InnsbruckFlyer
Why Does LH Re-Name Aircraft?
Fri Apr 19, 2019 9:16 am
Most Lufthansa aircraft are named after cities or provinces of Germany, and there are few planes named after non-German places (some A380s and A340-300 D-AIFC). My question is: why do they re-name some aircraft? For example, up until recently, D-AIZH was named after the city of Hanau, but after it got re-painted in the Star livery, it was named after the city of Ahlen. The same thing sort of applies for D-ABVM, the first 747-400 to wear the new livery. It didn't have a name until it was re-painted, when it became Kiel. Only D-ABTK was Kiel before that... Anyone have any insight into this? Surely there must be a reason for this?
2019: A3 2x A320 | CL E195 | FB A319, E190 | LH A320, A321, A346, A359 | OS A320, B772, 3x DH8Q | UA A319
arcticcruiser
Re: Why Does LH Re-Name Aircraft?
Fri Apr 19, 2019 9:41 am
Yes there must be a reason. Ordnung muss sein!
KLDC10
Fri Apr 19, 2019 10:01 am
Lufthansa Magazin provides the following article, which gives an excellent explanation:
https://magazin.lufthansa.com/xx/en/fle ... r-name-is/
DC9/MD90/MD11/F70/BAE146
737/738/739/744/748/752/763/772/789
A319/A320/A321/A332/A333/A346/A359
Q400/E170/E175/E190/CS300
zkojq
Fri Apr 19, 2019 12:31 pm
I think it's simply upcycling whereby the larger cities get larger aircraft named after them, but when fleets get introduced and retired things get complicated as names get shuffled around. Hamburg had a short gap between the retirement of D-ABTD (747-4M) in April 2013 and the delivery of D-AIML (A380) in May 2014. Essen had a big gap between the retirement of D-ADJO (DC10) in 1994 and the delivery of D-AIXE in September 2017.
I've flown on that! :D
First to fly the 787-9
trent768
Fri Apr 19, 2019 1:23 pm
Oh my, that article is excellent and somehow shows how organised/logical the Germans are lol! I always thought it was similar with the 3 letters registration format (first letter shows the airline, second letter represents the type, and third one is individual ID).
aarbee
Fri Apr 19, 2019 5:16 pm
How true this is ? This means that LH will have only 26 aircrafts of a certain type???
Love the AIXes
S0Y
Fri Apr 19, 2019 5:20 pm
.....not with 4 letter registrations
XAM2175
Fri Apr 19, 2019 5:37 pm
Except that German registration marks use four characters after the "D" prefix:
D-AAAA to D-ATZZ for aircraft with more than 20 t MTOW
D-AUAA to D-AZZZ test registrations for aircraft manufactured by Airbus at Finkenwerder
D-BAAA to D-BZZZ for aircraft with 14–20 t MTOW
D-CAAA to D-CZZZ for aircraft with 5.7–14 t MTOW
D-EAAA to D-EZZZ for single-engine aircraft up to 2 t MTOW
D-FAAA to D-FZZZ for single-engine aircraft from to 2–5.7 t MTOW
D-GAAA to D-GZZZ for multi-engine aircraft up to 2 t MTOW
D-HAAA to D-HZZZ for rotorcraft
D-IAAA to D-IZZZ for multi-engine aircraft from 2–5.7 t MTOW
D-KAAA to D-KZZZ for powered gliders
D-LAAA to D-LZZZ for airships
D-MAAA to D-MZZZ for powered ultralight aircraft
D-NAAA to D-NZZZ for non-powered ultralight aircraft
D-OAAA to D-OZZZ for manned free balloons
D-0001 to D-9999 for gliders.
Within these standards, LH are fond of using the second letter to designate the aircraft's manufacturer.
lugie
Fri Apr 19, 2019 6:06 pm
The only limit it imposes on LH is them being able to have a maximum of 676 aircraft by each manufacturer:
D-AIxx are Airbus aircraft. For the 3rd and 4th position in the registration there are 26 letters of the alphabet, hence an Airbus fleet of 26*26 = 676 different frames.
