kdeg00
Is regulatory approval required for livery changes?
Thu Jun 13, 2019 10:06 pm
It's an oddball question, but but bear with me. Driving north this morning and watched an AS 737 in new livery take off towards west from PDX. From my distance of about a mile, and the angle of light, it looked easily mistakable the new LH scheme. Got me to wondering if there is regulatory oversight to maintain differentiation?
grbauc
Re: Is regulatory approval required for livery changes?
Thu Jun 13, 2019 10:09 pm
I 100% believe that there is no such thing.....
KFLLCFII
Thu Jun 13, 2019 10:48 pm
You may want to alert the German Embassy, just to be safe:
Embassy of the Federal Republic of Germany
+1 (202) 298-4000
4645 Reservoir Road NW
Washington, DC 20007
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
TheFlyingDisk
Thu Jun 13, 2019 10:58 pm
Regulatory approval for livery changes is only for nationalized airlines.
Private airlines can do as they please.
I FLY KLM+ALASKA+QATAR+MALAYSIA+AIRASIA+MALINDO
32andBelow
Thu Jun 13, 2019 11:53 pm
Heck no. The only thing that’s necessary is the operating carrier market by the door if it’s oainted different. Skywest horizon and Alaska all wear the same livery.
AtomicGarden
Fri Jun 14, 2019 1:03 am
I wouldn't be surprised if at leas they have to pass a "visibility" test of some sort. Like a fully black aircraft is a nono, to prevent incidents at night (at the airport in particular). But likely nothing to do with copyright infringement or anything commercial.
You killed a black astronaut, Cyril! That's like killing a unicorn!
FriscoHeavy
Fri Jun 14, 2019 1:09 am
Yes, you can paint a plane black.
Whatever
jaybird
Fri Jun 14, 2019 1:26 am
Yes .. the Playboy DC-9 (and maybe others?) was painted all black.
September11
Fri Jun 14, 2019 1:39 am
FAA-approved paint?
Airliners.net of the Future
Karlsands
Fri Jun 14, 2019 1:42 am
All that matters is that call sign and what they file by , paint for most part is for the customers eyes
Gemuser
Fri Jun 14, 2019 2:16 am
Actually that is not always correct. Some aircraft are required to have certain finishes on the skin [not always paint] usually specified by the OEM.
Gemuser
shamrock350
Fri Jun 14, 2019 2:32 am
Meet Alsie Express, not only is the livery all black but it's also in a matte finish.
It's the night mode of turboprops!
fraspotter
Fri Jun 14, 2019 2:58 am
If it comes down to the paint scheme being the deciding factor for aircraft visibility at night then you have much bigger problems to worry about in that aircraft and airport lighting are down. Aircraft all over the world currently have or have had all black liveries. The Air New Zealand "All Blacks" livery would be a nono then? What about Star Flyer Japan? Or the old Playboy DC9? Donald Trump's 757 is cutting it close too.
"The strength of the turbulence is directly proportional to the temperature of your coffee."
— Gunter's Second Law of Air Travel
VHOGU
Fri Jun 14, 2019 3:35 am
jaybird wrote:
Yes .. the Playboy DC-9 (and maybe others?) wats painted all black.
There was a DJ 737 VH-VOI that was black for a while there. As well as a few NZ aircraft.
cschleic
Fri Jun 14, 2019 3:49 am
Slightly off topic but I believe there are rules in the U.S. for general aviation aircraft for the size of the registration number so it's visible by ATC and perhaps other pilots. That can figure into the paint job. Older planes may be grandfathered.
benjjk
Fri Jun 14, 2019 5:20 am
They should hire me for that job. Same old Eurowhite livery? Denied.
Blerg
Fri Jun 14, 2019 6:15 am
#RoyalJordanian
VSMUT
Fri Jun 14, 2019 7:17 am
There are rules in every country regarding nationality markings, all building on minimim standard guidelines set out by ICAO.
PHBVF
Fri Jun 14, 2019 8:08 am
I don't think a regulatory body needs to approve a livery change, but (for search and rescue) the color markings of the aircraft do need to be filed on the flightplan...
