Page 1 of 3
OAG Changes 3/17/2019: NK Closes CAP;UA Suspends SFO-AMS
Posted: Sun Mar 17, 2019 2:00 pm
by enilria
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3E BRL-STL APR 1.5>1.9[1.9]
7H AKN-ANC APR 0.2>0[0.9]
7H AKN-DLG APR 0.2>0[0.9]
7H ANC-DLG APR 0.2>0[0.9]
9X DFW-ELD MAY 3>1.7[3] JUN 3>1.7[3] JUL 3>1.7[3] AUG 3>1.7[3] SEP 3>1.7[3] OCT 3>1.7[3] NOV 3>1.7[3] DEC 3>1.7[3]
9X EYW-PBI MAY 0.8>0.4[0] JUN 0.9>0.5[0] JUL 0.8>0.4[0] AUG 0.9>0.5[0] SEP 0.9>0.4[0] OCT 0.8>0.4[0] NOV 0.9>0.5[1.1] DEC 0.8>0.4[1.5]
9X MGW-PIT MAY 5>3[3] JUN 4>3[3] JUL 5>3[3] AUG 4>3[3] SEP 4>3[3] OCT 5>3[3] NOV 4>3[3] DEC 4>3[3]
AA ACT-DFW JUN 5>6[5]
AA AVL-CLT MAY 7>8[6] JUN 7>8[7]
*AA BOI-DFW SEP 1.0>3[1.0] OCT 1.0>3[1.0] NOV 1.0>3[1.0] DEC 1.0>2[1.3]
AA BOS-JFK MAY 3>1.2[4] JUN 0.8>1.3[5]
AA BRO-DFW JUN 3>4[4]
AA BWI-JFK MAY 2.0>1.0[1.0]
AA CAE-DFW SEP 2>3[1.8] OCT 2>3[1.9]
AA CDG-DFW NOV 1.0>1.4[0.9] DEC 1.0>1.4[1.0]
AA CHS-MIA MAY 3>4[3] JUN 3>4[3]
AA CID-ORD JUN 5>6[5]
AA CLE-JFK MAY 1.9>1.0[2.0]
AA CLE-ORD MAY 6>7[6] JUN 7>8[6]
AA CLT-CMI MAY 1.0>1.9[0] JUN 1.0>2[0]
AA CLT-SGF MAY 3>4[2] JUN 3>4[3]
AA CLT-YYZ JUL 4>5[4] AUG 4>5[4] SEP 4>5[4] OCT 4>5[4] NOV 4>5[4] DEC 4>5[3]
AA COU-ORD MAY 3>4[3] JUN 3>4[2]
AA CVG-ORD MAY 7>8[6] JUN 7>8[7]
AA DFW-GSP SEP 2>3[2.0] OCT 2>3[2]
AA DFW-LAS SEP 11>12[9] OCT 11>12[8] NOV 11>12[8] DEC 11>12[9]
AA DFW-MAD NOV 1.0>1.6[0.9] DEC 1.0>1.6[0.9]
AA DFW-MIA AUG 10>11[10] SEP 10>11[10] OCT 10>11[10] NOV 10>11[10] DEC 10>11[10]
AA DFW-MTJ DEC 1.9>1.5[1.8]
AA GRR-ORD MAY 5>6[6] JUN 6>7[6]
AA GYE-MIA JUN 1.3>2[2]
AA JAX-MIA MAY 5>6[5]
AA JFK-ORF MAY 1.0>3[2] JUN 1.0>3[2] JUL 1.8>3[2] AUG 2>3[2] SEP 2>3[2] OCT 2>3[1.7] NOV 2>3[1.6]
*AA JFK-PHL MAY 1.0>0.1[6] JUN 1.0>0[1.9] JUL 1.0>0.8[1.0]
AA JFK-RDU MAY 4>2[4] JUN 3>2[4]
AA LHR-MIA NOV 1.0>2[1.0] DEC 1.0>2[1.0]
AA LHR-PHL NOV 2>1.0[1.8] DEC 2>1.0[1.8]
AA LIT-ORD MAY 3>4[3] JUN 3>4[3]
AA MDT-ORD MAY 3>4[3] JUN 3>4[3]
AA MIA-ORF MAY 3>4[2.0] JUN 3>4[3]
AA MIA-PIT MAY 2>3[3] JUN 2>3[2]
AA ORD-RIC MAY 4>5[4] JUN 4>5[4]
AA ORD-TVC MAY 5>6[3] JUN 5>6[4]
*AI BOM-JFK APR 0.4>0[0] MAY 0.5>0[0]
AM MEX-SEA JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>2[1.0]
That didn't last long
*AN HHR-LAX APR 0.4>0[0] MAY 0.5>0[0] JUN 0.4>0[0.1] JUL 0.5>0[0] AUG 0.4>0[0] SEP 0.4>0[0] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0]
*AN HHR-PHX NOV 0.4>0.0[0] DEC 0.4>0[0]
AS ANC-DUT JUN 2>3[3]
AV GUA-JFK MAY 1.0>0.6[0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0.1] NOV 1.0>0[1.0] DEC 1.0>0[1.0]
AV GUA-LAX MAY 2>1.0[1.0] JUN 2>1.0[1.0] JUL 2>1.0[1.0] AUG 2>1.0[1.0] SEP 2>1.0[1.0] OCT 2>1.0[1.1] NOV 2>1.0[2] DEC 2>1.0[2]
CM FLL-PTY JUL 0.7>1.0[0.6] AUG 0.7>1.0[0.7] SEP 0.7>1.0[0.7] OCT 0.7>1.0[0.7] NOV 0.7>1.0[0.7] DEC 0.7>1.0[0.7]
CZ LAX-SHE NOV 0>0.4[0] DEC 0.2>0.4[0.2]
D8 BGO-SWF MAY 0.3>0[0.3]
D8 DUB-SWF APR 2>1.4[1.2] MAY 2>1.4[2] JUN 2>1.4[2] JUL 2>1.4[2] AUG 2>1.5[2]
DL ATL-AVL OCT 8>7[7]
DL ATL-FLL OCT 11>12[11]
DL AZO-DTW OCT 5>4[4] NOV 5>4[4]
DL BNA-LAX DEC 1.8>1.3[1.2]
DL CVG-SEA MAY 0.5>0.9[0.7] SEP 0.7>0.9[0.7]
DL JFK-SAV OCT 3>2[2] NOV 3>2.0[1.9] DEC 3>2[1.9]
DL LAX-PDX OCT 5>4[5]
DL MCI-SEA MAY 0.7>1.0[0]
DL MSP-PSC DEC 1.6>1.1[1.0]
DL PHL-SLC SEP 1.6>1.0[0.8] OCT 1.8>0.8[0.8] NOV 1.8>0.8[0.8]
HA KOA-LIH APR 1.4>1.0[1.4] MAY 1.4>1.0[1.4]
J5 HNS-JNU NOV 0>2[3] DEC 0>2[3]
J5 HNS-SGY OCT 0>0.5[0.8] NOV 0>0.5[1.0] DEC 0>0.5[1.0]
J5 JNU-KLW APR 0.6>0.3[0] MAY 2>1.0[0] JUN 2>1.0[0] JUL 1.9>1.0[1.0] AUG 2>1.0[0] SEP 0.4>0.2[0.4]
J5 JNU-SGY OCT 1.0>4[3] NOV 0.9>2[3] DEC 0>1.9[3]
K3 CGA-KLW APR 1.7>1.3[0.8] MAY 1.7>1.3[0.8] JUN 1.7>1.3[0.9] JUL 1.7>1.3[0.8] AUG 1.7>1.3[0.9] SEP 1.7>1.3[0.8] OCT 1.7>1.3[0.8] NOV 1.7>1.3[0.8] DEC 1.7>1.3[0.8]
K3 CGA-KTB APR 0.9>0.4[0.4] MAY 0.9>0.4[0.4] JUN 0.8>0.4[0.4] JUL 0.9>0.4[0.4] AUG 0.9>0.4[0.4] SEP 0.8>0.4[0.4] OCT 0.9>0.4[0.4] NOV 0.9>0.4[0.4] DEC 0.8>0.4[0.4]
K3 HYL-KLW MAY 0.7>0.4[0.3] JUN 0.8>0.4[0.4] JUL 0.9>0.4[0.4] AUG 0.9>0.4[0.4] SEP 0.8>0.4[0.4] OCT 0.9>0.4[0] NOV 0.9>0.4[0] DEC 0.8>0.4[0]
K3 HYL-KTN MAY 0.4>0[0.3] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0]
K3 KLW-KTN APR 0.9>0.4[0.8]
LF BWI-MCN SEP 0>0.9[1.7]
M5 BFI-ESD APR 0.5>1.5[1.5] MAY 0.5>2[1.9] JUN 0.5>2[2] JUL 0.5>3[2] AUG 0.5>3[2] SEP 0.5>2[2] OCT 0.5>1.4[1.7] NOV 0.5>1.0[1.2] DEC 0.5>1.0[1.5]
M5 BFI-FRD APR 1.0>1.5[1.5] MAY 1.0>2[1.9] JUN 1.0>3[3] JUL 1.0>3[3] AUG 1.0>3[3] SEP 1.0>2[2] OCT 1.0>2[1.7] NOV 1.0>2[1.2] DEC 1.0>2[1.5]
M5 CXH-LKE APR 0>1.5[0] MAY 0>1.5[0] JUN 0>1.3[0.8] JUL 0>1.5[0.7] AUG 0>1.4[0.9] SEP 0>1.4[0.5]
M5 ESD-FRD APR 1.0>2[2] MAY 1.0>3[2] JUN 1.0>3[2] JUL 1.0>3[2] AUG 1.0>3[2] SEP 1.0>3[3] OCT 1.0>1.9[2] NOV 1.0>1.5[1.5] DEC 1.0>1.5[2]
M5 KEH-LKE APR 0>0.4[3] MAY 0>0.4[3] JUN 0>0.3[0.5] SEP 0>0.4[0.5]
Seasonal extension
*MS CAI-IAD NOV 0>0.4[0] DEC 0>0.4[0]
Dec is only a partial month filed, so not meaningful. You can compare the NOV last year to the new NOV number for a valid compare.
