rising
Is there meaning behind WN Flight Numbers?
Sat Jun 29, 2019 3:19 am
Always wondered, Southwest has a huge range of flight numbers, from two digit to like 48 all the way up to 5900s.
Is there a pattern or sequence behind the numbers huge variation?
If it doesn't make sense, it's probably not true.
ctrabs0114
Re: Is there meaning behind WN Flight Numbers?
Sat Jun 29, 2019 4:30 am
The only ones that I can pick up on are how some low flight numbers (roughly the range of WN1 through WN30-WN40 - give or take a few numbers) are assigned to flights which operate "Herb's Original Triangle" (DAL-HOU, DAL-SAT, HOU-SAT), but could be attached to other segments (WN1 is the first weekday morning DAL-HOU flight, but WN2 is a weekday evening rotation which works HOU-DAL-MCI-PHX). Other than that, I don't see much of a rhyme or reason for scheduled flights.
2019: DAL, MCI, PHX, LAS, DFW, SAT, ORD, SLC, SEA, DTW; B73G (WN x3), B738 (WN, AA, DL), A20N (NK), MD83 (AA), B788 (AA x2), CS1 (DL), 739 (DL), 712 (DL)
Next: AA: DFW-PHL (752), PHL-MIA (763), MIA-LAX (77W), LAX-DFW (789)
midway7
Sat Jun 29, 2019 1:29 pm
I believe some of the 4XXX and 6XXX may be weekend only flights?
BC77008
Sat Jun 29, 2019 2:02 pm
I have always wondered about this! With the way Southwest numbers many their flights you'd almost expect to board a Saab 340 turboprop :lol:
MY favorite airline and hub is bigger and/or better than YOUR favorite airline and hub!
Dominion301
Sat Jun 29, 2019 2:07 pm
Here’s one thing WestJet still has in common with Southwest, WS’ flight numbering scheme also doesn’t make much sense. Although, apart from AC, none of the major North American carriers have a really consistent numbering scheme apart from Express carriers being > 4000 in most instances.
MO11
Sat Jun 29, 2019 3:36 pm
Nope. Anything below 7000 is in the general population. The low numbers are still used for the HOU-DAL flights, but occasionally get used for one-off holiday or schedule change flights.
jplatts
Sun Jun 30, 2019 11:57 am
WN uses some of the odd numbers in the 1-63 range on DAL-HOU nonstops and some of the even numbers in the 2-64 range on HOU-DAL nonstops.
WN had also previously used WN 1492 on one of its MDW-CMH nonstops, even though WN currently uses flight number 1492 on PHX-MCO and MCO-HOU nonstop service.
IAHFLYR
Sun Jun 30, 2019 2:18 pm
SWA 1 is always "crew of the month"!!! :rotfl: :bigthumbsup:
737max8
Mon Jul 01, 2019 3:51 am
I thought there was some fun ones at some point, like a 777 flight number to Vegas. They are using 808 on OAK-HNL, the area code of Hawaii.
The thoughts and opinions expressed in my comments do not represent that of any airline or affiliate.
Flown on: 717 733 734 735 736 737 738 739 7M8 744 744ER 752 753 762 763 772 773ER 788 789 A319/20/21 A332 A333 A343 A359 A388
jplatts
Mon Jul 01, 2019 4:34 am
WN also operates WN 410 (the area code where BWI Airport is located) on one of its CLT-BWI nonstop flights.
