enilria
OAG Changes 4/28/2019: AA Adds DFW-SAP/TGU,MIA-SCU;BA Exits FLL;KL Back in BOS for Winter;AM/WN/D8 Roll MAX Cuts Forward
Sun Apr 28, 2019 1:14 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
4B MCE-OAK JUN 1.2>0[1.8]
4B MCE-SMF JUN 0>1.2[0]
If not an error, significant cutback at LAX.
*4O BJX-LAX JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0]
*4O CUN-JFK JUN 1.0>0.6[1.1] JUL 1.3>0[1.3] AUG 1.4>0[1.2] SEP 1.0>0[1.0] OCT 0.9>0[0.7] NOV 1.0>0[1.1] DEC 1.0>0[1.2] JAN 1.0>0[1.1] FEB 1.0>0[1.3]
*4O LAX-PVR JUN 0.6>0[0.6] JUL 0.6>0[0.6] AUG 0.5>0[0.6] SEP 0.6>0[0.6] OCT 0.5>0[0.6] NOV 0.6>0[0.6] DEC 0.6>0[0.6] JAN 0.6>0[0.5] FEB 0.6>0[0.6]
*4O LAX-SJD JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.5>0[0.4] SEP 0.4>0[0.4] OCT 0.5>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.5] FEB 0.4>0[0.4]
7H ANC-SNP JAN 0.1>0.4[0] FEB 0>0.4[0]
AA AMA-DFW SEP 8>7[7] OCT 8>7[6] NOV 8>7[6] DEC 8>7[6] JAN 8>7[6] FEB 8>7[6]
AA BDA-DCA AUG 0.6>1.0[0.6]
AA BHM-DFW SEP 7>6[5] OCT 7>6[5]
AA CID-DFW JUN 3>4[3] JUL 3>4[3] AUG 3>4[3]
AA DFW-FLL SEP 6>5[5] OCT 6>5[5]
AA DFW-ICT SEP 6>7[6] OCT 6>7[6]
AA DFW-LIT SEP 8>9[8] OCT 8>9[8]
AA DFW-MSY SEP 9>8[7] OCT 9>8[7] NOV 9>8[7] DEC 9>8[6] JAN 9>8[7] FEB 9>8[7]
*AA DFW-SAP AUG 0.4>0.5[0] SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.6[0] DEC 0>0.6[0] JAN 0>0.6[0] FEB 0>0.6[0]
AA DFW-SJT SEP 5>6[4] OCT 5>6[4]
AA DFW-SLC SEP 7>6[6] OCT 7>6[6] NOV 7>6[6] DEC 7>6[6] JAN 7>6[7] FEB 7>6[7]
*AA DFW-TGU AUG 0.3>0.5[0] SEP 0>0.4[0] OCT 0>0.5[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0]
AA DFW-TYR SEP 4>5[4] OCT 4>5[4]
AA GGT-MIA AUG 1.4>1.8[1.0]
AA JFK-PUJ AUG 0.6>1.0[0.6]
AA MHH-MIA AUG 0.6>1.0[0.6]
Very interesting to see this back
**AA MIA-SCU DEC 0.5>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0]
AA MIA-TGU AUG 1.6>2[1.6]
AA PHL-SXM AUG 0.6>0.9[0]
AC BNA-YYZ JUL 2>3[3] AUG 2>3[3]
AC HNL-YVR JUL 1.0>0.6[0.7]
*AC LAS-YEG JUL 1.0>0[0] AUG 1.0>0[0]
AC LAS-YVR JUL 2>1.0[2] AUG 2>1.0[2]
AC OGG-YVR JUL 1.0>0.4[0.3]
AC RDU-YYZ JUL 3>4[4] AUG 3>4[4]
AC STL-YYZ JUL 4>3[3] AUG 4>3[3]
More MAX related delays to new routes. AM said they would use the E-Jets to backfill the MAX planes.
