enilria
OAG Changes 4/7/2019:AA Further Trims JFK;D8 Suspends PVD-ORK/SNN.SNN-SWF;ET Moves ABJ from EWR to JFK;VC SFB-MOB>BFM
Sun Apr 07, 2019 12:01 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3F HYL-KTB MAY 0.9>0[0.9] JUN 0.8>0[0.9] JUL 0.9>0[0.8] AUG 0.9>0[0.9] SEP 0.8>0[0.8] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.8>0[0.8] JAN 0.9>0[0.9]
3F KTB-KTN MAY 0.9>3[3] JUN 0.8>3[3] JUL 0.9>3[3] AUG 0.9>3[3] SEP 0.8>3[3] OCT 0.9>3[3] NOV 0.9>3[0.9] DEC 0.8>3[0.8] JAN 0.9>3[0.9]
3F KTN-MTM MAY 1.7>3[3] JUN 1.7>3[3] JUL 1.7>3[3] AUG 1.7>3[3] SEP 1.7>3[3] OCT 1.7>3[3] NOV 1.7>3[1.7] DEC 1.7>3[1.7] JAN 1.7>3[1.7]
4A ATY-PIR MAY 1.7>0[0] JUN 1.7>0[0] JUL 1.7>0[0] AUG 1.7>0[0]
4A AZA-CLD MAY 0.9>0[0] JUN 0.8>0[0] JUL 0.9>0[0] AUG 0.5>0[0]
4A CLD-LAS MAY 0.8>0[0] JUN 0.9>0[0] JUL 0.8>0[0] AUG 0.6>0[0]
4A CLD-RNO MAY 0.6>0[0] JUN 0.6>0[0] JUL 0.6>0[0] AUG 0.4>0[0]
4A CLD-SJC MAY 1.7>0[0] JUN 1.7>0[0] JUL 1.7>0[0] AUG 1.1>0[0]
4A DEN-PIR MAY 1.7>0[0] JUN 1.7>0[0] JUL 1.7>0[0] AUG 1.7>0[0]
4O CUN-JFK JUL 1.0>1.3[1.3] AUG 1.0>1.4[1.2]
4O MCO-MEX JUL 1.0>1.3[1.0]
7H ADQ-ANC MAY 3>2[5] AUG 3>2[4] JAN 5>3[3]
7H AKN-ANC JUN 0.2>0.5[1.5] AUG 0.2>0.5[1.1] JAN 0.8>0.1[0.2]
7H AKN-DLG JUL 0.2>0[0.7] AUG 0.2>0[0.9] JAN 0.8>0.1[0.2]
7H ANC-DLG MAY 0.2>0.7[1.0] JUN 0.2>0.8[1.3] JAN 0.8>0.1[0.2]
7H ANC-ENA JUL 9>11[11] AUG 9>11[11] JAN 12>9[8]
7H ANC-FAI JUL 2>1.3[3] AUG 2>1.3[2] JAN 3>2[2.0]
7H ANC-HOM JUL 4>5[6] AUG 4>5[5] JAN 5>4[4]
7H ANC-OTZ JAN 0.7>0.3[0.4]
7H ANC-SNP MAY 0.4>0.2[0]
7H BET-SNP MAY 0>0.2[0]
7H FAI-SCC JAN 0.6>0.3[0.3]
9K ACK-EWB JUN 1.0>2[3] JUL 1.0>3[4] AUG 1.0>3[4] SEP 0.9>1.5[3]
9K HPN-MVY JUL 3>2[3]
9X HNL-JHM MAY 0>7[0] JUN 0>7[0] JUL 0>7[0] AUG 0>7[0] SEP 0>7[0] OCT 0>7[0] NOV 0>7[0] DEC 0>7[0] JAN 0>7[0]
9X HNL-LUP MAY 0>0.9[0] JUN 0>1.8[0] JUL 0>1.9[0] AUG 0>1.9[0] SEP 0>1.8[0] OCT 0>1.9[0] NOV 0>1.9[0] DEC 0>1.8[0] JAN 0>1.9[0]
9X HNL-MKK MAY 0>11[0] JUN 0>11[0] JUL 0>11[0] AUG 0>11[0] SEP 0>11[0] OCT 0>11[0] NOV 0>11[0] DEC 0>11[0] JAN 0>11[0]
9X HNL-OGG MAY 0>3[0] JUN 0>4[0] JUL 0>4[0] AUG 0>4[0] SEP 0>4[0] OCT 0>4[0] NOV 0>4[0] DEC 0>4[0] JAN 0>4[0]
9X HNM-OGG MAY 0>1.9[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0]
9X IPL-LAX MAY 0>3[0] JUN 0>3[0] JUL 0>3[0] AUG 0>3[0] SEP 0>3[0] OCT 0>3[0] NOV 0>3[0] DEC 0>3[0] JAN 0>3[0]
9X JHM-KOA MAY 0>1.9[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0]
9X KOA-OGG MAY 0>12[0] JUN 0>12[0] JUL 0>12[0] AUG 0>12[0] SEP 0>12[0] OCT 0>12[0] NOV 0>12[0] DEC 0>12[0] JAN 0>12[0]
9X LUP-MKK MAY 0>0.9[0] JUN 0>1.8[0] JUL 0>1.9[0] AUG 0>1.9[0] SEP 0>1.8[0] OCT 0>1.9[0] NOV 0>1.9[0] DEC 0>1.8[0] JAN 0>1.9[0]
9X MKK-OGG MAY 0>10[0] JUN 0>9[0] JUL 0>9[0] AUG 0>9[0] SEP 0>9[0] OCT 0>9[0] NOV 0>9[0] DEC 0>9[0] JAN 0>9[0]
9X MUE-OGG MAY 0>1.9[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0]
AA AMA-DFW JUL 8>7[7]
AA ANU-MIA MAY 1.7>1.0[1.0]
AA ATL-CLT JUL 9>8[8]
AA AUS-JFK MAY 2>1.1[1.0]
AA AUS-LAX MAY 4>3[4]
AA BDL-DFW MAY 1.8>1.0[1.9]
AA BNA-LAX MAY 3>1.8[2]
Significant JFK cuts throughout the list
Wow that's a big cut
*AA BOS-JFK JUL 4>1.0[5] AUG 5>1.0[5] SEP 5>1.0[4] OCT 5>1.0[3] NOV 5>2[3]
AA BOS-MIA MAY 7>6[7]
AA BOS-ORD MAY 9>8[9]
AA BWI-JFK JUL 1.8>1.0[2] AUG 2>1.0[1.9] SEP 2>1.0[1.7] OCT 2>1.0[1.1] DEC 2>5[1.0] JAN 2>5[1.0]
AA BWI-ORD JUL 5>4[4]
AA CAE-DCA JUL 3>4[3]
AA CHS-MIA JUL 3>5[3] AUG 3>4[3]
AA CID-ORD JUL 5>6[5]
AA CLE-JFK JUL 1.8>1.0[3] AUG 2>1.0[3] SEP 2>1.0[3] OCT 2>1.0[3] NOV 2>1.3[3]
AA CLT-CMI JUL 1.2>2[0] AUG 1.0>1.6[0]
AA CLT-JFK MAY 7>6[6] JUL 6>7[6]
AA CLT-MSY JUL 7>6[7] AUG 7>6[7]
AA CLT-SGF JUL 3>4[3]
AA CMH-JFK NOV 1.0>1.3[0.9] DEC 1.0>2[1.0] JAN 1.0>2[1.0]
AA CMH-MIA JUL 3>4[3] AUG 3>4[3]
AA CMH-ORD JUL 8>9[7]
AA CMH-PHL JUL 6>5[6] AUG 7>6[6]
AA DCA-JFK MAY 4>3[4]
AA DCA-MYR JUN 1.2>1.5[1.0]
AA DCA-YYZ JUL 3>1.8[2] AUG 3>2[3]
AA DEN-DFW AUG 9>10[9] SEP 9>10[8] OCT 9>10[8] NOV 9>10[8] DEC 9>10[8] JAN 9>10[8]
AA DFW-GRK JUL 7>8[7]
AA DFW-LFT JUL 5>6[4]
AA DFW-OAK MAY 1.0>0.2[1.0]
AA DFW-SGF JUL 7>8[7]
AA DFW-TUS MAY 7>6[6]
AA DRO-PHX JUL 2.0>3[2.0] AUG 2>3[1.9]
AA ELP-LAX JUL 2>3[2] AUG 2>3[2]
AA FAT-LAX JUL 4>3[3]
AA FAT-PHX JUL 6>5[5]
AA FSD-ORD JUN 3>4[3]
AA GCM-MIA MAY 3>2[3]
AA IAD-LAX MAY 1.6>1.0[2.0]
AA IAH-PHL JUL 4>3[3] AUG 4>3[3]
AA ILM-ORD AUG 1.0>1.5[0.6]
AA IND-LAX JUL 1.8>1.0[1.9] AUG 2>1.4[1.9]
AA JAX-MIA JUN 5>6[5]
AA JFK-LAS MAY 1.9>1.1[2] JUL 3>1.9[3] AUG 3>1.9[3] SEP 3>2[2.0] OCT 3>2[1.7] NOV 3>2[1.7] DEC 3>2[1.8] JAN 3>2[1.9]
AA JFK-MIA MAY 6>5[6] DEC 6>7[6] JAN 6>7[6]
AA JFK-ORD MAY 3>1.5[1.0] JUL 1.2>2[1.0] AUG 1.0>2[1.0] SEP 1.0>2[1.0] OCT 1.0>2[1.0] NOV 1.0>3[1.0] DEC 1.0>4[1.4] JAN 1.0>4[1.9]
Completely gone, but to 5RTs in DEC?
