to be based at MIA to replace the 763s. Or, I might have mixed that up with the replacements of the 332/333s at PHL and CLT. I know AA palletized our luggage on a 788 between ORD and DFW, and i can't pretend to know if the 763 has that capability, but if cargo is a major impact for those destinations you listed, then I'm going to make an educated (read: wild) guess that the 788 might fit that mission.
2019: DAL, MCI, PHX, LAS, DFW, SAT, ORD, SLC, SEA, DTW, PHL, MIA, LAX; B73G (WN x3), B738 (WN, AA, DL), A20N (NK), MD83 (AA), B788 (AA x2), CS1 (DL), B739 (DL), B712 (DL), B752 (AA), B763 (AA), B77W (AA), B789 (AA)
Next: TBA
Ishrion
Tue Mar 12, 2019 11:34 am
787s just like they’re doing in PHL
Ishrion
Tue Mar 12, 2019 11:36 am
jfk777
Tue Mar 12, 2019 11:55 am
The perfect airplane for AA on the longer Latin Routes not needing 777 capacity would be the Boeing NMA. GRU, GIG, EZE and SCL still need the 777 cargo capacity passenger lift plus the lie flat Business Class seats.
LA704
Tue Mar 12, 2019 12:17 pm
I would expect LIM to get the 787 due to cargo and LA feed. GYE could get the 787 for the same reason, but I'm not convinced. IMHO MVD and CNF will get the 321neo once they arrive in numbers
318 319 320 321 332 343 722 731 732 735 73G 742 744 752 762 763 77W M11
MIflyer12
Tue Mar 12, 2019 1:34 pm
Has AA ordered LRs or XLRs? If they haven't there's a problem - base 321Neos won't be flying MIA-CNF/MVD non-stop.
ojjunior
Tue Mar 12, 2019 2:00 pm
Stop thinking AA will send the A321 to LA. This aircraft will simply not meet demand and cargo, period.
We'll probably see 777, 787 or A330 family variations swapping for those destinations.
dfw88
Tue Mar 12, 2019 2:01 pm
    Belo Horizonte
    Guayaquil
    Lima
    Montevideo
AA no longer flies to CNF. That flight was cut last summer.
As for the others, the announced plan is that 787s will do most of the work. That being said, I predict there's a strong chance that some of the 332s migrate down from PHL to fill in some gaps as well, depending on the market.
Weatherwatcher1
Tue Mar 12, 2019 2:39 pm
AA has one 737 and one 767 to GYE a day from MIA. That is a candidate for upgauging to a 787-9 or 777 and dropping the frequency of the 737 flight, but they would lose the benefit of having both a morning and evening departure from GYE. Alternatively they could fly three 737s per day.
Weatherwatcher1
Tue Mar 12, 2019 2:43 pm
AA is already flying 737s to Ecuador, A319s to Colombia and 757s to Peru in addition to 767s. They have quite a variety of planes flying, but no A321s as far as I know.
AA300B
Tue Mar 12, 2019 3:53 pm
Briefly, AA actually operated the A321 on the morning departure out of GYE as before converting it back to a 757 and then to 737. The A321 was rumoured to have quite a few issues regarding weight and balance out of GYE due to cargo, this being one of the reasons for the equipment change, so maybe this would probably not be a change from the 767.
AA has one 737 and one 767 to GYE a day from MIA. That is a candidate for up-gauging to a 787-9 or 777 and dropping the frequency of the 737 flight, but they would lose the benefit of having both a morning and evening departure from GYE. Alternatively they could fly three 737s per day.
Having 1 per day 789 or 777 would be an interesting alternative. They are switching the morning departure from GYE to a B737-8 MAX starting summer 2019. Having 3x B737 per day would also be interesting however I am not sure of the cargo capacity of the B737, keeping in mind passenger loads are strong as well.
codc10
Tue Mar 12, 2019 4:09 pm
It depends on the nature of the freight. If it can be bulk loaded, then 3x MAX8 would be a reasonable solution as there won't be much in the way of weight restrictions. If containerized freight in GYE is a big advantage, then 787 or 332 obviously makes more sense.
Weatherwatcher1
Tue Mar 12, 2019 5:20 pm
I’m surprised the A321 has issues regarding weight and balance. It is only a 2000 mile flight and both airports are at sea level. Do you have any insight regarding what the issues were?
CarlosSi
Tue Mar 12, 2019 5:23 pm
I’m surprised, that if the 788 is AA’s 767 replacement, that more aren’t already present in MIA. Probably just consolidating them there now and putting 788s at other places that used to see the 767 more often (ORD and DFW). Once they’re out it’ll probably see 787s or other narrowbodies.
AA300B
Tue Mar 12, 2019 7:38 pm
I was talking with AA staff at GYE airport a few months after the type was introduced on the route and they mentioned at times passenger capacity was restricted due to weight and balance + cargo. Unfortunately I do not have more relevant details. This flight was switched to a B737 shortly after.
It would be interesting to know if preparations are being made at MIA (Maintenace, Crews) to receive the 787-8 by the end of next year. This does seem like the better alternative considering they are not premium-heavy (20 J seat/28J seat versions) suitable for the markets currently operated by 767.
AA300B
Tue Mar 12, 2019 7:39 pm
AA300B
Tue Mar 12, 2019 7:40 pm