AM DTW-GDL JUN 0.4>0.2[0]
AM DTW-SLP JUN 0.4>0.2[0]
AM MEX-SEA JUN 2>1.5[1.0]
Couldn't be more clearly following Norwegian moves
*BA FLL-LGW OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.5] JAN 0.4>0[0.4] FEB 0.4>0[0.4]
Norwegian has rolled their MAX backup plan through 10/31 appears
D8 BGO-SWF AUG 0.3>0[0.3] SEP 0.3>0[0.3] OCT 0.2>0[0.2]
D8 DUB-PVD AUG 1.0>0.6[0.7] SEP 1.0>0.6[0.7] OCT 0.8>0.5[0.7]
D8 DUB-SWF AUG 1.5>1.0[2] SEP 1.7>1.1[2] OCT 1.6>1.1[2]
D8 ORK-PVD AUG 0.4>0[0.5] SEP 0.4>0[0.4] OCT 0.4>0[0.4]
D8 PVD-SNN AUG 0.6>0[0.5] SEP 0.6>0[0.6] OCT 0.5>0[0.5]
D8 SNN-SWF AUG 0.7>0[0.4] SEP 0.7>0[0.4] OCT 0.5>0[0.5]
DL ABQ-ATL DEC 3>2[2]
DL ATL-RNO DEC 0.4>0.6[0.3]
DL BOS-DCA SEP 3>0.2[0]
DL BOS-EWR SEP 1.8>0.1[0]
DL BOS-ORD SEP 2>0.2[0]
DL CUN-JFK JAN 2>3[2] FEB 2>3[2]
DL DEN-SLC NOV 7>6[7] DEC 7>6[6]
MBJ is pretty clearly response to NK. I assume PUJ is more of a block of what was likely next.
*DL DTW-MBJ JAN 0.2>1.0[0.2] FEB 0.2>1.1[0.2]
*DL DTW-PUJ JAN 0.3>1.0[0.3] FEB 0.2>1.1[0.2]
DL LGA-RSW OCT 1.9>3[3] NOV 1.9>3[3] DEC 2>3[3]
Venezuela loses another link
*ES CCS-JFK JUN 0.3>0[0] JUL 0.3>0[0] AUG 0.3>0[0] SEP 0.3>0[0] OCT 0.3>0[0] NOV 0.3>0[0] DEC 0.3>0[0] JAN 0.3>0[0.4] FEB 0.3>0[0.4]
F9 LAS-MCO JUL 0.7>0.9[1.0]
They do not move quickly to adjust their published schedule. Odd...
*FI CLE-KEF JUN 0.2>0[0.7] JUL 0.6>0[0.7] AUG 0.5>0[0.7] SEP 0.6>0[0.7] OCT 0.5>0.0[0.6]
G3 BSB-MCO JUL 1.5>1.0[0]
G3 BSB-MIA JUL 1.0>0.5[0]
G3 FOR-MIA JUL 1.0>0[0]
HA HNL-SYD FEB 1.0>0.7[0.9]
HA KOA-LIH JAN 1.3>1.0[1.1] FEB 1.4>1.0[1.0]
I had just seen an article saying IG was dropping basically all long-haul routes. Looks as if they just weren't loaded. I'm sure more QR driven propaganda drove that article and IG responded by loading the schedule.
