  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
terrificturk
Re: How come the DL A350 can't fly LAX-SYD it is rumored!?
Mon Apr 29, 2019 9:23 am
BoeingGuy wrote:
The 767-400 was developed mostly as a domestic airplane for a couple of customers. It was a DC-10/L-1011 replacement.
IIRC, DL required that it be capable of operating into LGA. It was a bit sub-optimized.
The biggest problem the 767-400 had is that it was sold during the darkest years of the Phil Condit and Harry Stoneciper era. The then 767 Chief, John Quinlivan was kind of a moron too IMHO.
Boeing was unwilling to make any investments in the -400 to make it more competitive. It’s not a bad airplane but could have used more range and power. Plus the flight deck was a one-off. CO had difficulty having the same pool of 757/767 pilots flying the -400. DL had a separate pilot pool.
During this dark era, Boeing didn’t make product improvements to be more competitive or sell airplanes. Product improvements were only made if it had an 18 month rate of return so Harry and Phil could line their pockets with money.
Bottom line is that the 767-400 isn’t a bad airplane, but it suffered from lack of investment to make it more competitive due to the very poor Boeing leadership in place at the time.
Thank you for this honesty and insight ! I was with Dornier at that time and we had the Do728/928 going. All airlines that visited us preferred it over the competition... Due to bad cashflow, we were looking for a senior partner. We were being offered on a silver plate to Boeing and everybody there - except these two morons, wanted to make this happen. Everybody could see the long-term gains for bothsides...except these two morons... shame it didnt go through.
Pacific
Re: How come the DL A350 can't fly LAX-SYD it is rumored?
Mon Apr 29, 2019 9:44 am
moyangmm wrote:
While I know you get those number from ACAPS, in real world A350's performance is not as good as you suggested (true for all aircrafts, not just A350). Some member has done a very good job analyzing the result, using real world data (viewtopic.php?f=3&t=1393909&start=350#p21034697).
I agree that ACAPS is optimistic, thus I also wrote this:
Pacific wrote:
It also has a lot of margin for wind, diversions and indirect routing to fly LAX-SYD which is 6,500nm Great Circle distance.
The margin is 1,600nm.
moyangmm wrote:
DL188 flight from PEK to DTW(viewtopic.php?f=3&t=1396117&start=53#p20487075), the performance is 49t payload @ 5763nm.
That's basically max structural payload, since ACAPS does assume a very light cabin. (ACAPS states 52t max payload, which a heavier cabin will eat into)
From the other thread which you linked:
trav777 wrote:
DL is seeing max 6500nm or so out of their 268t variant...
...Thus they needed to upgauge to 275t to do the routes they wanna do, 268t wasn't cutting it...
...7t fuel will carry you 600nm or so.
According to your data source, DL's A359 can realistically fly 7,100nm, which means LAX-SYD is flyable with full pax and bags.
Web500sjc
Mon Apr 29, 2019 12:41 pm
eta unknown wrote:
If DL is in fact losing $2M/month as one poster stated above, then isn't dedicating a 77L on the route a bad economic decision?
If DL is loosing $2M//month on the route, the A350 won’t make it profitable.
Boiler Up!
moyangmm
Mon Apr 29, 2019 3:46 pm
WIederling wrote:
That imho is more or less bull.
You are arguing manufacturer B ACAPS data vs (unknown) real world data from manufacturer A.
( same dysfunctional argument was brought forward in the 753 vs A321LR payload range discussions.)
ACAPS data for all manufacturers show the same/similar limitation. ( still air, 10% reserves or what ever )
Comparing ACAPS data should be at least first order relevant for relative performance comparisons.
I have never cited B ACAPS data.
Also, ACAPS from B and A are under different assumptions. B's assumptions are more conservative so are closer to the performance of real planes airlines use.
moyangmm
Mon Apr 29, 2019 3:48 pm
MrHMSH wrote:
DL can order a higher MTOW A350 if they really need to, but for now the 77L makes more sense. That doesn't mean by default that the plane can't make it with an economically viable payload.
So you agree with me the current A350 (275t) is having troubles do LAX-SYD. Otherwise why do they need to order a higher MTOW version?
WIederling
Mon Apr 29, 2019 5:11 pm
Anything real world that would give substance to your conviction ?
Murphy is an optimist
seabosdca
Mon Apr 29, 2019 5:12 pm
AsiaTravel wrote:
It's the other way around. You can't disprove expected performance (ACAPS) with a few single data points. It is like saying climate change is false because today's and two weeks ago's temperature was 5 degree below average.
