qf789
AD to be issued on 787 RR Trent 1000 TEN engines
Wed Apr 10, 2019 10:29 am
More problems for RR
EASA is expected to issue an AD on 787's powered by Rolls Royce Trent 1000 TEN after detecting higher wear on turbine blades. The AD comes after Singapore Airlines confirmed 2 787-10's being grounded due to higher wear.
The latest version of the Trent engine has been dogged by problems since entering service at the end of 2017. According to Rolls-Royce, by late February 35 787s had been grounded globally due to engine blades corroding or cracking prematurely.
“This blade deterioration is a known issue but it is occurring faster than we expected on some engines,” Chris Cholerton, Rolls-Royce President for Civil Aerospace, said on Wednesday.
https://www.reuters.com/article/us-roll ... SKCN1RM0MU
Currently there are approximately 180 RR Trent TEN engines in service
https://twitter.com/rschuur_aero/status ... 79264?s=20
Forum Moderator
tealnz
Re: AD to be issued on 787 RR Trent 1000 TEN engines
Wed Apr 10, 2019 11:14 am
Any indication it is affecting 789s? Or just -10s?
SteelChair
Wed Apr 10, 2019 11:47 am
Or A339s for that matter?
qf789
Wed Apr 10, 2019 7:10 pm
EASA has now issued AD requiring inspection before 650 flight cycles
https://twitter.com/rschuur_aero/status ... 96192?s=20
Forum Moderator
BlueSky1976
Wed Apr 10, 2019 7:32 pm
Newer 787-9s also have RR T1000-TEN, so presumably AD would apply to them as well.
The queen of the skies is dead.
LY777
Wed Apr 10, 2019 8:26 pm
What’s wrong with manufacturers these days ???
Flown:717,727,732,733,734,735,738,73H,742/744/748,752,753,762/2ER/763/3ER,772/77E/773/77W, 788, 789, DC8,DC10,E190,E195,MD83,MD88, L1011, A3B2,A319,A320-100/200,A321,A332/A333,A343,A388
aerorobnz
Wed Apr 10, 2019 10:46 pm
Well, I guess NZ will be hanging onto the 3 leased 777s for a while longer.
Flown to 147 Airports in 62 Countries on 83 Operators and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
grbauc
Thu Apr 11, 2019 12:10 am
I'm guessing that the engines are much more complex then ever. I don't know if it means something is wrong but rather that it needs inspection until engineer's can and figure a better system or way.
tealnz
Thu Apr 11, 2019 1:26 am
The reason I asked is that the groundings seem to be only for -10s. I believe they are running a higher thrust version of the -TEN and will be totting up more takeoffs than long-haul 789s. So it would not be a surprise if the 789s with -TENs are less affected.
lightsaber
Thu Apr 11, 2019 3:22 am
Presumably to the T7000 on the A339 too.
There is so much pressure to under test.
Lightsaber
Flu+Covid19 is bad. Consider a flu vaccine, if not for yourself, to protect someone you care about.
Pellegrine
Thu Apr 11, 2019 3:28 am
At what point would these RR T1000 problems affect ETOPS on the 787?
We fly JETS, we don't fly donkeys.
hongkongflyer
Thu Apr 11, 2019 3:33 am
I feel that we have reached the edge of current technology limits and continuing to push the new models and new engines beyond the limitations.
lutfi
Thu Apr 11, 2019 3:46 am
Lightsaber
Agree. Commercial teams push engineering to accept timelines without enough testing time -so launch customers become ‘beta’ testers
sciing
Thu Apr 11, 2019 5:28 am
Direct link without useless Twitter: https://ad.easa.europa.eu/blob/EASA_PAD ... D_19-059_1
strfyr51
Thu Apr 11, 2019 6:01 am
I'm not sure what Rolls Royce is doing anymore.. When did their engineering run off the rails? The RB211 was a reliable engine. the Trent flew for years on the 777 and I didn't see much of any trouble, But the 787? They've had monster problems. Did they try a step too far??
gloom
Thu Apr 11, 2019 6:57 am
+1, but I wouldn't call it "beyond limitations", it's just the wearoff, not fundamental wrong technology. It's more a manufacturing and quality problem (materials not good enough, or production technology not good enough yet, as I see it).
We've seen some new technologies entering the line, we've seen some old technologies being pushed to max and beyond to match. Engines gained two-digit numbers reduction in fuel burn in the past 15 years generation to generation. I guess we'll see a few years when those new techs mature and developed to last longer.
