justloveplanes
Re: Rumour: 777X First Flight Likely Delayed to Year End Due GE9X Issues
Tue Jun 11, 2019 12:19 am
keesje wrote:
If GE invested so much in the GE9x there would pressure to get significant ROI and the 777X program, as it looks now, won't offer that. Probably they will go for a GENX upgrade using new technology, to become available around 2025, like the geared Ultrafan.
TBD on the 779. Cathay Pacific's CEO saw something he said impressed him very much on the 779 that he would order 20 more (an earlier forum topic). Have to see what that is, but it might be early data on the engine. It was never clear from the topic thread what exactly he saw, just that he was very impressed. So we can expect some expansion out of this.
Just a rough guess, but one would have to expect Boeing built the 777x business case around a 500 or so frame target.
GEnX CMC PiP would be very good about now.
Chaostheory
Re: 777X First Flight Delayed to Year End Due GE9X Issues
Tue Jun 11, 2019 12:41 am
lightsaber wrote:
RR simplifies engines to reduce development cost, reduce development time, and reduce overhaul costs. These simplified engines burn more fuel. E.g., GENx vs. T1000. Not enough to stop sales, but there is a cost.
Lightsaber
Wrong here too.
Trent 1000 has much lower takeoff and climb burn, no difference in cruise and only slightly higher idle fuel burn.
Revelation
Tue Jun 11, 2019 12:47 am
Chaostheory wrote:
Lightsaber
Wrong here too.
Better send that info on to AirNZ, they just kicked T1000 to the kerb because GEnX could deliver more range.
Chaostheory
Tue Jun 11, 2019 12:51 am
Revelation wrote:
Chaostheory wrote:
Lightsaber
Wrong here too.
I have the respective performance manuals and there isn't a whisker of difference in trip fuel burn.
If engine A had llps hitting cycle limits at 10k versus engine B at 5k, which would you be inclined to buy?
There is quite a bit more to engine procurement decisions than just fuel burn you know.
ikolkyo
Tue Jun 11, 2019 12:52 am
Revelation wrote:
Chaostheory wrote:
Lightsaber
Wrong here too.
Better tell all the other airlines that went GE too, there is a reason they are the leading engine on the 787.
Chaostheory
Tue Jun 11, 2019 1:03 am
ikolkyo wrote:
Revelation wrote:
Chaostheory wrote:
Wrong here too.
Airlines don't play Top Trumps.
The RB211 on the 757 burns anywhere from 4-8% more than the Pratt (depending on mods) yet it still had more customers. The GTF on the neo has an appreciable fuel burn advantage over the leap which will widen when the PIPs become available in the next 12-18 months, yet the leap to my knowledge is the better seller.
acavpics
Tue Jun 11, 2019 1:21 am
Good. Let Boeing, GE and the FAA actually take their time with this one. The last thing we need is a 777 MAX.
YellowJ
Tue Jun 11, 2019 1:29 am
Please stop spouting nonsense.
RickNRoll
Tue Jun 11, 2019 1:41 am
lightsaber wrote:
FrenchPotatoEye wrote:
lightsaber wrote:
The GE9X is the mist ambitious engine ever. It is a full generation ahead of anything else. So delays are a risk of that level of technology.
Lightsaber
Could you expand on that?
I echo Zekes remarks to be honest. I see nothing substantially new or ground breaking???
1. CMCs, first engine with the tech in commercial service.
2. High Mach # compressor.
3. Enhanced variable cycle tech. For certain the variable turbine cooling of the LEAP. I see actuators being bought for more, but I do not know the specifics.
4. Far more cooling systems than I've ever seen. The turbine clearance control is two generations ahead of anything I've ever seen. In fact, it is was Lefebvre (one of the great chief engineers of engine design) presented in 1995 to graduate students (me), GE, Pratt, and RR. Apparently another grad student listened and made sure this happened. The problem for me is which of my three grad school friends who attended that lecture made it happen. And which of Lefebvre's variable cycle ideas..
5. Low turbine tech. See LEAP-1B and take it a generation forward. Traditionally, I have been a fan of Pratt being the leader here, but GE stole the right Pratt people. See the incredible efficiency bump of the PW1100G with the low turbine enhancement.
