26point2 wrote:KSNA has a “Private Terminal”...2 as a matter of fact. Atlantic Aviation has been there for years. Why does the LA Times article not mention this? And only 50 GA flights per day? Have you been to SNA? Always very busy with biz jets, piston, helicopter traffic. It’s one of the busiest in this regard in the nation.
Aesma wrote:Does the 50/57 limit include small piston aircraft ?
FF630 wrote:The business Jets NB hates probably belong to a number of NB residents. LOL
wnflyguy wrote:26point2 wrote:KSNA has a “Private Terminal”...2 as a matter of fact. Atlantic Aviation has been there for years. Why does the LA Times article not mention this? And only 50 GA flights per day? Have you been to SNA? Always very busy with biz jets, piston, helicopter traffic. It’s one of the busiest in this regard in the nation.
Everyone's complaining that non airlines like JetSuiteX for example are by passing the Slot noise allocation causing more Jet noise over Orange Country.
Also these types of services are not restricted to the Local airport curfews.
In Attendants at the board meeting we're Airlines also saying Schedule service needs to fall under the allocation.
In addition The Airlines think if your flying a published schedule you should be required to use the TSA and follow all Airlines safety requirements.
Flyguy
tphuang wrote:wnflyguy wrote:26point2 wrote:KSNA has a “Private Terminal”...2 as a matter of fact. Atlantic Aviation has been there for years. Why does the LA Times article not mention this? And only 50 GA flights per day? Have you been to SNA? Always very busy with biz jets, piston, helicopter traffic. It’s one of the busiest in this regard in the nation.
Flyguy
I'm not really sure what the airlines are upset about. If JSX is not using GA slots, they will be using airlines slots. They will get at minimal 3 slots as part of the regular allocation process. And maybe they will get even more than that overtime if they ask for more. As it stands, they are not taking up any slots that would go to regular airlines and are limited in how many pasengers that they can fly every year. It seems complaints just for the sake of limiting any additional competition.
I'm assuming "The Airlines" is codeword for WN, since they are the one affected by JSX competitoin.
n92r03 wrote:Slightly off topic, but... It appears the only 757 pax service out of SNA these days is DL to ATL. Back in the day (late 90's) I think I did SNA-DEN, regardless it was a shorter flight that was maybe 50% full. Was a pretty fun takeoff.
compensateme wrote:n92r03 wrote:Slightly off topic, but... It appears the only 757 pax service out of SNA these days is DL to ATL. Back in the day (late 90's) I think I did SNA-DEN, regardless it was a shorter flight that was maybe 50% full. Was a pretty fun takeoff.
DL operates the 757 to ATL (3x-4x daily) and DTW (1x daily).
Off the top of my head, in the past, the 757 has been operated to:
UA: ORD, DEN, SFO
DL: ATL, CVG, SLC, DFW, DTW
US: PIT, BWI
AA: ORD, DFW (and STL?)
TW: JFK, STL
BoeingGuy wrote:AA has used the 757 to SJC also. And yes, STL after the merger.
I’m not aware that US ever did BWI. PIT was a 733 and A319 for awhile.
YYZORD wrote:Hopefully AC & WS can get SNA slots, WS can add YYC where AC can add YYZ and a 2nd YVR route.
jplatts wrote:There are some more nonstop routes that could be added out of SNA by AA, DL, WN, and NK if slot restrictions and limits on the total number of passengers per year are loosened at SNA, including the following:
AA - SNA-CLT, SNA-MIA, SNA-JFK, SNA-PHL
DL - SNA-BOS, SNA-CVG, SNA-JFK
WN - SNA-AUS, SNA-BWI, SNA-MDW, SNA-MCI, SNA-BNA, SNA-PDX, SNA-SLC, SNA-STL, SNA-SAT
NK - SNA-ORD, SNA-DFW, SNA-DTW, SNA-LAS
AA and WN will likely add nonstop service to additional destinations out of SNA if the slot restrictions at SNA and limits on the number of passengers per year at SNA are eliminated (or significantly loosened).
Will Congress and/or the California State Legislature enact legislation that would eliminate the slot restrictions and limits on the total number of passengers per year at SNA?
BoeingGuy wrote:compensateme wrote:n92r03 wrote:Slightly off topic, but... It appears the only 757 pax service out of SNA these days is DL to ATL. Back in the day (late 90's) I think I did SNA-DEN, regardless it was a shorter flight that was maybe 50% full. Was a pretty fun takeoff.
UA: ORD, DEN, SFO
US: PIT, BWI
TW: JFK, STL
Flyguy
JSX isn't using GA slots:
https://www.ocair.com/generalaviation/d ... ted%20(002).pdf
ARE SCHEDULED CHARTERS, LIKE JETSUITEX, CONSIDERED TO BE GENERAL AVIATION?
Operators that sell tickets to the general public and have a published schedule of two or more
flights per week during any consecutive three-week period are considered to be regularly
scheduled commercial carriers, not GA. JetSuiteX is categorized as a regularly scheduled
commercial carrier, and is subject to all of the restrictions for commercial carriers set forth in the
1985 Settlement Agreement and the Access Plan, including abiding by the commercial carrier
curfew, noise limits and Million Annual Passengers limitation.
Charter aircraft that operate “on-demand” fractional ownership aircraft requiring paid
membership and private jets not available to the general public are not considered to be regularly
scheduled commercial carriers.
UA: ORD, DEN, SFO
US: PIT, BWI
TW: JFK, STL
HP had 757's from PHX and LAS flying into SNA US had 737-500's then switched to 757's from PIT
gmcc wrote:jplatts wrote:There are some more nonstop routes that could be added out of SNA by AA, DL, WN, and NK if slot restrictions and limits on the total number of passengers per year are loosened at SNA, including the following:
The short answer is No. The settlement agreement, see link below, is grandfathered in under the Airport Noise and Capacity Act of 1990. The agreement allows for some expansion of the passenger cap from it's current limit but not a lot.
https://www.ocair.com/communityrelation ... nt/default
The only hope for more service short term is for the airport board to change the definition of what a commuter plane is. It is currently set at 70 seats. All airlines except WN support the definition of a commuter plane being changed to a plane with 76 seats. That would open up a pool of unused slots and capacity that could be used by 76 seat E175s.
SurfandSnow wrote:YYZORD wrote:Hopefully AC & WS can get SNA slots, WS can add YYC where AC can add YYZ and a 2nd YVR route.
AC and WS did get SNA slots. AC's YYZ-SNA service quickly failed, as did WS's YYC-SNA service (which quickly went seasonal - and was then cut altogether). If those services didn't work a few years ago, why would they suddenly work now?
YYZORD wrote:AC back then didn't have so much international routes like they do now from YYZ. Also YYC had many European destinations added recently and the WS/DL JV should help this time.SurfandSnow wrote:YYZORD wrote:Hopefully AC & WS can get SNA slots, WS can add YYC where AC can add YYZ and a 2nd YVR route.