This is right. ACAPS documents are never identical to the real world, but if you are arguing that real world performance is dramatically worse than what's in the ACAPS, you have to show why.
OP is trying to do that using unconfirmed rumor/hearsay without hard numbers, but his point is being disproven by what multiple A350 operators are actually doing with the aircraft in service. It does what it says on the tin. Sure, it can't fly 6500 nm with the same amount of cargo as a 77L, but no one ever claimed it could. Saying that it can't fly the distance at 275 t MTOW with a full passenger load, though, is just disconnected from everyday reality at multiple airlines including DL itself.
This isn't just a tendency among Airbus haters, either--I've noticed plenty of Boeing haters claiming that the 787-9 can't possibly do the things that United Airlines does with it every day.
sadiqutp
Mon Apr 29, 2019 5:15 pm
Listen carefully!
There are two groups who read these discussions:
= Those who are in the aviation industry, and non seem to support your argument. Numerous have debunked your assumptions and "extrapolations"
= Enthusiasts (like me) who might be tricked by your argument points, however I have an Engineering degree and could differentiate between blind stubbornness and reasonable arguments. I am sure I am not the only one.
MrHMSH
Mon Apr 29, 2019 5:46 pm
No, I disagree wholeheartedly. They might want to lift more cargo which would require a higher MTOW variant, but there is no evidence for this besides what you say, and I would very seriously question your credentials compared to others on here.
Now can you answer these questions for me:
Where is the evidence that DL is unhappy with the A350's performance? Where does the evidence come from?
Why is an aircraft not good enough for a route if it has to take a slight payload hit?
oslmgm
Mon Apr 29, 2019 7:03 pm
At least Delta CEO Ed Bastian is not unhappy with the A350's range:
"We have Airbus 350s, which is our ultra long haul widebody aircraft. [...] it's got all the range capability you'd ever want in an aircraft."
https://twitter.com/YahooFinance/status ... 6887710720 (at 5:26 and 6:34)
StTim
Mon Apr 29, 2019 7:24 pm
You keep on making that statement re the ACAPS documents. The reality is Boeing had to make theirs more realistic as the previous versions were becoming laughable (but believed by many armchair planners on here). From memory of the discussions at the time the view was they were now being produced on a similar basis.
Kindanew
Mon Apr 29, 2019 7:28 pm
He's lying because Airbus have bribed him. </sarcasm>
Bonafide
Mon Apr 29, 2019 9:28 pm
Let me just clear something up that I keep hearing regarding the profitability of LAX-SYD on DL. That route goes out full everyday...EVERYDAY. you will not find open J class seats or W seats and even during the offseason you may get 40 seats max open on a random day in the back. It is known to be the hardest route for employees to travel on due to passenger loads. Now, one of you armchair genius's who dont work in the industry care to explain to me how the route isnt profitable...im all ears
aerohottie
Mon Apr 29, 2019 10:44 pm
Guess Moyangmm was just being a Boeing fanboy then... shocked (not shocked)
What?
strfyr51
Mon Apr 29, 2019 11:22 pm
aerohottie wrote:
x1234 wrote:
Also I looked up the longest flights currently on the DL A359 and they are both DTW-PVG and ATL-ICN westbound averaging 14-14.5 hours so the A359 can clearly do almost 15 hour flight with reserves:
https://www.flightradar24.com/data/flights/dl583
https://www.flightradar24.com/data/flights/dl27
You answered your own question. DL's A359's can do LAX-SYD, with a full passenger load. But they chose to operate that aircraft elsewhere.
Some Boeing fanboys have tried to push that narrative that the A350 is lacking in performance, but this tends to get corrected by those with real knowledge, such as Zeke, pretty quickly.
To the other part of your post, I would go the DL 772LR over the AA 787-9 any day. Both operate a 9 abreast configuration, which makes a MASSIVE different on a 14 hour flight IMHO
HAS IT OCCURRED TO ANYONE? Rolls Royce had some pretty serious performance and Wear issues on their newest Trent engines which required some performance limitation issues in restricting the ETOPS performance. I have No Idea whether all those issues have been resolved but the fact that they had them might have restricted their ETOPS and EROPS limits and not ONLY on the A350 but the B787 Rolls Royce engines as well. Luckily for Boeing? the GE engine is going "Great Guns"...