6. Fan blade tip Mach number, without a GTF a required tech for installing the low turbine tech. You get one guess why Pratt is so far behind in this tech.
7. Enhanced materials in combustor (less cooling air)
8. Finally imitating Pratt in modeling airflow through the whole engine. Engines are a system and tweaking how air flows from:
a. Low compressor to high, the GE-90 and TrentXWB botched this to the tune of 1 to 1.5% system fuel burn. Hint, the director if Pratt engine development warned of this botch with the PW6000 early in his carrier. I'm quite certain Steve will never allow this to happen again.
b. High compressor to pre-diffuser. GE was always good at this, modern modeling has allowed a nice fuel efficiency increase.
c. High turbine to low turbine. Seriously, compared to Pratt the LEAP and Txwb are amateur hour here. Seriously? Pratt has only been mocking GE and RR on this since Pratt won the F119 vs. F120 clearly on this tech. I only mention military for the clear' this tech is awesome!' timeframe.
But the people who focus on component efficiency do not get how to maximize system efficiency. 'How can the engine burn 2% less fuel by making the low compressor 1/4% less efficient?'. Because that makes the high compressor and pre-diffuser that much more efficient... Sigh...
Then there are a bunch of little technologies GE is just good at such as pre-diffuserss and shorter combustors. Not to mention fans. GE invests more in fan design because they are the least ready for GTFs. Oops.
The Mach numbers in the high compressor still are not at what that one lecture discussed. That is because bearings and seals are not there (see PW1100G issues).
I like how people who don't understand the internals of an engine mock me. Everything I listed is a generation ahead. Everything presents risk being a generation ahead. That means the first flight delay when risk is realized.
I haven't yet begun to discuss what wing efficiency is enabled by folding wing tips. I could do a wing with 4% better L/D than the A350 wing, but only with the aspect ratio. At least I wouldn't do it without that extension to mitigate the risks. Nor have I discussed Boeing's latest take on electrical subsystems. I'm still scratching my head
I work aerospace R&D. I've been exposed to a lot. If you need an example of when adding weight improves a product, see A330NEO (extended wingspan that is heavy and much heavier engines)
Lightsaber
I don't recall anyone ever mocking you. Great discussion of the multiple technology paths the engine companies are taking. None of them are capable of owning the whole technology space so they all focus on the subset they can move forward of the pack with.
I agree that the bleeding edge can cause a lot of problems. I work in the IT sector and have many painful experiences of new technology causing massive disruption, and not in a good way. Fortunately you don't kill anyone if your new technology fails when it doesn't move from ground level.
IIRC when the GE90 first appeared it had numerous problems too but they were managed carefully and the GE90 is now highly reliable and respected engine. Without it the 777 would not have been the success it was.
Maybe this is not the time to be taking any risks, though.
musman9853
Tue Jun 11, 2019 1:53 am
SFOtoORD wrote:
Can you explain the logic of your post or some data to back it up? I don’t follow the point.
ge's spending a lot to develop the tech in th ege9x, they'll likely want to bring that tech to other engines like for the 787
Welcome to the City Beautiful.
lightsaber
Tue Jun 11, 2019 2:22 am
Revelation wrote:
Chaostheory wrote:
Lightsaber
Wrong here too.
Trent does have lower takeoff and climb fuel burn. Data I've seen, GE has 2% lower cruise fuel burn, equal fuel consumption at 4000nm.
GE has longer overhaul intervals, but less than 10k in practice. Much longer than RR if flying into highly polluted cities right now.
No engines are ever identical. If RR matched or burnt less fuel at all stages, early sales would have been better.
The GEnX has slightly more range, for a given payload.
I fully expect half of the new GE9x tech to make it's way into the GEnX.
The T700 outsold the CF6 on the A330 for good reason. Just as the smaller diameter CF6 outsold the RB211.
The GE is winning on maintenance and payload at range on the 787, but the competition continues.
But this is a GE9x thread. A complicated and risky engine. I believe an engine that will sell very well. But it looks like risk has been realized in a time delay.
Lightsaber
You know nothing John Snow.
DenverTed
Tue Jun 11, 2019 2:42 am
2025 for the geared Ultrafan? I thought there was no way Boeing/CFM could deliver 2025 for the NMA? How's the Ultrafan do it then?
