PixelFlight
Re: Boeing 737MAX Grounded Worldwide Q3 2019
Thu Jul 11, 2019 6:56 am
sgrow787 wrote:
In fact it looks like the only engineering Boeing did was to reverse engineer the certification process starting with how do we get a MAX certified under a 737 type certificate.
LOL, but sadly true to some extend. Well, there did a lot of others engineering, but there should not have do that one.
sgrow787 wrote:
Chemist wrote:
It's not unstable and MCAS is not a stability system. Cut the ridiculous hyperbole.
MCAS my ass. It's a stall prevention system given an alternative innocent sounding name so they could assign it a lower safety classification, so the FAA wouldn't ask questions.
In fact I'm going to go ahead and say it. Because everyone I've listened to in the aerospace industry agrees it's ludicrous for a one-sensor design to have ended up in the Max.
The recent FCC processor "data flow" issue may have been the real reason Boeing went forward with a Max with a one-sensor MCAS system. Everything else that happened follows logically from there.
- the lowering of the safety classification
- the deletion of MCAS information from pilots' FCOM
- the (intentional) failure to notify the FAA of the increased MCAS authority
I'm thinking the G + AOA worked because both sensors are onside. But two AOAs means the offside AOA may have to come from the offside FCC, and that would be through something like a SPI bus or other FCC-to-FCC communication, which would be more resource intensive.
You could call a babysitter an MCASer. All they do is maneuver the baby's sleeping position so they don't cry all night.
The raw processor capability issue is still a speculation a this time, there are so many way to overload a processor and there no real detail available. Fact is that Boeing say there expect to fix this by software (no hardware). Time will tell if it's possible or not.
I don't think that the raw processor capability can be the reason Boeing went forward with a Max with a one-sensor MCAS system. The same type rating and same training was already critical goals when the project was started for evaluation, long long before there have identified the non-compliance while doing a test flight and consequently modified the MCAS to use a single sensor.
Each FCCs are already exchanging data together as shows the two figures in the middle of this blog: https://www.satcom.guru/2018/11/737-fcc ... mmand.html The same article say:
"While engaged, even single channel, the FCC uses inputs from both ADIRUs to avoid a potential issue if one ADIRU produces false data." The resources to exchange the extra AoA value, if not already done, should be just one byte or two in each directions. What worry me in the schematic is that the FCC, contrary to the SMYD, don't seem to have each independent input of the two ADIRU. It look like there need to pass trough the other side FCC to get the other side ADIRU data. I see this fragile principle as more likely a source of issue. For example, there could need the SDP-185 processor running to copy the ADIRU values from the ADIRU link input buffer to the other FCC link output buffer. If that processor fail, the other FCC no longer get the updated ADIRU values of that side, including the AoA value.
planecane
Thu Jul 11, 2019 7:01 am
seahawk wrote:
The dispatch reliability is not an argument imho, as the 2 sensors are flight critical anyway, as they supply the flight computers for captain and co-pilot.
The reasoning was flawed but the anonymous insider told a reporter that it was the reason. Perhaps the MCAS software team didn't know that both sensors needed to be functional for dispatch.
PixelFlight
Thu Jul 11, 2019 7:57 am
planecane wrote:
The investigative reports said that the single sensor was chosen for dispatch reliability.
Really ? Please give a link on that.
I don't see how a software change could have anything to do with the dispatch reliability of two AoA sensors that are already mounted anyway on the previous model.
seahawk
Thu Jul 11, 2019 8:02 am
I can see how a risk analysis might go wrong, I can even see commercial interests playing a role, but such basic lack of knowledge about the 737 avionics by people developing a system for that plane would be outright scary for me.
Interested
Thu Jul 11, 2019 8:35 am
planecane wrote:
Interested wrote:
planecane wrote:
Stop posting this garbage. It isn't true. MCAS does not keep the plane level. It is intended to activate in a part of the flight envelope that will rarely, if ever be entered into in service.
Lion Air 043 flew without MCAS for over an hour. If the MAX was so unstable how were they able to have an uneventful rest of the flight?
Because they didn't have to avoid anything with a quick manoeuvre the rest of the flight?
These arguments are getting so tiresome with you anti-Boeing posters. The post I replied to stated that MCAS was needed to keep the aircraft level because it is unstable.
These quick maneuvers are also speculation. The "old school" test pilot was ok with MCAS because he thought it would almost never activate. If the maneuvers that activate it are somewhat common his opinion would have been different.
So like I say - your preference is to go with the view that because the maneuvers aren't common that we can ignore them?
Is that your solution?
The claim that because the Lion air flight had no problems with MCAS after it was turned off and all is ok without MCAS isnt that convincing to me as an outsider looking in?
