Ishrion
AA Upgauges DFW-Key West to A319
Thu Jun 13, 2019 2:36 pm
It looks like on December 18th, AA will upgrade its 1 daily DFW-EYW flight from an E-175 to an A319.
The route gains 56 economy seats and loses 4 first class seats.
It seems that it’ll revert back to the E-175 on April 2nd.
AA has been expanding nicely at EYW, with adding routes to DFW/ORD/LGA/PHL in the past year.
I believe this may be the largest commercial aircraft operating out of EYW now? Slightly bigger than DL’s 737-700 from ATL.
mikejepp
Re: AA Upgrades DFW-Key West to A319
Thu Jun 13, 2019 2:46 pm
Interesting, now that AA mainline is flying there, could we see a similar upgauge from CLT?
boeingguy1
Thu Jun 13, 2019 2:48 pm
wow - blows my mind that there are 4 more FC seats on a regional jet compared to mainline AA's 319.
"...Gatwick South!? Id rather crash in Brighton!"
Longhornmaniac
Thu Jun 13, 2019 2:55 pm
Gotta love scope clauses.
Cameron
mercure1
Thu Jun 13, 2019 3:00 pm
"Upgauge" is the term to describe capacity increase.
mercure f-wtcc
UnitedTristar
Re: AA Upgauges DFW-Key West to A319
Thu Jun 13, 2019 3:28 pm
Yea but how many will be weight seats, DL just barley makes the 737 work to ATL with any kind of weather requiring an alternate, I can’t imagine how much DFW will take with the longer stage length...
9w748capt
Thu Jun 13, 2019 3:33 pm
As a frequent E75 passenger, I love it. Upgrades are frequent and plentiful (depending on your route, of course).
ilovelamp
Thu Jun 13, 2019 3:37 pm
“Just barely?” That’s just wrong. Most of the operational issues are getting into EYW and its associated self-imposed, company restrictions especially when the runway is wet. In 4+ years of flying that jet into/out of EYW, I’ve never been weight restricted either way. In fact, yesterday I took off with an engine de-rate and assumed temp, alternate fuel to ATL, and climbed straight to FL400 all with just a handful of seats open.
ericm2031
Thu Jun 13, 2019 3:55 pm
Which is why UA is moving their A319's to 12F and A320's to 16F. Provides little to no room for close-in bookings, paid/complimentary upgrades, IRROPs protection. This will match DL's configuration as well.
jfern022
Thu Jun 13, 2019 6:32 pm
Excellent factual slap down.
I get that this is an enthusiasts site, but the BS and self anointed experts bloviating just gets too deep sometimes.
The only one of DL's flights that takes a hit is the CR7, especially if wx is present in ATL and requires alternates. Not sure if it was just EV's or if 9E faces the same fate. The 73W would be the plane when I worked in EYW, that we would pile the bags in that we left off the CR7, in order to accom all the CR7 pax. The 319 usually never took a hit, but did require a lot of ground handling. Needed to cool down brakes upon arrival with big fans, before departure.
Now one day a EV CR9 came in as a sub and had to leave 40 people behind the next day as it was against its RATOW.
FlyingElvii
Fri Jun 14, 2019 2:27 am
Not to mention the diversions to Miami whenever the runway is wet.....
Gulfstream500
Fri Jun 14, 2019 2:29 am
I predicted this in the OAG thread two+ weeks ago! Although, I'm a bit surprised that AA did not upguage CLT instead.
So, when is UA doing mainline???
Can someone please start a wikipedia list of failed startup airlines? I am interested in seeing just how long it would be...
TTailedTiger
Fri Jun 14, 2019 2:36 am
An upguage in seats but definitely a downgrade in terms of comfort. The E-170/15 is the best jet in the sky as far as comfort goes.
grbauc
Fri Jun 14, 2019 4:08 am
Agree AA A319 are a must avoid aircraft for me.
B1168
Fri Jun 14, 2019 4:29 am
Well, if mainline can fly in, how about the West Coast?
DylanHarvey
Fri Jun 14, 2019 4:45 am
With no passengers? Yes it might work.
dbo861
Fri Jun 14, 2019 4:52 am
Even if runway length wasn't an issue, is there even a market for West Coast to EYW? I love Key West, and I'm actually flying there next week from Sacramento..connecting in DFW. But, that being said, there are plenty of convenient enough connections from the west. I don't see the need for a west coast flight.