I think a 2030 EIS on the Ultrafan is more realistic. Gives the 777 burrito supreme a window. I don't think it will sell in huge numbers, but 500 seems plausible.
gatibosgru
Looking forward to seeing it in the air!
@DadCelo
Chaostheory
Tue Jun 11, 2019 3:09 am
lightsaber wrote:
Revelation wrote:
Chaostheory wrote:
Wrong here too.
Lightsaber
You brought the T1000 and GEnx-1 into this discussion.
I'm referring to llp cycle limits not shop visits for overhaul and performance restoration. The two don't go hand in hand. That was clear. You are an engine guy right?
Whichever way you look at it, cycle limits for LLPs or EGT deterioration, the Trent loses.
No cruise advantage to the GEnx-1. For an 8 hour sector, the trip fuel difference would be less than 3 digits. In other words, it's not even worth mentioning. I've verified that by double checking our performance planning manual from Boeing flight ops engineering against the numbers I have from Ethiopian, BA and Qatar.
smartplane
Tue Jun 11, 2019 4:08 am
Chaostheory wrote:
Lightsaber
Wrong here too.
One difference is in PBTH / prepaid maintenance. RR is harsher on 'exceptional use' penalties, which make it less likely if EK proceed with the 787, it will be RR powered. However, RR will fix prices for longer. Most GE engine maintenance plans are 1-3 years (5 years is the exception), then re-priced rollovers. In contrast, RR will fix flat 10-12 years (14 for EK).
justloveplanes
Tue Jun 11, 2019 4:13 am
Lightsaber
Your data agrees with lightsaber's or close to it. 4000nm at 8 hours is 500 knots or about 575mph... about the cruising speed of a 787. It would appear then, that the Trent is better below this Mark and the GE better above it. How much the change is away from this transition point is an interesting thing....
Chaostheory
Tue Jun 11, 2019 4:32 am
As I said, the difference is negligible and it doesn't diverge. The longest sectors I compared were against BA's South America sectors which can exceed 14 hours.
I don't know of any airline where 787 engine selection has boiled down to fuel consumption. It just isn't a factor.
When did a.netters become so one-dimensional?
justloveplanes
Tue Jun 11, 2019 5:27 am
I am not saying fuel burn is the only factor. I was just pointing out the datum in question that was raised (8 hours / 4K nm) was convergent. Your point of there not being a difference at 14 hours is new and interesting info.
downdata
Tue Jun 11, 2019 5:31 am
What does fuel burn or Genx or RR have anything to do with the GE9X issues?
marcelh
Tue Jun 11, 2019 6:05 am
Probably trying to deviate from the rumors about the GE9X issues, I guess. I only hope that the 779 flies asap.
Checklist787
Tue Jun 11, 2019 6:55 am
GE and Boeing already offer a significant Roi as the market has chosen the Boeing 777X / GE9X tandem.
Ultra Fan will not be available in 2025, but rather 2029-2030.
It's a very long time ... :roll:
We only hope that reliability will be there. It is the most important. Given the gloomy news of his last months
Airlines will wait
Tue Jun 11, 2019 7:14 am
lightsaber wrote:
Ok, I'll update first major use if CMCs in the turbine. Yes, CMCs as coatings have been forever.
But what parts, other than ciatings or guide swirlers?
It happens the turbine CMCs are a milestone the industry has been waiting for 35 years.
That is a major leap forward.
I was working with PMCs, MMCs, CMCs, weaving and stitching in the 1980s. This is not some new technology that has only just arisen recently.
In the mid 1990s Safran used SEPCARBINOXR A262 and CERASEPR A300 on the M88-2 engine. They went on to make mixers, nozzles, combustor liners (from CERASEP A410/A415). In early 2000s Japan was building CMC combustor and turbine blades. I know CMC nozzles and turbine shrouds have flown on the Trent 800.
RR developed dual wall CMC turbine blades as part of the FAA CLEEN program ( https://www.faa.gov/about/office_org/he ... r_2014.pdf ), the same program that GE developed TAPS under.
LAX772LR
Tue Jun 11, 2019 7:32 am
Interesting, like what? Would love to know more.
PW100 wrote:
Missed one . . .
