  • 1
  • 6
  • 7
  • 8
  • 9
  • 10
RyanairGuru
Re: Australian Aviation Thread - April 2019
Wed Apr 24, 2019 5:21 am
DeltaB717 wrote:
moa999 wrote:
Would VA be able to get better EDTO for their 777s these days if they wanted to restart JNB?
From memory it quit the route in 2010/11.
And longer ETOPS approval for the type didn't come for later - eg. NZ has operating using ETOPS330 since 2015
You're correct - the changes to Australia's EDTO rules came in 2015 by which time VA had been off JNB for many years.
To answer your question - yes, at least in theory. Back when VA was on JNB, CASA did not permit polar operations (or operations south of 60 degrees south, as Gemuser called it) on twins and only allowed EDTO180 (then called ETOPS and having different rules for tris and quads). Now, there is no EDTO time limit and polar operations with twins are permitted, subject to being granted approval. I think with a fleet of only 5 B777s, this would be a harder ask for VA than for QF.
On QF, they have quite extensive experience with what is now EDTO, having had the A330s certified for many, many years. I'm not sure, but I assume the A330s are certified to EDTO240 or thereabouts given the ops to Japan and Hawaii (and previously on AKL-LAX). The 787s must be at a similar level, too, and QF is no doubt using their ongoing experience with the B787 to build their case for EDTO330 ahead of the type being deployed to JNB and/or SCL.
Boof - I agree, as I said earlier, that QF should have no issue whatsoever achieving EDTO330. However, my read (and I did study ETOPS/EDTO for a postgrad a few years ago) of the situation when CASA changed the rules in 2015 (thanks for linking, by the way) was that CASA did so quite reluctantly following extensive lobbying by QF and, to a lesser extent, VA. I'm not sure I've seen anything to suggest they are any less reluctant to permit Australian carriers to operate twins on EDTO>180 or polar operations. I hope I'm wrong, because continuing any such reluctance flies in the face of the technical capabilities of the B787 and A350.
I am 98% certain that the A330s (and 787s for that matter) are EDTO180.
There are only three routes in Qantas' network that exceed 180: SYD-SCL, SYD-JNB and SYD-DFW. The deviation to remain within 180 on SYD-DFW is fairly minor, so SCL and JNB are the only routes where this is a major issue.
It is pretty much inevitable that Qantas will seek EDTO240 and EDTO330 for the 787 fleet, but I doubt they'd bother for the A330 fleet that don't fly anywhere outside of 180 range.
Worked Hard, Flew Right
JQ321
Wed Apr 24, 2019 6:12 am
jimmyah wrote:
Fuling wrote:
ZK-NBT wrote:
Please atleast re read my post on why I think HND will get it, no body has proved weather HND can not can’t take the A380.
HND has very few taxiway capabilities for the A380. Operations are restricted to late evening and early mornings, (Yes QF operate at those times but factor in any delays or diversions into HND and it adds complexities) Then take-off and landing directions are altered for the A380, and then there's also the additional separation that is imposed. And if I recall correctly, only two of the four runways can handle A380 ops.
In my opinion, QF will switch HND and SCL to the B789 (with a 3x weekly A330 to TYO from SYD) and operate as a SYD-SCL-SYD-HND-SYD rotation (3 frames). Then I see JNB going A380 and running a SYD-JNB-SYD-LHR-SYD rotation (4 frames).
NZ are operating into both HND and NRT (though I think this is ending soon), maybe QF can do something similar with 787's into HND and A380 into NRT?
That won't happen. TYO won't be able to take the massive increase a capacity to a A380 and a 787 from a 747. Maybe a A380 to NRT or 787 to HND and A330 to NRT but not 787 to HND and A380 to NRT. Maybe in the future but not now.
a19901213
Wed Apr 24, 2019 6:35 am
380 is way too premium heavy and will have problem filling those seats upstairs if used on NRT.
My 2cents is still on them down gauge HND from 747 to 789, which still has decent business class seat count, and open up a flight to NRT with 332.
JAL and ANA both use 789 and often substitute with 788s when demand is low.
As long as you can fill the premium seats plus the fuel saving you get from flying 789 they can still maintain or probably improve their margin on the route.
Gemuser
Wed Apr 24, 2019 6:49 am
DavidByrne
Gemuser wrote:
If the "someone from QF" is implying that CASA will not approve EDTO 330, well I can believe it BUT with them already approving a foreign airline flying EDTO 330 into Australia I don't think CASA would withstand the political blitz from QF
Maybe a false memory, but I'm pretty sure I read that the decision on whether EDTO 330 is approved (or indeed, any other EDTO level) rests with the country of registry of the aircraft, not the country into which the aircraft is operated. So this means that LA's MEL-SCL is operated under Chilean EDTO 30 approval, while QF on SYD-SCL/JNB would require Australian approval. Can anyone confirm this?