It's just the moment in time when technology was used to push efficiency too much. Now the pendulum will swing to reliability again, I guess. It's always like that.
Adam
WIederling
Thu Apr 11, 2019 9:01 am
Issue is that there is so much time spent until these things come up with beta testers that
a mole hill of produce has been pushed into the market in the meantime.
Contrary to software ( where this technique got "invented" ) you can't just "update" the parts online. :-)
Murphy is an optimist
Dalmd88
Thu Apr 11, 2019 9:07 am
This is not unexpected. The TEN turbine blades are the essentially the same as the original 1000 pack C blades. The new version of the 1000 C blade has just now been put into service. The XWB and the early 7000 will likely have the same issues.
StTim
Thu Apr 11, 2019 9:12 am
But also you cannot test the engines with every type of fuel and other environmental factors for the thousands of hours that may be necessary for such issues to become apparent. The testing schedule would be extremely long and costly.
I too get the feeling that certain parts are being pushed to the limits of current metallurgy and manufacturing processes in the desirable goal of increased fuel technology.
One thing that does surprise me is that so far there does not seem to have been similar issues on the XWB which has been successfully in operation for a number of years now.
JannEejit
Thu Apr 11, 2019 9:17 am
That's my feeling too and that the constant quest for more fuel efficient, and more powerful engine technology is partly to blame. Rolls Royce are not the only OEM to experience problems in recent times. 'End user beta testing' has IMHO become a scourge of modern manufacturing processes and not just within aviation technology either.
lutfi
Thu Apr 11, 2019 12:11 pm
Um the RB211 was the reason they went bankrupt and had to be nationalised by the U.K. government. It ended up reliable, but their attempts to use carbon fibre fan blades broke them
LaunchDetected
Thu Apr 11, 2019 12:30 pm
I don't understand why there is not the same amount of problems with the Trent XWB.
(The Trent 7000 is too recent and too few to encounter this kind of troubles.)
Caravelle lover
cledaybuck
Thu Apr 11, 2019 12:34 pm
Pun intended?
As we celebrate mediocrity, all the boys upstairs want to see, how much you'll pay for what you used to get for free.
Amiga500
Thu Apr 11, 2019 12:40 pm
Nope. You've got a pack of gormless gombeens running the show.
Processes are s**t. Tools are even worse. Decision makers are too ignorant to know enough to fix it. You have a few good people running around firefighting, but then you've got the program crowd running around with cans of petrol.
They could do with sending every single last employee they have on a month long course on databases and how to properly set up and use the f**king things.
Revelation
Thu Apr 11, 2019 12:55 pm
Lightsaber
How's that working out for Rolls? Boeing? Etc.
Yep, engineering these days is plagued by a bunch of well dressed gormless idiots too stupid to know that they don't know anything happily collecting fat pay packets while the ship runs aground.
I didn't see that particular rant coming...
Amiga500
Thu Apr 11, 2019 1:53 pm
Management is full of the generation that converted from type-writers to word processors.
They just don't realise that the world has moved on so much.
If we searched the internet (or even websites on the internet - like Amazon for instance) in the same way engineering companies index their data; then Jeff Bezos would have been bankrupted ages ago.
If I want to see the properties of any variable used within code - one click should do it - and give me everything I need to know. I shouldn't be running off to find various embedded excel sheets and text files inside word docs then manually cross referencing to see what bounds applies to any particular build.
Pudelhund
Thu Apr 11, 2019 2:05 pm
[boeingconspiritard]the engine problems were manufactured specifically for the Trent 1000 in order to sabotage Boring and the 787 program[/boeingconspiritard]
Revelation
Thu Apr 11, 2019 2:28 pm
Ok, I think I see where you are coming from. It seems to boil down to the idea that management doesn't understand how data is used in the organization, and they don't realize they need a Data Architecture and one or more Data Architects with the resources to clean up the mess.
LDRA
Thu Apr 11, 2019 2:54 pm
So true!!!
Users browsing this forum: BAeRJ100, Baidu [Spider], BDKLEZ, BUFJACK10, Cadet985, calt03, Flaps, Google [Bot], HII, hummingbird, Lusitanian, majano, Mortyman, MrHMSH, Oliver2020, overcast, tomcat, toobz and 280 guests