Motorhussy
Mon Apr 29, 2019 11:56 pm
Haven't you got it the wrong way round? My understanding is that it's the RR engines on the 787 that are the issue rather than those on the A350.
come visit the south pacific
rbavfan
Tue Apr 30, 2019 12:57 am
Based on released data sheets from the past Boeing assumes more weight per passenger & Airbus uses 95 kg (209 lb.)/pass.
This type of issue is also why operators are saying the CS100/A220 series is getting better fuel burn. The spec sheet uses 225 lb./pass.
gatibosgru
Tue Apr 30, 2019 1:05 am
moyangmm wrote:
The "rumor" that DL has complained A350 can't fly LAX-SYD is not totally unfounded.
Haven't seen anything that DL has complained at all, only that some people here ~*think*~ their A359 can't make it on LAX-SYD.
@DadCelo
LDRA
Tue Apr 30, 2019 1:13 am
Any holistic information on cargo load? Thanks in advance
Tue Apr 30, 2019 1:34 am
DL is using the least efficient aircraft on the route compared to the competitors, (A380/77W/789), there is lots of empty seats on the city pair over the year, to fill an aircraft up as you have stated all the time would indicate to me low yields.
Do you have any official statistics that support your claims of near 100% load factors ? I had a look at DL40 from the 4-10 of May showing 40+ empty seats every day.
RobertPhoenix
Tue Apr 30, 2019 2:01 am
Do you think BA and AB are influenced by the average weight of the people in the country or organization that certifies the aircraft ?
ElroyJetson
Tue Apr 30, 2019 3:06 am
I have heard yields have suffered on this route for quite a few years for all carriers. It is certainly highly competitive for an ULH route. I do not know how DL is doing financially on LAX -SYD, but as disciplined as DL is I find It hard to believe they are losing money.
****EDIT****
I just checked fares out of curiosity. AA offers a round trip LAX-SYD fare as low as $706. DL is as low as $737.
To put this in perspective, the much shorter LAX-LHR has a round trip fare at $662. Most are around $700. So yeah, it looks like there is fierce competition and price pressure at least in the back of the plane.
707 717 727 72S 737 733 737-700 747 757 753 767-300 764 A319 A320 DC-9-10 DC-9-30 DC-9-50, MD-82 MD-88 MD-90 DC-10-10 DC-10-40 F-100
Francoflier
Tue Apr 30, 2019 4:31 am
Ah yes, the old 'Boeing underpromises and overdelivers and vice-versa for Airbus' dogma that has been repeated ad nauseam on A.net, so much so that it has become gospel even without substantiation...
Customers know what their own passengers weigh and they'll use their own notional weights to calculate what they can and can't do with an airplane that's offered to them using the manufacturer's data for its weight and fuel burn.
Everything points to absolutely no performance shortfall for the A350 (-900 at least), and any notion of DL is discovering just now what the airplane can do on any of their route is ludicrous and a ridiculous attempt at unfounded and biased criticism.
The A350 is a 343/77E replacement aircraft that can take more payload much farther than them while burning a lot less fuel.
As said above, it will not carry the payload of a purpose-built ULH frame that's 75T heavier at take off, but on a heavily contested ULH route on which margins are razor thin and fuel costs are very high, one can indeed question the economics of sending an airplane that burns around 20T more fuel on the mission.
I am very confident that DL knows what they're doing, but there are way more metrics involved in the selection than we could ever try to guess.
gokmengs
Tue Apr 30, 2019 4:43 am
I can’t believe we still didn’t get a post from a DL 350 driver with cold hard facts (as if what we got isn’t enough) to close the subject only for it to come up again a month later.
As for the discussion regarding the profitability of the route I can’t imagine it being very profitable as the amount of competition is pretty decent.
P.S. never forget some fanboys (on either side of the aisle) won’t ever give up:)
Yaşa Mustafa Kemal Paşa Yaşa, Adın Yazılacak Mücevher Taşa
sciing
Tue Apr 30, 2019 6:11 am
The XWB had just reported 1 IFSD since EIS. I guess the Trent XWB is a kind of benchmark in terms of reliability.
AirwayBill
Tue Apr 30, 2019 6:33 am
Agreed. It is interesting how a thread based on vague and unfounded rumors can live on for such a long time without any solid evidence to support its main thesis.
I believe it is appropriate to call this fake news at this point.