*IG JFK-MXP DEC 0>0.9[1.0] JAN 0>0.8[0.9] FEB 0>0.7[0.8]
*IG MIA-MXP NOV 0>0.9[0.4] DEC 0>0.8[0.6] JAN 0>0.9[0.7] FEB 0>0.9[0.7]
**KL AMS-BOS NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.5[0] FEB 0>0.4[0]
LF BNA-TUP JUL 1.3>3[4] AUG 0>3[4] SEP 0>1.3[3]
MF SEA-SZX OCT 0.4>0.1[0.3]
MW LNY-OGG JUN 0>0.9[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0]
NK CLE-MCO JUN 1.3>1.9[1.0]
NK FLL-GYE SEP 1.0>0.8[1.0]
NK FLL-IAH OCT 1.6>1.0[1.3] NOV 1.3>1.0[1.5]
NK FLL-SJU NOV 1.1>0.8[0.5]
NK IAH-LAX OCT 3>2[1.9]
NK MCO-SJU JUN 1.5>1.8[1.2] NOV 1.2>0.9[0.9]
UA CHO-IAD JUN 1.6>2[2]
UA IAH-MOT AUG 0.1>0.3[0.3]
VH MDE-MIA JUN 0.4>0.7[0]
MAX cuts rolled further. I believe the cuts are loaded to something like July ~29, so a route that shows 0.1 is effectively dropped for now.
WN ABQ-MDW JUL 2>1.4[2]
WN ATL-IAD JUL 3>2.0[1.9]
WN ATL-LAS JUL 4>2[4]
WN AUS-EWR JUL 1.8>1.4[1.9]
WN AUS-LAX JUL 3>1.7[3]
WN AUS-OAK JUL 1.0>1.3[1.0]
*WN AUS-SFO JUL 1.0>0.1[1.0]
*WN BHM-LAS JUL 1.0>0.1[1.0]
WN BNA-LAS JUL 4>3[4]
WN BNA-LAX JUL 3>2[3]
WN BNA-SAN JUL 3>2[2.0]
*WN BOS-MCI JUL 1.0>0.1[1.9]
WN BWI-DEN JUL 6>5[6]
WN BWI-FLL JUL 10>8[10]
WN BWI-LAS JUL 5>3[6]
WN BWI-LAX JUL 4>3[3]
WN BWI-MCO JUL 10>9[9]
WN BWI-PHX JUL 3>2.0[3]
WN BWI-SAN JUL 3>2[3]
WN CMH-LAS JUL 2.0>1.1[2]
WN CUN-STL JUL 1.0>0.3[0.1]
WN DEN-EWR JUL 1.9>1.5[1.9]
WN DEN-LGB JUL 0.3>1.0[0.3] AUG 0.8>1.0[0.3] SEP 0>1.0[0.3]
WN DEN-TPA JUL 3>2[3]
*WN EWR-OAK JUL 0.9>0.1[1.0]
*WN EWR-SAN JUL 0.9>0.1[1.0]
WN FLL-SJU JUL 1.6>1.2[1.6]
WN GRR-MDW JUL 3>2[3]
WN HOU-SAT JUL 6>5[5]
*WN IND-OAK JUL 0.9>0.1[0.5]
WN IND-PHX JUL 2.0>1.2[2.0]
WN LAS-LGB SEP 0.1>3[3]
WN LAS-PIT JUL 2>0.4[2]
WN LAS-TPA JUL 1.1>0.3[1.8]
WN LAX-MSY JUL 3>1.8[2]
*WN LAX-OMA JUL 0.9>0.1[1.0]
*WN LAX-PIT JUL 0.9>0.1[1.0]
WN LAX-SAT JUL 2>1.6[2]
WN LGB-SJC AUG 3>4[0] SEP 0>4[0]
WN LGB-SMF SEP 2>4[3]
WN MCI-MDW JUL 8>7[8]
WN MCI-SAN JUL 2.0>1.5[1.9]
*WN MCO-OAK JUL 0.7>0.1[0.6]
*WN MCO-SAN JUL 1.0>0.1[1.0]
*WN MCO-SJC JUL 0.9>0.1[1.0]
*WN MCO-SMF JUL 0.7>0.1[1.0]
WN MDW-OAK JUL 4>3[4]
*WN MDW-PDX JUL 2>0.1[3]
WN MDW-PUJ JUL 1.1>0.3[1.1]
WN MDW-SAN JUL 5>4[4]
WN MDW-SEA JUL 4>3[5]
WN MDW-SFO JUL 2>1.1[3]
WN MDW-SJC JUL 2.0>1.6[1.7]
WN OAK-PVR JUL 0.5>0.2[1.0]
WN OAK-SJD JUL 0.7>0.2[1.0]
*WN SAN-TPA JUL 0.9>0.2[1.0]
*WN SJD-SNA JUL 1.0>0.2[1.0]
TropicalSky
Re: OAG Changes 4/28/2019: AA Adds DFW-SAP/TGU,MIA-SCU;BA Exits FLL;KL Back in BOS for Winter;AM/WN/D8 Roll MAX Cuts For
Sun Apr 28, 2019 1:15 pm
Thanks for the hard work Enilria
washingtonflyer
Sun Apr 28, 2019 1:18 pm
DL calling it quits on competition routes out of BOS?