Same for D-ABxx -> 676 Boeing frames
The other prefixes they use are D-AExx for the (Cityline) Embraer fleet which could technically be expanded to 676 frames, just as the D-ACxx Cityline CRJ fleet.
DH4 E75 E90 CR9 CRK M88 319 320 321 332 333 359 733 73G 738 739 748 764 772 788
X3 LH 4U TP US SN EI FR IB LX LA CM UA DL AA AS WN
FRA STR HAM TXL MUC ZRH ACE BRU BLL DUB MAN ARN MAD OPO LIS FNC AMS PHL RDU LGA CLT EWR ORD ATL SFO MDW SJO PTY
trent768
Fri Apr 19, 2019 6:37 pm
Not really I guess, since they can just assign another letter. For example, GA use PK-GHx for some of their A330 after running out of combination from PK-GPx. Even their 738 uses GMx/GFx/GNx/GDx. So I guess LH can do the same as well.
Also, I think the states only regulates the first letter of the reg right? Because AB used to have D-ABxx on their fleets, regardless of the aircraft type.
XAM2175
Fri Apr 19, 2019 7:03 pm
As already posted - yes, the final three characters of the mark have no regulated meaning for the German civil register.
... and so on ...
Thus LH could use D-ABxx registrations for Boeing aircraft while AB could use them for all their planes.
It's pretty much what you said, though:
PartsGuy20
Fri Apr 19, 2019 7:34 pm
Pan Am did that a few times as well, at least with their 747 fleet. N747PA was "Clipper America" for a long time before it became "Clipper Juan T. Trippe", N734PA was "Clipper Flying Cloud" before it became "Clipper Champion of the Seas", and the ill-fated "Clipper Victor" at Tenerife was "Clipper Young America" for a short time (although it was also "Clipper Victor" before that).
But to answer your question, I don't know!
LH707330
Fri Apr 19, 2019 8:22 pm
Then they'd need to use the last three letters though to make it clear, so they're limited to 676 total. As that article points out, they use the last two of D-AIMA, MA, to identify that type, so a D-ABMA wouldn't work in their current scheme.
In reality, there are fewer than 676 options, some have been skipped for various reasons (D-ABYB->rego of LH540 crash aircraft, D-AISA, SS, and a few others skipped to avoid NS-initialisms).
As to why the names are reused and how, it's basically a function of the city or state size for the fleet, then what's a shiny new toy. Many of the 744s lost their names to incoming 748s, and the 346s are losing theirs to the 359s. You can check this out at lh-taufnamen.
crownvic
Sat Apr 20, 2019 3:43 am
Or how difficult they can make things :)
aarbee
Mon Apr 22, 2019 5:27 pm
I understand if it was last 2 characters (4th & 5th). The article at https://magazin.lufthansa.com/xx/en/fle ... r-name-is/ specifically states that (with examples)
"The third letter is the code for manufacturer’s identity. “I” stands for Airbus and “B” for Boeing. The fourth letter states aircraft type; that’s “M” for the A380 and, for example; “Y” for the Boeing 747-8. The fifth letter is used to identify the individual plane."
So if 4th letter is aircraft type, then there's only 26 variations left for 5th letter.
How will you get 676, OR the article is wrong ?
Love the AIXes
jworks158
Mon Apr 22, 2019 5:34 pm
JetBlue does this too, and I really wish they didn't for a while there were two planes in the air named Blue print.
(A359,A343/A346,A332,A319/320/321,A220-100)(B788,B772,B762,B752,B744/B748,B732/B737/B738,B717)(E190,E145)(CRJ100/200, Dash 8-200)(MD-83)
JB,UA(C5,EV,CHQ,AX),AA(EGF,ZW,AX,PT),DL(OH,YX),FL,WN,LH,BA,AF,AZ,IB,VX,CO
https://my.flightradar24.com/theorangetechie
SRQKEF
Mon Apr 22, 2019 5:42 pm
Just Google LH's fleet. While the 4th letter is indeed exclusively for a certain type, that doesn't mean that same type can't have more exclusive letters for itself. For example, D-AIR* and -AIS* are both A321 registration series, as are D-AIU* and -AIZ* A320 registration series and D-ABT* and -ABV* 744 registration series. I hope that clears out for you that LH indeed has approximately 676 Airbus registrations to play with.
