InnsbruckFlyer wrote:D-AIZH was named after the city of Hanau
KLDC10 wrote:Lufthansa Magazin provides the following article, which gives an excellent explanation:
https://magazin.lufthansa.com/xx/en/fle ... r-name-is/
aarbee wrote:How true this is ? This means that LH will have only 26 aircrafts of a certain type???
trent768 wrote:I always thought it was similar with the 3 letters registration format (first letter shows the airline, second letter represents the type, and third one is individual ID).
trent768 wrote:Also, I think the states only regulates the first letter of the reg right? Because AB used to have D-ABxx on their fleets, regardless of the aircraft type.
XAM2175 wrote:Except that German registration marks use four characters after the "D" prefix:
D-AAAA to D-ATZZ for aircraft with more than 20 t MTOW
D-AUAA to D-AZZZ test registrations for aircraft manufactured by Airbus at Finkenwerder
D-BAAA to D-BZZZ for aircraft with 14–20 t MTOW
... and so on ...
Within these standards, LH are fond of using the second letter to designate the aircraft's manufacturer.
trent768 wrote:aarbee wrote:How true this is ? This means that LH will have only 26 aircrafts of a certain type???
Not really I guess, since they can just assign another letter. For example, GA use PK-GHx for some of their A330 after running out of combination from PK-GPx. Even their 738 uses GMx/GFx/GNx/GDx.
lugie wrote:aarbee wrote:How true this is ? This means that LH will have only 26 aircrafts of a certain type???
The only limit it imposes on LH is them being able to have a maximum of 676 aircraft by each manufacturer:
D-AIxx are Airbus aircraft. For the 3rd and 4th position in the registration there are 26 letters of the alphabet, hence an Airbus fleet of 26*26 = 676 different frames.
Same for D-ABxx -> 676 Boeing frames
The other prefixes they use are D-AExx for the (Cityline) Embraer fleet which could technically be expanded to 676 frames, just as the D-ACxx Cityline CRJ fleet.
trent768 wrote:KLDC10 wrote:Lufthansa Magazin provides the following article, which gives an excellent explanation:
Oh my, that article is excellent and somehow shows how organised/logical the Germans are lol! I always thought it was similar with the 3 letters registration format (first letter shows the airline, second letter represents the type, and third one is individual ID).
S0Y wrote:aarbee wrote:How true this is ? This means that LH will have only 26 aircrafts of a certain type???
.....not with 4 letter registrations
lugie wrote:The only limit it imposes on LH is them being able to have a maximum of 676 aircraft by each manufacturer:
Not really I guess, since they can just assign another letter. For example, GA use PK-GHx for some of their A330 after running out of combination from PK-GPx. Even their 738 uses GMx/GFx/GNx/GDx. So I guess LH can do the same as well.
InnsbruckFlyer wrote:Most Lufthansa aircraft are named after cities or provinces of Germany, and there are few planes named after non-German places (some A380s and A340-300 D-AIFC). My question is: why do they re-name some aircraft? For example, up until recently, D-AIZH was named after the city of Hanau, but after it got re-painted in the Star livery, it was named after the city of Ahlen. The same thing sort of applies for D-ABVM, the first 747-400 to wear the new livery. It didn't have a name until it was re-painted, when it became Kiel. Only D-ABTK was Kiel before that... Anyone have any insight into this? Surely there must be a reason for this?
aarbee wrote:S0Y wrote:aarbee wrote:How true this is ? This means that LH will have only 26 aircrafts of a certain type???
.....not with 4 letter registrationsXAM2175 wrote:Except that German registration marks use four characters after the "D" prefix:
Within these standards, LH are fond of using the second letter to designate the aircraft's manufacturer.lugie wrote:The only limit it imposes on LH is them being able to have a maximum of 676 aircraft by each manufacturer:
The other prefixes they use are D-AExx for the (Cityline) Embraer fleet which could technically be expanded to 676 frames, just as the D-ACxx Cityline CRJ fleet.trent768 wrote:aarbee wrote:How true this is ? This means that LH will have only 26 aircrafts of a certain type???
I understand if it was last 2 characters (4th & 5th). The article at https://magazin.lufthansa.com/xx/en/fle ... r-name-is/ specifically states that (with examples)
"The third letter is the code for manufacturer’s identity. “I” stands for Airbus and “B” for Boeing. The fourth letter states aircraft type; that’s “M” for the A380 and, for example; “Y” for the Boeing 747-8. The fifth letter is used to identify the individual plane."
So if 4th letter is aircraft type, then there's only 26 variations left for 5th letter.
How will you get 676, OR the article is wrong ?
zkojq wrote:I think it's simply upcycling whereby the larger cities get larger aircraft named after them, but when fleets get introduced and retired things get complicated as names get shuffled around. Hamburg had a short gap between the retirement of D-ABTD (747-4M) in April 2013 and the delivery of D-AIML (A380) in May 2014. Essen had a big gap between the retirement of D-ADJO (DC10) in 1994 and the delivery of D-AIXE in September 2017.InnsbruckFlyer wrote:D-AIZH was named after the city of Hanau
I've flown on that!
InnsbruckFlyer wrote:The same thing sort of applies for D-ABVM, the first 747-400 to wear the new livery. It didn't have a name until it was re-painted, when it became Kiel.
zkojq wrote:Essen had a big gap between the retirement of D-ADJO (DC10) in 1994 and the delivery of D-AIXE in September 2017.
InnsbruckFlyer wrote:InnsbruckFlyer wrote:D-AIZH was named after the city of Hanauzkojq wrote:I've flown on that!
Me too! LH1426, FRA-SOF.
lugie wrote:D-AIxx are Airbus aircraft. For the 3rd and 4th position in the registration there are 26 letters of the alphabet, hence an Airbus fleet of 26*26 = 676 different frames.
OlafW wrote:lugie wrote:The other prefixes they use are D-AExx for the (Cityline) Embraer fleet which could technically be expanded to 676 frames, just as the D-ACxx Cityline CRJ fleet.
Looking back, the fleets of Augsburg Airways and Contact Air, who did most flying for Lufthansa, also followed that scheme with D-ADxx for the Dash8-400s and D-AFxx for the Fokker 100s.
XAM2175 wrote:D-ABxx is obviously Boeing territory, but the D-ABQx range has a bunch of EW Dash-8s in it - presumably for "Bombardier Q-Series".
XAM2175 wrote:D-ADxx was also used for Douglas DC-8s and DC-10s at various points (MD-11s however ended up in D-ALxx)
DUSdude wrote:For whatever reason, it seems LH has decided to us D-ALxx for all freighters, regardless of manufacturer. Both the MD11 and the 777-200LRF fleets have regs starting with D-ALxx.
DUSdude wrote:XAM2175 wrote:D-ABxx is obviously Boeing territory, but the D-ABQx range has a bunch of EW Dash-8s in it - presumably for "Bombardier Q-Series".
I believe those regs predate the integration of those aircraft into LH's fleet, as those were previously with Air Berlin/Luftfahrtgesellschaft Walter. ...