eaa3
Sun Apr 28, 2019 1:20 pm
The reason Icelandair doesn’t take the flights out right away is because they start by zeroing out all inventory, then they spread the rebooking process over a couple of days, or weeks, to make sure they still have good customer service, and not overwhelmed costumer service staff. Then they take out the flights once that is done. However, you can’t see it in the booking engine after they zero out the inventory.
OAG really are the only ones that notice this.
adamh8297
Sun Apr 28, 2019 1:22 pm
DL pushed back the start dates on these routes until end of September. Example the 4x daily BOS-EWR starts 9/30.
Airlines flown: A3, AA, AC, AF, AM, BA, B6, CA, CO, CX, DL, EA, EL, IB, LH, MI, MQ, NH, NW, NZ, OU, PE, QF, S4, SQ, TP, UA, US, VS, WE, WN
2019: CX BOS-HKG, WE HKG-HKT, CA HKT-PEK-EWR, B6 EWR-BOS
Rdh3e
Sun Apr 28, 2019 1:27 pm
I'm just going to keep this list running until AS actually updates their schedule:
2/17: last real update viewtopic.php?f=3&t=1415825
2/24: Added one LAX-DAL Sep-Nov
3/3: One small change to August ANC-SCC
3/10: no changes
3/17: One June change to ANC-DUT
3/24: no changes
3/31: just one SNA cut
4/7: just reverses SNA cut
4/14: no changes
4/21: no changes
4/28: no changes
klm617
Sun Apr 28, 2019 1:36 pm
Interesting that ATL-RNO isn't flown at least daily.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
wedgetail737
Sun Apr 28, 2019 1:47 pm
Looks like Boutique Air is changing their EAS MCE route from OAK to SMF?
Chuska
Sun Apr 28, 2019 1:55 pm
Per Boutique's website, yes they are moving MCE-OAK to SMF starting May 15. I found the 1.2 frequency rather odd, they run a second roundtrip on late Sunday night.
sprxUSA
Sun Apr 28, 2019 2:01 pm
This part changes May 15th. Seems like an odd switch to me. I know highway 99 is no picnic lol. The MCE-LAX remains the same.
Gem State Airlines..."we have a gem of an airline"
pmanni1
Sun Apr 28, 2019 2:02 pm
Surprised a WN stronghold like MCI can't support a single flight to New England.
knope2001
Sun Apr 28, 2019 2:15 pm
Thanks as always, Enilria!
Yup, the community and Boutique both agreed to move it to SMF, believing their interline relationships with UA and AA will see more action there than they do at OAK. They have been operating 8x/week to Oakland and the Sacramento schedule is duplicating those frequencies.
Good to see them pulling the trigger on July. Last week's cuts were only June and it looked like maybe Southwest was going to do creeping cancellations only 45ish days out so they'd be selling a full July schedule until mid/late May. Southwest's summer peak schedule usually runs from about 6/8 through 8/8 so they have accounted for the the MAX grounding through nearly all of the summer bubble.
tlecam
Sun Apr 28, 2019 2:19 pm
I forget the exact reason, but it has something to do with the timing of getting the remaining gates in Terminal A back.