DylanHarvey
Fri Jun 14, 2019 11:48 am
[photoid][/photoid]
Pretty much spot on.
WN732
Fri Jun 14, 2019 3:08 pm
Which A319 is this? LAA or LUS? I would assume the LAA as they have Sharklets, but they have the CFM engine which as I understand it, performs slightly less than the IAE.
Ishrion
Fri Jun 14, 2019 4:54 pm
Is there a way to tell? On the bookings it shows WiFi and has power but I think all A319s in AA’s fleet have them now.
Zidane
Fri Jun 14, 2019 7:14 pm
Should be LAA, these are the -115 models fitted with sharklets and the largest thrust producing CFM engines. They're also the only A319 fleet based in DFW.
n797mx
Fri Jun 14, 2019 8:38 pm
I don't see how they are going to pull it off for the return flights. The -175 are weight restricted by 15 seats as it is. Even with CFM engines, sharklets, and ideal conditions, does the A319 have the performance?
Clear skies and strong tail winds.
trueblew
Fri Jun 14, 2019 10:05 pm
How would the A220 would do into EYW from ATL or LGA?
Ishrion
Sat Jun 15, 2019 1:39 am
Doing a dummy booking for March, which I don't think anyone has bought tickets for that yet, the seat map looks like they're blocking the last row, a few aisle seats, and a couple of seats in the middle.
So... around 22 seats seem to be blocked.
evank516
Sat Jun 15, 2019 3:32 am
Does that even make the upgauge worth it? I would have thought they'd do it from MIA first given the frequency of flights and maybe the lower cost of overnighting the plane in EYW if they did it for the RON.
alasizon
Sat Jun 15, 2019 3:50 am
Both LUS & LAA 319s rotate throughout the system. There is no LAA or LUS base any longer. There are actually more LUS 319 movements in DFW each day than there are LAA.
Internal system shows it is currently planned as a LAA 319.
There are reportedly some planned improvements at EYW that made this possible. What those improvements are; no idea.
Those are the same seats they block on every flight for family seating, handicapped seating and last minute premium flyers in-need of an aisle/window seat assignment. Everything shows 128 seats for sale.
Manager on Duty & Tower Planner
evank516
Sat Jun 15, 2019 3:57 am
Gotcha.
For the record, EYW's runway is now 5,076 feet long by 100 feet wide. There was a small extension to the runway on one side and it is only available for take offs to the east. Source: https://www.airnav.com/airport/KEYW
I would think the plane could do LGA-EYW without a problem.
DylanHarvey
Sat Jun 15, 2019 4:15 am
IIRC the LAA A319's have 27k CFM engines and obviously the sharklets which improve the field performance. AA also use these 319's to other airports needing the performance.
golfingboy
Sat Jun 15, 2019 4:31 am
Just a broad observation - I have watched planes at SNA in the past and noticed the A319s generally were able to get airborne much quicker than the other aircrafts. Also with their shorter airframe body with relatively tall gears the initial take off angle can be much more steep with ease compared to 737s and 320s.
ilovelamp
Sat Jun 15, 2019 9:05 am
Gotcha.
Runway 9 has a displaced threshold which makes that extra 100’ unusable for takeoff or landing. I can’t remember off the top of my head if operators can use it for runway 27.
Edit: just looked, that extra 100’ isn’t available for takeoff and landing calculations for either runway.
ILL
ilovelamp
Sat Jun 15, 2019 9:32 am
Out of ATL I don’t see why it would be necessary since the 737-700 is currently doing so well. I think the A220 would thrive to NYC.
ILL
UnitedTristar
Sat Jun 15, 2019 1:12 pm
Interesting, in my previous career while working in planning we couldn’t get mainline to work to DC/NYC with any weather at all either there or enroute even with short field performance package planes.
At the current company we make it work on the regional with occasional restrictions for weather.
I assumed ATL worked at the edge of the envelope with weather on either end (you did indeed confirm you have issues on landing with wet runways and full performance without a full plane)
I enjoy flying into EYW but 4,800 usable is a tight fit
evank516
Sat Jun 15, 2019 1:25 pm
Gotcha.
