seat64k
Re: SAA Leasing A350
Mon Nov 11, 2019 1:45 am
Good point!
MEX: 2,238 m
BOG: 2,548 m
UIO: 2,400 m
SCL: 474 m
SJO: 921 m
How does the A350 cope at 2400m?
gloom
Thu Nov 14, 2019 8:40 am
2400m would be more or less 8000ft, to simplify. Not quite sure how much temperature deviates from ISA, but a rough answer is in ACAPS. Their longest runway is 14500 ft long, that would be 4400m (4419.something, but keep the things simple). If there are no other restrictions (climb profile etc), this would give max MTOW at 254-255t, with OEW around 142t and full board with no cargo (35t assumed) this would give somewhere between 55 and 60t of fuel. 10hr range, or 5000nm still range.
Keep in mind that:
1. it's a rough estimation, with some elements simplified
2. based on ACAPS, not the exact plane SAA will use
3. not taking ISA, which could influence the numbers by probably 1hr up or down
4. not taking date/time into considerations
So basically this is just a "very much more or less" from deciding what would be the real range of real thing departing on specified time.
Adam
seat64k
Thu Nov 14, 2019 5:31 pm
Thanks @gloom - I need to look up some terms to fully understand your explanation :) But it looks like a significant penalty.
Does a longer runway allow for higher MTOW given the thinner air? I.e. a faster takeoff?
gloom
Fri Nov 15, 2019 8:36 am
Not by much. If you look that yourself, you'd be more familiar, however to give an example:
at 8000ft altitude and 4km runway MTOW would be around 250t
at 8000ft altitude and 5km runway MTOW would be around 257-258t.
So 7-8 tons for extra 1000m of runway.
https://www.airbus.com/content/dam/corp ... 0-1000.pdf
seat64k
Sun Dec 08, 2019 6:11 am
I see that ZS-SDE did a JNB-DUR-JNB round trip a few days ago. The flight number is the same both directions - SA4545. Does anyone know if this was a revenue flight? Or just a test run?
https://www.flightradar24.com/data/aircraft/zs-sde
trees
Sun Dec 08, 2019 7:47 am
Crew training flights. No passengers. You’ll see a few we’re done two weeks ago and more are scheduled.
LAX772LR
Sun Dec 08, 2019 8:09 am
gloom wrote:
N0ot by much. If you look that yourself, you'd be more familiar, however to give an example:
....and that's assuming that you don't hit your tire limit, and thus are even able to take advantage of the extra available length.
That was the issue DL initially faced on the JNB-ATL westbound: Boeing+Goodyear had to modify their 77Ls' tires, to give DL the limit they'd need to get the payload they wanted, on that segment.
DylanHarvey
Sun Dec 08, 2019 9:04 am
JNB is only 1.7km roughly in altitude. And has 4.4km in runways. So SAA will be just fine. The A359 is a more than capable 17+ hr aircraft even at altitude.
jfk777
Sun Dec 08, 2019 4:18 pm
What is the status if the A350 lease with SAA declaring Bankruptcy ?
gloom
Sun Dec 08, 2019 7:46 pm
A350 wing load at MTOW is really way lower than 777. I don't think it's speed limited at any weight and airport, even given GS on ground will be 16% greater than IAS at takeoff on 8k.
Adam
evanb
Sun Dec 08, 2019 9:24 pm
They didn't declare bankruptcy. They've entered a process under South Africa law called business rescue where an independent practitioner takes over de facto removing the power of the board and shareholders. They have to generate a business plan that can get approval from 75% of the creditors. The practitioners could receive up to several years to then implement this plan. Failure to get agreement will mean liquidation. The incentives are strongly lined up to get an agreement on a plan. The practitioner that was a appointed has a strong track record of success in this process, although the odds are clearly stacked against him.
It's not clear that the leases are part of the process. Firstly, lessors are not major creditors (there is no reason to believe SAA are in arrears to lessors), and secondly, the leases are generally not entered into under SA law and thus not subject to the SA legal jurisdiction.
andz
Mon Dec 09, 2019 1:17 pm
He doesn't have a lot of time though:
Within the next two weeks, SAA’s business rescue practitioner Les Matuson must inform creditors and unions whether he believes the beleaguered airline can be rescued.
If he doesn’t think it can be saved, he is obligated to apply for SAA to be liquidated: all its assets will be sold off to return some money to creditors, mainly a group of banks.
But if Matuson does believe the airline can be saved, the Companies Act affords him another fifteen business days to present a business rescue plan to its creditors.
I'm not sure what happened to the thread about the business rescue.