NK ACY-FLL JUL 2>1.3[2] AUG 2>1.3[2] NOV 0.7>2[3] DEC 0>1.5[3]
NK ACY-MCO NOV 0.9>2[2] DEC 0>1.2[2]
NK ACY-MYR NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK ACY-PBI NOV 0>0.6[0.8] DEC 0>0.6[1.0]
NK ACY-RSW NOV 0.4>1.6[1.7] DEC 0>1.0[1.8]
NK ACY-TPA NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK ATL-AUS NOV 0.4>1.0[0] DEC 0>0.6[0]
NK ATL-BOS NOV 0.2>0.4[0.4] DEC 0>0.3[0.4]
NK ATL-BWI NOV 1.3>2[2] DEC 0>1.0[1.9]
NK ATL-CLE NOV 0.3>0.9[0.9] DEC 0>0.4[0.8]
NK ATL-DFW NOV 0.7>1.3[1.1] DEC 0>0.6[1.0]
NK ATL-DTW NOV 0.9>2[2.0] DEC 0>1.2[2]
NK ATL-EWR NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK ATL-FLL NOV 1.5>5[5] DEC 0>2[5]
NK ATL-IAH NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK ATL-LAS NOV 0.4>1.0[1.1] DEC 0>0.6[1.0]
NK ATL-LAX NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK ATL-MCO NOV 0.7>1.9[2] DEC 0>1.0[2]
NK ATL-MSP NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK ATL-MSY NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK ATL-ORD NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK ATL-PHL NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK ATL-TPA NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK AUS-BWI NOV 0.3>0.9[0] DEC 0>0.4[0]
NK AUS-DEN NOV 0.4>1.0[0] DEC 0>0.6[0]
NK AUS-DTW NOV 0.4>1.0[0] DEC 0>0.6[0]
NK AUS-FLL NOV 0.3>0.9[0] DEC 0>0.6[0]
NK AUS-LAS NOV 0.7>1.3[0] DEC 0>0.6[0]
NK AUS-LAX NOV 0.3>0.9[0] DEC 0>0.4[0]
NK AUS-MCO NOV 0.3>0.9[0] DEC 0>0.6[0]
NK AUS-MSY NOV 0.3>0.9[0] DEC 0>0.4[0]
NK AUS-ORD NOV 0.3>0.9[0] DEC 0>0.4[0]
NK AVL-FLL NOV 0.2>0.5[0.5] DEC 0>0.2[0.5]
NK AVL-MCO NOV 0.2>0.5[0.5] DEC 0>0.2[0.5]
NK AVL-TPA NOV 0.1>0.3[0.4]
NK AXM-FLL NOV 0.2>0.4[0.4] DEC 0>0.3[0.4]
NK BDL-FLL NOV 0.4>1.6[1.7] DEC 0>1.0[1.8]
NK BDL-MCO NOV 0.7>1.9[1.9] DEC 0>1.0[1.8]
NK BDL-RSW NOV 0>0.6[0.7] DEC 0>0.4[0.8]
NK BDL-TPA NOV 0.3>0.9[0.9] DEC 0>0.6[1.0]
NK BOG-FLL NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK BOG-MCO NOV 0.4>1.0[0.8] DEC 0>0.6[1.0]
NK BOS-BWI NOV 0.7>1.9[1.9] DEC 0>1.2[2]
NK BOS-FLL NOV 0.7>1.8[1.8] DEC 0>1.0[1.8]
NK BOS-LAS NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK BOS-MCO NOV 0.7>1.9[1.9] DEC 0>1.0[1.8]
NK BOS-MSY NOV 0.3>0.9[0.9] DEC 0>0.4[0.8]
NK BOS-MYR NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK BOS-PBI NOV 0>0.6[0.8] DEC 0>0.6[1.0]
NK BOS-RDU NOV 0.3>0.9[0] DEC 0>0.6[0]
NK BOS-RSW NOV 0.3>1.4[1.5] DEC 0>0.6[1.4]
NK BOS-TPA NOV 0.2>0.7[0.9] DEC 0>0.6[1.0]
NK BQN-FLL JUL 0.5>0.3[0.5] AUG 0.5>0.3[0.5] SEP 0.5>0.3[0.5] OCT 0.5>0.3[0.5]
NK BQN-MCO NOV 0.2>0.5[0.5]
*NK BUR-LAS JUN 0>1.1[0] JUL 0>3[0] AUG 0>3[0] SEP 0>3[0] OCT 0>3[0] NOV 0>3[0] DEC 0>1.7[0]
NK BWI-CLT NOV 0.4>1.0[0] DEC 0>0.6[0]
NK BWI-CUN NOV 0.2>0.7[0.8] DEC 0>0.4[0.8]
NK BWI-DEN NOV 0.3>0.8[0.9] DEC 0>0.4[0.8]
NK BWI-DFW NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK BWI-DTW NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK BWI-FLL NOV 1.2>3[3] DEC 0>1.5[3]
NK BWI-IAH NOV 0.7>1.3[1.2] DEC 0>0.6[1.0]
NK BWI-JAX NOV 0.3>0.9[0] DEC 0>0.4[0]
NK BWI-LAS NOV 0.7>1.3[1.2] DEC 0>0.6[1.0]
NK BWI-LAX NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK BWI-MBJ NOV 0.3>0.9[0.9] DEC 0>0.4[0.8]
NK BWI-MCO NOV 0.9>3[3] DEC 0>1.4[3]
NK BWI-MSP NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK BWI-MSY NOV 0.4>1.0[0.9] DEC 0>0.6[1.0]
NK BWI-ORD NOV 0.7>1.3[1.2] DEC 0>0.6[1.0]
NK BWI-RDU NOV 0.9>2.0[0] DEC 0>1.0[0]
NK BWI-RSW NOV 0>0.6[0.8] DEC 0>0.6[1.0]
*NK BWI-SJU NOV 0>0.3[0] DEC 0>0.2[0]
NK BWI-TPA NOV 0.3>0.9[0.9] DEC 0>0.6[1.0]
NK CAK-MCO NOV 0.3>0.9[0.9] DEC 0>0.4[0.8]
NK CAK-RSW NOV 0>0.3[0.4] DEC 0>0.2[0.5]
NK CAK-TPA NOV 0>0.2[0.3]
**NK CAP-FLL JUL 0.4>0[0.5] AUG 0.5>0[0.4] SEP 0.4>0[0.4] OCT 0.5>0[0.4]
NK CLE-FLL NOV 0.3>0.9[1.5] DEC 0>0.8[1.5]
NK CLE-LAS NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK CLE-LAX NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK CLE-MCO NOV 0.5>1.1[1.6] DEC 0>0.7[1.5]
NK CLE-MSY NOV 0.1>0.3[0.4]
NK CLE-RSW NOV 0.2>0.8[0.8] DEC 0>0.4[0.8]
NK CLE-TPA NOV 0.3>0.9[0.9] DEC 0>0.5[0.8]
NK CLO-FLL NOV 0.4>1.0[0] DEC 0>0.6[0.4]
NK CLT-EWR NOV 0.4>1.0[0] DEC 0>0.6[0]
NK CLT-FLL NOV 0.4>1.0[0] DEC 0>0.6[0]
NK CLT-MCO NOV 0.4>1.0[0] DEC 0>0.6[0]
NK CMH-FLL NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK CMH-LAS NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK CMH-MCO NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK CMH-RSW NOV 0>0.6[0.7] DEC 0>0.4[0.8]
NK CMH-TPA NOV 0.1>0.7[0.8] DEC 0>0.4[0.8]
NK CTG-FLL NOV 0.3>0.6[0.6] DEC 0>0.4[0.5]
NK CUN-DFW NOV 0.3>0.5[0.5]
NK CUN-DTW NOV 0.1>0.6[0.7] DEC 0>0.4[0.8]
NK CUN-FLL NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK CUN-IAH NOV 0.2>0.4[0.4]
NK CUN-ORD NOV 0.1>0.6[0.8] DEC 0>0.4[0.8]
NK DEN-DFW NOV 0.7>1.3[1.0] DEC 0>0.6[1.0]
NK DEN-DTW NOV 0.4>1.0[0.9] DEC 0>0.4[0.9]
NK DEN-FLL NOV 0.7>1.9[1.2] DEC 0>1.0[1.6]
NK DEN-IAH NOV 0.4>1.0[1.4] DEC 0>0.6[1.4]
NK DEN-LAX NOV 0.3>0.9[0] DEC 0>0.4[0]
NK DEN-MCO NOV 0.4>1.0[0] DEC 0>0.6[0]
NK DEN-MSY NOV 0.4>1.0[0] DEC 0>0.6[0]
NK DEN-ORD NOV 0.7>1.3[1.2] DEC 0>0.6[1.0]
NK DFW-DTW NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK DFW-FLL NOV 1.3>2[2] DEC 0>1.2[2]
NK DFW-LAS NOV 1.4>3[3] DEC 0>1.7[3]
NK DFW-LAX NOV 0.7>1.9[2] DEC 0>1.0[2]
NK DFW-LGA NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK DFW-MCO NOV 0.9>2[2] DEC 0>1.2[3]
NK DFW-ORD NOV 0.9>1.4[1.2] DEC 0>0.6[1.0]
NK DFW-PHL NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK DFW-PHX NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK DFW-TPA NOV 0.3>0.9[0.9] DEC 0>0.6[1.0]
NK DTW-FLL NOV 0.9>2[2] DEC 0>1.2[2]
NK DTW-IAH NOV 0.3>0.9[0.9] DEC 0>0.6[1.4]
NK DTW-LAS NOV 1.3>3[3] DEC 0>1.5[3]
NK DTW-LAX NOV 0.7>1.3[1.2] DEC 0>0.6[1.4]
NK DTW-LGA NOV 0.9>2[2] DEC 0>1.2[2]
NK DTW-MCI NOV 0.3>0.9[0.9] DEC 0>0.6[1.0]
NK DTW-MCO NOV 1.2>3[4] DEC 0>1.9[4]
NK DTW-MSP NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK DTW-MSY NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK DTW-RDU NOV 0.3>0.9[0] DEC 0>0.4[0]
NK DTW-RSW NOV 0.4>3[3] DEC 0>1.6[3]
NK DTW-TPA NOV 0.4>2[2] DEC 0>1.5[3]
NK EWR-FLL NOV 1.0>2[2] DEC 0>1.4[2]
