ITSTours wrote:https://www.seattletimes.com/business/boeing-aerospace/british-airways-parent-company-delivers-a-massive-vote-of-confidence-in-the-boeing-737-max/
"Boeing said the deal is worth just over $24 billion at list prices. The real value of the planes after standard discounts in the industry, according to data from aircraft-valuation firm Avitas, is about $11 billion."
This assumes 54% discount I guess? Not that much but more than typical?
rbavfan wrote:x1234 wrote:With the MASSIVE range of the B737Max7 (7100km full payload), this can fly low volume routes in EMEA as far as DXB, LOS, ACC, GYD, IKA, etc. Basically BA now has a narrow-body for routes that previously required a wide-body.
Example routes: http://www.gcmap.com/mapui?P=LHR-ISB;+L ... PVD;&DU=km
I sense Europe, Middle East, Africa & Mid-West/East Coast USA/Canada expansion.
You forgot to figure in ETOPS & north atlantic winds. The 737-7 would be hard pressed to do do the midwest routes from LHR.
Momo1435 wrote:IAG still has enough neo on order to replace all the ceo's that are needed for BA's LHR T5 operations. The neo's now destined for Vueling can always be transfered to BA, so there's no problem there.
VV wrote:
Go away from that terminal and full stop. If BA operates from that terminal then fine they can use A320 or any other aircraft, but IAG is not only BA. Fact is BA signed a letter of intent to order 200 MAX. That's it.
And yes, please stop this obsession about containers. There are other ways to operate an aircraft. Just avoid areas where it cannot be operated.
Isn't that very very very easy to understand?
speedbird52 wrote:It will be nice to see 737s in the BA livery again.
Motorhussy wrote:Noticeable in its absence in IAG’s media release is any reference to MAX. The airline group is obviously very aware of and sensitive to PR fallout associated with the name. They have referred to their MAX order as that of the Boeing 737 -8 and -10.
They’re not prepared to kiss the shadow.
ewt340 wrote:I get how these dirt cheap plane going to their LCC like Level and Vueling. Cause they needed it.
I mean, look at Ryanair. The MAX problems is the exact same opportunity for many airlines to get heavy discount, just like back in the day during 9/11.
VV wrote:speedbird52 wrote:VV wrote:
Why are people so obsessed by containers on single aisle aircraft. Get over it.
Does Ryanair have issues with containers?
Do you know how expensive it is to carry a lot of baggage in Europe?
Damn! Please stop this madness about containers on short haul flights in Europe.
Someone clearly does not understand the Terminal 5 Baggage system. Good job getting angry about airplane suitcase boxes by the way.
If you can't go to terminal 5 then don't go there.
speedbird52 wrote:MrHMSH wrote:Revelation wrote:There's a long running meme here on a.net that suggests 737 is not acceptable due to its lack of containers despite loads (sic) of evidence otherwise, now augmented by this IAG deal for 200 frames.
Here's a charming thread from the past: https://www.airliners.net/forum/viewtopic.php?t=1371679
It seems like the era of the container fetishist is coming to an end.
Isn't it the case that BA uses containers at T5 exclusively, whereas T3 is bulk or containerised, as is LGW? If that is the case and the 737s are destined for LGW it doesn't disprove that BA needs container-capable aircraft at LHR (T5).
There is a reason BA kept the 737s at Gatwick. Correct me if I am wrong but the 757s never went to T5 either right? I suppose Heathrow will modify the system? Or BA will use the small 737 containers
Given that Willie Walsh has already said (and it has been mentioned repeatedly in this thread) that BA will use its share of this LOI at London Gatwick there's no need to do anything at Heathrow, as they won't be sending 737s there. You're entirely right though, LHR T5 was designed specifically around containerised baggage and it would be incredibly expensive to rebuild it for anything else. Loose-loaded planes have found their way to T5 occasionally, usually during disruption when cancellations free up enough baggage handlers to do the job manually - one of the reasons for containerisation in the first place was the massive reduction in the number of baggage workers required, and current staffing at LHR reflects that.
kimimm19 wrote:I wanna know how IAG expects to viably place these planes with everyone in Europe already shouting over over-capacity... It's not going to drive down prices either for mainline when you have emptier planes flying over all over the place...
JerseyFlyer wrote:I doubt the 738 will end up as BA's smallest frame at LGW. It is larger than all the 319s and 320s currently based there.