AECM
Mon Jan 20, 2020 3:31 pm
It appears that today the A350 starts to operate on the JNB-JFK route with SAA
seat64k
Mon Jan 20, 2020 7:26 pm
I see the flight is delayed. Hope SAA doesn't go out of business befoe it takes off...
andz
Mon Jan 20, 2020 7:29 pm
You win the prize for stupid comment of the day.
And it is before, not befoe.
x1234
Mon Jan 20, 2020 8:34 pm
A350 should be able to fly faster @ Mach 0.855 resulting in a quicker trip (15 hours)?
evanb
Mon Jan 20, 2020 8:47 pm
It can, doesn't mean it will. Tonight's will be about 15:50.
seat64k
Tue Jan 21, 2020 2:11 pm
@evanb do you have any information on the fuel use on SA203 of the A359 compared to the A346? Would be nice to know what sort of gains SAA are getting in efficiency.
Also, is passenger numbers taking a hit due to the troubles?
seat64k
Tue Jan 21, 2020 2:13 pm
I guess you haven't been following the news.
Fair play, I'll own my typoes.
evanb
Tue Jan 21, 2020 8:16 pm
Working numbers are about 90t on the A359 and 120t on the A346, so a savings of about 30t each way.
Very much so. It took a while to impact them but numbers on some routes have taken a dive in recent days.
seat64k
Wed Jan 22, 2020 12:19 pm
Holy moly! I didn't expect the difference to be that much. How does weight/passenger restrictions compare?
This is what I'm most worried about. Even if the funding comes through and Ghordan stops meddling and the business rescue is successessful, the public confidence is so damaged the airline won't be able to fill the seats.
evanb
Wed Jan 22, 2020 2:29 pm
Indeed, but you hint at an important point, the A350 also carries less payload so per ton of payload, the A350 doesn't burn 25% less. I suspect that SAA were flying the A346 on the route for payload and range rather than size, so in that respect they will see the full benefit.
I think many on the inside now feel the same. My belief is that they've thrown in the towel. What is going on now is delaying tactics to give them more time to sort out what they can, salvage the few functional or necessary parts and wind down the rest in an orderly fashion.
AECM
Wed Jan 22, 2020 2:42 pm
Do you have data regarding max payload difference between A346 and A359 on this route?
evanb
Wed Jan 22, 2020 3:02 pm
Very rough estimates, at 5,500ft AMSL
Standard day:
B77L RTOW 330t MTOW 347t
B789 RTOW 240t MTOW 254t
A359 RTOW 275t MTOW 280t
A346 RTOW 375t MTOW 375t (I'm rounding up on RTOW, but it's gets as close to MTOW as one could get)
Standard +15C:
B77L RTOW 320t MTOW 347t
B789 RTOW 233t MTOW 254t
A359 RTOW 270t MTOW 280t
A346 RTOW 365t MTOW 375t
andz
Wed Jan 22, 2020 7:53 pm
seat64k wrote:
successessful
Are you doing this deliberately?
And no I don't watch the news I have insider information.
seat64k
Thu Jan 23, 2020 1:54 am
andz wrote:
seat64k wrote:
successessful
No
So maybe you should take into account what the rest of us know before casting judgements?
Let's see: The company is out of cash. Government failed to come up with the 2bn. They're cancelling routes - international and domestic, including some of the JNB-CPT capacity. That last one is a biggy - it's one of the busiest routes by passenger numbers IN THE WORLD. Lack of demand here is not lack of demand for the route. It's passengers voting with their Rands.
While the timing component of my comment was clearly tongue in cheek, the chances of SAA going out of business at any moment is really not far fetched, given what's publicly known. So why not share some of that insider info rather than call people stupid?
mr02
Thu Jan 23, 2020 5:58 am
seat64k wrote:
andz wrote:
seat64k wrote:
successessful
No
Assuming you are South African,and don't fly SAA-you don't speak for the flying public. I was on CPT-JNB flight this school holidays,and the flight was full. If you look at the South African market in general,it is oversaturated.Even comair is canceling some flights in South Africa.
majano
Thu Jan 23, 2020 11:37 am
mr02 wrote:
seat64k wrote:
No
Comair is generally unreliable. At Lanseria for example, a great proportion of their flights are delayed substantially. Flysafair is doing a better job of on-time departure and arrival. Yes the market is saturated, but the established carriers have dropped the ball is certain areas that are important for the flying public.
