AsiaTravel
Updated: Air Astana incident caused by inverted aileron control
Sun Nov 11, 2018 2:27 pm
Whatever is happening with the plane does not look normal at all. I hope everything is fine with them.
Flight Path:
https://www.flightradar24.com/KZR1388/1e84fc24
Live ATC of LIS:
https://www.liveatc.net/search/?icao=lis
Reason: Title updated after threads have been merged
anshabhi
Re: Air Astana EMB 190 Squawking 7700 currently on an erratic flight over Lisbon
Sun Nov 11, 2018 2:33 pm
Where is it headed..? Doesn't look like it going towards any airport
Ohhhh just read the title. Very very sad and serious
rutankrd
Looks like a test flight out Alverca after maintenance to me
colingally
Re: Air Astana EMB 190 Squawking 7700 currently on an erratic flight over Lisbon asking permission to ditch in ocean
Sun Nov 11, 2018 2:34 pm
Listening to ATC at Lisboa, it sounds like it will be a sea landing!! Thoughts to everyone on board...
anshabhi
Sun Nov 11, 2018 2:37 pm
It's gaining altitude and speed now
colingally
Sun Nov 11, 2018 2:38 pm
Sounds like they have minimal control of the aircraft.
trnswrld
Sun Nov 11, 2018 2:40 pm
Whoa, that has got to be the most erratic flight path I have ever seen. Whatever is happening doesn't look good. :-(
Arion640
Sun Nov 11, 2018 2:42 pm
Flying in a straight line now. Looks like they may have some sort of control.
OA940
Sun Nov 11, 2018 2:43 pm
Definitely out of control. Pilots stated they intend to ditch at first. Now on liveATC they have asked for an airport with good weather.
A350/CSeries = bae
colingally
Sun Nov 11, 2018 2:44 pm
Heading east, currently trying to land at a good weather airport. Sounds like they have more control of the aircraft now..
dtwpilot225
Where are they heading east now?
AWACSooner
Sun Nov 11, 2018 2:45 pm
Headed on a straight path towards Spanish airspace now...slowly gaining altitude (FL190)
snn2003
This is scary. Best of luck to those onboard.
On behalf of your entire Boston based crew, thanks for flying with us today.
colingally
Sun Nov 11, 2018 2:46 pm
Being directed to turn 195 towards airport 75 miles away...not doing it so far...
Pexinho78
Sun Nov 11, 2018 2:47 pm
IS being directed to Beja Airport BYJ/LPBJ
dtwpilot225
Sun Nov 11, 2018 2:48 pm
Looks like they are headed there
anshabhi
Sun Nov 11, 2018 2:49 pm
plane is under control now!! great !!
colingally
Airplane under control now says pilot but needs good weather
crescent
Sun Nov 11, 2018 2:53 pm
What is the deal with this plane? It's last flight on fr24 shows MSQ-LIS over a month ago.
AWACSooner
Sun Nov 11, 2018 2:54 pm
Assume this was a delivery flight from Brazil to Kazakhstan?
KLASM83
Sun Nov 11, 2018 2:55 pm
Man, this is nutty! I hope they get down safely! Would like to hear the cause behind this one.
"The goodness of the true pun is in the direct ratio of its intolerability" -Edgar Allan Poe
Don't you want to hang out and waste your life with us?
GianiDC
Sun Nov 11, 2018 2:56 pm
Very likely heavy maintenance at LIS. This seems to be the first flight after.
soflaflyer
Sun Nov 11, 2018 3:00 pm
Did they remove the flight from FlightAware? Not able to see it. Any other comparable sites?
Virtual737
Sun Nov 11, 2018 3:01 pm
It's still there. Callsign KZR1388 on flightradar24 at least.
anshabhi
1388 is also not a regular flight for KC
Arion640
Sun Nov 11, 2018 3:02 pm
Flightradar24 has it.
Arion640
Sun Nov 11, 2018 3:07 pm
Coverage has stopped just over a large lake for me...
OA940
Just went off FR's radar. This can't be good.
A350/CSeries = bae
MileHFL400
Sun Nov 11, 2018 3:08 pm
Ditched on the lake?
Thanks and best Regards
AA
trnswrld
So I’m showing the track stopped pretty much over that lake. Hope everything is ok.
raylee67
Sun Nov 11, 2018 3:09 pm
When coverage stopped, it has just descended thru 3125 ft. That's the last reading.
319/20/21 332/33 342/43/45 359/51 388 707 717 732/36/3G/38/39 74R/42/43/44/4E/48 757 762/63 772/7L/73/7W 788/89 D10 M80 135/40/45 175/90 DH1/4 CRJ/R7 L10
AY LH OU SR BA FI
AA DL UA NW AC CP WS FL NK PD
CI NH SQ KA CX JL BR OZ TG KE CA CZ NZ JQ RS
ktof
Probably due to a lack of satellite signal, seems to be a bit in the middle of nowhere so probably not many FR24 receivers round there.
colingally
Always scary to see the tracker stop tracking but it happens regularly...hoping it's the same here.
scbriml
Sun Nov 11, 2018 3:10 pm
That's still about 10km from the airport.
GianiDC
Sun Nov 11, 2018 3:11 pm
I guess bad reception in lower altitude.
MileHFL400
3000ft 10kms away from the airport seems about right
AA
FlyingLaw1
Sun Nov 11, 2018 3:13 pm
That flight path and Squawking 7700? Something is clearly wrong.... Hoping for the best...
colingally
Sun Nov 11, 2018 3:14 pm
Reports coming in it was a successful landing at Beja.
ktof
Confirmed by volunteer emergency teams in Portugal that the plane landed successfully on runway 19R at Beja
silverado6x6
Sun Nov 11, 2018 3:15 pm
Been watching it as well until it just repeats itself, some major altitude changes!
A3801000
Sun Nov 11, 2018 3:16 pm
UPDATE on flight #KC1388 has SAFELY landed on runaway 19R of Beja airbase, after losing several system and attempted to land. Scorched by 2 F16 jets.
From several twitter sources. Not verified.
soflaflyer
Sun Nov 11, 2018 3:17 pm
Wonderful news, thanks for confirming
Dutchy
Sun Nov 11, 2018 3:19 pm
Good news.
OA940
Sun Nov 11, 2018 3:23 pm
If FR24 is to be trusted they were flying out of control for one entire hour! Amazing job by the crew! Glad to see it all ended well
A350/CSeries = bae
trnswrld
Sun Nov 11, 2018 3:25 pm
Wow, incredible. I bet those pilots are kissing the ground right now.
Pexinho78
Sun Nov 11, 2018 3:28 pm
3 atempts to land in Beja , but landed sucesfully
Dutchy
Sun Nov 11, 2018 3:31 pm
Great job by the crew.
Could we change the title, please?