BOS-LGA-JFK | A:319/20/21, 332/3, 346 || B:717, 735, 737, 738, 739, 752, 753, 762, 763, 764, 787, 772, 744 || MD80, MD90
AVLAirlineFreq
Sun Apr 28, 2019 2:23 pm
No AA cuts at JFK this week? What will we all do without our weekly debate about the future of AA at the former Idlewild? :lol:
Thanks for your work on this every week, enilria!
many321
Seems 4O is about to bite dust with those drastic cuts.
clrd4t8koff
Sun Apr 28, 2019 2:29 pm
Good to see KL maintaining BOS through winter. Is this the first time BOS has had 2x (some days) AMS in winter?
ucdtim17
Sun Apr 28, 2019 2:44 pm
Another week of tumbleweeds from AS
RJNUT
Sun Apr 28, 2019 2:55 pm
Already bookable on United.com
1,782 PQM | 1 PQS | $203 PQD
Merced, CA, US (MCE) to Sacramento, CA, US (SMF)
11:41 am - 12:21 pm (40m)
4B 324 | Pilatus PC-12
Operated By Boutique Air
Economy (B)
1h 49m connection
Sacramento, CA, US (SMF) to Chicago, IL, US (ORD - O'Hare)
2:10 pm - 8:16 pm (4h 6m)
UA 976 | Boeing 737-800
Wi-Fi
phxa340
Sun Apr 28, 2019 3:17 pm
I am a huge AS fan, but their lackluster earnings (albeit they are still in the early life of their merger) and their complete lack of schedule adjustments are beginning to concern me - it’s like they are on autopilot and in this case , that’s not a good thing.
FATFlyer
Sun Apr 28, 2019 4:04 pm
Boutique has had a difficult time northbound from Merced. Southbound MCE-LAX has done OK (currently at 20X weekly).
In 2018 they reduced MCE-OAK from 12X weekly to 8X weekly. Now they want to move to MCE-SMF.
MCE-SMF will, as stated, provide connecting opportunities with UA and AA. But LAX still provides many more connecting opportunities. I don't believe the SMF move will provide a large increase in passengers.
The Merced-SMF drive is under 2 hours so connecting fares will need to compete simply driving to SMF to board a flight.
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
RJNUT
Sun Apr 28, 2019 4:13 pm
4B is hitching their post to UA and AA connections of which UA offered none at OAK.
SANFan
Sun Apr 28, 2019 4:14 pm
3/10: no changes
3/24: no changes
4/14: no changes
4/21: no changes
4/28: no changes
Thanks for keeping track of this Rdh'. I just wonder what we will see -- or not see -- from AAG next? ...
bb
tphuang
Sun Apr 28, 2019 4:35 pm
3/10: no changes
3/24: no changes
4/14: no changes
4/21: no changes
4/28: no changes
bb
Doesn't AS finalize their summer schedule by this point normally? I would think we'd have to see some adjustments, right?
Chuska
Sun Apr 28, 2019 4:42 pm
When is, or was, Alaska due to start taking deliveries of MAX?
SANFan
Sun Apr 28, 2019 4:51 pm
From RoutesOnline:
Alaska Airlines outlines 737 MAX 9 network from July 2019
By Jim Liu
Posted 10 February 2019 09:45
Alaska Airlines in the last few days opened reservation for its planned Boeing 737 MAX 9 aircraft, with the configuration of F16Y162. The 737 MAX 9 is scheduled to enter service from July 2019, although this date remains likely to change.
Seattle – Los Angeles eff 15JUL19 1 daily AS310/465 (2nd daily AS400/351 from 15AUG19)
Seattle – San Diego eff 15AUG19 1 daily AS482/539
Seattle – San Jose CA eff 15JUL19 1 daily AS344/319
Current 737 MAX 9 schedule is listed until 26AUG19 inclusive.
