Page 1 of 1
Alaska Airlines Using The A320 Between Paine Field (Everett, Washington) & San Francisco?
Posted: Sat Apr 06, 2019 6:44 pm
by dc10lover
Re: Alaska Airlines Using The A320 Between Paine Field (Everett, Washington) & San Francisco?
Posted: Sat Apr 06, 2019 6:47 pm
by dc10lover
I HOPE it's TRUE. High demand requires Airbus & Boeing Aircraft.
Posted: Sat Apr 06, 2019 6:48 pm
by 717atOGG
I believe this is a maintenance ferry flight, since AS gets some maintenance work done in PAE IIRC, and the flight number is in the 9000's, which isn't usually used for passenger flights.
Posted: Sat Apr 06, 2019 6:53 pm
by ikolkyo
Maintenance
Posted: Sat Apr 06, 2019 10:28 pm
by wedgetail737
Mainline to PAE will happen eventually.
Posted: Sat Apr 06, 2019 10:41 pm
by F27500
And .. tell me again .. why does Seattle need to be served by2 separate airports?
Posted: Sat Apr 06, 2019 11:40 pm
by BoeingGuy
Because there are something like 2 million people closer to PAE and it can also be a 90+ minute drive in bad traffic from the north to SEA.
Posted: Sat Apr 06, 2019 11:58 pm
by AA737-823
For the same reasons that Chicago, Houston, Dallas, San Fran, LAX, New York, Miami, and eleventy-hundred other large cities in the world do.
Posted: Sun Apr 07, 2019 12:16 am
by F27500
Seattle is not NYC or LA or Chicago
Posted: Sun Apr 07, 2019 12:19 am
by Spetsnaz55
I live in Everett. Seatac can be a 2 hour drive for me in rush hour traffic. Not thanks. Paine field is also 25 miles from down town seattle.. it's not a block over. This airport is gonna serve the north end of wa state and there really is a lot of people here
Posted: Sun Apr 07, 2019 12:23 am
by eal
You're right it's none of those cities, it's more comparable to SFO/OAK, DAL/DFW, MIA/FLL, HOU/IAH
I'm pretty sure Alaska Airlines knows more about the operability of PAE then you do.
Posted: Sun Apr 07, 2019 1:17 am
by usxguy
Its taken me over an HOUR to get from the car rental center to the terminal.....
go check out google maps @ that distance, then ask yourself.....
and to add in, the non-Clear/Non-PreCheck lanes at SeaTac routinely are 30+ minute waits.
Posted: Sun Apr 07, 2019 1:38 am
by DocLightning
Airbii can get service at PAE? I assume it's not Boeing offering the service.
Posted: Sun Apr 07, 2019 1:43 am
by gunsontheroof
You've clearly never driven from Snohomish County to Sea-Tac within the last thirty years. PAE service was long-overdue.
Posted: Sun Apr 07, 2019 2:09 am
by MO11
Eh, it 's more comparable to SAN/CLD.
Posted: Sun Apr 07, 2019 2:19 am
by jetmechanicdave
I live 1 mile from PAE and you are correct. Way long overdue.
Posted: Sun Apr 07, 2019 2:29 am
by jetmechanicdave
Yes it was a maintenance flight.
Posted: Sun Apr 07, 2019 2:49 am
by gunsontheroof
They can and do! ATS would almost certainly be the outfit concerned--I think that HA still has all their A321s delivered to PAE for interior work prior to service.
I live almost exactly halfway between PAE and SEA. If flow is northbound, I can catch SEA departures and PAE arrivals from my apartment deck, which can make for some interesting spotting on a good day. Taking my first flight out of PAE in just under a month (AS, PAE-SJC), looking forward to seeing the new terminal and adding another airport to my log.
Posted: Sun Apr 07, 2019 3:01 am
by Jet-lagged
That’s right. Seattle is growing like gangbusters. Those cities on the other hand....
In any case Paine Field is just a couple of gates, it’s almost silly to call it an airport in the same manner or SeaTac. It’s like a mini airport.
Posted: Sun Apr 07, 2019 4:29 am
by airplanenut
I live 15 minutes north of SeaTac and work down the street from Paine. My commute can take anywhere from 35 minutes (once--an amazing record) to well over 2 hours, and during rush hour, the last bit of the drive from where I'd get off the highway to SeaTac can be 30-60 minutes on a bad day. Now consider the folks who live north of Paine. Right now there are no good transit options that bypass the highways, so service at an airport north of the city is hugely beneficial really for everyone that lives anywhere from a few miles north of downtown until you get north enough that Bellingham might be a viable option (if they serve a city useful to you).
Posted: Sun Apr 07, 2019 4:48 am
by EA CO AS
So, I’m going to go out on a limb here and guess you’ve gotten your answer, right? :rotfl:
Posted: Sun Apr 07, 2019 6:07 am
by hmmwv
Airbus getting work done at PAE, that's an interesting sight.
Posted: Sun Apr 07, 2019 6:39 am
by caflyboy
FYI the next largest city (MSA) in the US is PHX which is served by two airports. Both Tampa and Orlando MSAs are smaller than SEA and served by two airports. Just look at the population data. I think that will answer why.
Posted: Sun Apr 07, 2019 1:48 pm
by LAXBUR
Interesting how this went from an obvious non-scheduled flight to arguing about the viability of SEA having two airports. Amazing. Always something to argue on here.
Posted: Mon Apr 08, 2019 6:21 pm
by iamlucky13
It doesn't "need" to be served by 2 airports. But there is a strong case to make that enough demand is there to support a secondary airport in the region. SEA traffic will almost certainly grow this year by more than what PAE takes away, which will only be 2-3% of SEA's passenger volume. The sometimes long drive to SEA and time it takes to get from parking to your gate are strong incentives to give PAE a try.
And by and large, it is not Seattle itself that is served by Paine Field, but the areas north of Seattle.
True, but I think a lot of us on this thread were already aware that Aviation Technical Services does maintenance on some Airbus aircraft at PAE, so the question about why there would be two airports in the region was a more interesting point of discussion.
Posted: Mon Apr 08, 2019 7:18 pm
by 7673mech
Not really. There is a repair station there. Hawaiian Airlines flies the Airbus from Europe straight there for post delivery mods.
Posted: Mon Apr 08, 2019 7:23 pm
by dc10lover
It HAS to eventually but isn't the airport terminal / boarding area too small to have mainline aircraft? (Can't fit all the passengers in the boarding area)
Posted: Mon Apr 08, 2019 8:55 pm
by Brandon757
WN initially had plans to fly out of PAE, so I assume it can.
Posted: Mon Apr 08, 2019 9:16 pm
by formeraa
PAE has very limited slots right now. I don't recall any restrictions on aircraft type.