DeltaB717
That's my understanding, yes.
You are both right & wrong at the same time!
In everyday operations you are correct, it is the responsiability of the country of registration, HOWEVER nothing in the conventions & treaties interfears with a countries right to control its sovergin airspace. What ICAO does is set out the rules that everyone is to abide by, which if you are the country you are flying into accepts the country of registration that the rules are being abided by.
AFAIK there are only two cases where this does not hold true. Case 1): Where the national authrity of one country holds that the national authority of a second country is not enforcing the ICAO standards for its airlines/aircraft. This is what is happening when for example the FAA or EASA "bans" certain countries or airlines from their airspace. Case 2): where a country "reputates" an ICAO rule or part thereof. This is what Australia effectively [I belivev it was not offically done] did with EDTO until 2015.
Each country must approve an airline operating into its airspace, this is true of all airlines operating into all countries. Basically this is confirming that the airline is in compliance with all all ICAO requirments.
Gemuser
vhqpa
Wed Apr 24, 2019 6:51 am
The only EDTO180+ route I can see QF using its A330 fleet on is PER-JNB and while it looks like a long diversion it's only a further 300nm which is roughly around 40 minutes extra flight time (before factoring in winds). SAA have flown their A330-200s to Perth before and while I'm not 100% sure what ETOPS/EDTO they have I'd be surprised if it was more than 180 minutes.
http://www.gcmap.com/mapui?P=YPPH-FAOR%0D%0AYPPH-S22%B046%2750%22E079%B001%2703%22-FAOR&R=1200nm%40YPPH%0D%0A1200nm%40YPCC%0D%0A1200nm%40FIMP%0D%0A1200nm%40FAOR&MS=wls&DU=nm&E=180&E=240&EV=410&EU=kts
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
EK413
Wed Apr 24, 2019 7:53 am
that’s word on the street...
QF25/26 SYD-HND-SYD B789
QF21/22 SYD-NRT-SYD A330
EK413
Good evening, ladies and gentlemen. We are tonight’s entertainment!
qf789
Wed Apr 24, 2019 8:01 am
Sichuan to launch weekly CTU-KWE-MEL from late May
https://blueswandaily.com/sichuan-airli ... -may-2019/
Forum Moderator
777LRF
Wed Apr 24, 2019 1:50 pm
A bit off topic from the current discussion but I was wondering why VA694 from PER-MEL is taking this odd route as it heads north east initially and suddenly turns back down towards MEL.
https://www.flightradar24.com/VOZ694/2044fee2
I've seen this occur on this route a few times before.
qf789
Wed Apr 24, 2019 2:12 pm
The aircraft operating VA694 VH-XFH currently has an ETOPS related issue hence the longer flight. It has been flying routes with this sort of diversion for the past 2 days hence why every trans con flight it has operated has been delayed.
Forum Moderator
777LRF
Wed Apr 24, 2019 3:05 pm
Ah that explains it. Which airport(s) was it trying to stay in ETOPS range of?
GRJGeorge
Wed Apr 24, 2019 3:17 pm
Guess the decision on what to use on SYD-JNB could also depend somewhat on whether they get to launch the PER-JNB route as planned...any word on that, is it still on the table?
qf789
Wed Apr 24, 2019 3:49 pm
Between PER and MEL/SYD it would be ADL/ASP
Forum Moderator
x1234
Wed Apr 24, 2019 3:52 pm
If Air New Zealand can launch AKL-EZE with ETOPS 330 then QF can too on SYD-SCL and SYD-JNB.
https://www.ainonline.com/aviation-news ... ops-flight
https://aviation.stackexchange.com/ques ... ps-ranking
ben175
Wed Apr 24, 2019 4:31 pm
This is so interesting and bizarre! What causes a problem with the ETOPS of a single aircraft? I see it operated VA555 SYD-PER and also took the same route adding on over an hour of travel time. Would be an interesting explanation to give passengers.
EK413
Wed Apr 24, 2019 4:40 pm
Guess it’s a question as to when will both parties come to an agreement especially QF. From what’s been said previously the PER-JNB service could’ve been up and running as planned operating from T3/4 but QF has been refusing to cough up the balance owed to PAPL.
Take it due to VH-XFH having an ETOPS related issue has been restricted to East-West flying and nil HKG Ops.
