mxaxai wrote:No. Once the reversers are out and/or any noticeable braking has occured you won't attempt to go around any more. Spoilers are afaik a bit more variable since these are usually automatically deployed on touchdown, can be stowed quickly and don't actually slow the aircraft much. You have a few seconds to press the TOGA button, e. g. if you bounce.
Re failed brakes; reverse thrust alone will eventually stop the plane but the landing distance will be far greater. Here's a report of a full brake failure on an Alitalia A321 that deccelerated to ~ 40 knots within ~ 2500 m (8200 ft): http://avherald.com/h?article=43e9ebf7 Slowing to a full stop took another couple 100 meters.
AirKevin wrote:Once the reversers are deployed, you're committed to the landing. If you were to attempt a go-around with the reversers deployed and for some reason, one of them didn't stow properly, things are going to get very messy very quickly.
Thank you both. In that case, I'm guessing the main question will be whether the landing should have been attempted, or whether the pilots should have executed a go-around before landing. And of course an investigation of whether the proper landing procedures were followed and whether there were any mechanical failures. So could be pilot error or could be a mechanical failure.
Reminds me a little bit of AA1420 (https://en.wikipedia.org/wiki/American_Airlines_Flight_1420). That one was pilot error -- probably should not have landed in the conditions anyway, and did not complete the landing checklist and had not armed the autospoilers or autobrakes. Of course I'm not saying the same thing happened here and I don't intend to malign the pilots since this easily could have been a brake failure or something like that. But it was an overrun on a wet runway with t-storms in the area. Thankfully the outcome here was not nearly as bad as AA1420 (11 fatalities and many very serious injuries in that case).
Thanks also for the link to the Alitalia A321 incident. That's a heck of a loop around the taxiways. Impressive work by that crew.
