Planetalk
Re: Boeing 737MAX Grounded Worldwide Q3 2019
Sun Jul 14, 2019 3:47 pm
prebennorholm wrote:
crjflyboy wrote:
I find it rather strange that BOEING has only publicly stated they have set aside 1 billion for this fiasco... it will be in the several billions
It can wait. For the time being Boeing will fix the plane and have it certified so they can deliver planes again. $1B is plenty of money for that.
At some time, likely next year, the accident reports will be published. Very likely they will be at least partially disputed by some stake holders. That will keep time running.
At some uncertain time far out in the future there will then be a lot of work in different courtrooms around the world. They will work for years before they come up with rulings which will be appealed to a higher level to begin from scratch.
Etc. etc.
At this stage it is pure guesswork what money Boeing in the end will have to fork out. The only relatively certain things are that they will not pay one cent more than needed, and if it becomes a substantial money pile, then it will likely be in the time frame 5 to 10 years out in the future.
New subject: There are also companies which are earning millions on the MAX grounding. Airlines with no MAX planes enjoy decreased competition from airlines with MAX planes, higher load factors and booming revenue management systems. In a totally fair world they should hand out part of their extra profit to Boeing, but that's not gonna happen.
Also airlines with MAX fleet enjoy higher load factors and higher average ticket prices than what would have been the case if 500 MAX planes world wide were flying instead of parked. They will conveniently forget to subtract that when they finally present their grounding bill to Boeing.
Did you actually just say that in a fair world Airlines with nothing to do with the MAX should be paying Boeing for having designed a plane that killed over 350 people directly due to its design?
If coke changes its manufacturing processes and as a result starts poisoning people, should Pepsi pay coke when it is withdrawn from the market? Bizarre logic.
blrsea
Sun Jul 14, 2019 3:57 pm
Revelation wrote:
WSJ ( https://twitter.com/WSJ/status/1150405248822980610 ) tweets:
Boeing 737 MAX grounding could stretch into 2020 as company executives, FAA engineers and regulators expand safety analyses
Sounds ominous.
Article ( https://www.wsj.com/articles/boeing-737 ... 1563112801 ) is behind a paywall.
Anyone got a link that isn't behind a paywall?
Search for title from google.com and click the wsj link, you can read full article.
Excerpts from the article...
During early stages of work on the fix, Boeing and FAA officials disagreed behind the scenes about the extent of changes needed to reduce hazards posed by the MCAS system, according to people familiar with the details. Then in March, just as Boeing was slated to submit a long-awaited proposal with the goal of jump-starting the process, new questions arose about related software systems and emergency checklists, requiring weeks of additional intense evaluation.
The topics included concerns about whether the average pilot has enough physical strength to manually crank a flight-control wheel in extreme emergencies.
In late June, Boeing and the FAA disclosed still another flight-control problem on the MAX, involving failure of a microprocessor that meant test pilots couldn’t counteract a potential misfire of MCAS as quickly as required.
From a purely technical standpoint, some senior FAA officials believe they could be in a position to approve Boeing’s proposed fix at some point in October, though working with international regulators on a coordinated return to service could cause a delay, according to one person briefed on the matter. Another wild card, this person added, relates to the potential impact of new FAA leadership if the U.S. Senate confirms Stephen Dickson in the fall as the next agency administrator.
SEU
Sun Jul 14, 2019 4:23 pm
Sounds ominous.
Doesnt work for me?
planecane
Sun Jul 14, 2019 4:29 pm
Assuming the article is accurate (which is sometimes a stretch when it comes to aviation specifics), the most interesting part to me is:
Since the 737 MAX and its earlier version, called the 737 NG, share the same flight-control computer, fixes related to the microprocessor also apply to NG models, thousands of which remain in service around the world.
This seems to indicate that the MCAS 2.0 software is not what introduced the microprocessor issue. It also indicates that the slowed response time is not an issue on the NG with the extremely low number (which may be 0) of runaway stabilizer incidents.
flyingphil
Sun Jul 14, 2019 5:34 pm
https://www.marketscreener.com/BOEING-C ... -28902581/
Hmmm... hinting that the manual trim wheel may need to be modified.. but thats just my guess. You cant really expect the FAA to give a minute by minute summary I suppose. The trim wheel was shrunk for the NG cockpit.. so that opens another can of worms.