WIederling
Tue Apr 30, 2019 7:01 am
pretty inventive, you are! ( others may not be so kind in their assessment.)
could you point us to some factual information that gives substance to Trent XWB engines being "limited" as you say?
Well known is that Trent 1000(non TEN) for the 787 have rather pronounced issues.
Allegedly (mostly) fixed for the Trent 1000 TEN. Overall RR seems to have production volume shortcomings.
WIederling
Tue Apr 30, 2019 7:07 am
Payload range graph says nothing about per passenger weights. Carry on.
Nominal range for nn pax is 4color brochure information. ( Boeing used to be fully over the top there. They had to fix it a couple of years ago to avoid an excess of public snickering. I'd be surprised if they over did the correction. Not in character :-)
Jetty
Tue Apr 30, 2019 10:49 am
That makes a lot of sense if Boeing’s numbers are based on the weight of USA passengers and Airbus’ numbers on European passengers. :duck:
enzo011
Tue Apr 30, 2019 10:52 pm
You will need to show that Boeing's assumptions are more conservative than Airbus though. You cannot just assert it and it is true without something to show it. What is true is that Boeing's assumptions became more conservative due to the previous ones being from some fantasy land.
So what you will need to show is that the Boeing Typical Mission Rules are more conservative than the Airbus assumptions. Just showing that they changed it doesn't mean it is true, just means they changed their assumptions to be more realistic. It could still be way off even if it is more accurate than before. You will also see on both Airbus and Boeing ACAPS payload range charts they have the following statements:
"THESE CURVES ARE GIVEN FOR INFORMATION ONLY. THE APPROVED VALUES ARE STATED
IN THE "OPERATING MANUALS" SPECIFIC TO THE AIRLINE OPERATING THE AIRCRAFT." - Airbus ACAPS
"DO NOT USE FOR DISPATCH. CONSULT USING AIRLINE FOR FOR SPECIFIC OPERATING PROCEDURE AND OEW PRIOR TO FACILITY DESIGN" - Boeing ACAPS
Basically, do not believe these numbers but check the airline manuals as they will give you the numbers for an accurate payload range. So that is why information from pilots flying both these aircraft is valuable, as they will no divulge all of the information at their disposal but they have given us enough information through the years to get an accurate picture of what either model can and cannot do.
ITSTours
Wed May 01, 2019 7:06 am
DL load factor figures for LAX-SYD (and vice versa) is just decent at 81%. (Look at United... they're definitely losing money.)
LAX772LR
Wed May 01, 2019 8:17 am
How old are these data though? ....it's still listing VA as Virgin Blue/V-Australia.
Wed May 01, 2019 10:30 am
Nice work, I take it that it BITS data ?
Not the near 100% previously claimed.
I think that is the correct name for the AOC holder, Virgin Blue International Pty Ltd. The international company is separate to the domestic as it needs to be 51% Australian owned under Australian laws to operate international.
Motorhussy
Wed May 01, 2019 11:18 am
It says Virgin Blue, trading as Virgin Australia. Which is not uncommon in this part of the world.
usax777
Wed May 01, 2019 1:46 pm
The payload-range graph depends on the empty weight. Take-off weight = empty weight + payload, so if the cabin weight is higher than the ACAPS assumes, the actual payload will be less.
WIederling
Wed May 01, 2019 3:12 pm
did I ever deny that?
and you can easily check how sane the values are. MZFW - max structural payload : OEW
ITSTours
Wed May 01, 2019 4:31 pm
Welp why didn't I write it? 2018 01-10.
ITSTours
Wed May 01, 2019 4:36 pm
Yes. it is from US BTS.
usax777
Wed May 01, 2019 5:01 pm
B's data are indeed much more reasonable now after they change it; Airbus should do the same instead of remain on the fantasy land.
I guess the impression of 'Boeing underpromises and overdelivers and vice-versa for Airbus' is not entirely untrue. For example:
B789: brochure range: 7,635 nmi, longest actual range (LHR-PHR) 7,829 nmi
A350-900: brochure range: 8,100 nmi, longest actual range (MNL-JFK) 7,404 nmi
A350-900 ULR: brochure range: 9,700 nmi, longest actual range (EWR-SIN) 8,295 nmi
Olddog
Wed May 01, 2019 5:20 pm
I guess that usax777 is moyangmm new name ?
flipdewaf
Wed May 01, 2019 5:45 pm
with a pax load of ~230 compared to a spec load of 290 so a reduction of ~6t of weight and an increase of less than 1hr range at cruise speed, hardly surprising
I’m not sure anyone has any information on this flight such as loads or actual takeoff weights
on the first flight it was noted that it landed with over 10t of fuel in reserve compared to a standard 4-5t and that it took off at~272t according to evidence from a well respected pilot on this forum. Suggesting there could have been ~13-14t of fuel uplift if required and at 5.8t/hr that’s would give around 9500nm. Seems like there is about the same amount of shenanigans going on.