InnsbruckFlyer
Mon Apr 22, 2019 6:21 pm
Me too! LH1426, FRA-SOF.
DUSdude
Mon Apr 22, 2019 9:08 pm
It very much did have a name before. It was originally named "Hessen". I've flown on this aircraft in both incarnations. I assume D-ABVM lost the "Hessen" name when D-ABYL joined the fleet, since that aircraft wears that name now.
No, there was no gap. D-AIBD (A340-200) was "Essen" from 1993 to 2003, when that name transferred to D-AIHC (A340-600), which in turn became nameless when D-AIXE arrived.
zkojq
Tue Apr 23, 2019 1:55 pm
LH2240 MUC-CDG. My first ever flight with an all female crew.
No, there was no gap. D-AIBD (A340-200) was "Essen" from 1993 to 2003, when that name transferred to D-AIHC (A340-600), which in turn became nameless when D-AIXE arrived.[/quote]
Oh, right you are! :smile:
OlafW
Tue Apr 23, 2019 2:29 pm
Looking back, the fleets of Augsburg Airways and Contact Air, who did most flying for Lufthansa, also followed that scheme with D-ADxx for the Dash8-400s and D-AFxx for the Fokker 100s.
Some planes are also named after cities smaller than 40.000, but with another connection to aviation, e.g. Buxtehude and Nordenham, which both have Airbus plants.
XAM2175
Tue Apr 23, 2019 6:21 pm
It gets to be quite fun spotting what they got up to with it all:
D-ABxx is obviously Boeing territory, but the D-ABQx range has a bunch of EW Dash-8s in it - presumably for "Bombardier Q-Series".
D-ADxx was also used for Douglas DC-8s and DC-10s at various points (MD-11s however ended up in D-ALxx)
D-AExx was also used for BAe 146s with Eurowings.
D-AVRx was the main sequence used for CityLine's Avro RJ85s - meaning that one of them was indeed D-AVRO :D
DUSdude
Tue Apr 23, 2019 8:49 pm
I believe those regs predate the integration of those aircraft into LH's fleet, as those were previously with Air Berlin/Luftfahrtgesellschaft Walter. There is a similar registration-hodgepodge among Germanwings' Airbus fleet, some of which came from the original Eurowings, some from LH mainline, some from the Air Berlin/niki acquisition and some of which were directly delivered from Airbus to Germanwings. So there are D-AKxx, D-AExx, D-ABxx, D-AGxx, D-AIxx, not to mention the Austrian regs of the ex-niki arcraft.
For whatever reason, it seems LH has decided to us D-ALxx for all freighters, regardless of manufacturer. Both the MD11 and the 777-200LRF fleets have regs starting with D-ALxx.
787X30
Tue Apr 23, 2019 10:07 pm
M1F, Delta - Alfa Lufthansa Cargo Alfa ... November
77X, Delta - Alfa Lufthansa Freighter Alfa ... Golf
vandoc
Tue Apr 23, 2019 10:19 pm
DUSdude wrote:
I believe those regs predate the integration of those aircraft into LH's fleet, as those were previously with Air Berlin/Luftfahrtgesellschaft Walter. ...
They certainly do. Besides D-ABV*, D-ABT* (744) and D-ABY* (748) all Regs with D-AB** in LHs fleet are former Air Berlin aircrafts. In the Dash's case AB as their IATA-Code and Q for Bombardier Q-Series. On a side note, the Dashs were sold in April and left LH's fleet.
The next new aircraft with a D-AB** reg will be a 777-9.
The rule D-AI** for Airbus and D-AB** for Boeing only applies to Lufthansa. Its subsidaries have their own regs:
D-AKN*: oldest Germanwings A319 when Albrecht KNauf still owned most of Germanwings
D-AGW*: middle-aged Germanwings A319
D-AEW*: Eurowings A320
D-AXG*: Eurowings A330 operated by XG
All ACs within EW with D-AI regs are former LH aircrafts.