NK EWR-IAH NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK EWR-LAS NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK EWR-MCO NOV 1.2>3[3] DEC 0>1.5[3]
NK EWR-MSY NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK EWR-MYR NOV 0.3>0.6[0.6] DEC 0>0.3[0.6]
NK EWR-SDQ NOV 0.4>1.0[0.8] DEC 0>0.6[1.0]
NK FLL-GSO NOV 0.1>0.3[0.4]
NK FLL-GUA NOV 0.4>0.9[0.9] DEC 0>0.5[0.9]
NK FLL-GYE NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK FLL-IAG NOV 0.1>0.7[0.8] DEC 0>0.3[0.7]
NK FLL-IAH NOV 0.7>1.3[1.5] DEC 0>0.6[1.6]
NK FLL-JAX NOV 0.4>1.0[0] DEC 0>0.6[0]
NK FLL-KIN NOV 0.4>1.0[0.6] DEC 0>0.3[0.7]
NK FLL-LAS NOV 0.7>1.3[1.2] DEC 0>0.6[1.0]
NK FLL-LAX NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK FLL-LBE JUL 1.0>0.7[1.0] AUG 1.0>0.7[1.0] NOV 0.3>0.9[0.9] DEC 0>0.4[0.8]
NK FLL-LGA NOV 1.7>4[4] DEC 0>2[4]
NK FLL-LIM NOV 0.1>0.6[0.1]
NK FLL-MBJ NOV 0.3>0.9[0.9] DEC 0>0.4[0.8]
NK FLL-MCI NOV 0>0.3[0.4] DEC 0>0.2[0.5]
NK FLL-MCO NOV 0.9>2[2] DEC 0>1.2[2]
NK FLL-MDE NOV 0.3>0.9[0.9] DEC 0>0.6[1.0]
NK FLL-MSP NOV 0>0.6[0.8] DEC 0>0.6[1.0]
NK FLL-MSY NOV 0.9>2[2] DEC 0>1.2[2]
NK FLL-MYR NOV 0.6>1.2[1.3] DEC 0>0.6[1.0]
NK FLL-ORD NOV 0.9>2[2] DEC 0>1.2[2]
NK FLL-PAP NOV 0.3>0.9[0.9] DEC 0>0.4[0.8]
NK FLL-PBG NOV 0.1>0.7[0.8] DEC 0>0.3[0.7]
NK FLL-PHL NOV 0.7>1.9[1.6] DEC 0>1.2[1.9]
NK FLL-PIT NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK FLL-PTY NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK FLL-PUJ NOV 0>0.3[0.1]
NK FLL-RDU NOV 0.3>0.9[0] DEC 0>0.4[0]
NK FLL-RIC NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK FLL-SAL NOV 0.2>0.5[0.3] DEC 0>0.3[0.4]
NK FLL-SAP NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK FLL-SDQ NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK FLL-SJO NOV 0.9>2[1.0] DEC 0>1.1[1.4]
NK FLL-SJU NOV 0.2>1.1[0.5] DEC 0>0.4[1.0]
NK FLL-STI NOV 0.3>0.6[0.6] DEC 0>0.3[0.5]
NK FLL-STT NOV 0.2>0.4[0.5] DEC 0>0.3[0.5]
NK FLL-TPA NOV 0.7>1.9[1.9] DEC 0>1.2[2]
NK GSO-MCO NOV 0.2>0.5[0.5] DEC 0>0.2[0.5]
NK GSO-TPA NOV 0.1>0.3[0.4]
NK GUA-IAH NOV 0.2>0.5[0.5] DEC 0>0.3[0.6]
NK GUA-MCO NOV 0.2>0.6[0.6] DEC 0>0.3[0.6]
NK IAH-LAS NOV 1.2>2[2] DEC 0>1.2[2]
NK IAH-LAX NOV 1.0>2[2] DEC 0>1.0[2]
NK IAH-MCO NOV 1.3>2[2] DEC 0>1.0[2]
NK IAH-MSY NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK IAH-ORD NOV 0.7>1.9[1.9] DEC 0>1.0[1.9]
NK IAH-SAL NOV 0.2>0.4[0.4] DEC 0>0.3[0.4]
NK IAH-SAN NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK IAH-SAP NOV 0.3>0.6[0.6] DEC 0>0.3[0.5]
NK IAH-TPA NOV 0.3>0.9[1.0] DEC 0>0.6[1.0]
NK IND-LAS NOV 0.4>1.0[0] DEC 0>0.6[0]
NK IND-MCO NOV 0.4>0.7[0] DEC 0>0.3[0]
*NK IND-RSW NOV 0>0.6[0] DEC 0>0.6[0]
*NK IND-TPA NOV 0>0.6[0] DEC 0>0.6[0]
NK KIN-MCO NOV 0.2>0.4[0] DEC 0>0.3[0]
NK LAS-LAX NOV 1.2>3[3] DEC 0>1.5[3]
NK LAS-MCI NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LAS-MCO NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LAS-MSP NOV 0.7>1.9[1.9] DEC 0>1.0[1.9]
NK LAS-MSY NOV 0.3>0.9[1.0] DEC 0>0.6[1.0]
NK LAS-OAK NOV 1.6>3[3] DEC 0>1.5[3]
NK LAS-ORD NOV 1.3>3[3] DEC 0>1.3[3]
NK LAS-PDX NOV 1.2>2[2] DEC 0>1.0[1.9]
NK LAS-PHL NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LAS-PIT NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LAS-SAN NOV 1.5>3[3] DEC 0>1.5[3]
NK LAS-SEA NOV 1.5>3[3] DEC 0>1.5[3]
*NK LAS-SMF JUN 0>1.1[0] JUL 0>3[0] AUG 0>3[0] SEP 0>3[0] OCT 0>3[0] NOV 0>3[0] DEC 0>1.7[0]
NK LAS-TPA NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LAX-MCI NOV 0.4>1.0[0.9] DEC 0>0.4[0.9]
NK LAX-MSP NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LAX-MSY NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LAX-OAK NOV 0.9>2[2] DEC 0>1.2[2]
NK LAX-ORD NOV 0.9>2[2] DEC 0>1.2[2]
NK LAX-PHL NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LAX-PIT NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LBE-MCO NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK LBE-RSW NOV 0>0.3[0.4] DEC 0>0.2[0.5]
NK LBE-TPA NOV 0>0.2[0.3]
NK LGA-MYR NOV 0.9>2[2] DEC 0>1.2[2]
NK LGA-ORD NOV 0.9>2[2] DEC 0>1.2[2]
NK MBJ-MCO NOV 0.2>0.6[0] DEC 0>0.3[0]
NK MCI-MCO NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK MCO-MSP NOV 0.3>0.9[0.9] DEC 0>0.6[1.0]
NK MCO-MSY NOV 0.4>1.0[1.1] DEC 0>0.4[0.8]
NK MCO-ORD NOV 0.4>1.6[1.0] DEC 0>1.0[1.4]
NK MCO-PHL NOV 1.2>3[3] DEC 0>1.5[3]
NK MCO-PIT NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK MCO-PTY NOV 0.2>0.5[0.6] DEC 0>0.4[0.6]
NK MCO-RDU NOV 0.3>0.9[0] DEC 0>0.6[0]
NK MCO-RIC NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK MCO-SDQ NOV 0.4>1.0[0.9] DEC 0>0.6[1.0]
NK MCO-SJO NOV 0.4>1.0[0.9] DEC 0>0.6[1.0]
NK MCO-SJU NOV 0.4>1.2[0.9] DEC 0>0.5[1.3]
NK MSP-MSY NOV 0.2>0.5[0.5] DEC 0>0.2[0.5]
NK MSP-PHX NOV 0>0.6[0.8] DEC 0>0.6[1.0]
NK MSP-RSW NOV 0>0.6[0.8] DEC 0>0.6[1.0]
NK MSP-TPA NOV 0>0.6[0.8] DEC 0>0.6[1.0]
NK MSY-ORD NOV 0.4>1.0[1.0] DEC 0>0.6[1.0]
NK MSY-RDU NOV 0.3>0.9[0] DEC 0>0.6[0]
NK MSY-TPA NOV 0.4>1.0[0.9] DEC 0>0.6[1.0]
NK ORD-PHX NOV 0>0.6[0.8] DEC 0>0.6[1.0]
NK ORD-RDU NOV 0.4>1.0[0] DEC 0>0.6[0]
NK ORD-RSW NOV 0.3>1.4[1.6] DEC 0>1.0[1.8]
NK ORD-SAN NOV 0.3>0.9[0.9] DEC 0>0.4[0.9]
NK ORD-TPA NOV 0.3>1.4[1.6] DEC 0>1.0[1.8]
NK PHL-SJU NOV 0.2>0.4[0] DEC 0>0.2[0]
NK PHL-TPA NOV 0>0.3[0] DEC 0>0.3[0.4]
NK PIT-RSW NOV 0>0.6[0.7] DEC 0>0.4[0.8]
NK PIT-TPA NOV 0.2>0.8[0.9] DEC 0>0.6[1.0]
NK SJU-TPA NOV 0.2>0.4[0] DEC 0>0.2[0]
O6 GRU-MIA APR 1.0>0.3[1.0]
UA ABQ-IAH MAY 5>4[4]
Kinda surprised they were flying it
**UA AMS-SFO NOV 1.0>0[0] DEC 1.0>0[0]
UA ANC-SFO AUG 1.0>1.4[1.0]
UA AUA-EWR SEP 1.4>2[1.5]
UA BWI-IAH JUN 3>2.0[1.9] JUL 3>1.9[2] AUG 3>1.9[2.0]
UA CAK-ORD MAY 4>3[4]
UA CRP-IAH MAY 7>6[6]
UA DEN-HNL DEC 1.0>1.4[1.0]
UA ELP-IAH MAY 6>5[5]
UA ELP-ORD AUG 1.9>1.5[2]
UA EWR-LIM SEP 0.6>1.0[0.6]
UA GRR-IAH JUL 1.9>0.9[1.9] AUG 1.8>0.9[1.9]
UA HSV-IAH MAY 4>3[3]
UA IAH-JAN MAY 6>5[5]
UA IAH-MLU MAY 3>1.8[1.9]
UA IAH-OMA MAY 4>3[4]
UA IAH-PIT JUL 6>5[5] AUG 6>5[5]
UA IAH-TUS MAY 4>3[3]
UA JAN-ORD MAY 2>1.0[2.0]
UA LAX-RDM JUN 1.5>1.0[1.0]
UA ORD-PIA SEP 4>5[4] OCT 4>5[4] NOV 4>5[4]
UA ORD-RAP MAY 2>1.2[1.1]
UA ORD-RIC MAY 5>4[5]
UA ORD-SAV MAY 4>3[4]
NOV is a partially filed month, so compare last year OCT to the new OCT number.