LDRA
Sun Jul 14, 2019 5:47 pm
How is Boeing going to fix manual trim wheel? Mandate pilot training and physical strength test?
planecane
flyingphil wrote:
https://www.marketscreener.com/BOEING-COMPANY-THE-4816/news/Boeing-737-MAX-Grounding-Could-Stretch-Into-2020-28902581/
I think more likely it means getting the simulators to accurately simulate the required force and enhance training for load alleviation (aka "roller coaster procedure") when in extreme situations.
I don't think the changes to the wheel on the NG caused the issue as it was already present in the -100. The larger stabilizer exacerbated the issue. If they change the gearing to make it easier to move the stabilizer under extreme conditions, it will need a ridiculous number of turns to move it which will make normal situations more difficult.
See above.
PixelFlight
Sun Jul 14, 2019 6:46 pm
One solution could be to use a separate second electric motor powered from a backup power source (as the A350 do). On the cockpit this only require to find a place for the backup trim switch.
DenverTed
Sun Jul 14, 2019 7:14 pm
Sounds ominous.
Looking at that photo in the tweet, I don't see a wifi bump on the Air Canada, GOL, and Sun Country that United and American have. Do they not have wifi?
DenverTed
Sun Jul 14, 2019 7:24 pm
I estimate the cost of the grounding at 1/2B per month, so if it lasts a year that is 6B, plus the cost of the fix, and the payments to the victims, so the cost is now headed past 5B into the 5B to 10B range. Will they have to make physical changes to the trim wheel? If so, I don't see how the NG would escape this, which is a big can of worms in terms of logistics and cost.
Revelation
Sun Jul 14, 2019 7:31 pm
I think the article indeed isn't very specific, and is lumping together a bunch of suggestions that could have been picked up just surfing the web with the latest UA/AA postponements to weave together a pretty speculative piece.
My $0.02 click bait prediction: If the delays wipe out the Thanksgiving/Xmas/New Years travel cycles, heads will roll at Boeing, starting from the CEO on down. The losses from the summer peak are bad enough, if it wipes out the winter peak too the airlines are going to scream, and the shareholders are going to demand scapegoats.
LDRA
Sun Jul 14, 2019 7:52 pm
See above.
It might have been perfectly fine back in the 60s 70s and whatnot. But it is not OK in modern times. The demographics of aviators has changed. Significant portion of 737 type holders are female
planecane
Sun Jul 14, 2019 9:51 pm
See above.
However, if it isn't difficult to turn in normal situations (e.g. the electric motor stopped working) then it doesn't matter if there are female pilots. It's not like all male pilots are bodybuilders either. The males can't turn it in a severe out of trim situation either.
VS11
Sun Jul 14, 2019 9:53 pm
Bloomberg reports that AA and UA will extend non-MAX schedules until Nov 2/3.
https://www.bloomberg.com/news/articles ... nd=premium
RickNRoll
Sun Jul 14, 2019 10:03 pm
planecane wrote:
See above.
The whole plane is designed to cope with abnormal situations. Why should the trim system be any different?
planecane
Sun Jul 14, 2019 11:18 pm
The abnormal situation recovery will be load alleviation. The only time this appears to be necessary is if there is a runaway stabilizer AND the electric trim won't work. In service data seems to indicate that this hasn't happened on the NG. It shouldn't happen any more often on the MAX with MCAS 2.0. It actually may not have happened with MCAS 1.0. We won't know for sure until the final reports if the electric trim was functional on the two crash flights.
prebennorholm
Sun Jul 14, 2019 11:41 pm
Yes, I agree, I used bizarre logic to explain how the MAX crisis has many different economic consequences, and not only negative consequences for airlines.
To your last question, maybe Pepsi should change the name of Pepsi Max into something else…?
LDRA
Sun Jul 14, 2019 11:55 pm
At Vmo, Max electric trim is inhabited BY DESIGN. So it does not even take failure conditions to need to use manual trim wheel.
7BOEING7
Mon Jul 15, 2019 1:35 am
Did you mean inhibited? Where did this information come from? IIRC it isn’t on the NG. Please enlighten.