(Not surprisingly, current published flight numbers/dates do not match in some cases what this article reported.)
I assume deliveries were to happen sometime in June.
bb
717atOGG
Sun Apr 28, 2019 4:59 pm
Looks like MF's SEA-SZX-XMN flight is a goner, ending on September 25 (3 years after it started, which could indicate the end of the route's subsidy).
A320/321, A332, 712, 73G/8/9ER, 744, 752/3, E145, E175, CR9
Ishrion
Sun Apr 28, 2019 5:04 pm
So did AA extend DFW-SAP/TGU after the seasonal period? Because those two routes were announced a while ago.
AirFiero
Sun Apr 28, 2019 5:10 pm
Aaaahhhh, Sunday morning coffee with enilria. Thanks :thumbsup:
Wow, the Max 8 cuts are quite notable, especially from WN.
Because of a forecast for bad weather sitting on my planned route to New Orleans this coming week, I had to switch from flying the family myself to an airline flight from SJC - MSY. I can’t remember the last time I had to buy a last minute airline ticket, maybe never before, but holy crap the prices were murder. A last minute economy ticket was more than we usually pay for B/F, and the latter was $1,000 more, not worth it to us. Have any of you noticed a difference in fares possibly due to the reduced capacity, or am I just not used to the last minute fares being so high?
enilria
Sun Apr 28, 2019 5:28 pm
We've been told that is a gate issue, but I guess a one month delay isn't a big deal if that's all it is.
Interesting. WW used to do the same thing.
3/10: no changes
3/24: no changes
4/14: no changes
4/21: no changes
4/28: no changes
It's fair point, but the head of planning was announced this week. So he will probably start clearing the queue of decisions.
It's going to come back, but it is interesting they selected it to cut...and eht have clearly said they have cut the weakest routes they can cut.
So this change moved up the end date? Not surprised it sucks.
They did not operate last year in that timeframe and weren't previously for sale for that period. So they either weren't for sale at all before this or were seasonal. Don't seem like seasonal routes...
BoeingGuy
Sun Apr 28, 2019 5:33 pm
Too bad. I heard MF has the best service and product of any Chinese airline. HU being second.
Disappointing to see, but not a shock.
AirFiero
Sun Apr 28, 2019 5:37 pm
Another question...recently, someone posted a link to a website where you can put in a city pair and see all flights by all airlines on the route, one airline at a time, and even all flights at that airport in chronological order, like a schedule. I thought I bookmarked it, but I can’t find it. Does anyone have that link handy?
sargester
Sun Apr 28, 2019 5:55 pm
hallelujah I don't have to fight with anyone this week
Ishrion
Sun Apr 28, 2019 5:56 pm
Here it is: http://news.aa.com/news/news-details/20 ... fault.aspx
SAP originally announced to run from June 7th to August 17th 4x weekly.
TGU announced to run from June 6th to August 20th 3x weekly.
So it seems they're extending it to the winter.
dcajet
Sun Apr 28, 2019 6:00 pm
MIA-SCU is operating this summer and fall too. Have they added now Jan & Feb?
Rdh3e
Sun Apr 28, 2019 6:12 pm
Who's the poor soul?
deltacto
Sun Apr 28, 2019 6:15 pm
https://www.flightsfrom.com/
Sun Apr 28, 2019 6:16 pm
enilria wrote:
FAQ
How about MXP-LAX/SFO? Where those originally filed as summer seasonal thus you omitted them, or were they cut from year round to seasonal?
AirFiero
Sun Apr 28, 2019 6:23 pm
Yes! Thank you, dude!! :bouncy:
SANFan
Sun Apr 28, 2019 6:52 pm
I'd like to know as well -- to send some flowers or a large bottle of whiskey... he or she is going to need it!