Licensed 777/787 driver
aerolimani
Fri Jun 14, 2019 8:17 am
:thumbsup: :mrgreen:
That is badass!!!
rta
Fri Jun 14, 2019 8:44 am
There are probably regulations that airlines have to follow for marking doors, emergency windows, registration, etc but as long as they meet them, I doubt the specific livery matters that much. Just a guess.
BlueberryWheats
Fri Jun 14, 2019 11:49 am
The dark top US Airways was pretty dark too. I quite liked that livery.
DL717
Fri Jun 14, 2019 12:54 pm
Nope, just N number standards:
https://www.faa.gov/documentLibrary/med ... 045-2D.pdf
Welcome to Nothingburgers. May I take your order?
Weatherwatcher1
Fri Jun 14, 2019 1:06 pm
There are many regulations pertaining to liveries. The painting process is regulated since it must follow the Airplane Maintenance Manual procedures. The paint must be approved. Some areas have stricter paint and color requirements such as the wing. Then there are many regulations regarding placards, door marking markings, etc. decals have an approval process. Flight control surfaces also have balance requirements that affect paint.
So in the end, there are many regulations but none as far as I know about the actual color scheme as long as the paint is approved,
DL747400
Fri Jun 14, 2019 1:12 pm
Thank God most of the world is made up of countries which do not require airlines to seek and receive approval from government in order to change their livery. China, North Korea, Iran, Saudi Arabia? Now that is another story.
From First to Worst: The history of Airliners.net.
All posts reflect my opinions, not those of my employer or any other company.
TheEuphorian
Fri Jun 14, 2019 3:07 pm
Probably also the reason why airlines fro these countries have terrible liveries. In SV's case, however, is an exception.
ELBOB
Fri Jun 14, 2019 3:34 pm
You might want to ask why the BA retro BEA A319 couldn't have authentic red upper surfaces on its wings...
CWL757
Fri Jun 14, 2019 3:48 pm
And don't forget the HiFly A343!
A319, A320, 738, 743, 744, 752, 772, 788, C150, E175, E190, F70, R22
KlimaBXsst
Fri Jun 14, 2019 4:01 pm
High visibility should truly be an airline safety high priority.
Color, Font size, or livery uniqueness does not need to be overly regulated by government agenicies.
I liked Howard Hughes’ rebranding of Airwest’s merged airlines to Hughes Airwest with his High Visibility Yellow in the interest of safety.
I guess that is why I can stomach (NK) Spirit to look at anyway. That font they use has got to go though.
Aesthetically the A 340 got it right!
Jalap
Fri Jun 14, 2019 4:49 pm
+1 (202) 298-4000
Since when does one need to contact an embassy for a possible copyright infringement?
No, of course you were joking, but I found the question interesting nonetheless.
Has it ever happened that an airline got legal action based on copyright ingringement regarding to the livery?
fabian9
Fri Jun 14, 2019 5:28 pm
Black is a poor choice of colour for thermal management reasons on the ground - gets hot a lot quicker in a black plane compared to a white one.
KlimaBXsst
Fri Jun 14, 2019 5:35 pm
Yes especially if flying in the tropics too besides being nearly invisible at night.
aerolimani
Fri Jun 14, 2019 6:07 pm
WHAT???!! Blasphemy! Helvetica forever! :lol:
aeromoe
Fri Jun 14, 2019 7:37 pm
dupe
AA AC AS BA BD BF BN BR BY B6 CO CP(2) DG DL EA EI EN FL FT F9 HA HP ICX JI JQ J7 KE KS LH MC NW OC OO OZ(1) OZ(2) PA PI PT QF QQ RM RO RV(1) RV(2) RW SK SM SQ S4 TI TS TW UA UK US UZ VS VX WA WN WS W7 XV YV YX(2) ZZ 9K
aeromoe
Fri Jun 14, 2019 7:39 pm
Top Banana In The West! :checkmark: :checkmark: :checkmark:
32andBelow
Fri Jun 14, 2019 7:50 pm
Planes are visible through lights, radar, and ADSB
Coexstud
Fri Jun 14, 2019 8:40 pm
Ummm who ever said Donald trump is cutting it close must also have the worst combover problems too
DocLightning
Sat Jun 15, 2019 2:14 am
There are certainly some regulations. The reg number needs to be a specified font and minimum size and in a specified location, there needs to be a contrasting border around all doors. And I think there's a rule that the name of the airline has to appear prominently on the airframe if they are part 121 (so when AA did the PSA retro livery, it still has to say "AMERICAN" on the side of the plane). There are other legal issues that aren't regulations. For example, AA can't a plane to look like a DL livery (not that they'd want to), but that's because DL would sue for copyright infringement and a whole bunch of other stuff.
