jfklucky777
SQ A359 9V-SGE Suffers Engine Damage - EWR
Sat Mar 23, 2019 6:46 pm
It appears that 9V-SGE suffered engine damage due to a collision with a jet-bridge at EWR. The return flight to SIN has been cancelled.
The following Twitter post has a photo of the damage. https://twitter.com/frisco0303/status/1109497727833047041
LAX772LR
Re: SQ A359 9V-SGE Suffers Engine Damage - EWR
Sat Mar 23, 2019 6:52 pm
On the surface, looks like it should be a pretty straightforward fix... though who knows what was harmed internally. :(
global2
Sat Mar 23, 2019 6:53 pm
Wow, didn't realize door L2 is that close to the engine!
Sat Mar 23, 2019 7:24 pm
Engine looks fine it’s the inlet that got the ding
Sat Mar 23, 2019 7:26 pm
It isn’t, that’s someone driving the bridge into the aircraft I would suggest the engines were not even running at that stage with the aircraft on chocks.
strfyr51
Sat Mar 23, 2019 7:31 pm
That's a flush patch repair bit just to get TO the repair point? It's about 30 Hours to tear down that lip to get to the repair. At this point? It might be easier to cut out the section and replace it using Blind fasteners
questions
Sat Mar 23, 2019 7:57 pm
It amazes me that the task of aligning the jetbridge to the aircraft door has not been automated.
adambrau
Sat Mar 23, 2019 8:07 pm
I was on the AirTrain from Terminal A to NJTransit and was wondering why SQ was parked on a remote stand. Someone's in hot water, unfortunately.
Let's keep the skies friendly.
BojamDelta
Sat Mar 23, 2019 8:08 pm
Not a Write off then?
Thought I’d get it out the way, I’m leaving now! :D
Weatherwatcher1
Sat Mar 23, 2019 10:04 pm
If it is just the lip skin, it is a fairly easy replacement. They get damaged all the time from birdstrikes and debris.
Newark terminal B is terrible. It needs to be demolished so that taxiways are more maneuverable around the gates. The international flights are using concourses that are better designed for regional jets.