PM
Thu Jan 23, 2020 1:10 pm
Really? I only know them on the JNB-WDH route where they are far, far more reliable than SAA or Air Namibia.
seat64k
Thu Jan 23, 2020 1:15 pm
Is SAA cancelling routes depsite the flying public filling seats? I am South African, and as I alluded to I flew SAA two weeks ago. Usually when I fly in early Janaury, the flights are full. This time, on the JNB-CPT flight, the plane was half empty - I had a whole row to myself. The flight back on FlySafAir was packed. Of course, just an anecdote, like yours.
I'm guessing Ghordan didn't plead with the public to book on SAA for the great optics.
frigatebird
Wed Jan 29, 2020 9:30 pm
Don’t know if this has been posted before, but SAA will deploynthe A350 to FRA too. Booked a flight in September and although it shows A346 on booking sites, I noticed in my booking the seating is 3-3-3 so it’s an A350.
Too bad, A346 would be nice as we’re travelling with a group of 4, 2-4-2 seating of the A340 would have been a lot better.
146,318/19/20/21, AB6,332,333,343,345,346,359,388, 722,732/3/4/5/G/8,9, 742,74E,744,752,762,763, 772,77E,773,77W,788 AT4/7,ATP,CRK,E75/90,F50/70
evanb
Wed Jan 29, 2020 10:13 pm
All A340-600s will be withdrawn from use, 6 sold and 3 returned to lessors.
Chrisba320
Thu Jan 30, 2020 4:57 am
In 2011 SAA made a very decent profit but unfortunately then the looting, bad management and political interference started. They achieved this despite not having the most efficient aircraft and some routes that could never be profitable. SAA finds itself in its current position as a result of what happened higher up since 2011, not because it is a bad airline. Domestic and regional flights on SAA are excellent, much better than any of its competitors. Not least because of their A320’s which are a joy to travel on compared to the crappy old 737-800’s most of their competitors use. The difference in the passenger experience is vast. I am confident SAA will get through this, the business rescue practitioners are doing all the right things at the moment and the government has little or no influence over the process. SAA after this will be a very different airline to what went before. My guess at this stage is that they will cull most of their domestic routes with the possible exception of JNB - CPT which is one of the busiest routes in the world. Then focus on the best regional routes where the yields are excellent and trim their international network and only keep ones that can be operated profitably. Perhaps even introduce a new route or two, India is near certain. The A350is the right plane for SAA at the right time, so are the A330-300’s they already have. If things go well these can later be replaced with A330neo’s which will give them an efficient, capable fleet perfect for their requirements. We’ve been through a lot in this country, we’ll get through this as well.
TriStar500
Mon Feb 03, 2020 1:20 pm
Another new SAA A350 Destination is FRA. I just found out that the aircraft type on my SA260 trip next July has changed from A346 to A359.
P.S.: Sorry, just saw that someone else already found out about this.
seat64k
Tue Feb 04, 2020 9:36 am
I would have such mixed feelings if this happened to me ;)
AECM
Thu May 21, 2020 9:05 am
While the A359 was on the JNB-JFK routes does anyone have and can share some info about payload and fuel burns?
frigatebird
Thu May 21, 2020 10:01 am
Happened to me twice, and I had these mixed feelings too. Last autumn my IB flight to EZE changed from A346 to A359. First A350 flight for me though. Return flight from SCL still was A346, another first time for me and almost surely the last one too, sadly. Sorry A350 fans, but the A346 experience won hands down.
And the second time the change on SAA from FRA. Due next August, but if or when this will really happen God only knows. Will the SA A350s be returned to the lessors?
evanb
Thu May 21, 2020 10:11 am
Lifts 270t to 275t (depending on temperature) on the JNB-JFK sector carrying roughly 90t of fuel.
AECM
Thu May 21, 2020 10:32 am
90t of fuel is for the trip or also including reserves?
evanb
Thu May 21, 2020 10:42 am
Yes. Carrying 90t, not burning.
AECM
Thu May 21, 2020 10:51 am
So payloads were 35 ton up? Full passenger plus some cargo?
majano
Thu May 21, 2020 11:30 am
Thank you very much evanb. Do you expect this to change when summer comes around and by how much?
evanb
Thu May 21, 2020 11:42 am
Yeah, they were able to carry a nice payload. Not sure they did though. They brought it on the route when they were already suffering from very poor publicity and issues with travel insurance.
evanb
Thu May 21, 2020 11:46 am
JNB is southern hemisphere, so summer months run from October through March (on IATA winter) so they already operated it through summer. The flight has a relatively late departure (scheduled 9:10pm) ex JNB in those months to give them a little more room on the temperature side. They do lose about 5t on TOW in summer, sometimes a little more.
majano
Thu May 21, 2020 8:38 pm
Thank you.
