JAAlbert wrote:The Justice Department should be investigating the FAA as well.
ikramerica wrote:JAAlbert wrote:The Justice Department should be investigating the FAA as well.
I think thats the IG not DOJ who would do that. Or Congress?
CLTRampRat wrote:GalaxyFlyer wrote:
Oh dear.
Blerg wrote:If they find Boeing and the FAA guilty then could airlines sue either one of the two? Also don't national aviation authorities also need to approve new aircraft?
IWMBH wrote:Blerg wrote:If they find Boeing and the FAA guilty then could airlines sue either one of the two? Also don't national aviation authorities also need to approve new aircraft?
I don't know about airlines, maybe they could cancel their contracts if they want to?
I'm almost certain that relatives of the one deceased can sue Boeing if they get convicted.
Transportation Secretary Elaine Chao on Tuesday asked the agency's inspector general to investigate the Max certification.
It's not yet clear what possible criminal laws could be at issue in the probe. Among the things the investigators are looking into is the process by which Boeing itself certified the plane as safe, and the data it presented the FAA about that self-certification, the sources said.
The FBI Seattle office and Justice Department's criminal division in Washington are leading the investigation.
Blerg wrote:IWMBH wrote:Blerg wrote:If they find Boeing and the FAA guilty then could airlines sue either one of the two? Also don't national aviation authorities also need to approve new aircraft?
True, they could always claim MAX isn't what they were promised to be, not to mention that the model is unsafe.
Blerg wrote:Very, very interesting read. Seems like buying planes from Boeing is like buying a ticket on an LCC.
https://www.nytimes.com/2019/03/21/busi ... harge.html
From the article:
Neither feature was mandated by the Federal Aviation Administration. All 737 Max jets have been grounded.
“They’re critical, and cost almost nothing for the airlines to install,” said Bjorn Fehrm, an analyst at the aviation consultancy Leeham. “Boeing charges for them because it can. But they’re vital for safety.”
GEUltraFan9XGTF wrote:Where does it stink the most? I want names. Who is responsible for MCAS? Systems integration? Testing and certification? Who besides Dennis Muilenburg? Eric Linblad?
HaulSudson wrote:[code][/code]GEUltraFan9XGTF wrote:Where does it stink the most? I want names. Who is responsible for MCAS? Systems integration? Testing and certification? Who besides Dennis Muilenburg? Eric Linblad?
Hamilton.
He's now in charge of the lion air and Ethiopian crash team.
He knows first hand which evidence has to be shredded ASAP.
Boeing is taking no chances.
https://www.flightglobal.com/news/artic ... sh-456777/
You couldn't make it up, I know.
2175301 wrote:I personally believe that this is going nowhere. They have to look; but, I think they will find that there were no criminal activities involved.
GEUltraFan9XGTF wrote:They know they are facing jail time if they take out the shredders.
Revelation wrote:Seattle Times suggested FAA inspectors felt pressured by their bosses to deliver results more quickly. Guess what: most of us get such pressure every day.
ST suggested that FAA technical people felt that FAA managers delegated too much certification scope to Boeing yet also said it was management's prerogative to do so.
ST suggested that Boeing made changes to the way MCAS worked after the certification was done and did not update them on that. If proven true, is that a criminal offense?
ST suggested as always that FAA favors the advancement of aviation (i.e. commercial interests) over aviation interests. Seems to be more an issue for Congress than DoJ, IMHO.
To me that mainly leaves the issue of ordinary crimes such as fraud or corruption, but I've seen no allegations of that anywhere.
In the end it might be a lot of looking and not a lot of finding, IMHO.
JAAlbert wrote:ikramerica wrote:JAAlbert wrote:The Justice Department should be investigating the FAA as well.
Well whatever or whoever -- it just seems to me that you can't give away your authority and then claim surprise when someone else uses it to their advantage.
nycbjr wrote:Holy hell, this stuff should be standard equipment! I've always been a Boeing fan but more and more I'm left shaking my head.. I hope the company learns from this and comes out a better organization, but I fear any would be short lived.
ELBOB wrote:nycbjr wrote:Holy hell, this stuff should be standard equipment! I've always been a Boeing fan but more and more I'm left shaking my head.. I hope the company learns from this and comes out a better organization, but I fear any would be short lived.