But I'm not aware that regulators need to sign off. Most of the regulations about paint have good reasons for them and are not difficult to follow.
-Doc Lightning-
-Carl Sagan
grbauc
Sat Jun 15, 2019 2:42 am
Oakley has a black plane or did sitting at SNA.
Here one...
https://www.bing.com/images/search?view ... ajaxhist=0
planecane
Sat Jun 15, 2019 3:20 am
I don't think it really makes a difference for visibility. Looking out the window I have seen aircraft at various distances and probably seen all US airlines that have existed since 1997. None of them seem any more or less visible.
Isn't all nearby traffic shown on the TCAS display also?
planecane
Sat Jun 15, 2019 3:24 am
Just to nitpick, DL would sue for trademark infringement, not copyright. They'd probably just end up winning an injunction to force AA to change it. It would be difficult for DL to prove monetary damages.
ish2dachoppa
Sat Jun 15, 2019 5:20 am
How has no one mentioned the well-known-on-this-site all the black schemes of Air New Zealand?
BlueberryWheats
Sat Jun 15, 2019 6:05 am
They have.
questions
Sat Jun 15, 2019 6:14 am
There is also a regulation that states the livery of commercial aircraft can not include any of George Carlin’s seven words you can’t say on TV.
:D
Some1Somewhere
Sat Jun 15, 2019 8:23 am
Even NZ's ones aren't totally black. As far as heat absorption they likely are, but there's still a lot of high-contrast lettering and logos high up.
Sat Jun 15, 2019 9:03 am
Dont think that is entirely correct. Air Asia and Jetstar come to mine where different branches ave had to have livery changes to meet the local requirements. The local regulator wanted a visual difference between aircraft so the public was not confused if it is an Japanese, Chinese, Indonesian, India, Philippines, Thai, Malaysian Air Asia etc.
USAirKid
Sat Jun 15, 2019 9:31 am
I don't think the name has to appear prominently on the airframe. The regional operators all have their name painted near the door. I believe UA during the merger only painted their FAA certificate number on the airplanes that weren't in UA livery, that was enough to satisfy the regulatory requirements. You can see it in these two photos: https://www.netairspace.com/photos/N13138/United_Airlines/Boeing_757-224/MCO_KMCO_Orlando_International_McCoy/photo_26102/ and the titles of the plane: https://www.netairspace.com/photos/N13138/United_Airlines/Boeing_757-224/MCO_KMCO_Orlando_International_McCoy/photo_26103/
I'd agree with planecane, that they'd probably be more likely to sue over trademark infringement first before they sue on copyright infringement. Although most airlines could sue on copyright infringement if they wanted to.. The one notable exception is AA's flight widget thingy got rejected for copyright protection. (AFAIK, in some countries copyright protection is easier to enforce than trademark protection, so AA went and tried to register the copyright on their marks only to have it rejected.)
rbavfan
Sat Jun 15, 2019 9:34 am
Then how do you explain NZ's nearly all black fuselage. They use stobes o the planes to make them visible at airports at night. Note some countries probably do limit what they can look like. There also could be some specific things not allowed in certain countries. In the US for instance there are specific safety markings that have to be visible in certain areas of the airframes.
727LOVER
Sat Jun 15, 2019 12:23 pm
Why would there need to be differentiation if you were a mile away?
Up close, can you see the difference?
Would LH be operating a 737 into PDX? Even if they had them?
How about between different aircraft manufacturers?
From a mile away at certain angles, can you tell the difference between a Delta A320 and a Delta 737-800. Even if you CAN, can everyone else?
Even better, how about a Delta MD-88 vs a Delta MD-90?
Not picking on you, just making you think......LOL :lol:
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
sk736
Sat Jun 15, 2019 1:35 pm
And very nice it looks too!