LDRA
Mon Jul 15, 2019 2:01 am
Sorry should say inhibited. It is Max only, for detail see below
https://www.easa.europa.eu/sites/defaul ... S%2010.pdf
STATEMENT OF ISSUE
The aisle stand trim switches can be used to trim the airplane throughout the flight envelope and fully complies with the reference regulation Simulation has demonstrated that the thumb switch trim does not have enough authority to completely trim the aircraft longitudinally in certain corners of the flight envelope, e.g. gear up/flaps up, aft center of gravity, near Vmo/Mmo corner, and gear down/flaps up, at speeds above 230 kts.In those cases, longitudinal trim is achieved by using the manual stabilizer trim wheel to position the stabilizer. The trim wheel can be used to trim the airplane throughout the entire flight envelope.In addition, the autopilot has the authority to trim the airplane in these conditions.The reference regulation and policy do not specify the method of trim, nor do they state that when multiple pilot trim control paths exist that they must each independently be able to trim the airplane throughout the flight envelope.Boeing did not initially consider this to be a compliance issue because trim could always be achieved, even during the conditions where use of the aisle stand trim switch was required.Subsequent to flight testing, the FAA-TAD expressed concern with compliance to the reference regulation based on an interpretation of the intent behind “trim”. The main issue being that longitudinal trim cannot be achieved throughout the flight envelope using thumb switch trim only.
EASA POSITION
Boeing set the thumb switch limits in order to increase the level of safety for out-of-trim dive characteristics(CS 25.255(a)(1)). The resulting thumb switch limits require an alternative trim method to meet CS 25.161trim requirements in certain corners of the operational envelope. The need to use the trim wheel is considered unusual, as it is only required for manual flight in those corners of the envelope.The increased safety provided by the Boeing design limits on the thumb switches (for out-of-trim dive characteristics) provides a compensating factor for the inability to use the thumb switches throughout the entire flight envelope. Furthermore, the additional crew procedures and training material will clearly explain to pilots the situations where use of the trim wheel may be needed due to lack of trim authority with the wheel mounted switches.The trim systems on the 737Max provide an appropriate level of safety relative to longitudinal trim capability.
ArgentoSystems
Mon Jul 15, 2019 2:27 am
LDRA wrote:
EASA POSITION
[The trim systems on the 737Max provide an appropriate level of safety relative to longitudinal trim capability.
I don't fully understand all of what they are saying, but this last sentence seems clear enough. No problem with the trim system?
LDRA
Mon Jul 15, 2019 3:24 am
ArgentoSystems wrote:
LDRA wrote:
EASA POSITION
Provided the manual trim wheel always works at Vmo, which turns out to be not true
frmrCapCadet
Mon Jul 15, 2019 4:03 am
My solution becomes more probable: get Chicago out of the Boeing commercial unit, sell the later to Buffet. LOL
maint123
Mon Jul 15, 2019 4:23 am
snasteve wrote:
Dieuwer wrote:
CitiGroup: "Boeing's 737 MAX needs to return to service by Q4 or else airlines could make plans without the jet for summer 2020."
https://www.investors.com/news/boeing-7 ... n-warning/
Not much of a lawsuit. Mind you that anybody is free to file suit for anything, winning is of course another matter. Since the passenger was not injured, predict this lawsuit will fail and the request for class action status will be denied.
Some frivolous lawsuits might be filed to discredit genuine ones.
maint123
Mon Jul 15, 2019 4:33 am
planecane wrote:
LDRA wrote:
Firing working level technical staff solves zero issue. They need to look at Boeing corporate management, the ones that are company officers
Unless it is shown that corporate management made the call on the MCAS design I disagree. It is most likely engineers and engineering managers that made the choices.
If management gave the directive for minimal differences but the engineers and engineering managers didn't alert them to compromises being made, it isn't the fault of the people that made the "ask" it is the fault of the people that didn't bring up concerns.
But sometimes decisions are made at a senior level and the engineer has no option but to comply. And when it all goes south, the senior management wash their hands off it and punish the engineer. Keeping it all in writing also doesn't help. They will just bury the issue and you will become a target. Not being dramatic, speaking from experience.
maint123
Mon Jul 15, 2019 4:40 am
Getting the max back in air is not the issue. Suppose usa twists arms and the max is back in the air. But if the issues are not all tackled or the plane has inherent issues with flyability in certain envelopes, we might unfortunately face the same situation after some time.
Cant fight physics.
Max has to achieve the same reliability that NG or the other planes have. Anything less will be exposed in the real world.
DenverTed
Mon Jul 15, 2019 4:48 am
STATEMENT OF ISSUE
EASA POSITION
What's the "aisle stand trim switch"? I thought those were cutout switches.