Olympus?
keesje wrote:
than put all your money on 1 horse. That isn't winning the hearts everywhere so far. E.g. US.
Sincerely doubt Boeing ever expected the aircraft to be much of a seller, if at all, with US airlines..... *maybe* replacing AA/UA's 77Ws some 20yrs down the road, but that's about the foreseeable extent of it.
BlueSky1976
Tue Jun 11, 2019 9:00 am
If Boeing didn't expect the aircraft to be "much of a seller", it wouldn't start the program. It's got a reasonably healthy backlog with just the beginning of the 777-300ER replacement cycle. The loss of Etihad won't hurt much. I'd expect more sales to come in the next 5 - 10 years, once current orders are delivered. I'm sure that at least 400 - 500 of 777X family aircraft will end up being delivered over its lifespan (don't forget that some of those will eventually replace A380s and passenger 747-8s).
It's sad that "6 month delay" is the new norm, though...
Tarriffs are taxes. Taxation is theft. You are not entitled to anything.
If it's a Boeing, I'm not going.
BoeingVista
Tue Jun 11, 2019 9:10 am
Lightsaber
OK, well this is a great OT argument Lightsaber, but back to the actual problem with the GE9X, what is it and how long do you think it will take to resolve?..
BV
Max Q
Tue Jun 11, 2019 9:21 am
I find that really hard to believe, 4-8 %
more burn for the RB211 on the 757 is
a massive difference
tomcat
Tue Jun 11, 2019 9:22 am
Lightsaber
This thread is a non-sense. What the article posted in the opening post says is that
While Boeing and GE expect to have a fix ready soon, the first flight is likely to slip into July, if not later.
The GE9X problem is about to be solved, it will only take a few more weeks than expected, not 6 months.
Carmitage
Tue Jun 11, 2019 9:45 am
Revelation wrote:
Some people may have made a similar comment about the GE90 a year or more before 777's first flight, and we all know how that turned out.
You may find this link to be helpful.
Don't forget the GE90 was an absolute dog (so reliable BA used it on London to Paris, which is somewhat embarrassing for a long haul aircraft), it had sub 20% share and GE wrote off $1bn and told the market that was it. However, it wasn't and GE could either write off another $1bn (which would have messed up McNerney's chances of succeeding Jack Welch) or invest another $1bn buying their way to an exclusive position onto the long range versions of the 777, which were expected to be niche products.
The resulting GE90B was an absolute gem and airlines discovered that if they didn't need the range they could load up the belly with freight and nobody wanted the mainstream 777s anymore.
FrenchPotatoEye
Delays or not, Reuters is reporting Korean air Lines is going to order 777X and Parisian Airshow next week.
keesje
Tue Jun 11, 2019 9:54 am
Lightsaber
I think there are signs (Muilenburg, Zeke, Avweek) from multiple angles. If you need wait for Boeing to state officially (kicking, screaming, deflecting, generalizing), you are always at least 2 months behind the deed.
Carmitage
Tue Jun 11, 2019 10:07 am
The Rolls-Royce version of events is that the -535 did burn more fuel as a new engine (not sure it was as much as 4-8%), but the degradation was much less (the triple spool engine was shorter, so had less whip, reducing the wear on the abradable seals) so the fuel burn through the life of the engine was less - ie if you selected on the basis of initial fuel burn, you went for P&W; through-life, go to RR.
They also were very reliable and sat on the wing for a very long time (vs peers at the time).
CHRISBA35X
Tue Jun 11, 2019 10:08 am
I heard a whisper that TG were going to sign up for some 779Xs this year to replace their 744 and A388 fleets. Would be pretty compelling on the Europe - Aus trunk routes. Alongside the KE order it makes sense. Lets see what Paris brings.
keesje
Tue Jun 11, 2019 10:20 am
That would be a good win for Boeing. Airbus and Boeing have been competiting for the 777 replacement a Korean for a long time.
https://www.reuters.com/article/us-france-airshow-orders/planemakers-race-for-wide-body-orders-in-asia-showdown-idUSKCN1TC0WI
PW100
Tue Jun 11, 2019 10:48 am
LAX772LR wrote:
PW100 wrote:
Missed one . . .
Olympus?.
