musman9853 wrote:american is probably salivating at the thought of getting more slots at their fortress hubs
FSDan wrote:musman9853 wrote:american is probably salivating at the thought of getting more slots at their fortress hubs
DFW isn't slot restricted. AA will be happy to get more gates, though.
ctrabs0114 wrote:The latest on Terminal F from the Star-Telegram:
https://www.star-telegram.com/news/busi ... 18194.html
musman9853 wrote:FSDan wrote:musman9853 wrote:american is probably salivating at the thought of getting more slots at their fortress hubs
derp, yes lol.
derp, yes lol.
I'm interested to see what terminal design they settle on here, last i heard AA was in a fight with DFW over the future design of the terminals there, DP wanted more midfield development vs the 1/2 ovals... Logic on the AA side was by changing the design they could enable easier connections... I personally like the current DFW setup & find connections pretty easy but Management didn't agree.
stevend08 wrote:Posted in the DFW Thread:
The article suggests having a ORD terminal 3 like structure but not sure about how skylnk would tie in
tmoney wrote:stevend08 wrote:Posted in the DFW Thread:
The skylink rail actually curves around the parking lot spot that is potential T(F) just like it does for other terminals.
Now my biggest wish is to have direct airside walkways to terminals that are facing each other. So I won't have to cross 2 different terminals and 3-7 stops on the skylink whenever I'm connecting cross-terminal.
Planes4you wrote:https://www.nbcdfw.com/news/local/DFW-Airport-to-Start-Planning-6th-Terminal-for-More-Flights-508570351.html?amp=y
As the article states DFW is planning to build terminal F which is rumored(from people who are close to people who work at DFW) to be the new international terminal.If it’s an international terminal the other part of the rumor is AA will take over terminal D and all international carriers will be moved to terminal F.If it is built every terminal F concept shows it’ll replace the parking lot next to D.thoughts on this?
tmoney wrote:stevend08 wrote:Now my biggest wish is to have direct airside walkways to terminals that are facing each other. So I won't have to cross 2 different terminals and 3-7 stops on the skylink whenever I'm connecting cross-terminal.
w3gar wrote:I wonder if there will be any other additional changes to the terminals at DFW beside Terminals C and F
mcoatc wrote:w3gar wrote:I wonder if there will be any other additional changes to the terminals at DFW beside Terminals C and F
AA is already spending billions at LAX, ORD, CLT, and DCA. The airport already spent billions on TRIP and has endless airfield work to do. Pretty sure it's F and some lipstick on the pig that is C. You can't replace C until F exists anyway, and no one is going to spend tens of billions to reconfigure the entire airport.Planes4you wrote:https://www.nbcdfw.com/news/local/DFW-Airport-to-Start-Planning-6th-Terminal-for-More-Flights-508570351.html?amp=y
Like there's so many tenants other than AA to move out of D? What's that like 3 or 4 gates? You really think they're going to move QF and build a new A380 gate? Intl at F sounds logical, and you can be certain it's not going to be semi-circular because AA isn't down with that.
Planes4you wrote:mcoatc wrote:w3gar wrote:I wonder if there will be any other additional changes to the terminals at DFW beside Terminals C and F
Planes4you,
I hope you realize the International carrier area is extremely small and I don’t think you realize how many years its going to take to finish this terminal.By the time it’s finished dfw will have way more carriers then they’ve do now…
Planes4you,
I'm a local, but let's be honest; two of the things you mentioned just aren't true.
1. The need for international carriers is pretty small. 4, 5, 6 gates would be more than sufficient at this point for international carriers, like it is now.
2. There will not be 'way more' international carriers when this terminal is built than now.
Could we see the addition of a few carriers? Sure, that is very likely. But there won't be 'way more'.
5-10 gates more or less designated for international carriers will be sufficient. However, it's smart to design in so that there are enough international capable gates for both domestic and international airlines for decades to come, so I do hope most, if not all of the the new Terminal F is FIS capable (just like Terminal D).
flyPIT wrote:DFW should build an oversized version of PHX's T4 in phases to replace everything they have now.
Planes4you,
MIflyer12 wrote:flyPIT wrote:DFW should build an oversized version of PHX's T4 in phases to replace everything they have now.
I could spend a lot of time thinking about an ideal high-capacity hub airport and never get to PHX T4. Long walks if you have concourses close enough to inhibit aircraft movement, and even longer walks if you don't. Everyone needs to face it: they're not going to tear down DFW and build a facsimile of DEN or ATL. DFW's semicircular terminals from the 1968 plan predated hub and spoke operations by very big carriers. It's crippling, but no, they're not going to get a $20 Billion do-over.
w3gar wrote:It's usual to spot the Qantas A380 on a remote stand not far from D16 once each passenger has deboarded the plane. Therefore I think that a few more gates should be added for international carriers. https://twitter.com/unitedflyerhd/statu ... 5296494592
Listen, I'm not suggesting more intl gates aren't needed. They are, and D often has arrivals holding out for gates, but they're usually AA. Japan, Korean, and Emirates in the morning, Qantas, Lufthansa, Qatar, and now Air France in the afternoon. BA arrives and departs late evening these days. That leaves Aero Mexico, along with the random schedules of Interjet and Volaris. Am I missing anyone? They're all accommodated on the low D gates. Who are all of these airlines who want to start service that can't get gates (other than China Southern) ? I was simply saying AA has the need.