EK413
qf789
Wed Apr 24, 2019 5:02 pm
EK413
Yes it is restricted to PER-SYD/MEL plus the odd SYD-MEL flight, no NAN flying this weekend either for XFH. It hasn't helped that XFJ has had some tech issues in the past week which has left it on the ground as much as what it has been in the air, though to my understanding that has been fixed now
Forum Moderator
qf789
Wed Apr 24, 2019 5:10 pm
It probably has only added 30-35 minutes extra flight time to VA555 taking it to just over 5 hours. The flight that has seen the greatest time added to it was on Monday when VA690 PER-MEL clocked up a flight time of 4hrs and 37 minutes while the return flight being VA697 clocked up a flight time of 4 hours and 15 minutes. Over the past few days the typical PER-MEL flight would take around 3hrs and 10 minutes. Added to that the winds on flights coming into PER over the past 2-3 days have been relatively good, with most flights arriving ahead of schedule by around 30 minutes, the likes of MEL/SYD/HBA/OOL/BNE-PER have all experienced good flying conditions for this time of the year.
Forum Moderator
qf2048
Thu Apr 25, 2019 12:57 am
EK413
This is what i think will happen too. Would be nice, but we know won't happen, if the NRT departure from SYD was in the evening making for a daytime return back to Australia.
ZL,QF,KE,BA,AS,CX,FR,U2,W6,EI,IB,JL,AY,LH,AA,AC,FQ,DJ,JQ,LA,FJ,QS,NZ,NF,SB,PG,EK,AB,VA,MH,KA,VN
a19901213
Thu Apr 25, 2019 1:50 am
EK413
If it ever happen it will most likely be an overnight flight back to Sydney from NRT coinciding with other QF flights flying back to Mel and BNE. Also morning departure flight from NRT makes it really hard to squeeze in to suitable time before curfew in Sydney airport as well.
Qantas will want utilise and consolidate their resourse in NRT to maximum potential (lounge, check-in and cooperation with travel agent etc)
ZK-NBT
Thu Apr 25, 2019 2:11 am
EK413
Surely it would be as you say similar to the MEL and BNE services which would give SYD-TYO a choice of AM and PM departures, while a NRT service would arrive SYD earlier than HND.
Curious now, what does the bilateral allow With Japan? QF have added MEL/BNE-NRT and the possibility of a SYD-NRT on top of the 1 allowed HND service. Plus JQ fly CNS/OOL-NRT then QF SYD-KIX and JQ CNS-OOL, is that all for now?
QF in the 90’s had a lot of capacity with mainly 747s SYD/CNS/PER- NRT and SYD-CNS-NGO and I think a KIX service aswell.
a19901213
Thu Apr 25, 2019 2:34 am
Australia signed an open sky agreement for flying in to NRT with Japan in 2011 and effective from summer 2013.
As long as QF can obtain the slots they desire there shouldn’t be any issue. (Night time slots in NRT are still relatively easy to get)
ZK-NBT
Thu Apr 25, 2019 2:48 am
Ok thanks. I’m guessing this goes for Japanese carriers into Australia aswell? Good to see them adding capacity through new services.
CraigAnderson
Thu Apr 25, 2019 3:55 am
"Hong Kong’s Air Accident Investigation Authority is probing a "serious" incident on a February flight from Perth to Hong Kong when the captain became incapacitated. Cathay Pacific flight CX170 had taken off from Perth International Airport on February 21 and was flying over the South China Sea when the incident occurred."
https://www.smh.com.au/world/asia/passe ... 51h17.html
Pcoder
Thu Apr 25, 2019 6:51 am
To me it seems like the crew handled it well. Can't see too many things that were not done well.
JQ321
Thu Apr 25, 2019 10:11 am
Another reason to move to Computer controlled planes. They can't be incapacitated.
jupiter2
Thu Apr 25, 2019 10:25 am
They can be hacked though :scratchchin:
B742
Thu Apr 25, 2019 10:37 am
Does anyone know of anywhere where I can find SYD and BNE backdated movements? In the UK we have www.lhr-lgw.co.uk
VirginFlyer
Thu Apr 25, 2019 10:38 am
You’ve never had the term “fatal error” pop up on your screen have you...
V/F
It is not for him to pride himself who loveth his own country, but rather for him who loveth the whole world. The earth is but one country, and mankind its citizens. —Bahá'u'lláh
eamondzhang
Thu Apr 25, 2019 11:21 am
My understanding is that you not only needs approval from your own country of registry (so you can gain the EDTO status for your entire fleet), but you also needs approval from the country that you fly into in order for EDTO routing to be legal. I might be wrong though.
Michael
Gemuser
Thu Apr 25, 2019 11:55 am
Michael
Correct! The country you fly into is sseking to confirm that the airline is conforming to the ICAO rules. This used to be done by certification of such by the aviation authority of the airlines home country, today, I don't know.