Maybe 220s soon??
george77300 wrote:MrHMSH wrote:BAWLGW wrote:Wow, well this came as a shock. The likely price reductions probably gave IAG incentive to place this LOI.
This order gives me more reason to believe that IAG have their eyes/plan set on a big European aviation shake up. Personally, I think that Vueling will be merged with LEVEL and potentially BA LGW Shorthaul joining the fray. This order facilitates a easy take over of Norwegian later down the line also.
Later on, could we see IAG ordering more of the 737Max to replace A320s across the BA, Iberia and Aer Lingus brands? Perhaps!
Also, could the 737Max ever be containerised?
I think this is less likely, certainly not a 100% replacement. All the IAG airlines have neos on order and there's nothing to suggest they'll be cancelled. IAG airlines also tend to hold onto aircraft for the long term.
I can see the neos orders being rejigged internally to different airlines. With more focus on IB and EI and BA at LHR with less to VY. We will see I suppose. Wonder if Vueling in the long run will completely switch? A320 to 737. Has been done by others before. Who knows but interesting to see how this pans out. Still around 4 years out from first delivery.
dcajet wrote:VV wrote:IAG is a big group in Europe.
This is a very significant endorsement.
And one that knows how to get a very meaningful discount from Boeing...
speedbird52 wrote:Andy33 wrote:speedbird52 wrote:There is a reason BA kept the 737s at Gatwick. Correct me if I am wrong but the 757s never went to T5 either right? I suppose Heathrow will modify the system? Or BA will use the small 737 containers
Just so VV can understand: Heathrow is a large extremely spread out airport. It is almost impossible to connect between terminals. As BA has a lot of connecting traffic, they like to keep all their flights at one place. That place is Terminal 5. It makes no sense for BA to get a subfleet that will operate out of a separate terminal. BA cannot move terminals as T5 was basically built for them. It is the best optimized Terminal at Heathrow for British Airways to operate from. Additionally, there is no room in the other terminals, and no airline willing to trade with BA. Finally, T5 is the best terminal at Heathrow. Why would BA downgrade themselves just so they can have 737s at Heathrow? Anyways, considering WW confirmed they will be at LGW, I would say this argument is pointless.
hongkongflyer wrote:Boeing need a large order from 1st tier airline for PR matters and in exchange there must be a deep discount offered to the airline.
Same as what Ryanair did regarding 737NG. Boeing needed the order after 911 and Ryanair got the world's cheapest 737-800 in exchange.
Andy33 wrote:JerseyFlyer wrote:I doubt the 738 will end up as BA's smallest frame at LGW. It is larger than all the 319s and 320s currently based there.
Maybe 220s soon??
The operating cost of a 737-8 (ex MAX) is likely to be lower than an A319ceo, even with one extra cabin crew member, so if they can sell the extra seats for anything at all, they're still better off than they are now. Also UK regulations prevent cabin crew members from being current on more than 3 aircraft families concurrently. During the changeover period LGW based crew would need to be qualified on A32x; 737; and 777, and duty schedules do mix shorthaul and longhaul work - there's only the one crew pool at Gatwick and duties are mixed. So adding a 4th type would require extra crews for several years- since spare crews wouldn't be able to stand in for every aircraft type. Once the conversion process is completed, and there are no A32x planes at BA Gatwick, then A220s could be easily introduced, but by then there are no A319s to be replaced....
marcogr12 wrote:Andy33 wrote:JerseyFlyer wrote:I doubt the 738 will end up as BA's smallest frame at LGW. It is larger than all the 319s and 320s currently based there.
Maybe 220s soon??
So are we to assume that the LGW fleet will standardize around Boeing aircraft because BA is looking to replace its old 772s too..Does it mean that LGW will get 787s and 737MAXs and LHR the A320 family, 787,777,A350,A380?
Antarius wrote:speedbird52 wrote:Andy33 wrote:Given that Willie Walsh has already said (and it has been mentioned repeatedly in this thread) that BA will use its share of this LOI at London Gatwick there's no need to do anything at Heathrow, as they won't be sending 737s there. You're entirely right though, LHR T5 was designed specifically around containerised baggage and it would be incredibly expensive to rebuild it for anything else. Loose-loaded planes have found their way to T5 occasionally, usually during disruption when cancellations free up enough baggage handlers to do the job manually - one of the reasons for containerisation in the first place was the massive reduction in the number of baggage workers required, and current staffing at LHR reflects that.