Fred
usax777
Wed May 01, 2019 6:17 pm
Why don't you take into account below MTOW and extra reserve for Boeing, but you do for Airbus? I think you are biased.
Kindanew
Wed May 01, 2019 6:36 pm
But airlines don’t purchase planes based on publicly available brochure numbers.
Airbus and Boeing provide real performance data and weights and the airlines spend months crunching the numbers.
I also understand that Airbus and Boeing are contractually bound to meet the performance numbers they promise to airlines.
flipdewaf
Wed May 01, 2019 6:42 pm
Because, moyangmm, I don’t have those numbers to hand. My belief was that it was about 2.5t reserve on arrival to LHR but that number seems low to me so I didn’t think it could be right. Would you be so kind as to post them?
Fred
hooverman
Wed May 01, 2019 6:58 pm
LOL. It’s to obvious.
usax777
Thu May 02, 2019 1:30 am
Fred
I am not moyangmm. Do you really need to smear anyone who happens to agree with him or her? By the way, you do notice that the PR MNL-JFK flight has 295 seats, 30 seats below Airbus' "nominal" seating configuration right?
flipdewaf
Thu May 02, 2019 5:21 am
usax777 wrote:
Fred
Yep, I did actually, although my conclusion is that because we don’t have enough information to make a conclusion I will therefore not make a conclusion. You however, much like moyangmm, think not enough information means your are correct until proven otherwise, a poor way to determine truth.
Why don’t you read the thread on 787 vs A350 range, the information is all there. Two fine aircraft with slightly higher capabilities and so slightly higher fuel burn. If you don’t like the truth don’t just pretend it isn’t so, that’s why kids and creationists do.
Fred
Thu May 02, 2019 5:31 am
Just to clarify things, we do not live in a world without winds and ATC routes.
QF10 flight time 16:20 (236 seats)
PR129 16:40 (295 seats)
SQ21 18:20
If we assume a nil wind ground speed of 480 kts (approx cruise TAS of the A350/787), these flight times are equivalent to
QF10 7824 nm
PR129 7968 nm
SQ21 8784 nm
So PR129 carries 59 seats (approximately 6 tonnes more ) over a longer flight time than QF10. This agrees with the rule of thumb of the A350-900 vs 787-9, 5 tonnes more payload with greater range.
Francoflier
Thu May 02, 2019 5:59 am
Is this some sort of sarcastic joke I'm not getting?
Are you using the general public brochure figures as what Airbus or Boeing actually advertise to airlines?
And you are telling me that the fact no operator is sending the airplanes on routes near this vague range figure is proof that the airplane cannot do it?
I wouldn't even know where to start. A payload/range chart is not that hard to figure out, and at this stage I'm only hoping that you understand that an aircraft's range depends on so many factors, many of which are airline and/or route specific, that the figures made available to the public are merely there to give the average Joe a general idea.
In case you're wondering where the '8100' and '9700' nm range figures for the 350 come from, there are simply conversions of 15000 and 18000 km respectively, which are the round, broad figures that are printed on the public PR material that no prospective operator would even take a glance at. In the case of Airbus, they state the max range with a full tank of gas (logically), which would obviously mean a limited payload (about 25T). I'm not sure where on the payload chart Boeing takes their publicly stated range, but it doesn't matter.
It's all about much payload you can carry over a certain distance and whether a certain route is profitable depends on how many $$ you can squeeze out of every lb/kg of that payload.
The heavy payload penalty incurred on the PER-LHR route is compensated by the fact that QF can command much higher prices for the tickets.
And to come back to the topic, I realized I made an error in an earlier calculation I made upthread (unit conversion...) and it turns out that a 275T A359 can indeed easily do LAX-SYD in the winter with 35T of payload or more... There would be absolutely no need to block any seats at all, even in DL's config with 306 pax, and it could still take cargo.
moyangmm
Thu May 02, 2019 6:03 am
Why don’t you factor in tailwinds?
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