*AA JFK-PHL JUL 0.8>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>1.7[1.0] DEC 1.0>5[1.0] JAN 1.0>5[1.0]
AA JFK-PHX MAY 5>4[4] DEC 5>6[4] JAN 5>6[4]
I assume DEC is an error?
*AA JFK-PIT NOV 1.0>2[1.0] DEC 1.0>4[1.0] JAN 1.0>4[1.0]
AA JFK-RDU JUL 4>2[4] AUG 4>2[4] SEP 4>2[4] OCT 4>2[4] NOV 4>3[4]
AA JFK-SAN MAY 2>0.9[1.0] JUL 3>2[3] AUG 3>2[3] SEP 3>2[1.9] OCT 3>2[1.4] NOV 3>1.7[1.6] DEC 3>1.0[1.8] JAN 3>1.0[1.2]
AA JFK-SEA MAY 1.9>0.0[1.0] JUL 3>2[3] AUG 3>1.9[3] SEP 3>1.9[1.5] OCT 3>1.9[1.0] NOV 3>1.6[0.9] DEC 3>1.0[1.0] JAN 3>1.0[1.0]
AA JFK-YUL JUL 1.8>1.0[2] AUG 2>1.4[2]
AA KIN-MIA MAY 3>2[3]
AA LAX-MIA MAY 8>7[8]
AA LAX-MSY MAY 1.1>0.4[1.0] JUL 1.8>1.0[1.0] AUG 2>1.4[1.0]
AA LAX-PHL JUL 6>7[6]
AA LAX-RDM JUL 1.1>1.7[1.0] AUG 1.0>1.5[1.0]
AA LAX-SAN JUL 6>5[6]
AA LAX-SFO JUL 11>8[9] AUG 11>9[11]
AA LAX-SJC JUL 6>5[5]
AA LAX-SLC JUL 4>3[3]
AA LGA-MIA MAY 12>10[12]
AA LGA-MSP JUL 2>1.8[2]
AA LGA-ORD MAY 13>12[13]
AA MGA-MIA MAY 3>1.7[3]
AA MIA-ORD MAY 9>7[9]
AA MIA-ORF JUL 3>4[3] AUG 3>4[3]
AA MIA-PAP MAY 3>2[3]
AA MIA-PIT JUL 2>3[2] AUG 2>3[2]
AA MIA-SDQ MAY 4>3[4]
AA MIA-SKB MAY 1.7>1.1[1.7]
AA MRY-PHX JUL 3>4[4] AUG 3>4[3]
AA MSP-PHL JUL 4>3[3]
AA MSP-PHX JUL 4>3[4]
AA MYR-PHL JUL 3>2[2]
AA OAK-PHX JUL 5>3[4] AUG 5>4[4]
AA ORD-PHX JUL 9>8[9]
AA ORD-STL JUL 5>6[6] AUG 6>7[6]
AA ORD-TYS JUL 3>4[4] AUG 3>4[3]
AA ORH-PHL JUL 0.9>1.7[0] AUG 1.0>1.6[0]
AA PBI-PHL JUL 3>4[3] AUG 3>4[3]
AA PDX-PHX MAY 4>3[4]
AA PHL-PNS JUL 1.1>1.9[1.0] AUG 1.0>1.6[1.0]
AA PHL-PWM JUL 5>4[6]
AA PHL-SEA JUL 4>3[3]
AA PHL-SWF JUL 3>4[3] AUG 3>4[3]
AA PHL-TPA JUL 5>6[4]
AA PHL-YOW JUL 3>2.0[3] AUG 3>2[3]
AA PHX-RNO JUL 4>5[4]
AA PHX-SAN MAY 6>5[5]
AA PHX-SBA JUL 5>4[5]
AA PHX-STL MAY 2.0>1.2[2]
AA PHX-TUS JUL 6>7[6]
AC ANC-YVR JUN 2>1.5[1.0]
AC RDU-YYZ JUN 3>4[4]
AF JFK-ORY JAN 1.0>0.4[0.4]
AS SFO-SNA SEP 5>6[5] OCT 5>6[5]
*AV BOG-BOS JUL 0.8>0[0.6] AUG 0.9>0[0.5] SEP 0.9>0[1.0] OCT 0.8>0[1.0] NOV 0.9>0[0.9] DEC 0.8>0[0.9] JAN 0.9>0[0.8]
AV BOG-MCO JUL 1.0>1.6[1.0] AUG 1.0>1.5[1.0] SEP 1.0>1.6[1.0]
*AV BOG-ORD SEP 0.6>0[0] OCT 0.5>0[0] NOV 0.6>0[0.3] DEC 0.5>0[0.6] JAN 0.6>0[0.5]
*AV CTG-JFK JUL 0.4>0[0.4] AUG 0.4>0[0.5] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.5>0[0.4]
B6 BOS-BUR JUN 1.0>0.7[0] JUL 1.0>0.4[0] AUG 1.0>0.4[0]
B6 BOS-OAK JUN 0.6>0.3[0.6] JUL 1.0>0.6[1.0] AUG 1.0>0.5[1.0]
D8 BGO-SWF JUN 0.3>0.0[0.3]
D8 DUB-PVD MAY 1.0>0.4[0.7] JUN 1.0>0.4[0.7]
D8 DUB-SWF MAY 1.4>1.0[2] JUN 1.4>1.0[2]
*D8 ORK-PVD MAY 0.5>0[0.4] JUN 0.4>0[0.4]
*D8 PVD-SNN MAY 0.5>0[0.6] JUN 0.6>0.0[0.6]
*D8 SNN-SWF MAY 0.7>0[0.4] JUN 0.7>0[0.4]
DL ABE-DTW JAN 1.9>3[3]
DL ABQ-MSP JAN 0.1>0.3[0.1]
DL AMS-SEA OCT 1.5>1.8[1.5]
DL ASE-SLC NOV 0.7>1.0[2]
DL ATH-JFK SEP 1.1>2.0[1.3]
DL ATL-DAB JAN 4>5[4]
DL ATL-DFW SEP 10>8[10] OCT 10>9[10] NOV 10>9[9] DEC 10>8[10]
DL ATL-FCO OCT 1.0>1.8[0.9]
DL ATL-GDL MAY 0.7>1.0[0.7]
DL ATL-LAX JUL 12>13[13]
DL ATL-ONT JAN 1.1>1.9[0]
DL BIL-MSP SEP 3>1.8[2.0]
DL BIL-SLC SEP 3>4[3] OCT 3>4[3]
DL CLE-LGA JAN 4>5[4]
DL CVG-SEA SEP 0.9>0.7[0.7]
DL DLH-MSP SEP 6>5[5] OCT 7>6[5] NOV 6>5[4] DEC 6>4[4]
*DL DTW-HNL JAN 0.0>0.5[0]
DL DTW-JFK JAN 5>4[4]
DL DTW-SMF SEP 0.8>0.6[0]
DL DTW-STL OCT 5>4[5] NOV 5>4[5]
DL HNL-MSP JAN 0.2>0.6[0.7]
DL KOA-SEA NOV 0.8>0.5[0.7] DEC 0.8>0.6[0.8]
DL LAX-MEX MAY 1.0>3[1.0]
DL OKC-SLC OCT 2>1.8[1.8] NOV 2>1.6[1.8]
DL PDX-SEA JAN 7>8[7]
DL SAN-SEA SEP 5>4[4]
*ET ABJ-EWR JUN 0.4>0.2[0.4] JUL 0.5>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.5] NOV 0.4>0[0.4] DEC 0.4>0[0.5] JAN 0.4>0[0.4]
*ET ABJ-JFK JUN 0>0.2[0] JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
*ET IAH-LFW JUL 0>0.4[0] AUG 0>0.5[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
I think NOV is a partial month so I would ignore it
F9 ALB-DEN AUG 0.2>0.4[0] SEP 0>0.4[0.1] OCT 0>0.5[0.4]
F9 ALB-MCO AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0.4]
F9 ALB-RDU AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 ATL-AUS AUG 0.2>0.6[0.6] OCT 0>0.5[0.6] NOV 0>0.3[0.5]
F9 ATL-COS AUG 0.2>0.5[0.4] OCT 0>0.5[0] NOV 0>0.3[0]
F9 ATL-CVG AUG 0.2>0.4[0.7] SEP 0>0.4[0.6] OCT 0>0.5[0.6]
F9 ATL-DEN AUG 0.5>1.4[1.0] SEP 0>1.4[1.0] OCT 0>1.5[1.0] NOV 0>0.6[1.0]
F9 ATL-ISP AUG 0.2>0.6[0.2] SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.3[0]
F9 ATL-LAS AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 ATL-LAX AUG 0.2>0.4[0.4] OCT 0>0.5[0.4]
F9 ATL-LGA AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 ATL-MCO AUG 0.4>1.1[1.0] SEP 0>1.1[1.0] OCT 0>1.1[1.0] NOV 0>0.5[1.0]
F9 ATL-MIA AUG 0.2>0.4[0.4] OCT 0>0.5[0.4]
F9 ATL-PHL AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 ATL-SAT AUG 0.2>0.4[0.4] OCT 0>0.5[0.4]
F9 ATL-SLC AUG 0.2>0.6[0.6] OCT 0>0.5[0.6] NOV 0>0.3[0.5]