Short lived? Boeing have often had engineering issues with new types. Some examples from the jet era:
- Lack of rudder boost on the 707 which led to dozens of deaths in training accidents due to lack of control authority with an outer engine failed. Forced to make the change by the UK regulator so as to sell to BOAC;
- Four 727 approach crashes at night within six months of entering service in 1965, killing over 280. Whilst the root cause was identified, most perished because of fires started when broken generator leads ignited the severed centre-section aluminium fuel lines. Those were replaced in 300 in-service aircraft with stronger, flexible tubes in an emergency fix program;
- 737 Classic rudder actuator, often discussed here;
- 747 tail control runs inadequately separated, leading to loss of control when rear pressure bulkhead failed. 505 died due to this.
- 767 thrust reverser issues already mentioned
In fact the 757 and 777 are the only two which come to mind which didn't suffer from significant engineering oversights or shortcuts.
nycbjr wrote:Blerg wrote:Very, very interesting read. Seems like buying planes from Boeing is like buying a ticket on an LCC.
From the article:
As to the FBI/DOJ looking into, very smart thing to do, not sure much will come of it.
DL717 wrote:JAAlbert wrote:The Justice Department should be investigating the FAA as well.
And EASA.
yuomi wrote:DL717 wrote:JAAlbert wrote:The Justice Department should be investigating the FAA as well.
And EASA.
Erm...why?
DL717 wrote:yuomi wrote:DL717 wrote:
And EASA.
Erm...why?
You think the FAA is the only agency that certified the MAX? Europe and Canada’s FBI equivalents should get busy.
mjoelnir wrote:DL717 wrote:yuomi wrote:
Erm...why?
But the USA justice department has no jurisdiction over EASA. At least not in this case, a frame manufactured and certified in the USA. If we would be looking at a European manufactured frame, it could be a different case.
I mean thousands of people die every year in auto accidents that probably could be avoided with modern safety tech, if their cars had them. No one blames ford is someone dies in a crash that could have been avoided if they bought forward collision assist. It's not really different
art wrote:I mean thousands of people die every year in auto accidents that probably could be avoided with modern safety tech, if their cars had them. No one blames ford is someone dies in a crash that could have been avoided if they bought forward collision assist. It's not really different
If it were not really different, Ford would be marketing a car with a design weakness eg incorrect front/lrear weight distribution where the weight over the front wheels was excessive. To counteract the problem a computer-based system is added to limit brake pressure to the rear wheels to prevent lock up but if the system failed it would lprevent any pressure being applied to the rear brakes with attendant problems (increased braking distance / front wheel skids).
After a few people had been killed after losing control on a corner/driving into the back of a truck, I think the model concerned would be grounded until the anti-skid system was fixed. I also think Ford 's letter box would be full of correspondence from lawyers representing the families of the deceased.
CWizard wrote:Why is anyone surprised?
Over the last thirty years or so the multi-national corporations, banks, etc. and their lobbyist have perverted the system to the point the U.S. is as corrupt as any third world banana republic. Especially the Justice Department, where anti-trust has become a complete joke.
Even if it was a European manufactured plane the FBI has no jurisdiction or grounds to investigate the EASA, they would have to investigate why the FAA certified the aircraft. It is up to the Europeans to decide if they want to investigate why EASA did not put up a bigger fight.
I think the FBI would ask EASA directly, if it would be a European manufactured frame. If EASA would decline to answer, EASA employees should be careful and stop traveling to the USA.
It is just that in this case the primary certification agency is the FAA, the worst EASA could be accused of is rubber stamping a decision by an USA agency and I assume the FBI will keep going straight to the source.
kalvado wrote:There is a treaty between EU and USA regarding these certifications. Basically, it says "if our friends at FAA thinks it is good enough, it is good for EASA as well. We may check a few things, as our requirements are a touch different - but overall we trust them"
So EASA is a victim here as well.
Blerg wrote:So if they find a legal breach, what could be the consequences?
PW100 wrote:The one thing I do fear, is that these type of folks won't stopinvestigatingdigging until they found something they think is not right and should be prosecuted, without fully understanding the underlying context.
mxaxai wrote:Volkswagen's diesel manipulations or Airbus' corruption probes are some recent, comparable examples that led to some or all of the above.