While I applaud you for the excellent suggestion, actually I was thinking along the lines of my username :-)
Checklist787
Tue Jun 11, 2019 11:27 am
Nothing surprising for me.
I have NEVER seen the 777-X as a bad seller.
The Triple 7 continues its history for me... :roll:
Waterbomber2
Tue Jun 11, 2019 12:05 pm
Yeah but the RB211 are more powerful, more durable, more reliable and easier to maintain.
Waterbomber2
Tue Jun 11, 2019 12:07 pm
It always starts with whispers, so you should get that checked.
Can you see what's whispering at you? :ghost:
musman9853
Tue Jun 11, 2019 1:00 pm
this might be the first airshow where the only orders boeing gets are widebody orders
Revelation
Tue Jun 11, 2019 1:03 pm
Agreed, the problem child ended up being a major star, which supports my point that one should not rush to judge so early in the game.
Add that to the rumor about China interested in 100 787/777X (which obviously will take a while to sort out due to current circumstances, yet in the end IMO will happen) and it should be an interesting buying season.
marcelh
Tue Jun 11, 2019 4:31 pm
Reading a lot of comments, I get the impression that the 779 won’t sell. If an airline needs the capacity and is able to fill it, they will buy the plane. And how “superior” it will be to the A35K remains to be seen. Time will tell.
Checklist787
Tue Jun 11, 2019 4:51 pm
And Iran Air who wanted to order 15 777-X and 15 777-300ER then been boycotted.
Anyway the 777-X arouses a strong interest... :roll:
Revelation
Tue Jun 11, 2019 4:52 pm
Thing is, blue chip carriers like BA, CX, QR and EY have found room for both in their fleets, so it doesn't seem to be an "either/or" proposition.
Carmitage
Tue Jun 11, 2019 6:20 pm
Agreed - the minimum economic number of a wide body type in a fleet seems to be decreasing - maybe 10 for the A380 and 10-20 for other types - as pilots tend to single routes (?) so the pilot pool is less of a problem. Presumably with long term service agreements, this becomes even easier as the maintenance issues are covered by a monthly cheque rather than having to maintain the skill base to look after multiple types. Contrasts with NB, where it seems like 200 or so seem to be required (i.e. a total fleet of over 400).
I suspect that LTSAs also make swapping engine types (Emirates on the A380, ANZ on the 787) much easier too - is there any pilot training required to fly a Trent 1000 engine 787 or a GEnx one?
stephanwintner
Tue Jun 11, 2019 6:49 pm
lightsaber wrote:
2. CF-34 (first 'high bypass')
Lightsaber, Um, TF-39 first ran in 1964, TF34/CF34 first run is 1971. I'd always regarded TF39 as the "first high bypass", which led for the CF6 first models and the JT9D a couple years later. (Granted, I got those dates from Wikipedia).
Can you clarify ? Why is the CF34 on your list and the TF39 not on your list ?
Stephan
GoSharks
Tue Jun 11, 2019 7:04 pm
You missed "with US airlines."
lightsaber
Tue Jun 11, 2019 7:15 pm
Stephan
Mistake on my part. Fist commercially successful high bypass.
Anyway, everyone has a different list.
Lightsaber
9Patch
Tue Jun 11, 2019 8:57 pm
With the demise of the A380 program the 777X is the only passenger VLA on the market.
That should be good for a few more sales.
Dutchy
Tue Jun 11, 2019 9:05 pm
What's up with engine manufactures lately, seems that every new model has issue's with the new engines and even got delayed.
smartplane
Tue Jun 11, 2019 9:13 pm
Perhaps another reason for a delay, is review of FAA compliance maturity accorded to Boeing, which underpins the level of self-approval for the MAX and X? Required / actual processes for the MAX are being traced from inception to now, and have already extended to the NG. Seems likely the X will be included, and Boeing will be keen not to link MAX and X, so attribute to GE? Silver lining, is GE have more time to make other improvements.
zkojq
Tue Jun 11, 2019 10:23 pm
Agreed. For nearly all missions, the 787-10 is a far superior platform. Boeing has optimised the 777-9 for ULH ops, so on shorter routes the 787-10 has much better economics. Even more so if there is substance to the 6t extra MTOW bump.
First to fly the 787-9