F9 ATL-TTN AUG 0.4>1.0[1.0] NOV 0>0.4[0.8]
F9 AUS-CVG SEP 0>0.3[0.4] OCT 0>0.3[0.4]
F9 AUS-DEN AUG 0.4>1.0[1.5] SEP 0>1.0[1.3] OCT 0>1.0[1.5] NOV 0>0.4[1.3]
F9 AUS-IAD AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.4] NOV 0>0.2[0.6]
F9 AUS-LAS AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 AUS-MSP AUG 0.2>0.5[0.5] OCT 0>0.5[0.4] NOV 0>0.3[0.2]
F9 AUS-MSY AUG 0.2>0.4[0.4] OCT 0>0.5[0.4]
F9 AUS-ONT AUG 0.2>0.6[0.6] NOV 0>0.2[0.4]
F9 AUS-ORD AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 AUS-PHL AUG 0.2>0.6[0.5] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.4]
F9 AUS-SAN AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.4]
F9 AUS-SEA AUG 0.2>0.4[0.5] OCT 0>0.5[0.4]
F9 AUS-SFO AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.3[0]
F9 AUS-SLC AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.4]
F9 AUS-SNA AUG 0.2>0.6[0.3] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.5]
F9 AUS-TPA AUG 0.2>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.5[0.0]
F9 BDL-DEN AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 BDL-MCO AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 BDL-RDU AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 BFM-DEN AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.2[0]
F9 BFM-ORD AUG 0.1>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
F9 BHM-DEN AUG 0.1>0.4[0.4] NOV 0>0.2[0.4]
F9 BHM-MCO OCT 0>0.5[0.3]
F9 BIL-DEN AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 BIS-DEN AUG 0.2>0.4[0.4] SEP 0>0.4[0.6] OCT 0>0.5[0.4]
F9 BKG-DEN AUG 0.2>0.5[0.4] NOV 0>0.3[0.2]
Season extended
*F9 BKG-DFW SEP 0>0.3[0] OCT 0>0.3[0]
*F9 BKG-ORD SEP 0>0.3[0] OCT 0>0.3[0]
F9 BMI-DEN AUG 0.2>0.4[0] SEP 0>0.4[0.1] OCT 0>0.5[0.4]
F9 BMI-MCO AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0.4]
F9 BNA-DEN AUG 0.4>1.0[0.6] SEP 0>1.0[0.9] OCT 0>1.0[0.6] NOV 0>0.4[0.8]
F9 BNA-LAS AUG 0.2>0.6[0.5] OCT 0>0.5[0.6] NOV 0>0.3[0.6]
F9 BNA-MCO AUG 0.2>0.5[0.5] SEP 0>0.6[0.8] OCT 0>0.5[0.9] NOV 0>0.3[0.9]
Kinda surprised this was extended with such light frequency
*F9 BNA-ORD SEP 0>0.3[0] OCT 0>0.3[0]
F9 BNA-PHL AUG 0.2>0.6[0.6] OCT 0>0.5[0.6] NOV 0>0.3[0.4]
F9 BOI-DEN SEP 0>0.3[0.4] OCT 0>0.3[0.4]
F9 BOS-DEN AUG 0.4>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.4[0]
F9 BOS-MCO AUG 0.4>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.4[0]
F9 BOS-RDU AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.3[0]
F9 BTV-DEN AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.2[0]
F9 BUF-DEN AUG 0.3>0.7[0.7] OCT 0>0.7[0.6] NOV 0>0.3[0.4]
F9 BUF-MCO AUG 0.4>1.0[0.7] SEP 0>1.0[0.6] OCT 0>1.0[0.6] NOV 0>0.4[0.8]
F9 BWI-DEN AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.3[0]
F9 BWI-MCO AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 BZN-DEN AUG 0.2>0.6[0.4] NOV 0>0.3[0.4]
*F9 CHS-CLE SEP 0>0.3[0] OCT 0>0.3[0]
F9 CHS-PHL AUG 0.2>0.4[0.5] SEP 0>0.4[0.6] OCT 0>0.5[0.6]
F9 CID-DEN AUG 0.2>0.6[0.7] SEP 0>0.7[0.8] NOV 0>0.3[0.5]
F9 CLE-LAS AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 CLE-MCO AUG 0.5>1.3[1.2] SEP 0>1.0[1.3] OCT 0>1.0[1.3] NOV 0>0.4[1.2]
F9 CLE-MSP AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.2]
F9 CLE-PHX AUG 0.2>0.6[0.1] SEP 0>0.6[0] OCT 0>0.6[0] NOV 0>0.2[0.5]
F9 CLE-RDU AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.2]
F9 CLE-RSW AUG 0.4>1.0[0.9] SEP 0>1.0[0.8] OCT 0>1.2[0.9] NOV 0>0.5[0.9]
F9 CLE-SAN AUG 0.1>0.3[0.2]
F9 CLE-SEA AUG 0.2>0.6[0.2]
F9 CLE-SFO AUG 0.2>0.4[0]
F9 CLE-SRQ AUG 0.1>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
F9 CLE-TPA AUG 0.5>1.4[1.0] SEP 0>1.4[1.0] OCT 0>1.5[1.0] NOV 0>0.6[1.0]
F9 CLT-DEN AUG 0.4>1.3[1.0] SEP 0>1.4[1.0] OCT 0>1.4[1.0] NOV 0>0.6[0.8]
*F9 CLT-LAS JUL 0>0.7[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.4[0]
F9 CLT-MCO AUG 0.2>0.6[0.6] OCT 0>0.5[0.6] NOV 0>0.3[0.8]
F9 CLT-PHL AUG 0.4>1.0[0.6] SEP 0>1.0[0.6] OCT 0>1.0[0.6] NOV 0>0.4[0.8]
F9 CLT-TTN AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.4]
F9 CMH-DEN AUG 0.2>0.5[0.6] SEP 0>0.6[0.8] OCT 0>0.5[0.6] NOV 0>0.3[0.4]
F9 CMH-MCO AUG 0.1>0.3[0.3] OCT 0>0.3[0.4]
F9 CMH-RDU AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 COS-IAD AUG 0.2>0.4[0.2] SEP 0>0.4[0] OCT 0>0.5[0]
F9 COS-LAS AUG 0.5>1.3[1.0] SEP 0>1.3[1.0] OCT 0>1.3[1.0] NOV 0>0.6[1.0]
F9 COS-MCO AUG 0.2>0.6[0.6] SEP 0>0.6[0.5] OCT 0>0.6[0.5] NOV 0>0.3[0.6]
F9 COS-MSP AUG 0.2>0.4[0.4] OCT 0>0.5[0]
F9 COS-PHX AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 COS-SAT AUG 0.2>0.6[0.6] OCT 0>0.5[0] NOV 0>0.3[0]
F9 CUN-DEN AUG 0.2>0.6[1.0] NOV 0>0.3[0.9]
F9 CUN-ORD AUG 0.4>0.7[1.0] SEP 0>0.6[1.0] OCT 0>0.5[1.0] NOV 0>0.3[1.0]
F9 CUN-PHL AUG 0.2>0.4[0.6] SEP 0>0.4[0.6] NOV 0>0.2[0.6]