WN ABQ-AUS OCT 0.0>1.3[0.5]
WN ABQ-BWI OCT 0.1>2.0[1.2]
WN ABQ-DAL OCT 0.2>5[5] NOV 0>0.3[5]
WN ABQ-DEN OCT 0.1>3[3]
WN ABQ-HOU OCT 0.1>3[3] NOV 0>0.2[3]
WN ABQ-LAS OCT 0.1>4[4] NOV 0>0.2[4]
WN ABQ-LAX OCT 0.1>2[2]
WN ABQ-MDW OCT 0.0>2.0[2]
WN ABQ-OAK OCT 0.1>3[2]
WN ABQ-PHX OCT 0.2>6[6] NOV 0>0.3[6]
WN ABQ-SAN OCT 0.1>1.9[1.9]
WN ABQ-SJC OCT 0.0>1.0[0.1]
WN ALB-BWI OCT 0.2>6[6] NOV 0>0.4[5]
WN ALB-MDW OCT 0.1>2[2]
WN ALB-TPA OCT 0>1.0[0.9]
WN AMA-DAL OCT 0.1>4[4] NOV 0>0.2[4]
WN ATL-AUS OCT 0.1>3[3]
WN ATL-BNA OCT 0.2>4[4] NOV 0>0.3[4]
WN ATL-BOS OCT 0.0>1.0[3]
WN ATL-BWI OCT 0.2>7[6] NOV 0>0.4[6]
WN ATL-CLE OCT 0.1>1.8[1.7]
WN ATL-CMH OCT 0.1>3[3]
WN ATL-CUN OCT 0>0.5[1.0]
WN ATL-DAL OCT 0.2>5[5] NOV 0>0.3[5]
WN ATL-DCA OCT 0.1>4[4] NOV 0>0.3[4]
WN ATL-DEN OCT 0.2>5[4] NOV 0>0.3[4]
WN ATL-FLL OCT 0.1>4[4] NOV 0>0.3[5]
WN ATL-GSP OCT 0.1>3[3]
WN ATL-HOU OCT 0.2>6[5] NOV 0>0.3[5]
WN ATL-IAD OCT 0.1>3[1.8]
WN ATL-IND OCT 0.1>3[3]
WN ATL-JAX OCT 0.1>3[3]
WN ATL-LAS OCT 0.1>3[3] NOV 0>0.2[3]
WN ATL-LAX OCT 0.1>3[3]
WN ATL-LGA OCT 0.2>5[5] NOV 0>0.3[5]
WN ATL-MCI OCT 0.1>3[3]
WN ATL-MCO OCT 0.2>6[6] NOV 0>0.4[5]
WN ATL-MDW OCT 0.2>6[6] NOV 0>0.4[6]
WN ATL-MKE OCT 0.1>1.9[1.9]
WN ATL-MSY OCT 0.1>4[4] NOV 0>0.2[4]
WN ATL-PHL OCT 0.1>2.0[2.0]
WN ATL-PHX OCT 0.1>3[1.9]
WN ATL-PIT OCT 0.1>3[1.9]
WN ATL-PUJ OCT 0>0.7[1.0]
WN ATL-RDU OCT 0.1>3[3]
WN ATL-RIC OCT 0.1>3[3]
WN ATL-RSW OCT 0.1>1.7[1.0]
WN ATL-SAT OCT 0.1>2[1.9]
WN ATL-STL OCT 0.1>4[4] NOV 0>0.2[4]
WN ATL-TPA OCT 0.2>5[5] NOV 0>0.3[5]
WN AUS-BNA OCT 0.1>3[3] NOV 0>0.2[3]
WN AUS-BOS OCT 0.0>1.1[1.0]
WN AUS-BWI OCT 0.1>3[2.0]
WN AUS-DAL OCT 0.3>9[10] NOV 0>0.6[9]
WN AUS-DEN OCT 0.2>6[5] NOV 0>0.3[5]
WN AUS-ELP OCT 0.1>3[3]
WN AUS-EWR OCT 0.1>1.8[1.8]
WN AUS-HOU OCT 0.2>5[5] NOV 0>0.3[5]
WN AUS-LAS OCT 0.1>4[3] NOV 0>0.2[3]
WN AUS-LAX OCT 0.1>3[3]
WN AUS-MCO OCT 0.0>3[2]
WN AUS-MDW OCT 0.1>4[3] NOV 0>0.2[3]
WN AUS-MSY OCT 0.1>3[2]
WN AUS-PHX OCT 0.1>5[4] NOV 0>0.3[4]
WN AUS-RDU OCT 0.0>1.0[0]
WN AUS-SAN OCT 0.1>3[3]
WN AUS-SFO OCT 0.0>0.9[1.0]
WN AUS-SJC OCT 0.1>3[1.8]
WN AUS-STL OCT 0.1>2[1.8]
WN AUS-TPA OCT 0.0>1.8[1.0]
WN BDL-BWI OCT 0.2>5[6] NOV 0>0.3[6]
WN BDL-DEN OCT 0.0>1.0[1.1]
WN BDL-MCO OCT 0.1>2[1.9]
WN BDL-MDW OCT 0.1>3[3]
WN BHM-BWI OCT 0.0>1.1[1.0]
WN BHM-DAL OCT 0.1>2[1.9]
WN BHM-HOU OCT 0.1>1.8[1.9]
WN BHM-MCO OCT 0.1>2[2]
WN BHM-MDW OCT 0.1>1.9[1.8]
WN BHM-TPA OCT 0.0>1.8[1.9]
WN BNA-BOS OCT 0.1>4[4] NOV 0>0.2[2]
WN BNA-BUF OCT 0>0.3[0]
WN BNA-BUR OCT 0.0>1.0[0]
WN BNA-BWI OCT 0.2>6[6] NOV 0>0.4[6]
WN BNA-CHS OCT 0.0>1.8[1.0]
WN BNA-CLE OCT 0.1>3[3]
WN BNA-CLT OCT 0.1>1.9[1.8]
WN BNA-CMH OCT 0.1>3[1.9]
WN BNA-DAL OCT 0.2>5[4] NOV 0>0.3[4]
WN BNA-DCA OCT 0.1>4[3] NOV 0>0.2[4]
WN BNA-DEN OCT 0.2>6[5] NOV 0>0.3[4]
WN BNA-DTW OCT 0.1>3[1.8]
WN BNA-ECP OCT 0.1>2[2]
WN BNA-EWR OCT 0.1>3[0]
WN BNA-FLL OCT 0.1>4[3] NOV 0>0.3[3]
WN BNA-HOU OCT 0.1>4[4] NOV 0>0.2[4]
WN BNA-JAX OCT 0.1>3[3] NOV 0>0.2[3]
WN BNA-LAS OCT 0.1>4[3] NOV 0>0.2[3]
WN BNA-LAX OCT 0.1>3[3]
WN BNA-LGA OCT 0.1>3[3] NOV 0>0.2[3]
WN BNA-MCI OCT 0.1>4[4] NOV 0>0.2[3]
WN BNA-MCO OCT 0.1>5[4] NOV 0>0.4[4]
WN BNA-MDW OCT 0.2>7[7] NOV 0>0.4[6]
WN BNA-MKE OCT 0.1>2.0[1.9]
WN BNA-MSP OCT 0.1>1.9[1.0]
WN BNA-MSY MAY 3>4[3] OCT 0.1>4[4] NOV 0>0.2[3]
WN BNA-ORF OCT 0>0.3[0]
WN BNA-PHL OCT 0.1>3[3]
WN BNA-PHX OCT 0.1>4[3] NOV 0>0.2[3]
WN BNA-PIT OCT 0.1>2[1.9]
WN BNA-PNS OCT 0.1>2[2]
WN BNA-RDU OCT 0.1>3[3]
WN BNA-SAN OCT 0.1>3[2.0]
WN BNA-SAT OCT 0.1>2.0[2]
WN BNA-SJC OCT 0.0>1.0[0]
WN BNA-SMF MAY 0>0.8[0] JUN 0>0.2[0]
WN BNA-STL OCT 0.1>4[3] NOV 0>0.2[3]
WN BNA-TPA OCT 0.1>3[3] NOV 0>0.2[4]
WN BOI-DEN OCT 0.1>2[2]
WN BOI-GEG OCT 0.1>1.7[1.5]
WN BOI-LAS OCT 0.1>2.0[2]
WN BOI-OAK OCT 0.1>2.0[2.0]
WN BOI-SJC OCT 0.1>1.7[1.0]
WN BOI-SMF OCT 0.0>1.0[1.2]
WN BOS-BWI OCT 0.3>9[9] NOV 0>0.5[9]
WN BOS-DEN OCT 0.1>1.9[2]
WN BOS-HOU OCT 0.0>1.1[1.0]
WN BOS-MCI OCT 0.0>1.1[1.7]
WN BOS-MDW OCT 0.2>5[5] NOV 0>0.3[4]
WN BOS-MKE OCT 0.0>1.1[1.2]
WN BOS-STL OCT 0.1>4[4] NOV 0>0.2[3]
WN BUF-BWI OCT 0.2>5[6] NOV 0>0.3[5]
WN BUF-DEN OCT 0.0>1.0[0]
WN BUF-LAS OCT 0.0>1.8[1.9]
WN BUF-MCO OCT 0.1>2[2]
WN BUF-MDW OCT 0.1>3[3] NOV 0>0.2[3]
WN BUF-TPA OCT 0.0>1.3[1.1]
WN BUR-DAL OCT 0.0>1.0[0.9]
WN BUR-DEN OCT 0.1>3[1.8]
WN BUR-HOU OCT 0.0>1.0[0]
WN BUR-LAS OCT 0.4>10[9] NOV 0>0.6[9]
WN BUR-MDW OCT 0.1>1.7[0]
WN BUR-OAK OCT 0.5>13[12] NOV 0>0.8[12]
WN BUR-PHX OCT 0.2>6[6] NOV 0>0.4[6]
WN BUR-SFO OCT 0.2>5[4] NOV 0>0.3[4]
WN BUR-SJC OCT 0.4>11[8] NOV 0>0.6[8]
WN BUR-SMF OCT 0.4>11[8] NOV 0>0.6[8]
WN BWI-CHS OCT 0.1>3[3] NOV 0>0.2[4]
WN BWI-CLE OCT 0.1>3[3] NOV 0>0.2[3]
WN BWI-CLT OCT 0.1>3[3]
WN BWI-CMH OCT 0.1>4[4] NOV 0>0.2[4]