Also, since I've been in a construction meeting or two, I'm not completely oblivious as to the airport's building needs and scheduleFriscoHeavy wrote:Planes4you wrote:
Planes4you,
Exactly fellow Frisco-ite. Friscoan? Still not sure.
Anyway, they're already extending the low D gates for short term growth. Who are all these carriers?
chunhimlai wrote:Will they build new mega terminals to replace the semi-circles?
texl1649 wrote:The challenge for DFW will always be how it can continue to grow (or operate) if so much as a minor storm front rolls across town. It tends to become a disaster for the day if a quarter inch of rain falls in the space of 20 minutes in the morning. Part of that is AA's ground ops being run by abject fools (who are seemingly unprepared half the time a plane lands), but it has only gotten worse lately.
enilria wrote:FSDan wrote:musman9853 wrote:american is probably salivating at the thought of getting more slots at their fortress hubs
But other carriers will get more gates too. These days the legacies are typically happy to not grow gates, suppress capacity, and jack up fares.
mfe777 wrote:F needs to get going very soon, even the people in charge said a decision needed to be made quickly to avoid a gate shortage. And that was months ago. That way, C can be torn down and rebuilt once F is operational.
In the future, what about building a large, singular terminal on the outskirts of the airport to service LCC carriers and/or non-Oneworld domestic carriers? Especially if WN ever decides to operate flights at DFW (once the gate-for-gate restrictions expire). I mean further down the road, if AA/OW need more space at DFW even after the new terminal is built. DFW has a lot of empty land on the peripheries of the airport.
FSDan wrote:
My understanding was that AA's latest growth spurt at DFW (mostly regional adds like MRY, BFL, AVL, MDT, etc.) was enabled by them taking control of the satellite concourse on Terminal A. Assuming that's true, it seems AA's growth at DFW is gate constrained. If they want to expand even further in the future, they'll need even more gates.
Another reason AA might be behind a new Terminal F is that new gates could allow them to shift some of their operation from Terminal C there while renovating or rebuilding on that site.
The satellite concourse is in Terminal E, not Terminal A, but the substance of this is correct. AA wants to grow DFW to as close to ATL levels as possible, but could not do so due to gate constraints. Having the satellite helps immensely, while having a new terminal would probably get them there. Whether or not that's wise is, of course, a separate discussion.
PHASE 1 (2022-2025)
Terminal will build two new "arms" across the central road to the south of terminal D, and the airside and landside are would be expanded.
The upgrade terminal E would increase 10mpax capacity.
PHASE 2 (2025-2032)
Two new terminal would be built in the north and south of the existed terminals. Each of them can serve 25mpax.
Central road would be undergrounded for taxiway bridge in the future.
A new apm system next to central road would connect terminal A,B,C,D through new structure and terminal E. Altogether there are 8 stations in the new APM and it will replace the existing APM system.
PHASE 3 (2032-2045)
The new concourse would be built and replace the existing terminal A-E. The concourse would be built from terminal A/B, then C/D and final terminal E. Each concourse could service 15mpax, with 2 terminals the new DFW could serve 140mpax.
QXfactor wrote:tmoney wrote:stevend08 wrote:Now my biggest wish is to have direct airside walkways to terminals that are facing each other. So I won't have to cross 2 different terminals and 3-7 stops on the skylink whenever I'm connecting cross-terminal.
They already have airside walkways from A to B, and C to D, where you go right over the highway. In fact, other than Terminal E, the terminals all connect to each other (A to both B and C, B to both A and D, C to both A and D, and D to both B and C.)
chunhimlai wrote:DFW is planning a new terminal for its overcapacity passengers. In stead of building a new semicircle terminal, the largest operator, AA prefer a liner terminal layout.
The plan would base on what American perfer, with 2 large terminal and 6 concourse, the maximum capacity would increase to 140million.
PHASE 1 (2022-2025)
PHASE 2 (2025-2032)
PHASE 3 (2032-2045)
Fargo wrote:chunhimlai wrote:DFW is planning a new terminal for its overcapacity passengers. In stead of building a new semicircle terminal, the largest operator, AA prefer a liner terminal layout.
PHASE 1 (2022-2025)
PHASE 2 (2025-2032)
PHASE 3 (2032-2045)
So AA wants an ATL style layout after all? I believe it was just a few months ago I was vilified for suggesting this.
EvanWSFO wrote:Fargo wrote:chunhimlai wrote:DFW is planning a new terminal for its overcapacity passengers. In stead of building a new semicircle terminal, the largest operator, AA prefer a liner terminal layout.
Appears for E and future F. Its going to be tricky to rebuild E with current tenants.
That’s just phase 1. If you scroll down and look at the remaining plan, it calls for constructing two large terminals on both sides and then replacing the remainder with linear concourses.
Will be difficult, but it’s necessary.
PHASE 1 (2022-2025)
PHASE 2 (2025-2032)
PHASE 3 (2032-2045)
Planes4you wrote:mfe777 wrote:F needs to get going very soon, even the people in charge said a decision needed to be made quickly to avoid a gate shortage. And that was months ago. That way, C can be torn down and rebuilt once F is operational.
The international carrier area is in a gate shortage with how small it is scheduling is tight and soon passengers might have to board on the ramp