F9 CUN-STL AUG 0.3>0.6[1.0] SEP 0>0.4[1.0] OCT 0>0.5[1.0]
F9 CVG-DEN AUG 0.4>1.1[1.0] NOV 0>0.4[0.8]
F9 CVG-JAX AUG 0.1>0.3[0.5] SEP 0>0.3[0.6] OCT 0>0.3[0.6]
F9 CVG-LAS AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 CVG-LGA AUG 0.4>1.0[1.0] NOV 0>0.4[0.5]
F9 CVG-MCO AUG 0.4>1.1[1.3] SEP 0>1.1[1.4] OCT 0>1.1[1.4] NOV 0>0.5[1.2]
F9 CVG-MSP AUG 0.2>0.4[0.4] SEP 0>0.4[0.3] OCT 0>0.4[0.3] NOV 0>0.2[0.1]
F9 CVG-PHL AUG 0.2>0.4[0.2] SEP 0>0.4[0] OCT 0>0.5[0]
F9 CVG-PHX AUG 0.1>0.4[0.2] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.2[0.3]
F9 CVG-RDU SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 CVG-RSW AUG 0.2>0.5[0.6] SEP 0>0.4[0.6] OCT 0>0.5[0.6] NOV 0>0.3[0.8]
F9 CVG-SAN AUG 0.1>0.3[0.4]
F9 CVG-SFO AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 CVG-TPA AUG 0.2>0.6[0.5] SEP 0>0.6[0.4] OCT 0>0.7[0.4] NOV 0>0.3[0.4]
F9 DCA-DEN AUG 1.1>3[3] NOV 0>1.3[3]
F9 DEN-DFW AUG 0.7>2[1.2] SEP 0>2[1.1] OCT 0>2[1.3] NOV 0>0.9[1.0]
F9 DEN-DSM AUG 0.2>0.5[0.7] OCT 0>0.5[0.6] NOV 0>0.3[0.6]
F9 DEN-DTW AUG 0.4>1.0[1.0] NOV 0>0.4[0.5]
F9 DEN-FAR AUG 0.1>0.4[0.4] NOV 0>0.2[0.4]
F9 DEN-FAT AUG 0.2>0.4[0.4] OCT 0>0.5[0.3]
F9 DEN-FLL AUG 0.4>0.8[0] SEP 0>0.7[0] OCT 0>0.8[0] NOV 0>0.4[0]
F9 DEN-FSD AUG 0.2>0.6[0.6] OCT 0>0.5[0.6] NOV 0>0.3[0.5]
F9 DEN-GRB AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 DEN-GRR AUG 0.2>0.6[0.4] OCT 0>0.5[0.6] NOV 0>0.3[0.5]
F9 DEN-GSP AUG 0.2>0.5[0] SEP 0>0.4[0.2] OCT 0>0.4[0.3] NOV 0>0.2[0.3]
F9 DEN-HRL AUG 0.1>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
F9 DEN-HSV SEP 0>0.3[0] OCT 0>0.5[0.3]
F9 DEN-IAD AUG 0.4>1.0[1.0] NOV 0>0.4[0.5]
F9 DEN-IAH AUG 0.7>2[1.0] SEP 0>2[1.0] OCT 0>2[1.0] NOV 0>0.9[1.0]
F9 DEN-ICT AUG 0.2>0.4[0.0] OCT 0>0.5[0.4]
F9 DEN-IND AUG 0.4>1.0[0.4] SEP 0>1.0[0.4] OCT 0>1.0[0.5] NOV 0>0.4[0.5]
F9 DEN-JAC AUG 0.2>0.4[0.4] OCT 0>0.2[0]
F9 DEN-JAN AUG 0.1>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0.2]
F9 DEN-JAX AUG 0.2>0.6[0.6] SEP 0>0.6[0.7] OCT 0>0.5[0.6] NOV 0>0.2[0.4]
F9 DEN-LAS AUG 1.0>3[3] SEP 0>4[3] OCT 0>4[3] NOV 0>1.6[3]
F9 DEN-LAX AUG 0.7>2[2] NOV 0>0.9[1.7]
F9 DEN-LFT AUG 0.1>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0.1]
F9 DEN-LGA AUG 0.4>1.0[1.0] NOV 0>0.4[0.5]
F9 DEN-MCI AUG 0.4>1.0[1.0] NOV 0>0.4[0.8]
F9 DEN-MCO AUG 0.7>2[1.0] SEP 0>2[1.3] OCT 0>2[1.7] NOV 0>0.9[2]
F9 DEN-MDT AUG 0.1>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.4[0.3] NOV 0>0.2[0.1]
F9 DEN-MEM AUG 0.2>0.6[0.6] SEP 0>0.6[0.7] OCT 0>0.5[0.6] NOV 0>0.3[0.6]
F9 DEN-MIA AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 DEN-MKE AUG 0.4>1.3[1.0] SEP 0>1.4[1.0] OCT 0>1.5[1.0] NOV 0>0.6[0.8]
F9 DEN-MSN AUG 0.2>0.6[0.5] OCT 0>0.7[0.6] NOV 0>0.3[0.5]
F9 DEN-MSP AUG 0.7>2[2] NOV 0>0.9[1.9]
F9 DEN-MSY AUG 0.4>1.0[0.6] OCT 0>1.0[0.7] NOV 0>0.4[1.0]
F9 DEN-OKC AUG 0.2>0.4[0.6] SEP 0>0.4[0.6] OCT 0>0.5[0.6]
F9 DEN-OMA AUG 0.3>0.7[1.0] SEP 0>0.7[0.9] OCT 0>0.7[0.8] NOV 0>0.3[0.6]
F9 DEN-ONT AUG 0.4>0.8[1.0] SEP 0>0.7[1.0] NOV 0>0.4[0.7]
F9 DEN-ORD AUG 0.7>2[1.7] NOV 0>0.9[1.4]
F9 DEN-ORF AUG 0.2>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 DEN-PDX AUG 0.7>2.0[1.8] SEP 0>2[1.7] OCT 0>2[1.7] NOV 0>0.9[1.5]
F9 DEN-PHL AUG 0.4>1.0[1.1] NOV 0>0.4[1.0]
F9 DEN-PHX AUG 0.7>2[1.6] SEP 0>2[1.9] NOV 0>0.9[2]
F9 DEN-PIT AUG 0.2>0.4[0.4] SEP 0>0.4[0.5] OCT 0>0.5[0.4]
F9 DEN-PNS AUG 0.2>0.4[0.4] OCT 0>0.5[0.4]
F9 DEN-PVD AUG 0.2>0.4[0.7] SEP 0>0.4[0.6] OCT 0>0.5[0.6]
F9 DEN-RDU AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 DEN-RNO AUG 0.2>0.4[0.6] SEP 0>0.4[0.6] OCT 0>0.5[0.6]
F9 DEN-RSW AUG 0.2>0.5[0.3] SEP 0>0.4[0.3] OCT 0>0.6[0.3] NOV 0>0.2[0.7]
F9 DEN-SAN AUG 0.7>2[1.7] NOV 0>0.9[2.0]
F9 DEN-SAT AUG 0.4>1.0[0.6] NOV 0>0.4[1.0]
F9 DEN-SBA AUG 0.2>0.4[0.2] OCT 0>0.5[0.4]
F9 DEN-SDF AUG 0.2>0.6[0.6] NOV 0>0.2[0.4]
F9 DEN-SEA AUG 0.7>2[1.6] SEP 0>2[1.6] OCT 0>2[1.6] NOV 0>0.9[1.4]
F9 DEN-SFO AUG 0.9>2[1.6] SEP 0>2[1.6] OCT 0>2[1.5] NOV 0>1.0[1.4]
F9 DEN-SJC AUG 0.2>0.5[1.0] SEP 0>0.6[1.0] OCT 0>0.5[1.0] NOV 0>0.3[0.6]
F9 DEN-SLC AUG 0.8>2[3] SEP 0>2[3] OCT 0>2[4] NOV 0>1.0[3]
F9 DEN-SMF AUG 0.2>0.5[0.5] OCT 0>0.5[0.6] NOV 0>0.3[0.5]
F9 DEN-SNA AUG 0.5>1.4[1.4] SEP 0>1.4[1.0] OCT 0>1.5[1.0] NOV 0>0.6[1.0]
F9 DEN-STL AUG 0.7>2[1.0] SEP 0>2[1.0] OCT 0>2[1.0] NOV 0>0.9[0.8]
F9 DEN-SYR AUG 0.2>0.6[0.4] SEP 0>0.6[0.3] OCT 0>0.5[0.3] NOV 0>0.3[0.1]
F9 DEN-TPA AUG 0.4>1.0[0.6] SEP 0>1.0[0.6] OCT 0>1.0[0.6] NOV 0>0.4[1.1]
F9 DEN-TUL AUG 0.2>0.5[0.4] NOV 0>0.2[0.5]
*F9 DEN-TYR JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 DEN-TYS AUG 0.2>0.6[0.5] OCT 0>0.5[0.4] NOV 0>0.3[0.4]
F9 DFW-LAS AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.3[0]