StTim
Mon Jul 15, 2019 4:58 am
Wow - that is some leap. You Airbus/Airlines flying airbus's have gained. You now need to share that with poor old Boeing.
7BOEING7
Mon Jul 15, 2019 5:17 am
STATEMENT OF ISSUE
EASA POSITION
Interesting question. The aisle stand "cutout" switches remove power from the system -- they're either ON of OFF so to speak. We have this "official looking statement" that doesn't even use the correct nomenclature gives me some concern or I guess it could be interpreted that if those switches are engaged the system will operate normally throughout the envelope. The other interesting statement is relative to the VMO/MMO corner which seems to indicate if you're doing VMO or MMO and aren't within "X" knots/Mach number of the corner there is no issue. Wonder what that number is?
Just to be clear I believe that statement has been there since the model was certified and didn't come about because of the MCAS issue.
rheinwaldner
Mon Jul 15, 2019 7:13 am
Yes, and the same applies to the oil companies, that gain(ed) from higher fuel consumption overall. :)
In truth, the MAX is bad luck for the airlines that have it and nobody can be asked to pay back the losses except Boeing. Leeham estimates, that Boeings final losses could come near to the dimension of a fully fledged new development program. Rather than financing the MAX grounding Boeing could have gotten the NSA or the NMA mostly for free.
The airlines on the other hand had business plans, that required the MAX to be delivered & operated in order to serve the network and realize fuel burn reductions. Of course the airlines liked the very competitive purchase prices Boeing offered. With hindsight, they probably better would have payed a bit more to get a less cheaply designed aircraft (because MCAS smells like a cheap&quick-solution allover).
But how competitive would the MAX have been, if it would have been designed safely from the beginning? EIS would surely have been delayed about the same time, as the grounding takes (because designing the systems rightly seems to take a lot longer than it took to create MCAS v1)? The MAX would have had EIS at the end of 2017 instead of in May 2017.
Something else to consider is Boeing reputation regarding groundings. Boeing now has superseded McDonnel Douglas in the number of grounded aircraft designs. Going by "experience" airlines might start to "calculating in" grounding phases for new Boeing designs. Flagging that risk correctly regarding "occurrence probability" (2 out of the last 3 were affected) and "impact" might start to give a dent to the overall business proposition of ordering unproven Boeing designs.
Many things are difficult, all things are possible!
majano
Mon Jul 15, 2019 8:19 am
Francoflier wrote:
majano wrote:
Thank you for all these responses. If it is based on cost incurred, then I would agree that any cost "saved" due to the grounding has to be seen as a credit.
Boeing is saving the airlines' money by preventing them from spending it on new aircraft!
:rotfl:
(Sorry, couldn't resist)
Fair game. Not offended at all.
flyingphil
Mon Jul 15, 2019 9:19 am
PW100
Mon Jul 15, 2019 9:35 am
LDRA wrote:
STATEMENT OF ISSUE
The aisle stand trim switches can be used to trim the airplane throughout the flight envelope and fully complies with the reference regulation Simulation has demonstrated . . . .
What are "aisle stand trim switches"
Initially I thought they meant the trim cut off switches (as they are on the centre pedestal), but they aren't used to "trim the airplane throughout the flight envelope".
Can anyone enlighten me?
Thanks.
EDIT: just noticed I'm not the only one with this question. To me, that EASA quote would seem rather useless when it does not correctly describe the intended function of the switches.
uta999
Mon Jul 15, 2019 12:43 pm
Is an MCAS type event (accident) more or less likely when the MAX-8 flies empty to a storage airport? Boeing are still flying these new builds around the US daily.
Your computer just got better
Revelation
Mon Jul 15, 2019 12:55 pm
The "MCAS type event" we have are both due to faulty Angle of Attack sensors causing the flawed MCAS 1.0 system to kick in, and the pilots not being able to recover.
If you either (a) have good AoA sensors -- OR -- (b) have pilots who can recover then you do not have a problem.
I think it's safe to presume that the company pilots Boeing uses on these flights are very well informed on recovery from faulty AoA triggering MCAS.
I would imagine some special training is a requirement of the special ferry permits authorizing these flights.
IWMBH
Mon Jul 15, 2019 12:59 pm
This :checkmark: . The -Max is not as safe as other airplanes. But informed aircrew can counter a "MCAS type event'', especially when it is one of the only thing on their mind when they flying the aircraft.