WN BWI-CVG OCT 0.1>3[3] NOV 0>0.2[3]
WN BWI-DAL OCT 0.1>4[4] NOV 0>0.3[4]
WN BWI-DEN OCT 0.2>5[5] NOV 0>0.3[5]
WN BWI-DTW OCT 0.1>3[3]
WN BWI-EWR OCT 0>1.9[0]
WN BWI-FLL OCT 0.2>8[8] NOV 0>0.6[9]
WN BWI-HOU OCT 0.1>4[4] NOV 0>0.2[4]
WN BWI-IND OCT 0.1>4[3] NOV 0>0.2[3]
WN BWI-ISP OCT 0.2>5[5] NOV 0>0.3[4]
WN BWI-JAX OCT 0.1>3[3] NOV 0>0.2[3]
WN BWI-LAS OCT 0.1>4[4] NOV 0>0.3[4]
WN BWI-LAX OCT 0.1>3[3]
WN BWI-MBJ OCT 0.0>2.0[1.3]
WN BWI-MCI OCT 0.1>3[3]
WN BWI-MCO OCT 0.2>8[7] NOV 0>0.6[9]
WN BWI-MDW OCT 0.2>7[7] NOV 0>0.4[7]
WN BWI-MEM OCT 0.0>1.1[1.0]
WN BWI-MHT OCT 0.2>6[6] NOV 0>0.4[6]
WN BWI-MKE OCT 0.1>3[3]
WN BWI-MSP OCT 0.1>1.8[1.9]
WN BWI-MSY OCT 0.1>4[4] NOV 0>0.2[3]
WN BWI-NAS OCT 0>0.3[0.1]
WN BWI-ORF OCT 0.2>5[5] NOV 0>0.3[4]
WN BWI-PBI OCT 0.1>2[1.8]
WN BWI-PHX OCT 0.1>3[3] NOV 0>0.2[3]
WN BWI-PIT OCT 0.1>3[3]
WN BWI-PUJ OCT 0.0>1.1[1.0]
WN BWI-PVD OCT 0.2>6[8] NOV 0>0.4[7]
WN BWI-PWM OCT 0.1>4[4] NOV 0>0.3[3]
WN BWI-RDU OCT 0.2>6[6] NOV 0>0.3[6]
WN BWI-ROC OCT 0.1>3[3] NOV 0>0.2[3]
WN BWI-RSW OCT 0.1>3[3] NOV 0>0.2[4]
WN BWI-SAN OCT 0.1>3[3] NOV 0>0.2[3]
WN BWI-SAT OCT 0.1>1.9[1.9]
WN BWI-SDF OCT 0.1>4[4] NOV 0>0.2[3]
WN BWI-SEA OCT 0.0>0.9[0.7]
WN BWI-STL OCT 0.1>4[4] NOV 0>0.3[4]
WN BWI-TPA OCT 0.2>7[7] NOV 0>0.4[7]
WN CHS-DAL OCT 0.0>1.0[0.3]
WN CHS-DEN OCT 0>0.3[0.1]
WN CHS-MDW OCT 0.0>2.0[2]
WN CLE-DEN OCT 0.1>1.7[1.0]
WN CLE-LAS OCT 0>0.3[1.0]
WN CLE-MCO OCT 0>0.3[0.1]
WN CLE-MDW OCT 0.2>5[5] NOV 0>0.3[5]
WN CLE-MKE OCT 0.1>1.6[1.7]
WN CLE-PHX OCT 0.0>1.1[1.0]
WN CLE-STL OCT 0.1>3[1.9]
WN CLE-TPA OCT 0>0.3[0]
WN CLT-MDW OCT 0.1>3[3]
WN CMH-DAL OCT 0.0>1.1[1.0]
WN CMH-DCA OCT 0.1>1.9[1.9]
WN CMH-FLL OCT 0.0>1.0[0.9]
WN CMH-HOU OCT 0.0>1.0[0.9]
WN CMH-LAS OCT 0.1>2[2]
WN CMH-MCO OCT 0.1>3[3] NOV 0>0.2[4]
WN CMH-MDW OCT 0.2>6[6] NOV 0>0.4[5]
WN CMH-OAK OCT 0.0>0.9[1.0]
WN CMH-STL OCT 0.1>2[2]
WN CMH-TPA OCT 0.1>3[1.9]
WN CRP-HOU OCT 0.1>4[4] NOV 0>0.2[4]
WN CUN-FLL OCT 0.0>1.0[2]
WN CUN-HOU OCT 0.1>2[2]
WN CUN-LAX OCT 0>0.3[1.0]
WN CUN-STL OCT 0>1.0[0.1]
WN CVG-MCO OCT 0>0.3[0]
WN CVG-MDW OCT 0.2>4[5] NOV 0>0.3[5]
WN DAL-DCA OCT 0.2>5[4] NOV 0>0.3[4]
WN DAL-DEN OCT 0.2>7[7] NOV 0>0.4[7]
WN DAL-ECP OCT 0.1>1.0[0.3]
WN DAL-ELP OCT 0.1>4[4] NOV 0>0.2[4]
WN DAL-FLL OCT 0.1>3[2] NOV 0>0.2[2]
WN DAL-HOU OCT 0.6>18[19] NOV 0>1.1[17]
WN DAL-JAX OCT 0.0>1.0[0.1]
WN DAL-LAS OCT 0.2>5[5] NOV 0>0.3[5]
WN DAL-LAX OCT 0.2>5[4] NOV 0>0.3[4]
WN DAL-LBB OCT 0.2>5[5] NOV 0>0.3[4]
WN DAL-LGA OCT 0.2>5[4] NOV 0>0.3[5]
WN DAL-LIT OCT 0.1>3[3]
WN DAL-MAF OCT 0.2>5[5] NOV 0>0.3[4]
WN DAL-MCI OCT 0.2>6[6] NOV 0>0.3[6]
WN DAL-MCO OCT 0.1>5[4] NOV 0>0.3[4]
WN DAL-MDW OCT 0.2>7[7] NOV 0>0.4[7]
WN DAL-MEM OCT 0.1>3[1.3]
WN DAL-MKE OCT 0.0>1.0[0]
WN DAL-MSP OCT 0.0>1.0[0]
WN DAL-MSY OCT 0.2>7[7] NOV 0>0.4[7]
WN DAL-OAK OCT 0.1>1.7[1.8]
WN DAL-OKC OCT 0.1>3[3]
WN DAL-OMA OCT 0.0>1.1[1.0]
WN DAL-PHX OCT 0.2>6[6] NOV 0>0.4[6]
WN DAL-PNS OCT 0.0>1.0[0]
WN DAL-SAN OCT 0.1>4[4] NOV 0>0.2[4]
WN DAL-SAT OCT 0.3>9[9] NOV 0>0.6[8]
WN DAL-SDF OCT 0.0>1.0[0]
WN DAL-SFO OCT 0.0>1.0[1.8]
WN DAL-SJC OCT 0.1>2[1.7]
WN DAL-STL OCT 0.2>6[6] NOV 0>0.3[6]
WN DAL-TPA OCT 0.1>3[2] NOV 0>0.2[2]
WN DAL-TUL OCT 0.1>4[4] NOV 0>0.2[3]
WN DCA-FLL OCT 0.0>2.0[2]
WN DCA-HOU OCT 0.1>3[3] NOV 0>0.2[3]
WN DCA-MCI OCT 0.1>1.9[1.9]
WN DCA-MCO OCT 0.0>2.0[2]
WN DCA-MDW OCT 0.2>6[6] NOV 0>0.4[6]
WN DCA-MKE OCT 0.1>1.9[1.9]
WN DCA-MSY OCT 0.1>2[2]
WN DCA-OKC OCT 0.0>1.0[0]
WN DCA-PVD OCT 0.1>2[2]
WN DCA-STL OCT 0.1>4[4] NOV 0>0.3[4]
WN DCA-TPA OCT 0.1>2[2]
WN DEN-DTW OCT 0.1>2[1.9]
WN DEN-ELP OCT 0.0>1.0[0.1]
WN DEN-EWR OCT 0.1>1.8[1.9]
WN DEN-GEG OCT 0.1>2[2]
WN DEN-HOU OCT 0.2>7[6] NOV 0>0.4[6]
WN DEN-IAD OCT 0.1>3[3]
WN DEN-IND OCT 0.1>4[4] NOV 0>0.2[4]
WN DEN-LAS OCT 0.3>9[8] NOV 0>0.6[8]
WN DEN-LAX OCT 0.2>7[7] NOV 0>0.4[7]
WN DEN-LBB OCT 0.0>1.0[0]
WN DEN-LGA OCT 0.1>3[2]
WN DEN-MCI OCT 0.2>7[7] NOV 0>0.4[6]
WN DEN-MCO OCT 0.1>4[4] NOV 0>0.3[4]
WN DEN-MDW OCT 0.3>9[9] NOV 0>0.6[8]
WN DEN-MEM OCT 0.0>1.0[0.9]
WN DEN-MKE OCT 0.1>4[4] NOV 0>0.2[3]
WN DEN-MSP OCT 0.2>5[5] NOV 0>0.3[4]
WN DEN-MSY OCT 0.1>3[2]
WN DEN-OAK OCT 0.2>5[5] NOV 0>0.3[5]
WN DEN-OKC OCT 0.1>3[3]
WN DEN-OMA OCT 0.1>3[3]
WN DEN-ONT OCT 0.1>3[1.9]
WN DEN-PDX OCT 0.2>5[4] NOV 0>0.3[4]
WN DEN-PHL OCT 0.1>3[2]
WN DEN-PHX OCT 0.4>11[11] NOV 0>0.7[11]
WN DEN-PIT OCT 0.1>1.7[1.0]
WN DEN-RDU OCT 0.1>1.8[1.9]
WN DEN-RNO OCT 0.1>2[2]
WN DEN-SAN OCT 0.2>6[6] NOV 0>0.4[6]
WN DEN-SAT OCT 0.1>3[3]
WN DEN-SEA OCT 0.1>5[4] NOV 0>0.3[4]
WN DEN-SFO OCT 0.1>5[5] NOV 0>0.3[5]
WN DEN-SJC OCT 0.2>5[4] NOV 0>0.2[4]
WN DEN-SLC OCT 0.2>6[6] NOV 0>0.3[5]
WN DEN-SMF OCT 0.2>5[4] NOV 0>0.3[4]
WN DEN-SNA OCT 0.1>4[5] NOV 0>0.2[5]