Starting with a very old peak summer schedule due to begin in less than 6 weeks that hasn't been tweaked in at least 2 1/2 - 3 months, beginning deliveries of brand-new but useless MAX-9 airplanes, and the apparently world-class question of "SFO vs. PDX?" to answer, good luck my friend! I will be looking forward to seeing how quickly news and action begin flowing out of AAG.
bb
MIflyer12
Sun Apr 28, 2019 10:37 pm
In fact, MCI-BOS gets two (at least on Wed, May 1): as Delta Connection.
compensateme
Mon Apr 29, 2019 12:16 am
Nice to finally see daily (seasonal) PUJ from DTW. Quite frankly, I find it puzzling that it took DL this long — (from DTW) PUJ’s a larger market than several others with incumbent service, and many smaller Midwestern communities have daily/near daily service to PUJ (via charters).
It seems like only yesterday I took my first trip to PUJ — the ONLY flight operating into the market during the fall (a 738 from MIA). Tons of options now...
We don’t care what your next flight is.
wedgetail737
Mon Apr 29, 2019 12:28 am
I hope you both are wrong on this...but their load factors haven't been too encouraging. It's too bad considering SEA was their first US city served...if not the first in North America.
MAH4546
Mon Apr 29, 2019 12:45 am
It’s crazy. Once upon a time the only PUK service to the States was a weekly LANChile flight to Miami, a route that LAN still operates today.
a.
williaminsd
Mon Apr 29, 2019 1:48 am
May 16 faux book shows MCE-SMF-CHI at $504 RT. That's the cheapest option for that day and shortest duration (6:35). SMF-CHI RT same flight is $450. Cheapest SFO-CHI is $496 (redeye). SJC is $520. No OAK-CHI on United.
$100 RT to fly into hometown airport... Looks like they're making the effort.
Btw - One-way fares MCE-SMF as low as $28.00!
AirFiero
Mon Apr 29, 2019 1:51 am
bb
On this site, I’m surprised that we didn’t know the persons name the day before they were hired, their complete bio 10 minutes before they were publicly announced, and immediately after what kind of fruit they like to put on their corn flakes in the morning. :lol:
I thought the Max 9 didn’t have the MCAS issue?
mwmav8r01
Mon Apr 29, 2019 4:56 am
bb
I believe its MAX 7 and 10s that dont have MCAS.
Dieuwer
Mon Apr 29, 2019 2:52 pm
Is this not a MAX issue?
enilria
Mon Apr 29, 2019 5:13 pm
I take it SCU is not a beach market since it wasn't operating in Winter peak? What is the market?
bb
bb
He was Head of Alliances at AS. Now it's Managing Director of Network. Presumably the person who built their rather impressive list of code share partners. We'll see how that translates into a slightly different pond. Best of luck to him.
B747forever wrote:
enilria wrote:
FAQ
Nothing omitted. Routes only appear in this report when there is a change to the published schedule. If a route was never published for a period of time then it being gone is not a change.
Yes, but they publicly said they have now optimized to drop their poorest routes. So while I am sure it will return, it is now outted as a poor performer.
FSDan
Mon Apr 29, 2019 5:16 pm
AA's MIA-Cuba services seem to be (unsurprisingly) the best performers in the market. Daily 319s to VRA, CMW, and SCU, a daily 738 to HOG, double daily 738s to SNU, and 5-6 daily 738s to HAV. WN's TPA-HAV is another bright spot. UA and DL have reduced their service to regional jets only (although UA did make IAH-HAV daily instead of just weekly), and it seems that WN and B6 have had some struggles from FLL.
This is my signature until I think of a better one.
FSDan
Mon Apr 29, 2019 5:18 pm
I wouldn't call these 4O cuts "drastic". Their bread and butter routes in the Mexico-U.S. market are really from MEX, GDL, and MTY. These cuts (with the exception of LAX-BJX) are just beach markets that are very heavily U.S. point of sale.