XRAYretired
Mon Jul 15, 2019 1:18 pm
Much more sensible to fly @~20Kft, slow with Flaps 1, as they seem to do in Europe. Bit boring for US sky gods though.
Ray
Revelation
Mon Jul 15, 2019 1:48 pm
Flying at max alt/speed efficiency is doing their part to help save the environment, lol.
LDRA
Mon Jul 15, 2019 2:15 pm
I don't know why EASA is calling manual trim system "aisle stand trim switches". Could be what Boeing is referring to manual trim system in their submitted document
The EASA document does specifically refers to trim wheel later in the same cited paragraphs
XRAYretired
Mon Jul 15, 2019 3:45 pm
Reckon they just got their 'wheels' confused and tried to make it read comprehensibly (and failed).
If you read it as:
'Aisle mounted trim switches' = 'Aisle mounted trim wheels'
and
'Wheel mounted trim switches' = 'Yoke mounted trim switches'
It makes sense, although somewhat repetitive, another sign they were struggling with language by the way.
Ray
flyingphil
Tue Jul 16, 2019 6:42 am
https://www.cnbc.com/2019/07/15/boeing- ... gs-on.html
Maybe news of what happened here will leak out.. I expect the lessors are losing patience.
maint123
Tue Jul 16, 2019 6:51 am
https://www.bbc.com/news/business-48995509
"Boeing ditches 737 Max name on new Ryanair plane"
"A Boeing 737 Max due to be delivered to Ryanair has had the model's name changed on the nose of the aircraft, it has emerged.
Photos shared on Twitter show a plane in Ryanair colours outside Boeing's manufacturing base, with the name 737 Max replaced by 737-8200.
It has fuelled speculation that the troubled Max will be rebranded after two fatal accidents led to a worldwide grounding.
Boeing and Ryanair have yet to comment."
That's one way to solve the problem.
MrBren
Tue Jul 16, 2019 7:12 am
Certainly not. Changing a name does not change the DNA.
flyingphil
Tue Jul 16, 2019 7:35 am
So now Ryanair are warning of routes being cut and base closures due to the 737MAX (or 737-8200).
No doubt they will want even more compensation from Boeing.
The bad PR for Boeing seems unending.. plus the way information leaks out does not do them any favours.
https://www.flightglobal.com/news/artic ... ys-459684/
oschkosch
Tue Jul 16, 2019 10:58 am
Well clearly Mr MOL is applying an excellent tactic here. He will certainly screw Boeing for every penny possible.
ArgentoSystems
Tue Jul 16, 2019 12:14 pm
It seems Boeing could not care less about bad PR. The only metric they have to answer for is stock price, and by that measure they are doing superb job. And no amount of bad press make the stock drop.
Revelation
Tue Jul 16, 2019 12:30 pm
We have an entire 737-8200 thread dedicated to this item.
viewtopic.php?f=3&t=1426977
And yet we read Ryanair CEO says confident in 'great' Boeing 737 MAX despite delays:
“While it is disappointing that we have delays, while it is disappointing that the growth for next year will be slightly slower than we had originally planned, we remain confident in the aircraft. We still think it is a great product,” O’Leary told a conference call with investors.
As soon as we can reasonably organize these deliveries with Boeing we would intend to take all of the 135 firm aircraft we have ordered over the next five years,” he said.
He seems to be working all the angles.
If he wanted to do that, he'd retain those employees and bases for those 135 737s he will be taking after the ungrounding and bill Boeing for the cost of keeping them.
I think this shows he's using the grounding as an excuse to trim excess employees and bases.
par13del
Tue Jul 16, 2019 12:31 pm
So is that a Boeing problem or the stockholders?
If Boeing only responds to them and they are keeping the stock price high, perhaps we are looking in the wrong place?
ArgentoSystems
Tue Jul 16, 2019 12:39 pm
Perhaps.
Too bad Boeing is owned by entities who at the moment are more concerned with preserving value of their stakes (i.e. keep stock from falling) rather than with fixing the issue. That's what being TBTF does to you.
FluidFlow
Tue Jul 16, 2019 12:45 pm
O'Leary will use it for everything possible to improve the bottom line, e.q. cuts in staff and bases and to squeeze every single cent he can grab out of Boeing. He would have switched to Airbus or any other aircraft he would have seen a business case in if it would have been cheaper, it is not like he has loyalty to anyone except money. This is of course legit and he is doing really well with Ryanair (except for the strikes and forgetting to give his crew enough holidays).