WN DEN-STL OCT 0.2>6[5] NOV 0>0.4[5]
WN DEN-TPA OCT 0.1>3[3]
WN DEN-TUL OCT 0.1>2[2]
WN DEN-TUS OCT 0.1>2[2]
WN DSM-PHX OCT 0>0.3[0]
WN DSM-STL OCT 0.1>1.9[1.9]
WN DTW-LAS OCT 0>0.3[1.0]
WN DTW-MDW OCT 0.2>4[4] NOV 0>0.3[3]
WN DTW-STL OCT 0.1>3[1.9]
WN ELP-HOU OCT 0.1>3[3]
WN ELP-LAS OCT 0.1>2[2]
WN ELP-LAX OCT 0.1>1.8[2]
WN ELP-PHX OCT 0.1>3[4] NOV 0>0.2[4]
WN ELP-SAN OCT 0.0>1.0[0.1]
WN ELP-SAT OCT 0.1>2.0[3]
WN EWR-MDW OCT 0.2>6[5] NOV 0>0.3[6]
WN EWR-OAK OCT 0.0>0.9[1.0]
WN EWR-SAN OCT 0>0.8[1.0]
WN EWR-STL OCT 0.1>1.9[1.9]
WN FLL-HAV OCT 0.1>3[3] NOV 0>0.2[3]
WN FLL-HOU OCT 0.1>3[2] NOV 0>0.2[3]
WN FLL-JAX OCT 0.1>2[3]
WN FLL-MBJ OCT 0.1>2[2]
WN FLL-MCI OCT 0.0>1.0[1.6]
WN FLL-MCO OCT 0.1>4[5] NOV 0>0.2[4]
WN FLL-MDW OCT 0.1>3[3] NOV 0>0.2[4]
WN FLL-MSY OCT 0.1>1.9[1.0]
WN FLL-NAS OCT 0.1>2[2]
WN FLL-PHX OCT 0.0>1.1[1.0]
WN FLL-PLS OCT 0>0.3[0.1]
WN FLL-SJU OCT 0.0>1.5[1.0]
WN FLL-STL OCT 0.1>2[2.0]
WN FLL-TPA OCT 0.1>4[5] NOV 0>0.3[4]
WN GEG-LAS OCT 0.1>2[2]
WN GEG-OAK OCT 0.1>2[2]
WN GEG-SAN OCT 0.0>1.0[0]
WN GEG-SJC OCT 0.0>0.9[1.0]
WN GRR-MDW OCT 0.1>3[3]
WN HAV-TPA OCT 0.0>1.1[1.0]
WN HNL-KOA OCT 0.1>4[0] NOV 0>0.3[0]
WN HNL-OAK OCT 0.1>2[0]
WN HNL-OGG OCT 0.1>4[0] NOV 0>0.3[0]
WN HNL-SJC OCT 0.0>1.0[0]
WN HOU-HRL OCT 0.2>5[5] NOV 0>0.3[4]
WN HOU-IND OCT 0.1>2.0[1.3]
WN HOU-LAS OCT 0.2>5[5] NOV 0>0.3[4]
WN HOU-LAX OCT 0.2>5[4] NOV 0>0.3[4]
WN HOU-LGA OCT 0.1>3[3]
WN HOU-LIR OCT 0>0.3[0.1]
WN HOU-MAF OCT 0.1>4[3] NOV 0>0.2[3]
WN HOU-MBJ OCT 0>1.0[0.5]
WN HOU-MCI OCT 0.1>3[3]
WN HOU-MCO OCT 0.1>5[5] NOV 0>0.3[5]
WN HOU-MDW OCT 0.2>6[6] NOV 0>0.4[6]
WN HOU-MEM OCT 0.1>1.9[1.7]
WN HOU-MSY OCT 0.3>9[9] NOV 0>0.5[8]
WN HOU-OAK OCT 0.1>3[3]
WN HOU-OKC OCT 0.1>4[4] NOV 0>0.2[4]
WN HOU-PHL JUN 0.4>1.0[0] JUL 0.1>1.0[0] AUG 0.1>1.0[0] SEP 0.2>1.0[0] OCT 0>1.0[0]
WN HOU-PHX OCT 0.2>5[5] NOV 0>0.3[5]
WN HOU-PIT MAY 1.1>1.7[1.0] OCT 0.0>1.7[1.0]
WN HOU-SAN OCT 0.1>3[1.9] NOV 0>0.2[2]
WN HOU-SAT OCT 0.2>6[5] NOV 0>0.4[5]
WN HOU-SDF OCT 0.0>1.0[0.9]
WN HOU-SLC AUG 0.3>0.9[0.1] SEP 0.3>1.0[0.2] OCT 0>1.0[0.1]
WN HOU-SMF AUG 0.0>0.9[0] SEP 0>1.0[0] OCT 0>1.0[0]
WN HOU-STL OCT 0.1>4[4] NOV 0>0.2[4]
WN HOU-TPA OCT 0.1>3[3] NOV 0>0.2[3]
WN HOU-TUL OCT 0.1>3[3]
WN ICT-STL OCT 0.1>1.9[1.9]
WN IND-LAS OCT 0.1>3[3]
WN IND-MCI OCT 0.1>1.9[1.9]
WN IND-MCO OCT 0.1>3[3] NOV 0>0.3[3]
WN IND-MDW OCT 0.0>1.3[1.8]
WN IND-OAK OCT 0.0>0.7[1.0]
WN IND-PHX OCT 0.1>1.7[1.1]
WN IND-RSW OCT 0>1.4[2]
WN IND-TPA NOV 0>0.2[2]
WN ISP-MCO OCT 0.1>2[2]
WN ISP-PBI OCT 0.1>1.9[1.8]
WN LAS-LAX OCT 0.4>10[11] NOV 0>0.6[9]
WN LAS-LBB OCT 0.0>1.0[1.1]
WN LAS-LGB JUL 0.3>3[0.6]
WN LAS-MCI OCT 0.1>4[4] NOV 0>0.2[4]
WN LAS-MCO OCT 0.1>2[2.0]
WN LAS-MDW OCT 0.3>9[9] NOV 0>0.6[7]
WN LAS-MKE OCT 0.1>3[3]
WN LAS-MSY OCT 0.1>2.0[2.0]
WN LAS-OAK OCT 0.3>9[9] NOV 0>0.5[9]
WN LAS-OKC OCT 0.1>2[1.9]
WN LAS-OMA OCT 0.1>3[3]
WN LAS-ONT OCT 0.1>4[4] NOV 0>0.3[4]
WN LAS-PDX OCT 0.1>4[4] NOV 0>0.3[4]
WN LAS-PHX OCT 0.4>10[10] NOV 0>0.6[9]
WN LAS-PIT OCT 0.1>2[1.8]
WN LAS-RNO OCT 0.3>9[9] NOV 0>0.6[8]
WN LAS-SAN OCT 0.4>11[10] NOV 0>0.7[9]
WN LAS-SAT OCT 0.1>4[4] NOV 0>0.3[4]
WN LAS-SEA OCT 0.1>3[3]
WN LAS-SFO OCT 0.2>6[7] NOV 0>0.4[6]
WN LAS-SJC OCT 0.4>10[9] NOV 0>0.6[9]
WN LAS-SLC OCT 0.2>5[5] NOV 0>0.3[4]
WN LAS-SMF OCT 0.3>8[8] NOV 0>0.5[7]
WN LAS-SNA OCT 0.2>5[6] NOV 0>0.3[6]
WN LAS-STL OCT 0.1>4[4] NOV 0>0.2[3]
WN LAS-TPA OCT 0.0>1.3[2.0]
WN LAS-TUL OCT 0.0>1.1[1.0]
WN LAS-TUS OCT 0.1>4[4] NOV 0>0.2[4]
WN LAX-MCI OCT 0.1>3[3]
WN LAX-MDW OCT 0.2>6[6] NOV 0>0.3[6]
WN LAX-MSY OCT 0.1>3[3]
WN LAX-OAK OCT 0.5>12[12] NOV 0>0.6[12]
WN LAX-OMA OCT 0.0>0.9[1.0]
WN LAX-PDX OCT 0.1>3[3]
WN LAX-PHX OCT 0.3>8[8] NOV 0>0.4[8]
WN LAX-PVR OCT 0.0>0.6[1.0]
WN LAX-RNO OCT 0.1>3[3]
WN LAX-SAT OCT 0.1>1.7[1.8]
WN LAX-SFO OCT 0.3>8[9] NOV 0>0.4[9]
WN LAX-SJC OCT 0.4>11[10] NOV 0>0.5[10]
WN LAX-SJD OCT 0>0.7[1.0]
WN LAX-SLC OCT 0.1>3[3]
WN LAX-SMF OCT 0.3>8[8] NOV 0>0.4[8]
WN LAX-STL OCT 0.1>3[3]
WN LAX-TPA OCT 0.0>0.9[1.0]
WN LAX-TUS OCT 0.1>3[3]
WN LGA-MCI OCT 0.1>1.9[1.0]
WN LGA-MDW OCT 0.2>6[6] NOV 0>0.4[6]
WN LGA-MKE OCT 0.1>1.9[1.9]
WN LGA-MSY OCT 0.0>1.1[0]
WN LGA-STL OCT 0.1>3[3]
WN LGA-TPA OCT 0.0>1.7[2]
WN LGB-OAK OCT 0.1>4[4] NOV 0>0.2[4]
WN LGB-SJC JUL 0>4[0]
WN LGB-SMF JUL 2.0>4[2] OCT 0.1>2[3]
WN LIT-PHX OCT 0.0>1.0[0.9]
WN LIT-STL OCT 0.1>1.9[1.9]
WN MBJ-MCO OCT 0>0.3[0.7]
WN MCI-MCO OCT 0.1>2[2]
WN MCI-MDW OCT 0.3>8[8] NOV 0>0.5[7]
WN MCI-MKE OCT 0.1>1.9[1.7]
WN MCI-MSP OCT 0.1>1.7[1.6]
WN MCI-MSY OCT 0.0>1.1[1.0]
WN MCI-OAK OCT 0.0>0.7[1.0]
WN MCI-PHX MAY 3>4[3] OCT 0.1>4[4] NOV 0>0.2[3]
WN MCI-RDU OCT 0.0>0.9[1.0]
WN MCI-SAN OCT 0.1>1.7[1.8]
WN MCI-STL OCT 0.1>4[4] NOV 0>0.2[4]
