DocLightning
LH D-ABVU (B744) hard landing at PHL
Fri May 31, 2019 3:46 am
https://aviation-safety.net/wikibase/225615
Appears the aircraft made a hard landing, which caused a piece of one of the left engine cowlings to separate. Aircraft is on the ground at PHL.
Scanned the first three pages, searched under multiple terms and couldn't find any mention of it here.
Reason: Title updated
-Doc Lightning-
-Carl Sagan
Antarius
Re: LH D-AVBU (B744) hard landing at PHL
Fri May 31, 2019 4:05 am
Saw this in the news.
Interesting.
2019: SIN HKG NRT DFW IAH HOU CLT LGA JFK SFO SJC EWR SNA EYW MIA BOG LAX ORD DTW OAK PVG BOS DCA IAD ATL LAS BIS CUN PHX OAK SYD CVG PHL MAD ORY CDG SLC SJU BQN MHT YYZ STS BIS DOH BLR KTM MFM MEX MSY BWI DEN
speedbird52
Fri May 31, 2019 4:14 am
Small correction: It is LH426. On a side note it's cool that Philly is getting another 747 service
AirlineCritic
Fri May 31, 2019 4:15 am
That sounds pretty hard!
Where's the video? :-)
Plexiglass came off the left engine cowling, and the occurrence aircraft is still on the ground in Philadelphia about 21 hours after landing.
What plexiglass is there in a cowling?
djvalume
Fri May 31, 2019 5:13 am
None :)
mchei
Fri May 31, 2019 5:20 am
Yep! There’s a pic somewhere showing the LH and Speedbird 747s next to each other - nice!
It’s an A332 during winter. Before 2018, this was a LH CityLine route on an A343.
F70-F100-E145-E170-E190-319-320-321-735–736-737-738-752-763–742-744-333-343-ATR72-Metroliner-Saab2000-Lockheed Electra-C172-C182-C182RG-MD11
acentauri
Fri May 31, 2019 5:50 am
mchei wrote:
Yep! There’s a pic somewhere showing the LH and Speedbird 747s next to each other......
PHL- https://pbs.twimg.com/media/D3OhENsWsAEn23u.jpg:large
speedbird52
Fri May 31, 2019 7:26 am
Gorgeous
stylo777
Fri May 31, 2019 7:52 am
LH doesn't have 332's; you probably mean 333 in winter?
DABYT
Fri May 31, 2019 8:26 am
Small typo in the title: it’s D-ABVU.
usairways85
Fri May 31, 2019 12:25 pm
It appears you can see this LH 744 in the distance on the deicing pad of the PHLAirport twitter picture.
https://twitter.com/PHLAirport/status/1 ... 4459027466
mchei
Fri May 31, 2019 3:43 pm
You’re right of course. Sorry!
hmmwv
Fri May 31, 2019 5:51 pm
Considering it's a 744 I'm surprised no one has asked if it's a write off. :)
Aircellist
Fri May 31, 2019 6:09 pm
Now, that's cool! 8-)
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
PHLspecial
Fri May 31, 2019 6:18 pm
So the B744 is parked at a deice stand and waiting for crews to look at the damage and fix it.
On June 2nd A340-600 will be substituted for the B744 according to the Philadelphia thread.
Would like to mention there were severe storms and a tornado in the area.
DAILN
Fri May 31, 2019 7:04 pm
Sorry, but no storms at time of landing. There was a small system considerably northeast of airport and he may have passed through it, but all was fine at airport. A larger and stronger system passed over airport later in day after aircraft had already been moved to the deice pad. Approach was fine, but he may have caught a gust after touching down initially - only speculating. Aircraft will likely remain at least through Sunday if not longer. Next eight days scheduled to be operated with D-AIHU. Appears it will ping pong back and forth. This aircraft normally based at MUC.
mchei
Fri May 31, 2019 9:26 pm
Does LH need the capacity of an A346 for FRA PHL during summer that they even need to move an aircraft from MUC to FRA for it?
I mean LH has quite some planes based in FRA like 343, 744, 748.
DAILN
Fri May 31, 2019 9:45 pm
One B744 out of service indefinitely and others are needed for various other routes. B748 cannot be accommodated at PHL gates due to taxiway restriction. A346 is closest remaining aircraft in fleet when it comes to capacity - still has 74 less seats than B744. The A346 can easily be swapped between FRA / MUC - both hubs operate them. At moment the PHL flights are already at capacity with the originally planned B744 so this to minimize disruption.
mchei
Fri May 31, 2019 10:26 pm
Danke dir!
LH had sent a 748 to PHL a couple of weeks ago (saw it on FR) and last time I flew to PHL (around end of October 2018) the load factor of the A333 was at about 80%. Seems to be more during summer.
BTW, seeing your name: D-AIPA is scheduled to leave the fleet by the end of June. Just saying ;)
spudsmac
Fri May 31, 2019 10:58 pm
Not sure how it happened. Maybe a little wake turbulence during the flare from a preceding airplane. That's all I can think of. Here's a page from the Flight Crew Training Manual that shows what it takes to have a cowling strike on landing. I'm guessing they had a pitch of around 4 degrees on landing so they probably rolled around 6 or 7 degrees. It's a GE bird so use that line on the graph.
https://imgur.com/XeLM2rQ
DAILN
Fri May 31, 2019 11:10 pm
Yes, the B748 went to a hardstand and had about a three hour ground time - not the LH standard. FRA planned another one about two weeks after that, but fortunately switched back to B744. Actually D-AIPA had last official flight on Wednesday BRU-FRA. Did a flyover at Airbus on Tuesday and possibly also over Buxtehude which was it's given name. It is close to HAM.
PHLspecial
Sat Jun 01, 2019 12:03 am
Hypothetical scenario. What if the aircraft is deemed not worth the cost of fixing and is written off. What would be the procedure for PHL and LH?
spudsmac
Sat Jun 01, 2019 12:06 am
Doubt that would happen but even if it was, it would get a temp fix, then fly it somewhere for a permanent repair or scrapping. Delta did that with their 747 when they flew it into a storm over China and had a bunch of hail damage. Did temp fix then flew to the boneyard.
DAILN
Sat Jun 01, 2019 2:56 am
As spudsmac states, unlikely that it would be scrapped at PHL. Damage is considerable, but LH will do everything to get this a/c back into rotation. Checks are still ongoing, so it appears that it will be parked for some time.
DAILN
Wed Jun 12, 2019 2:16 pm
Maintenance work began this morning...new engines planned to arrive tomorrow. Still on position at de-ice pad.