F9 DFW-MCO AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.3[0]
F9 DFW-PHL AUG 0.2>0.4[0.1] SEP 0>0.4[0] OCT 0>0.5[0]
F9 DTW-LAS JUN 0.5>0.7[0] JUL 0.4>0.7[0] AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.3[0]
F9 DTW-MCO AUG 0.2>0.6[0.6] OCT 0>0.5[0.9] NOV 0>0.3[0.7]
F9 DTW-RDU AUG 0.2>0.5[0.4]
F9 DTW-TTN AUG 0.2>0.4[0.6] SEP 0>0.4[0.6] OCT 0>0.5[0.6]
F9 GEG-LAS AUG 0.2>0.4[0.2] SEP 0>0.4[0.3] OCT 0>0.4[0.3] NOV 0>0.2[0.3]
F9 GRR-MCO AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.5[0.6] NOV 0>0.3[0.8]
F9 HRL-ORD AUG 0.1>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
F9 HSV-MCO SEP 0>0.3[0] OCT 0>0.5[0.2]
F9 IAD-LAS AUG 0.2>0.4[0.7] SEP 0>0.4[0.5] OCT 0>0.5[0.4]
F9 IAD-MCO AUG 0.2>0.5[0.5] SEP 0>0.6[0.5] OCT 0>0.6[0.4] NOV 0>0.2[0.7]
F9 IAD-SAT AUG 0.1>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.4[0.3] NOV 0>0.2[0.1]
F9 IAH-LAS AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 IAH-MCO AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 IAH-PHL AUG 0.2>0.6[0.2] SEP 0>0.6[0] OCT 0>0.6[0] NOV 0>0.3[0]
F9 IAH-RDU AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.4]
F9 IND-LAS AUG 0.2>0.4[0.5] OCT 0>0.5[0.4]
F9 IND-MCO AUG 0.2>0.6[0.7] SEP 0>0.6[0.7] OCT 0>0.5[0.7] NOV 0>0.3[0.6]
F9 ISP-MCO AUG 0.4>1.0[1.0] OCT 0>1.0[0.9] NOV 0>0.4[1.1]
F9 ISP-MYR AUG 0.2>0.5[0.5] OCT 0>0.5[0.4]
F9 ISP-PBI AUG 0.2>0.4[0.2] SEP 0>0.4[0] OCT 0>0.5[0]
F9 ISP-RDU AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 ISP-TPA AUG 0.2>0.5[0.5] SEP 0>0.6[0.4] NOV 0>0.3[0.5]
F9 JAN-MCO AUG 0.1>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0.1]
F9 JAX-LAS AUG 0.2>0.6[0.6] SEP 0>0.6[1.0] OCT 0>0.5[0.6] NOV 0>0.3[0.6]
F9 JAX-ORD AUG 0.2>0.4[0.4] OCT 0>0.5[0.3]
F9 JAX-PHL AUG 0.2>0.6[0.5] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.4]
F9 JAX-RDU AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 JAX-TTN AUG 0.2>0.4[0.4] OCT 0>0.5[0.4]
F9 LAS-MCO AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 LAS-MKE SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 LAS-MSN AUG 0.2>0.4[0.4] OCT 0>0.5[0.4]
F9 LAS-OMA AUG 0.2>0.4[0.3] OCT 0>0.5[0.4]
F9 LAS-ORD AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 LAS-PHL AUG 0.4>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.4[0]
F9 LAS-RDU AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 LAS-SAN AUG 0.3>0.8[0] SEP 0>0.9[0] OCT 0>0.8[0] NOV 0>0.4[0]
F9 LAS-SAT AUG 0.2>0.8[0.4] SEP 0>1.0[0.4] OCT 0>1.0[0.6] NOV 0>0.4[0.5]
F9 LAS-SFO AUG 0.2>0.8[0.4] SEP 0>1.0[0.4] OCT 0>1.0[0.4] NOV 0>0.4[0.5]
F9 LAS-SLC AUG 0.2>0.4[0.4] SEP 0>0.4[0.3] OCT 0>0.5[0.4]
F9 LAS-SMF AUG 0.4>0.9[0.3] SEP 0>1.0[0.3] OCT 0>1.0[0.3] NOV 0>0.4[0.3]
F9 LAS-STL AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 LAS-TPA AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 MCI-PHL AUG 0.2>0.4[0.4] OCT 0>0.5[0.4]
F9 MCO-MDT AUG 0.1>0.4[0.3] NOV 0>0.2[0.4]
F9 MCO-MKE AUG 0.4>1.0[0.6] SEP 0>1.0[0.4] OCT 0>1.0[0.7] NOV 0>0.4[0.8]
F9 MCO-MSP AUG 0.4>0.8[0] SEP 0>0.7[0] OCT 0>1.0[0] NOV 0>0.4[0.3]
F9 MCO-MSY AUG 0.2>0.4[0.7] SEP 0>0.4[0.7] OCT 0>0.5[0.7]
F9 MCO-ONT AUG 0.4>0.8[0.6] SEP 0>0.7[1.0] NOV 0>0.4[1.0]
F9 MCO-ORD AUG 0.4>1.0[1.0] OCT 0>1.2[1.0] NOV 0>0.5[1.0]
F9 MCO-PHL JUL 3>4[3] AUG 1.0>3[2] SEP 0>4[2] OCT 0>4[3] NOV 0>1.6[3]
F9 MCO-PSM AUG 0.2>0.4[0] SEP 0>0.3[0] OCT 0>0.3[0]
F9 MCO-PUJ AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.2[0]
F9 MCO-PVD AUG 0.2>0.6[0.7] OCT 0>0.5[0.6] NOV 0>0.3[0.7]
F9 MCO-RDU AUG 0.4>0.9[0.6] SEP 0>0.9[0.7] OCT 0>1.0[0.7] NOV 0>0.4[0.9]
F9 MCO-SAN AUG 0.4>1.0[0] OCT 0>0.5[0] NOV 0>0.4[0.5]
F9 MCO-SAT AUG 0.2>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 MCO-SJU AUG 0.2>0.9[0.5] SEP 0>1.0[0.5] OCT 0>1.0[0.5] NOV 0>0.4[0.5]
F9 MCO-STL AUG 0.4>1.0[1.0] NOV 0>0.4[1.0]
F9 MCO-SYR AUG 0.2>0.4[0.3] OCT 0>0.5[0.3]
F9 MCO-TTN AUG 0.4>1.0[1.0] NOV 0>0.4[1.3]
F9 MEM-PHL AUG 0.1>0.3[0.3]
F9 MIA-PHL AUG 0.2>0.6[0.2] SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.3[0.4]
F9 MKE-PHL AUG 0.2>0.4[0.4] SEP 0>0.4[0.3] OCT 0>0.5[0.0]
F9 MKE-RDU AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.4]
F9 MSN-PHL AUG 0.1>0.3[0.4]
F9 MSP-TTN AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.2]
F9 MSY-PHL AUG 0.3>0.7[0.6] SEP 0>0.7[0.6] OCT 0>0.7[0.6] NOV 0>0.3[0.7]
F9 MYR-PHL AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 ONT-SAT AUG 0.1>0.4[0.4] NOV 0>0.2[0.4]
F9 ORD-PHX AUG 0.2>0.7[0.7] SEP 0>0.7[0.6] OCT 0>0.9[0.6] NOV 0>0.4[0.5]
F9 ORD-PUJ NOV 0>0.4[1.0]
F9 ORD-SYR AUG 0.2>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 ORD-TPA AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0.4]
F9 ORD-TTN AUG 0.4>1.0[1.0] NOV 0>0.4[0.5]