WN MCO-MDW OCT 0.2>7[7] NOV 0>0.6[7]
WN MCO-MEM OCT 0.0>1.3[1.1]
WN MCO-MHT OCT 0.0>2.0[1.9]
WN MCO-MKE OCT 0.1>3[2] NOV 0>0.2[3]
WN MCO-MSY OCT 0.1>4[3] NOV 0>0.3[3]
WN MCO-OAK OCT 0>0.8[1.0]
WN MCO-ORF OCT 0.0>1.3[1.0]
WN MCO-PHL OCT 0.1>3[3] NOV 0>0.2[4]
WN MCO-PIT OCT 0.1>3[4] NOV 0>0.3[4]
WN MCO-PVD OCT 0.1>3[3] NOV 0>0.2[4]
WN MCO-RDU OCT 0.1>2[2]
WN MCO-RIC OCT 0>0.3[0]
WN MCO-SAT OCT 0.0>1.8[1.0]
WN MCO-SDF OCT 0.0>2.0[1.1]
WN MCO-SJC OCT 0>0.8[1.0]
WN MCO-STL OCT 0.1>4[4] NOV 0>0.3[4]
WN MDW-MEM OCT 0.1>1.9[1.8]
WN MDW-MHT OCT 0.1>3[3]
WN MDW-MSP OCT 0.2>7[7] NOV 0>0.4[6]
WN MDW-MSY OCT 0.1>4[4] NOV 0>0.2[3]
WN MDW-OAK OCT 0.1>4[4] NOV 0>0.2[3]
WN MDW-OKC OCT 0.0>1.1[1.0]
WN MDW-OMA OCT 0.1>5[5] NOV 0>0.3[4]
WN MDW-PDX OCT 0.1>2[2]
WN MDW-PHL OCT 0.2>6[6] NOV 0>0.3[5]
WN MDW-PHX OCT 0.2>7[7] NOV 0>0.4[7]
WN MDW-PIT OCT 0.2>5[5] NOV 0>0.3[5]
WN MDW-PUJ OCT 0.0>0.6[0.5]
WN MDW-PVD OCT 0.1>3[3]
WN MDW-RDU OCT 0.1>4[3] NOV 0>0.2[3]
WN MDW-RSW OCT 0.1>3[2] NOV 0>0.2[3]
WN MDW-SAN OCT 0.1>4[3] NOV 0>0.2[3]
WN MDW-SAT OCT 0.1>3[2]
WN MDW-SDF OCT 0.1>4[4] NOV 0>0.2[3]
WN MDW-SEA OCT 0.1>1.9[2]
WN MDW-SFO OCT 0.1>1.9[2]
WN MDW-SJC OCT 0.1>1.7[1.6]
WN MDW-SLC OCT 0.1>2[2]
WN MDW-STL OCT 0.2>7[7] NOV 0>0.4[6]
WN MDW-TPA OCT 0.1>4[4] NOV 0>0.3[4]
WN MKE-PHX OCT 0.1>1.9[1.8]
WN MKE-STL OCT 0.1>1.9[1.9]
WN MKE-TPA OCT 0.0>1.1[0.9]
WN MSP-OAK OCT 0.0>0.9[1.0]
WN MSP-PHX OCT 0.1>2[2.0]
WN MSP-STL OCT 0.1>3[3]
WN MSY-PHX OCT 0.0>1.0[1.7]
WN MSY-SAT OCT 0.1>1.9[1.0]
WN MSY-STL OCT 0.1>2[1.9]
WN MSY-TPA OCT 0.1>3[3]
WN OAK-OGG OCT 0.1>2[0]
WN OAK-ONT OCT 0.2>7[6] NOV 0>0.4[7]
WN OAK-PDX OCT 0.2>6[6] NOV 0>0.4[6]
WN OAK-PHX OCT 0.2>6[6] NOV 0>0.3[7]
WN OAK-PVR OCT 0>0.5[0.9]
WN OAK-RNO OCT 0.1>1.9[1.9]
WN OAK-SAN OCT 0.4>11[10] NOV 0>0.7[11]
WN OAK-SAT OCT 0.0>0.9[1.0]
WN OAK-SEA OCT 0.2>7[6] NOV 0>0.4[6]
WN OAK-SJD OCT 0>0.7[1.0]
WN OAK-SLC OCT 0.1>3[3]
WN OAK-SNA OCT 0.2>7[7] NOV 0>0.4[7]
WN OGG-SJC OCT 0.0>1.0[0]
WN OKC-PHX OCT 0.1>2[2]
WN OKC-STL OCT 0.1>1.9[2]
WN OMA-PHX OCT 0.0>1.8[1.7]
WN OMA-SAN AUG 0.8>1.0[0] SEP 0.7>1.0[0] OCT 0.0>0.9[0]
WN OMA-STL OCT 0.1>3[3]
WN ONT-PHX OCT 0.2>6[6] NOV 0>0.4[6]
WN ONT-SFO OCT 0.1>4[0] NOV 0>0.2[0]
WN ONT-SJC OCT 0.2>5[4] NOV 0>0.3[5]
WN ONT-SMF OCT 0.3>7[7] NOV 0>0.4[7]
WN PDX-PHX OCT 0.1>3[3] NOV 0>0.2[3]
WN PDX-SAN OCT 0.1>1.9[1.8]
WN PDX-SJC OCT 0.2>6[5] NOV 0>0.3[6]
WN PDX-SMF OCT 0.2>5[5] NOV 0>0.2[5]
WN PHL-STL OCT 0.1>3[3]
WN PHX-RNO OCT 0.1>2[1.8]
WN PHX-SAN OCT 0.4>11[10] NOV 0>0.6[10]
WN PHX-SAT OCT 0.1>4[4] NOV 0>0.2[4]
WN PHX-SEA OCT 0.1>4[4] NOV 0>0.3[3]
WN PHX-SFO OCT 0.2>5[5] NOV 0>0.3[5]
WN PHX-SJC OCT 0.2>6[6] NOV 0>0.4[6]
WN PHX-SLC OCT 0.2>6[5] NOV 0>0.3[5]
WN PHX-SMF OCT 0.2>6[6] NOV 0>0.3[5]
WN PHX-SNA OCT 0.2>7[7] NOV 0>0.4[7]
WN PHX-STL OCT 0.1>3[3] NOV 0>0.2[3]
WN PHX-TUL OCT 0.1>1.0[1.7]
WN PIT-STL OCT 0.0>1.1[1.0]
WN PIT-TPA OCT 0.1>2[2]
WN PVD-TPA OCT 0.0>1.7[1.6]
WN RDU-STL OCT 0.1>2[2]
WN RDU-TPA OCT 0.1>1.9[1.7]
WN RIC-TPA OCT 0>0.3[0]
WN RNO-SAN OCT 0.1>3[2]
WN RNO-SJC OCT 0.1>2[1.7]
WN SAN-SAT OCT 0.1>2[1.8]
WN SAN-SFO OCT 0.3>8[7] NOV 0>0.4[8]
WN SAN-SJC OCT 0.5>15[11] NOV 0>0.8[12]
WN SAN-SLC OCT 0.1>1.9[1.0]
WN SAN-SMF OCT 0.5>14[11] NOV 0>0.8[12]
WN SAN-STL OCT 0.1>2[2]
WN SAN-TPA OCT 0>0.8[1.0]
WN SAN-TUS OCT 0.1>2[1.9]
WN SAT-STL OCT 0.1>1.9[1.9]
WN SEA-SJC OCT 0.2>4[5] NOV 0>0.3[4]
WN SEA-SMF OCT 0.2>5[5] NOV 0>0.3[5]
WN SJC-SLC OCT 0.1>1.9[1.5]
WN SJC-SNA OCT 0.3>9[9] NOV 0>0.5[10]
WN SJC-TUS OCT 0.0>0.9[0]
WN SJU-TPA OCT 0.0>0.6[0.5]
WN SLC-STL AUG 0>0.2[0] SEP 0>0.3[0] OCT 0>1.0[0]
WN SMF-SNA OCT 0.2>6[6] NOV 0>0.3[6]
WN STL-TPA OCT 0.1>2[2.0]
WN STL-TUL OCT 0.1>1.9[1.9]
*WW EWR-KEF MAY 1.8>1.0[1.1] JUN 2>1.0[1.8] JUL 2>1.0[1.8] AUG 2>1.0[1.9] SEP 2>1.0[1.5] OCT 1.8>1.0[1.0]
Why was this still filed? Weird...
*WW KEF-ORD MAY 0.9>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.5>0[1.0]
Re: OAG Changes 3/17/2019: NK Closes CAP;UA Suspends SFO-AMS
Posted: Sun Mar 17, 2019 2:16 pm
by AVLAirlineFreq
On this St. Patrick's Day, I raise a toast to you, enilria, for doing these posts each week. Thank you. :champagne:
by mcdu
UA SFO to AMS is seasonal service as I recall. I don’t believe it operated in NOV or DEC last year.
Posted: Sun Mar 17, 2019 2:19 pm
by LHUSA
It's a brand new route which has not even started yet. It was announced as year-round
Posted: Sun Mar 17, 2019 2:25 pm
by sargester
It was filed for those months and they canned it its only been around since the beginning of this year I thought
Posted: Sun Mar 17, 2019 2:27 pm
by Midwestindy
If AA would stop cutting JFK that would be great, almost impossible for me not to chose DL at this point.
