sonicruiser wrote:Just curious what people here think, people are always saying how WN might be interested in the 797. But are they actually? If they haven't ordered anything besides a 737 yet, why would that change now?
TTailedTiger wrote:I think it's the only way they could expand at slot controlled airports like LGA and DCA. WN has a disproportionately low number of slots at those airports.
barney captain wrote:TTailedTiger wrote:I think it's the only way they could expand at slot controlled airports like LGA and DCA. WN has a disproportionately low number of slots at those airports.
Somehow I don't see a 7 abreast, dual aisle, wide-body serving LGA or DCA.
TTailedTiger wrote:barney captain wrote:TTailedTiger wrote:I think it's the only way they could expand at slot controlled airports like LGA and DCA. WN has a disproportionately low number of slots at those airports.
Delta and Air Canada regularly served LGA with the 767. I'm not saying WN will order the 797 but if they did I could see it working at those two airports.
GalebG4 wrote:Nobody really knows how 797 will look like, for what market and routes is it going to most optimized. Is it going to be 737 successor? For long haul probably makes a lot of sense. But are they ever going to change money making practices which they use over 30 years. They should and they will but just in 5 to 10 years period.
TTailedTiger wrote:Delta and Air Canada regularly served LGA with the 767. I'm not saying WN will order the 797 but if they did I could see it working at those two airports.
zkojq wrote:If you believe the regular a.net cheerleaders United, Southwest, Delta, Singapore, Lufthansa, Air Canada, Qantas, one or both of the Japanese carriers, Icelandair, Alaska, TAP and half a dozen other carriers are all fighting each other fiercely for the honour of being the launch customer for this as-yet unspecified paper plane.
musman9853 wrote:
WaywardMemphian wrote:BNA-ANC-Tokyo and using the overlooked ability to transit through ANC with going through customs to the lower 48.
WaywardMemphian wrote:One wonders if JetBlue enters TATL and is su cessful at it, how long will WN sit by.
NameOmitted wrote:WaywardMemphian wrote:One wonders if JetBlue enters TATL and is su cessful at it, how long will WN sit by.
WN is not an airline known for emulating the sides of others. I don't see them going to Europe in the next decade but if they do, it won't be beacause B6 made it work for them.
ericm2031 wrote:I think a big problem, if its a wide body, will be its gates. Most of WN’s gates aren’t equipped to handle anything bigger than a 737. They’re still working on getting them all capable to handle the -800/-8.
Revelation wrote:zkojq wrote:If you believe the regular a.net cheerleaders United, Southwest, Delta, Singapore, Lufthansa, Air Canada, Qantas, one or both of the Japanese carriers, Icelandair, Alaska, TAP and half a dozen other carriers are all fighting each other fiercely for the honour of being the launch customer for this as-yet unspecified paper plane.
Your exaggeration and sarcasm would make more sense if we didn't actually have CEOs who have seen detailed presentations on NMA telling the media that they want to be the launch customer.
Aptivaboy wrote:Somehow I don't see a 7 abreast, dual aisle, wide-body serving LGA or DCA.
The DC-10 and the L-1011 were designed, in large part, specifically to operate out of smallish airports like LGA. LGA operations were a part of their design briefs, and the reason they went with three engines and a widebody cabin was to literally get the most passenger bang for the buck for each flight, and to possess sufficient thrust to get into and out of LGA's shorter runway.
Sorry, but that's the historical truth.
NameOmitted wrote:ericm2031 wrote:I think a big problem, if its a wide body, will be its gates. Most of WN’s gates aren’t equipped to handle anything bigger than a 737. They’re still working on getting them all capable to handle the -800/-8.
Since we know nothing about what Boeing is actually planning, we can throw all sorts of things into the wish list. Like, for instance, folding wing tips that allow the larger aircraft to dance with the 737 on the tarmac.
WaywardMemphian wrote:Out of left field but one route that I have wondered about as it seems like one of those perfect GCM routes combines with the car industry. BNA-ANC-Tokyo and using the overlooked ability to transit through ANC with going through customs to the lower 48.
That’s great, but it’s 2019 and not the 1970’s anymore. Airlines don’t generally work like that anymore. I would be surprised if LGA is a main influence on the 797.