F9 PBI-RDU AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 PBI-TTN AUG 0.2>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 PHL-PNS AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 PHL-PUJ AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] NOV 0>0.2[0.4]
F9 PHL-RDU AUG 0.2>0.4[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 PHL-RSW AUG 0.4>0.8[0.5] SEP 0>0.7[0.4] OCT 0>1.0[0.6] NOV 0>0.4[0.9]
F9 PHL-SAV AUG 0.2>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 PHL-SJU AUG 0.2>0.8[0.5] SEP 0>1.0[0.5] OCT 0>1.0[0.5] NOV 0>0.4[0.5]
F9 PHL-TPA AUG 0.4>1.0[0.6] SEP 0>1.0[0.4] OCT 0>1.0[0.4] NOV 0>0.4[0.8]
F9 PVD-RDU AUG 0.2>0.4[0.4] OCT 0>0.5[0.4]
F9 RDU-SAN AUG 0.2>0.4[0.2]
F9 RDU-SYR AUG 0.2>0.5[0.3] SEP 0>0.4[0.3] OCT 0>0.4[0.3] NOV 0>0.2[0.1]
F9 RDU-TPA AUG 0.2>0.5[0] SEP 0>0.4[0] OCT 0>0.5[0]
F9 RDU-TTN AUG 0.2>0.5[0.6] OCT 0>0.5[0.6] NOV 0>0.3[0.4]
F9 RSW-TTN AUG 0.2>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 SAN-SAT AUG 0.2>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 TPA-TTN AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.5[0.4] NOV 0>0.3[0.6]
Is MCI the only USA route to gain KEF last year that still has it?
*FI CLE-KEF MAY 0.3>0.0[0.4]
G3 FOR-MCO MAY 0.6>0.2[0] JUN 0.7>0.4[0] AUG 0.9>0.1[0] SEP 0.9>0.2[0]
G3 FOR-MIA MAY 0.4>0[0] JUN 0.6>0.3[0]
I guess they mistakenly published their charters last week
G4 CUN-PIT MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.3>0[0]
G4 PIT-PUJ MAY 0.3>0[0] JUN 0.3>0[0] JUL 0.3>0[0] AUG 0.2>0[0]
GV AKN-EGX MAY 0.4>4[0.9] JUN 0.4>4[1.0] JUL 0.4>4[1.0] AUG 0.4>4[1.0] SEP 0.4>0[1.0] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV AKN-IGG SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV AKN-KCG SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV AKN-KLL SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV AKN-PTH SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV AKN-UGB SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV BET-DLG JUN 0>0.3[0] JUL 0>0.4[0] AUG 0>0.5[0]
GV BET-KWK MAY 0.1>1.4[1.4] JUN 0.1>1.4[1.9] JUL 0.1>1.4[1.9] AUG 0.1>1.4[1.9] SEP 0.1>1.4[1.9] OCT 0.1>0.9[1.0] NOV 0.1>0.5[1.0] DEC 0.1>0.5[1.0] JAN 0.1>0.5[1.0]
GV BET-SCM OCT 1.8>1.4[2] NOV 1.8>1.4[2] JAN 1.8>1.4[2]
GV BET-VAK OCT 1.8>1.4[2] NOV 1.8>1.4[2] JAN 1.8>1.4[2]
GV BET-WTL MAY 0.1>1.4[1.4] JUN 0.1>1.4[1.9] JUL 0.1>1.4[1.9] AUG 0.1>1.4[1.9] SEP 0.1>1.4[1.9] OCT 0.1>0.9[1.0] NOV 0.1>0.5[1.0] DEC 0.1>0.5[1.0] JAN 0.1>0.5[1.0]
GV CLP-DLG SEP 0.8>0.4[1.4] OCT 0.9>0.4[1.7] NOV 0.9>0.4[1.7] DEC 0.8>0.4[1.7] JAN 0.9>0.4[1.7]
GV CLP-KMO SEP 0.8>0.4[0] OCT 0.9>0.4[0] NOV 0.9>0.4[0] DEC 0.8>0.4[0] JAN 0.9>0.4[0]
GV DLG-KMO SEP 1.7>1.3[0] OCT 1.7>1.3[0] NOV 1.7>1.3[0] DEC 1.7>1.3[0] JAN 1.7>1.3[0]
GV DLG-TOG MAY 0.9>1.4[1.0] JUN 0.8>1.4[1.0] JUL 0.9>1.4[1.0] AUG 0.9>1.4[1.0] SEP 0.8>0[1.0] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.8>0[0.8] JAN 0.9>0[0.9]
GV DLG-TWA MAY 0.9>1.4[1.0] JUN 0.8>1.4[1.0] JUL 0.9>1.4[1.0] AUG 0.9>1.4[1.0] SEP 0.8>0[1.0] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.8>0[0.8] JAN 0.9>0[0.9]
GV DUT-STG MAY 0.2>0.4[0] JUN 0.2>0.4[0] JUL 0.2>0.4[0] AUG 0.2>0.4[0] SEP 0.2>0.4[0] OCT 0.2>0.5[0] DEC 0.2>0.5[0.2] JAN 0.2>0.4[0.2]
GV EGX-PIP SEP 0.4>0[0] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV HPB-SCM OCT 1.8>1.4[2] NOV 1.8>1.4[2] JAN 1.8>1.4[2]
GV HPB-VAK OCT 1.8>1.4[2] NOV 1.8>1.4[2] JAN 1.8>1.4[2]
GV IGG-KLL SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV KCG-KCL SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV KCL-KCQ SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV KCQ-KPV SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV KKH-KWK MAY 0.1>1.4[1.4] JUN 0.1>1.4[1.9] JUL 0.1>1.4[1.9] AUG 0.1>1.4[1.9] SEP 0.1>1.4[1.9] OCT 0.1>0.9[1.0] NOV 0.1>0.5[1.0] DEC 0.1>0.5[1.0] JAN 0.1>0.5[1.0]
GV KKH-WTL MAY 0.1>1.4[1.4] JUN 0.1>1.4[1.9] JUL 0.1>1.4[1.9] AUG 0.1>1.4[1.9] SEP 0.1>1.4[1.9] OCT 0.1>0.9[1.0] NOV 0.1>0.5[1.0] DEC 0.1>0.5[1.0] JAN 0.1>0.5[1.0]
GV KPV-PTH SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV PIP-UGB SEP 0.4>0[0.5] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
GV SNP-STG MAY 0.7>0.4[0] JUN 0.7>0.4[0] JUL 0.6>0.4[0] AUG 0.6>0.4[0] SEP 0.7>0.4[0] NOV 0.7>0.4[0.7] JAN 0.7>0.4[0.6]
GV TOG-TWA MAY 0.9>1.4[1.0] JUN 0.8>1.4[1.0] JUL 0.9>1.4[1.0] AUG 0.9>1.4[1.0] SEP 0.8>0[1.0] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.8>0[0.8] JAN 0.9>0[0.9]
*KL AMS-LAS NOV 0>0.4[0] DEC 0>0.5[0] JAN 0>0.3[0.0]
LH FRA-ORD NOV 1.0>2[1.0] DEC 0.8>1.5[0.8] JAN 1.0>2[1.0]
UA BOS-SFO MAY 7>5[7]
UA BWI-SFO JAN 1.9>1.2[1.2]
UA BZN-IAH JAN 0.3>0.5[0.4]
UA CLE-SFO JAN 2>1.3[1.2]
UA CNY-DEN OCT 1.7>2[1.7]
UA GUA-IAH JUN 3>2[2] JUL 3>2[3]