ILL
??? TORA, TODA, and ASDA for runway 9 is 5,076 feet. The displaced threshold is 275 feet long and IS available for take off on runway 9 ONLY. I don't know where you're getting this extra hundred feet thing from.
ILL
I'll back this statement about the 220. I think it is the perfect aircraft for this route.
ilovelamp
Sat Jun 15, 2019 2:14 pm
ILL[/quote]
ilovelamp wrote:
My mistake on the 100’ thing. I mistakenly used that number instead of the actual runway extension as you pointed out.
I also forgot to mention that Delta computes runway 9 takeoff data from taxiway Bravo which is the same place we’ve been using for years. That means we don’t taxi back and use the full length that is now available. Essentially, nothing has changed on runway 9 for takeoff.
ILL
Weatherwatcher1
Sat Jun 15, 2019 4:16 pm
I’m impressed the A319 can fly 1000 miles from the runway at Key West. Very curious how many seats will be blocked and if AA will restrict baggage.
Replacing the Embraer 170s will help save some flight time since they have to fly up along the coast since they aren’t equipped with life rafts and life vests. The A319 should save about 150 miles.
Noise
Sat Jun 15, 2019 4:31 pm
EYW needs to extend that runway to accommodate flights to YYZ.
GalaxyFlyer
Sat Jun 15, 2019 5:05 pm
Expand where?
Noise
Sat Jun 15, 2019 5:13 pm
To the east, expand over Roosevelt Blvd. To the west, expand towards the High School.
GalaxyFlyer
Sat Jun 15, 2019 5:19 pm
Deleted
toltommy
Sat Jun 15, 2019 5:24 pm
Why? There's already service to EWR and ORD. I would think YYZ is possible using the existing runway. The locals won't support expansion of the runway.
A300/A310/A319/A320/A321/A332/A333/707/712/727/732/733/734/735/738/739/752/753/762/763/764/772/789/DC8/DC9-10/30/40/50/MD81/83/87/88/90/L1011-/250/500/CRJ200/440/700/900/EMB135/140/145/170/175/190/328Jet/F70/SF3/BE1/J31
GalaxyFlyer
Sat Jun 15, 2019 5:28 pm
The displaced threshold on 09 indicates there is no room in that direction as the displacement means there’s obstacles already penetrating the 34:1 plane. You could extend the TORA on the west end, but not by much as the locals might not like jet blast at the HS. At the other end, the Best Western would have to go and there’s just not that much when include the RESA area. Also, where does Roosevelt (A1A) go—a tunnel?
Better answer would be to relocate to the NAS, I’m not sure why that hasn’t been converted to joint use long ago. It’s occasionally busy with deployments but that is a better answer. I’ve flown out of both many times.
I would think AC or DL A220-100s could easily make YYZ or YUL most days.
usxguy
Sat Jun 15, 2019 6:07 pm
The locals b*tched to the heavens about "all that noise" when Delta brought in the ERJs & CRJs in the early 2000s. The airport had to essentially pay to refurbish 400 some homes/condos south of Flagler Ave for sound proofing. I think even the Doubletree & Sheraton got some money.
Then if course Wilma hit, err flooded.
xx
OB1504
Sun Jun 16, 2019 3:56 pm
I can’t remember the last time we had an EYW-bound DL flight divert to MIA.
evank516
Sun Jun 16, 2019 8:43 pm
I've literally tracked a 73G inbound from ATL land in EYW in the middle of a thunderstorm via FlightAware. MIA diverts are very rare. How about we all accept that the 73G isn't as limited at EYW as everyone wants to think they are?
GalaxyFlyer
Sun Jun 16, 2019 9:17 pm
I’m pretty certain it didn’t land in TRW, especially if you’re using Flight Aware as your weather source. It’s just not that accurate as the crews’ weather radar.
GF
Varsity1
Sun Jun 16, 2019 9:48 pm
AA bought these for their performance to supplement the 757. They were purposely the highest performance narrow body airbus had available.
"PPRuNe will no longer allow discussions regarding Etihad Airlines, its employees, executives, agents, or other representatives. Such threads will be deleted." - ME3 thug airlines suing anyone who brings negative information public..
