Interflug74
German DFS denies transfer flight trough german airspace of an Norwegian 737 Max
Wed Jun 12, 2019 6:24 pm
https://www.focus.de/finanzen/boerse/we ... 19845.html
After holding in french airspace, german DFS (Deutsche Flugsicherung) denies entering german airspace to an Norwegian 737 MAX, and the flight had to land in french Châlons Vatry.
I thought ALL flights of the MAX are halted in this moment? How can they take off in Spain and countinue to France in the first place?
litz
Re: German DFS denies transfer flight trough german airspace of an Norwegian 737 Max
Wed Jun 12, 2019 6:27 pm
Ferry movements are governed under special flight rules (and one time permits)
WayexTDI
Wed Jun 12, 2019 7:59 pm
The 737 MAX has been grounded worldwide for almost 3 months now; why did it take so long for Norwegian to ferry one of their planes back? Sounds like poor planning on their end.
Chemist
Wed Jun 12, 2019 8:11 pm
:lol: I'm sure the Germans weren't going to let it land at Berlin's new airport!
sciing
Thu Jun 13, 2019 5:02 am
There are 300 moves each day on the runway for the later BER.
https://www.berlin-airport.de/en/_docum ... SXF-EN.pdf
ikolkyo
Thu Jun 13, 2019 5:44 am
737 MAXs have literally been flying daily since the grounding. Just as ferry flights and mostly Boeing moving aircraft around/testing.
PatrickZ80
Thu Jun 13, 2019 6:01 am
They were just pestering Norwegian.
I'm sure within a few days this plane will continue to Stockholm, only this time without overflying Germany. They'll fly straight north, over the Netherlands and then over the North Sea towards Norway. Once north of German airspace they'll bend off to the east towards Stockholm.
CXfirst
Thu Jun 13, 2019 6:03 am
You don't have any idea about their operational needs.
It could be simply that they now have knowledge of what the eventual fix will be and it requires it to be done in Stockholm, or simply the frame is coming close to some scheduled service, or a whole other heap of operational needs.
So, why does it matter if the ferry flight was done a day after grounding or 3 months? It was approved by EASA and Eurocontrol, just denied by Germany (and France) after it was already in the air.
ei146
Thu Jun 13, 2019 6:07 am
Not all i's dotted and t's crossed on some request form?
zkncj
Thu Jun 13, 2019 6:53 am
All depends on the situation, e.g. originally it might of just been an simple software fix that could be done in remote locations. And Norwegian now has more infomation it was now best to fly it back to one of there bases.
Or it could even been they have only just got given there ferry permits to bring the aircraft home. I can see some countries being hesitant at first about the ferry permits due to risks even being an no passenger carrying flight .
WayexTDI
Thu Jun 13, 2019 2:56 pm
It looks like other airlines have quickly gathered their planes in one spot after the grounding; so why did Norwegian wait 3 months and then decided to ferry that plane?
They had no operational needs for the plane since it was grounded; sounds more like a maintenance decision.
The ferry flight for this specific plane was not denied by France since the plane was already over France and landed in France. Google translation of the quoted article:
After flying several queues in French airspace, the pilots had to land at Châlons Vatry airport in the French province
Dalmd88
Thu Jun 13, 2019 3:38 pm
Why did they wait? Maybe it is a space issue. Not every airport has the room for many grounded airplanes. They could have left the planes scattered around their system where they had space and are only now moving them to where they can get the fix or other work done. Other airlines have sent their aircraft to a couple of large storage type of airports, like Mohave, that isn't the option that all others have taken.
dcajet
Thu Jun 13, 2019 4:03 pm
Why do airlines bother, when all they need to do is consult the many specialists available on hand here on A.net? They know better!
AIRT0M
Thu Jun 13, 2019 4:12 pm
Poor planning by Norwegian, or maybe a fault of Eurocontrol. The German airspace was initially closed for MAX flights until 11 June (the day Norwegian tried to ferry the plane), but was later extended until 8 September (for now).
CXfirst
Thu Jun 13, 2019 7:35 pm
First of all. The plane came from Malaga, which isn't an out station, but a base. So there are plenty of good reasons for it to stay there 3 months, and they probably had good reasons to ferry it now. Most airlines did ferry flights straight away, back to base, and Norwegian wasn't an exception. When I talked about operational need, it was in regards to continue operations from Malaga when the ban is lifted.
Also, France decided to close its airspace as Germany did (with Norwegian already in their airspace), and it wasn't just a simple landing. Norwegian had to hold for a while before being directed to land at Vatry.
If French airspace had been open as normal, Norwegian would not have gone to Vatry, they would have elected to go to a much more suitable airport. Probably back to Malaga, a reroute via another country, or at least another Norwegian base.
CrimsonNL
Thu Jun 13, 2019 7:38 pm
They are not the only ones in Europe. TUI Netherlands' PHTFO has been in SOF ever since the grounding. Numerous attempts have been made to ferry her back, some really crazy (airspace avoiding) routes too, but no luck yet.
Martijn
ACDC8
Thu Jun 13, 2019 7:40 pm
WestJet moved one of their Max's yesterday from YLW to YVR. As mentioned above, ferry flights happen all the time.
A Grumpy German Is A Sauerkraut
smartplane
Thu Jun 13, 2019 8:27 pm
When a commercial aircraft model is grounded, it's insurance cover is also suspended, with ground risk only remaining.
Flight approval is on a one for one basis, and perhaps in this case, not all the t's were crossed, and i's dotted.
There is also an issue for the crew, whose life and injury cover will also be suspended for the duration of the flight.
Relocating aircraft in these situations is usually done under experimental cover, with approved crew, so perhaps the delay was sourcing Boeing or Boeing-approved flight crew, and covering the aircraft under the Boeing flight-test policy.
Despite EU airspace management, individual countries have the veto when experimental or grounded aircraft propose over flights.
Or this very aircraft may turn up at Paris next week.
VSMUT
Thu Jun 13, 2019 10:00 pm
AFAIK, France forbids ferry flights too, they just didn't realise it was a MAX until the Germans refused it. Guess it's stuck in Vatry until the ungrounding.