Posted: Sun Mar 17, 2019 2:33 pm
by avi8
So much for GUA becoming a focus city for Avianca. JFK and ORD gone, LAX back to once a day instead of twice daily. I wonder what else will be gone soon with the fleet reduction.
Posted: Sun Mar 17, 2019 2:42 pm
by Chuska
On AA's Jun 6 skd, ELP will get an A321 on their 1430 DFW trip and ABQ will get another shot of an MD-80 on the 1035 DFW trip. Thought we saw our last MD-80 last summer but will get to enjoy it again this summer.
Posted: Sun Mar 17, 2019 2:53 pm
by psa1011
It was announced as year round, starting 3/31. Maybe it is now seasonal.
Posted: Sun Mar 17, 2019 2:58 pm
by AirFiero
Short and convenient flight from ABQ to ROW? ;)
Posted: Sun Mar 17, 2019 3:08 pm
by enilria
I raise a whiskey to ye.
Posted: Sun Mar 17, 2019 3:10 pm
by enilria
I was shocked not even PHL-JFK is daily. It's short, but plenty of feed.
Posted: Sun Mar 17, 2019 3:15 pm
by enilria
I should have marked this, but forgot about it. It's been talked about in the WN schedule change thread. A bit of a weird choice with EWR so tight on ops, but I guess connectivity through BWI.
Posted: Sun Mar 17, 2019 3:21 pm
by LAXdude1023
SFO-AMS never made much sense to me. No surprise there.
Posted: Sun Mar 17, 2019 3:22 pm
by Cubsrule
I suspect it may be “slot” squatting for when EWR gets re-slotted. EWR has been a struggle for WN, which is a little odd because they seem to have carved out a successful - albeit relatively small - niche at LGA.
Thanks, as always, for your work on these threads.
Posted: Sun Mar 17, 2019 3:26 pm
by Fargo
Why? Is SFO not big enough to be served on both KL and UA metal?
Posted: Sun Mar 17, 2019 3:35 pm
by United1
Looks like it's changing to a seasonal route...runs daily 3/31-10/26 on a 789. Hopefully returns next year as this route is rather useful for me :)
Posted: Sun Mar 17, 2019 3:37 pm
by phatfarmlines
Was OceanAir (dba Avianca Brasil) granted an extension? From recent posts regarding O6 on this board, I believe this service was supposed to end at the end of March as the A330s were being repossessed.
Posted: Sun Mar 17, 2019 3:38 pm
by N717TW
Can someone who understands Air India, BOM and the Indian market explain this cut to me? I realize that EWR is a stronger airport market (b/c Northern NJ has more ties and American-Indians than the L.I. side) for India, how Jet dropped JFK but kept EWR years ago, that AI operates a bigger operation from DEL, and that the Star alliance base (mostly via UA) aren't great at JFK. Still JFK is the stronger international airport in NYC and this strikes me as surprising.
Posted: Sun Mar 17, 2019 3:42 pm
by United1
Both SFO and AMS are huge financial and cultural centers so should be more than enough room. Despite being a Skyteam stronghold UA has always been able to hold its own in AMS. UA also knows how many passengers it was flowing SFO-EWR/ORD/IAH/IAD-AMS before offering a non-stop so am sure they believe there is enough of a market. Assuming that yields look yucky this winter.
Posted: Sun Mar 17, 2019 3:51 pm
by Planeboy17
Apparently not in the winter according to UA.
Posted: Sun Mar 17, 2019 3:52 pm
by amax1977
Don't spread rumors! UA not suspending SFO-AMS. It's a new route that will launch in April...
Posted: Sun Mar 17, 2019 3:55 pm
by SUNCTRY738
I agree, thank you enilria! Happy St Patty's Day!
Posted: Sun Mar 17, 2019 4:03 pm
by Aliqiout
I have suspected UA's SFO-AMS was not doing well. I have been seeing many second tier cities-AMS on UA for close to $400 RT.
by RJNUT
these are my favorite posts of the week, but as we get closer to the busy summer schedules, these posts are often more about Fall seasonal drops versus exciting new adds, but informative nonetheless. Thanks!
Posted: Sun Mar 17, 2019 4:14 pm
by mmahpeel
Considering UA has recently changed the formerly seasonal SFO-MUC to year-round service, it makes sense that SFO-AMS will become seasonal. More connectivity at MUC with LH indicates MUC can be viable year-round.
Posted: Sun Mar 17, 2019 4:19 pm
by LAXBUR
Re: BOI-DFW
Summer is 2x 738 daily. Fall and beyond goes from 1x 738 to 3x E175 daily.
by klm617
They heard Delta was going to start BOM in 2019 so they thought they better drop it in fear.
Posted: Sun Mar 17, 2019 4:25 pm
by dcajet
Thanks, was going to ask the same, as almost all international services (*) are being dropped on 31/3 (SCL MIA & JFK) and the A330-200s returned to the lessors. Is this a residual service lasting through April or has there been a change?
(*) FOR-BOG will continue to be operated for Avianca Holdings, dba Avianca Colombia. Or, at least, that was the plan.
Posted: Sun Mar 17, 2019 4:27 pm
by hiflyeras
So much for capacity restraint...NK and WN are going all out. It's shocking to read the huge additions to some frequencies by WN and all the new flying by NK.
by wedgetail737
Who is "AN"?
Posted: Sun Mar 17, 2019 4:30 pm
by kondoo
Pretty sure ORD will be gone soon.
Posted: Sun Mar 17, 2019 4:47 pm
by Midwestindy
Will be interesting to see how these start impacting JFK-LHR, for example MCO and RDU are the top 2 US airports for JFK-LHR feed....
Posted: Sun Mar 17, 2019 4:48 pm
by MIAFLLPBIFlyer
Might be related to the closure of Pakistani airspace to Indian-bound vessels. Also explains MAD and BHM suspensions.
Then again it might just again be AI not performing well from JFK. As you note the Indian-American community has shifted through the years more and more from NY to NJ and with it EWR has become stronger for Indian-bound traffic, that isn't business-oriented.
Posted: Sun Mar 17, 2019 4:50 pm
by MIAFLLPBIFlyer
NK suspension of CAP another Caribbean route from FLL that eventually gets pulled. Spirit has been much stronger historically in maintaining flights from FLL to Central and South America than to the Caribbean where routes have often come and gone with regularity.
Posted: Sun Mar 17, 2019 5:02 pm
by Prost
I have a question about M5 (Kenmore Air) CXH-LKE CXH = Vancouver Harbour Water Airport (Coal Harbour Seaplane Base).
My question is I thought all Canadian airports began with ‘Y’, is the Coal Harbour designation of CXH a hold over from maritime uses?
Posted: Sun Mar 17, 2019 5:04 pm
by chonetsao
PHL-LHR cut in the winter is inevitable considering the loads.
Assume this slot is transferred to second daily MIA-LHR
Now the million dollar question is whether second daily PHL-LHR would be cut earlier than OCT let us say SEP.
Posted: Sun Mar 17, 2019 5:05 pm
by LAXdude1023
SFO is a huge financial center. AMS’s economy isn’t financially turned. The economy there is much more centered around oil and natural gas, machinery, and marine based industries.
Posted: Sun Mar 17, 2019 5:08 pm
by chonetsao
I thought AA was cutting MCO-JFK...RDU already has a daily RDU-LHR, surprise that there are sizeable feed from RDU to LHR via JFK.
But again there is other weird things. I think it is a matter of time that a premium heavy aircraft to be used on JFK-LHR to match the O&D demand. Maybe a 48J seats version of B772 (even a reconfigured A333 that could be solely based in JFK for JFK-LHR, JFK-PHX, JFK-MIA and JFK-SFO routes!!)?
Posted: Sun Mar 17, 2019 5:09 pm
by N717TW
what's funny about that joke is actually how AI dropping the route makes me wonder if DL will commit to BOM after all their back and forth about the ME3. Alternatively I wonder if they will chose ATL rather than JFK. I mean if a known money losing gov't run airline drops a route that is clearly a high profile "prestige" route, then it doesn't paint a very optimistic picture for bean-counter friendly Delta Air Lines to open the same route.
Posted: Sun Mar 17, 2019 5:13 pm
by 717atOGG
Interesting that SEA-MEX is going twice-daily. Although the route isn't doing horribly, it's certainly not a rock-star performer, if its LF is any indicator. Maybe AM's cancellation of PDX-MEX benefited SEA?
Posted: Sun Mar 17, 2019 5:26 pm
by United1
AMS's economy might be a bit more financially tuned than you realize. It's considered to be on par with SF in terms of influence and diversification although not to the same scale. You can usually find Amsterdam ranked in the top 40 global financial centers.
Posted: Sun Mar 17, 2019 5:31 pm
by cledaybuck
Those aren’t huge additions, it’s just a schedule extension.
Posted: Sun Mar 17, 2019 5:51 pm
by tphuang
so now the june cuts extends to May. Hard to see how this doesn't extend to July. Not sure why they still keep JFK-PHL on schedule. RDU will probably go at some point and same with BWI/CLE. Not sure about BOS, seems like too important of a market to drop out of JFK. They can always go back to 2x daily for A321T utilization.
Posted: Sun Mar 17, 2019 6:02 pm
by Chuska
Re: Who is AN? in post 31:
AN is Advanced Air, a new commuter to the industry that recently won the EAS service to Silver City, NM. They keep announcing plans to start other routes but then cancel them before they start.
Posted: Sun Mar 17, 2019 6:28 pm
by FATFlyer
Advanced Air also flies the SurfAir routes in California. Then they operate the FBO at Hawthorne (HHR).
Posted: Sun Mar 17, 2019 6:33 pm
by babastud
Stop with the Fake News!! The route has not even started yet...
Posted: Sun Mar 17, 2019 6:39 pm
by dcajet
Connecting the 2 hubs of this JV?
Posted: Sun Mar 17, 2019 6:46 pm
by LAXdude1023
It doesn’t appear to be. It ranks alongside Wellington and Busan. Not saying there’s no finance there at all but that clearly wasn’t enough to make this route not a dud. Amsterdam is going to be a lot closer tied to a city like Houston because the drivers of the economy are more similar.
by shadez
True. However, STX seems to be performing very well, at least in terms of loads.