BA also operates out of T3.
Andy33 wrote:They do. T3 handles the overflow because T5 isn't big enough to hold all the flights, especially since the takeover of BMI in 2012, though it had a few before that. T3 was designed as a long haul terminal for multi-airline use, and long haul baggage on most airlines has been containerised for years. BA flights from T3 are all containerised, both short and long haul, so they don't have the staff to loose load there either. The terminal itself can cope with loose loading, though it is optimised for containers.
skipness1E wrote:T5 can deal with non containerised aircraft. BA used to fly the odd B757, had three based leased Jettime B737s and had one of the LGW based G-DBC* fleet when the BEA retrojet was swapped to Gatters recently.
It’s not a dealbreaker.
UAL777UK wrote:I think its great that we will see the 737 back in BA colours again in the UK. No doubt they got a great deal and Boeing will also be "happy" to have sold the MAX to such a group at this given time.
Maybe 220s soon??
Andy33 wrote:kimimm19 wrote:I wanna know how IAG expects to viably place these planes with everyone in Europe already shouting over over-capacity... It's not going to drive down prices either for mainline when you have emptier planes flying over all over the place...
What makes you think that all these planes are for service expansion? IAG airlines have a lot of middle aged A32x ceos. By the time MAXs start arriving in quantity these will be getting due for replacement. IAG takes great pride in the way they have standardised their more modern A32x planes internally, so that to transfer one from one fleet to another takes less than a week, including a repaint.
Then BA's fleet at LGW is 29 A319s and A320s, all ceo, mostly leased. These can be directly replaced by MAX8s (or 737-8s as the LOI calls them). It's a heavily slot controlled airport, so not much scope for expansion other than by replacing 10 x 144 seat A319s with 180-186 seat 737-8s.
Vueling and Level shorthaul has just under 130 planes, a mix of 319/320/321 with some neos. If the entire fleet was made 737-8 and 737-10, their newest Airbuses could be transferred to EI or IB or BA (Heathrow) fleets replacing more elderly ceos
Really, there's only about 40 planes in this LOI that look like being purely for expansion, over 5 years.
Revelation wrote:Andy33 wrote:They do. T3 handles the overflow because T5 isn't big enough to hold all the flights, especially since the takeover of BMI in 2012, though it had a few before that. T3 was designed as a long haul terminal for multi-airline use, and long haul baggage on most airlines has been containerised for years. BA flights from T3 are all containerised, both short and long haul, so they don't have the staff to loose load there either. The terminal itself can cope with loose loading, though it is optimised for containers.
Yes, the largest terminal at the largest hub of the group's largest airline requires containers, as does its overflow terminal at its largest hub, yet the group ordered 200 aircraft that do not support containers.
Remarkable, isn't it?
Something that should be making the heads of a few container fetishists spin, I would think.
speedbird52 wrote:Revelation wrote:Andy33 wrote:They do. T3 handles the overflow because T5 isn't big enough to hold all the flights, especially since the takeover of BMI in 2012, though it had a few before that. T3 was designed as a long haul terminal for multi-airline use, and long haul baggage on most airlines has been containerised for years. BA flights from T3 are all containerised, both short and long haul, so they don't have the staff to loose load there either. The terminal itself can cope with loose loading, though it is optimised for containers.
this has already been answered by BA explicitly saying they are going to Gatwick! How on Earth are you turning actual facts into "container fetishist". Why are you getting so emotional over suitcase boxes?
Arion640 wrote:skipness1E wrote:T5 can deal with non containerised aircraft. BA used to fly the odd B757, had three based leased Jettime B737s and had one of the LGW based G-DBC* fleet when the BEA retrojet was swapped to Gatters recently.
I thought that’s why the 757’s got canned with so much life left in them, the container issue at T5?
airzona11 wrote:IAG as a group is like all other large airlines / groups. They operate a mixed fleet of nearly all types. Will be a great win for Boeing. I am not sure this is really even a blow for Airbus, the A320 family is selling like hotcakes. Airlines are not proBoeing or Airbus, the reality is the arbitrage that they get from a mixed fleet keeps the purchase price down and even more so, each plane excels in different areas. They are compliments. The largest / most profitable airlines in the world operate them side by side.
BrianDromey wrote:Have Boeing pulled another United-Style order here?