UA IAH-JAC JAN 0.3>0.5[0.4]
UA IAH-LAS MAY 7>6[7]
UA IAH-LAX MAY 10>8[10]
UA IAH-MSY MAY 8>7[8]
UA IAH-NAS SEP 0>0.4[0] OCT 0.1>0.5[0.1]
UA IAH-PVR JUN 2>1.3[2.0] JUL 2>1.3[2] AUG 1.8>1.3[1.8]
UA IAH-SFO MAY 9>8[9]
UA IAH-SJD JUL 3>2[3] AUG 2>2.0[3]
UA IND-SFO NOV 1.8>0.9[1.8] DEC 1.9>0.9[1.9] JAN 1.9>0.9[1.2]
UA ITO-LAX OCT 0.7>0.9[0.7]
UA LAX-SGU OCT 1.9>1.0[1.0] NOV 2>1.0[1.1] DEC 2>1.0[1.0] JAN 2>1.0[1.0]
UA OMA-SFO NOV 2>1.0[1.0] DEC 2>1.0[1.0] JAN 2>1.0[1.0]
UA PIT-SFO DEC 2>1.1[1.4] JAN 2>1.0[1.2]
UA SFO-SJD SEP 0.6>1.0[0.6]
*VC BFM-SFB MAY 0>0.6[0] JUN 0>0.6[0] JUL 0>0.5[0] AUG 0>0.6[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0]
*VC MOB-SFB MAY 0.6>0[0.3] JUN 0.6>0[0.6] JUL 0.5>0[0.6] AUG 0.6>0[0.3] SEP 0.3>0[0.6] OCT 0.3>0[0.5] NOV 0.3>0[0.6] DEC 0.3>0[0.6] JAN 0.3>0[0.5]
VS ATL-MAN NOV 0.7>0.5[0.4] DEC 0.7>0.5[0.5]
VS BOS-MAN OCT 0.4>0.1[0.1]
Wynnster8
Re: OAG Changes 4/7/2019:AA Further Trims JFK;D8 Suspends PVD-ORK/SNN.SNN-SWF;ET Moves ABJ from EWR to JFK;VC SFB-MOB>BF
Sun Apr 07, 2019 12:06 pm
How much longer will AA have a hub at JFK?
Favorite plane is 757-200 Favorite airport is Singapore Favorite route is SYD-JNB
eaa3
Sun Apr 07, 2019 12:17 pm
[quote="enilria"]
/quote]
No, SFO is still there. Remember that there were two seperate times in which these routes were added. CLE and DFW were added in the fall of 2017, and then BWI, SFO and MCI were added in January. Only BWI is gone of the january addition. All of these routes started in May/June 2018.
Cointrin330
Sun Apr 07, 2019 12:21 pm
Since the merger with US, AA does not consider JFK a hub. It's an O&D station and that's about it.
EK77WNH
Sun Apr 07, 2019 12:24 pm
5 is the lightest I’ve seen UA go on BOS-SFO.They may be signaling that there’s too much metal flying between these cities.
Next Trip:
JAL 7-8 BOS-NRT-BOS, 787-9
September
Boof02671
Sun Apr 07, 2019 12:32 pm
Could AA’s cuts be due to the runway closure?
flyPIT
No error according to http://www.aa.com
4x daily E140s in Dec and Jan
FLYi
tomaheath
Sun Apr 07, 2019 12:33 pm
Do they still put a 777 in peak season?
EssentialBusDC
Sun Apr 07, 2019 12:35 pm
It’s for May, so most likely due to the Max groundings and having to shuffle around exisitng airframes to cover the flying.
MIflyer12
Sun Apr 07, 2019 12:47 pm
So they call LGA a hub then? Right from an AA press release less than a week old:
American has hubs in Charlotte, Chicago, Dallas/Fort Worth, Los Angeles, Miami, New York, Philadelphia, Phoenix and Washington, D.C.
QF744
Sun Apr 07, 2019 1:10 pm
Interesting to see SAN dropping off a lot from three key AA destinations... market softening?
OVER 150 FLIGHTS PER YEAR.
jasoncrh
Sun Apr 07, 2019 1:19 pm
There’s a runway closure at JFK from May-November. Most carriers will reduce frequencies during that time as there simply isn’t enough runway capacity.
Runway28L
Sun Apr 07, 2019 1:27 pm
Considering BA added PIT-LHR and AA is upping capacity on PIT-LGA, I’m really surprised they are adding frequency on this route.
Midwestindy
Sun Apr 07, 2019 1:37 pm
I think it is an error in the booking system as JFK-PHL also appears to be going from completely cut to 5r/t in the dead of winter which wouldn't make sense.
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
AVLAirlineFreq
A bunch of close-in cuts for May for AA. I assume these are MAX related.
golfingboy
Sun Apr 07, 2019 1:47 pm
Looks like AA is just boosting up PIT/BWI in December to squat on slots until they figure out how to use those slots. AA has cut down JFK considerably so I am sure they have quite few slots sitting around that they don't want to give up too easily, especially when UA is talking about re-entering JFK most likely adding further competition on AA's bread and butter SFO/LAX flights.
The runway closure came at a perfect time for AA as they have a good excuse to not use those slots without risking forfeiture, but come December its a different ball game.
malev2012
Sun Apr 07, 2019 1:59 pm
No doubt this close in they are max related. However it shows that JFK is the weakest link. B6 and DL fly against them on many of these routes. It seems that AA is turning into the incredible shrinking airline in New York.
Airlines flown: AA, AB, AC, AY, BA, CO, DL, DY, EW, F9, G4, IB, KL, LH, LX, NK, NW, NZ, OS, QF, SN, TP, UA, US, VA, VC, WN, XE
PVD757
Sun Apr 07, 2019 2:28 pm
The D8 cuts are related to the MAX groundings.
panamair
Sun Apr 07, 2019 2:46 pm
The runway closure has been known for a long time. Why would changes for summer only be made now when carriers have been informed quite some time ago? Also, why haven't B6 and DL reduced summer flights at JFK to the degree AA has been doing?