Gemuser
JQ321
Thu Apr 25, 2019 8:17 pm
V/F
Computers never make a mistake they do what they're told or they were made incorrectly. It was always a human failure in coding or manufacturing which caused this not a computer.
a19901213
Thu Apr 25, 2019 8:21 pm
I believe so but we probably won’t be seeing both Japanese carriers adding new service apart from the new Perth service.
I think JL was thinking coming back to BNE a while ago but not sure if this is still on their mind.
Also Given that most of the expanded slots in HND in 2020 have been allocated to US routes JL probably won’t be able to shift their current service to HND anytime soon.
T54A
Thu Apr 25, 2019 10:03 pm
Well then prepared to be surprised. SAA has beyond 180min approval for all the A330’s.
T6, Allouette 3, Oryx, King Air, B1900, B727, B744, A319, A342/3/6 A332/3 A359
qf2220
V/F
404 not found....
jupiter2
Thu Apr 25, 2019 10:13 pm
qf2220 wrote:
V/F
404 not found....
Just turn it off and then on again.......usually works out ok
eamondzhang
Thu Apr 25, 2019 10:22 pm
jupiter2 wrote:
qf2220 wrote:
V/F
404 not found....
If no pilot onboard try restarting the computer especially FMC.....
Michael
jupiter2
Thu Apr 25, 2019 10:25 pm
eamondzhang wrote:
jupiter2 wrote:
qf2220 wrote:
404 not found....
Michael
Um yer, exactly.
DeltaB717
Fri Apr 26, 2019 1:07 am
Gemuser wrote:
DavidByrne
DeltaB717
Gemuser
Thanks for clarifying this, I appreciate it! I've worked in 'international air transport' regulation before and also spent a lot of time studying EDTO ops, just hadn't joined the dots about receiving country certification. I assume the receiving country certification process is less involved than the home country process, i.e. Australia would rely to some degree on the authorities in the home countries of the likes of LA, SA, UA, etc. rather than requiring the airline in question to go through the same full process that we would require for QF or VA?
Could be anything - an APU fault, a starter fault, a comms fault, a piece of survival equipment that's been removed for repair... it could be any one (or more) of a number of things.
ben175
Fri Apr 26, 2019 1:25 am
VH-ZNC is operating today’s QF589 BNE-PER. Is this scheduled or just a temporary equipment swap?
Boof
Fri Apr 26, 2019 1:33 am
I read somewhere (maybe here on earlier post/thread) it is for crew training and will happen a few times.
Bring back Virgin Blue!
DeltaB717
Fri Apr 26, 2019 2:03 am
It's every Friday that I've looked at between now (actually end of March) and the end of October, i.e. the full northern summer season.
Captdasbomb
Fri Apr 26, 2019 3:52 am
Will be till October when the next 3 birds arrive. Will be also used for re-training of the ex-747 pilots.
Gangurru
Fri Apr 26, 2019 4:51 am
Cathay Pacific is reportedly ending it’s Cairns flights.
https://www.tropicnow.com.au/2019/april ... ights.html
Obzerva
Fri Apr 26, 2019 5:35 am
Could CX be planning on swapping it with UO?
Pcoder
Fri Apr 26, 2019 5:50 am
With the a321neo coming to KA, it would probably be a better option.
They might be cancelling the route due to the enhanced relationship with QF. The route itself could have already been marginal and the probably preferred to have a direct flight to Brisbane.
F100Flyer
Fri Apr 26, 2019 6:01 am
QR908 DOH-SYD is currently diverting to Perth. Seems to be at a relatively low altitude of 29,000ft too.
qf789
Fri Apr 26, 2019 6:04 am
VA operating a PER-AVV charter this afternoon
Forum Moderator
Gangurru
Fri Apr 26, 2019 6:06 am
Cairns links to Cathay go back to the very first flight in 1946 which was Hong Kong-Sydney with the DC3 Betsy.
This means that Cairns was the first Australian port to ever welcome a CX flight.
Besty later ended up in Cairns, as part of the Bush Pilots Airways/ Air Queensland fleet. She was restored and flown back to Hong Kong. The story of her return to Hong Kong from Cairns on the reverse itinerary of the inagural flight is told on the link below.
http://www.bushies.net/pdf/Betsy's%20last%20ride.pdf
Qantas16
Fri Apr 26, 2019 6:21 am
This is really sad news for CNS and goes on top of the recent announcement that CZ was also "suspending" flights too:
https://www.newsport.com.au/2019/march/ ... gion/?L=44
qf789
Fri Apr 26, 2019 6:25 am
Diverting due to a tech issue, aircraft being towed after arrival
Forum Moderator
  • 1
  • 6
  • 7
  • 8
  • 9
  • 10