The below link was from Sep 2018 and at that time, the timeframe (April till end 2019) was already known:
https://www.6sqft.com/port-authority-ap ... d-taxiway/
iyerhari
Sun Apr 07, 2019 2:47 pm
enrilria - thank you for all your efforts. Looks like you waking up and compiling the info sooner is getting better responses from everyone :)
Prime O&D taken over by B6 and DL IMO. This makes the story even more clearer - very few pax choose JFK using AA to take connections. Maybe
Related to MAX or because of their dire financial status?
Reduction here to account for LGW?
FlyingElvii
Sun Apr 07, 2019 2:58 pm
UA cutting back IND-SFO, and AA cutting the second LAX daily. Meanwhile, Frontier seems to be beefing up CVG. The CVG-RDU is interesting...
FlyingElvii
Sun Apr 07, 2019 3:00 pm
JFK is going to be an operational nightmare this summer. I am dreading the first rounds of NYC thunderstorms.
FlyingElvii
Sun Apr 07, 2019 3:02 pm
Agreed...
These are easy Xcls when you need to free up some space, when the edicts hit.
mfe777
Sun Apr 07, 2019 3:07 pm
/quote]
DFW still has KEF. American Airlines, seasonal. 3 carriers jumped on the route, one is left.
Chuska
Sun Apr 07, 2019 3:08 pm
4A, California Pacific, shut down a couple months ago. I think we can ignore all of their cutbacks as they've already happened.
Enilria, kudos to you each and every week!
HVNandrew
Sun Apr 07, 2019 3:16 pm
BOS-JFK is not heavily O&D; most of the BOS-NYC O&D traffic is to LGA (the shuttle flights). The JFK flights are used primarily to feed connections.
I think the cuts speak more to AA refocusing its attention away from connections at JFK and towards the core NYC O&D market (which they still serve quite well).
PVD757
Sun Apr 07, 2019 3:45 pm
Fairly well publicized that these are MAX related. These routes are all operated with the MAX, are close in cuts, and are currenty in the schedule after June.
MAH4546
Sun Apr 07, 2019 3:56 pm
Context guys! A lot of these cuts are only for April/May when the 737MAX is grounded and airlines have to plan appropriately.
a.
Scarebus34
Sun Apr 07, 2019 4:00 pm
And yes while AA has been cutting JFK lately, these are just operational cuts due to runway construction. It’s going to be a nightmare, might as well cut some flights to lessen the pain. But hey, let all the conspiracy theorists have their fun.
DanDun
Sun Apr 07, 2019 4:16 pm
AA has will now cancel an additional 90 flights a day through June 5, many of these JFK Cuts are Max related.
malev2012
Sun Apr 07, 2019 4:19 pm
They wouldn't be cutting these if they were profitable, right? We aren't seeing similar cuts by DL/B6 at JFK.
tphuang
Sun Apr 07, 2019 4:27 pm
There is plenty of O&D between BOS-JFK. Plenty of New Yorkers and LI people that prefer JFK over LGA.
Some of it is Max related, but more than not, those routes are just bleeding money and are not going to stick around much longer. JFK-SEA might have been the single lowest yielding transcon route in AA's entire network in Q4. Even worse than ATL/MCO-LAX.
Again, B6 and DL make no cuts at all.
AA somehow found enough capacity to add to JFK-ORD from May on, but cut actual business markets SEA/SAN and BOS/RDU.
If you have seen the numbers I posted out of JFK, this would not be a surprise at all.
Also, the Dec/Jan adds are just slot squatting moves. AA needs to figure out how to keep those slots around since it's down to 80 flights in peak summer season.
Scarebus34
Sun Apr 07, 2019 4:30 pm
Well it would make sense to me to cut your least profitable routes ahead of expected operational challenges.
FSDan
Sun Apr 07, 2019 5:40 pm
The AA JFK cuts are just extending the June schedule through most of the rest of the year. No new cuts that I can see beyond what we already discussed in previous weeks.
This is my signature until I think of a better one.
flyPIT
Sun Apr 07, 2019 5:43 pm
I think it is a simple matter of AA wanting to put up a fight against DL in the important PIT-NYC market. DL has been very aggressive with PIT-LGA. Perhaps a lack of slots and/or the terminal reconstruction at LGA is limiting AA from adding frequency so they are adding at JFK to match the capacity DL already offers there? If they are simply sitting on JFK slots then why the cuts at CLE, BOS, and elsewhere? We'll see if these adds stick.
FLYi
EA CO AS
Sun Apr 07, 2019 6:02 pm
Man, the cuts by AS at SFO just keep coming! Oh, wait...
klm617
Sun Apr 07, 2019 6:20 pm
Only four flights a day on DTW-STL from your hub carrier is pretty laughable
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
MAH4546
Sun Apr 07, 2019 6:36 pm
I can’t speak to that, no idea. I assume JFK is a money losing operation, AA offer a poor ULCC product, unlike B6 and DL, so I assume the others can command strong revenue premium. But I also know that cutting stuff like JFKBOS and JFKPHL is easy, because it’s mostly connecting traffic that can be rerouted.
Neither DL nor B6 have Max jets, of course they are not cutting.
a.
YellowJ
Based upon my observations passing through JFK 2 days ago; runway 13L/31R is already closed.
enilria
Sun Apr 07, 2019 6:49 pm
I bet AA was first to volunteer in order to not lose slots. I don’t see much of this stuff coming back.
Oh I get up about the same time each week. They have become consistent again on the release time of the data. It goes through periods where the time of availability moves around. Don’t know why.
Agreed on Norwegian. If you are talking about AA, I think they would cut the worst flying which is apparently JFK. Norwegian doesn’t really have a choice of what to cut except with the 787 now operating SWF-DUB.
Exactly. I think that’s 90% of what everybody is going. I would like to see WN’s cuts.
So I’ve mentioned this before, but after the VP of network at AS left in NOV they have basically frozen these sorts of strategy changes until the job is filled. It still is not, but will be soon. I think SFO’s future is job one for the new person. So they are in a holding pattern.
Rdh3e
Sun Apr 07, 2019 6:57 pm
This just reverses cuts from last week. AS has not made a meaningful schedule update in over a month. Something is obviously going on. Either something is wrong in their process or they are planning a big announcement.
Enilria, not to heap more on you, but do you think you could start including a link to the previous week's thread in your initial post each week?
AirFiero
Sun Apr 07, 2019 7:19 pm
Yeah. ONE flight. Oooohhh.
Rdh3e
I've just looked back:
2/17: last real update viewtopic.php?f=3&t=1415825
2/24: Added one LAX-DAL Sep-Nov
3/3: One small change to August ANC-SCC
3/10: no changes
3/17: One June change to ANC-DUT
3/24: no changes
3/31: just the SNA cut
4/7: just the SNA ADD
AirFiero
Sun Apr 07, 2019 7:23 pm
AS did say only a planned 2% growth for this year, right? PAE is probably taking up some of that. We probably shouldn’t expect to see a lot of growth from them this year.
dfwjim1
Sun Apr 07, 2019 7:24 pm
mfe777 wrote:
/quote]
I wonder how much longer this route will last being that it is a "dead end" destination for AA.
Dominion301
Sun Apr 07, 2019 7:40 pm
Indeed and look at all the slot squatting once the runway is back up and running again. At least they’re spreading it around instead of the old 20x/day Dash 8 PHL-LGA squatting.
BDL757
Nice, hopefully these stick.
I'm assuming AM will reduce LAX-MEX
cschleic
Sun Apr 07, 2019 8:12 pm
Sure, some is PAE. But isn't part of the point of PAE to shift traffic away from overcrowded SEA vs. all of PAE being growth?
777Mech
Sun Apr 07, 2019 8:14 pm
Because ATL is better.
spinkid
Sun Apr 07, 2019 9:00 pm
for D8, those are all Max related. They simply don't have enough planes. They are wet leasting an A330 to make the DUB-SWF runs for now. These routes will likely be back as soon as the Max is up and flying. Hopefully DY can hang on that long.