Being honest
It seems that everything about Max 737 is a compromise?
asdf
Thu Jul 11, 2019 11:07 am
planecane wrote:
.......The "old school" test pilot was ok with MCAS because he thought it would almost never activate. If the maneuvers that activate it are somewhat common his opinion would have been different.
i dont know waht the "old school test pilot said" but the boeing testpilots wasn´t OK with the test flight result, because they tuned up MCAS to counteract the unusual behavior of the MAX much more as it was initialy planed and initialy reportet to the FAA
that alone is a big red hering that the whole case of the very unusual engine position is not that simple and that harmless
ArgentoSystems
Thu Jul 11, 2019 12:14 pm
The five requirements the European Aviation Safety Agency have listed so far are as follows:
Reduce the difficulty manually turning the trim wheel
Address the unreliability of Angle of Attack sensors
Address the training situation
Investigate software issues with a lagging microprocessor
https://samchui.com/2019/07/10/easa-ide ... lot-fault/
This will take how long again to fix? Flying end of September, huh?
Virtual737
Thu Jul 11, 2019 12:21 pm
Did you mean red flag?
par13del
Thu Jul 11, 2019 12:47 pm
Being honest
Well the claim was that MCAS was needed to keep the MAX in level flight, that alone was proof along with the hundreds of other flight performed with MCAS inactive because the autopilot was on or they were in manual flight with the flaps deployed on take off and landing.
So being honest, the claim of MCAS being needed for level flight should be debunked, now we can move on to more substantive issues.
ArgentoSystems
Thu Jul 11, 2019 12:52 pm
That is factually incorrect since AOA sensor is not on MEL. Both sensor must be working at all times.
ArgentoSystems
Thu Jul 11, 2019 12:56 pm
I mentioned a while back that grounding in 2019 (assuming it ends in 2019) will affect airlines' ability to absorb new planes in 2020. Now RyanAir CEO confirms that.
https://www.reuters.com/article/us-ryan ... SKCN1U52ME
oschkosch
Thu Jul 11, 2019 1:04 pm
MOL has thus told Boeing to fork some cash over, compensation for the missing planes, lower prices than IAG. This will become expensive for Boeing! And he also clearly states FR cannot take more than 6-8 new planes per month due to internal processes.
Gesendet von meinem SM-G950F mit Tapatalk
par13del
Thu Jul 11, 2019 2:34 pm
Boeing has cut production from 50+ to 40 or so, so even when the a/c is fit to fly, it will take time to get all the already produced and parked frames updated for delivery to clients, I don't think Boeing will get back to 50+ in 2020, not unless they go on a hiring binge, at present the backlog in resources is at Boeing where frames are piling up, vendors are pushing out at a smaller reduced rate.
The airlines growth or efficiency projections based on the MAX frames definitely will continue to take a hit, how long is a big question, until the a/c is released it is hard to make decently accurate projections.
ArgentoSystems
Thu Jul 11, 2019 4:00 pm
I think they told that they did not cut production rates for their suppliers. So if they run at -10 planes/month for 9 months, they will need to run at +10 plane/month for another 9 month to consume all of the supply chain excess.
planecane
Thu Jul 11, 2019 4:30 pm
Feel free to go find it in the Q2 thread. It was WSJ or Bloomberg.
It quotes a source that said when they had to remove the g-force sensor they wanted to keep it simple and only use one AoA sensor because using two would lead to more failures.
Clearly the left hand didn't know what the right hand was doing so the people making that decision didn't know that the aircraft couldn't be dispatched with either AoA sensor not functioning.
majano
Thu Jul 11, 2019 4:46 pm
Firstly, I am not sure if this is the best thread to ask this question, but I think it is better than opening a separate thread. AA has a fleet of 24 737 MAX whilst Norwegian has a fleet of 18. AA says the MAX grounding cost it USD185 million in Q2 alone. https://www.cnbc.com/2019/07/10/america ... arter.html Norwegian on the other hand claims it suffered only USD83 million. On face value, this difference is substantial given the number of aircraft of each operator. Are the damages calculated on margins rather than revenue? With AA's gross and operating margins being better than Norwegian's, the differences may appear reasonable.
planecane
Thu Jul 11, 2019 5:26 pm
Do you even read my post before responding? How is it factually incorrect. With what was going on internally during the design, don't you think it is very possible that the same team that didn't properly analyze the MCAS failure scenario also didn't bother to ask if the sensors were on the MEL. The fact is that a source told the reporter that dispatch reliability was the reason.
asdf
Thu Jul 11, 2019 5:27 pm
yes, sir ...
this proofs that it is a seriouse problem
why should testpilots insist on that much increasing MCAS interventions if the behavior of the MAX its not really a problem in normal circumstances
planecane
Thu Jul 11, 2019 5:36 pm
The Bloomberg article that this article is rehashing does not use the same semantics with respect to the trim wheel. From the actual article (not the author paraphrasing it for clicks and ad revenue):
EASA’s checklist includes a number of issues that have been disclosed: the potential difficulty pilots have in turning the jet’s manual trim wheel
This does not say anything about reducing the difficulty with hardware changes. It could simply be proving that it can be turned if MCAS 2.0 inputs the new maximum authority out of trim. It could also be training for aerodynamic load alleviation (known as the "roller coaster procedure" in the 737-200 training manual).
Contrary to popular belief, at least the NG training manual says that in extreme situations it may be necessary to alleviate the load to turn the wheel. It just uses different, more technical wording than the -200 manual.
planecane
Thu Jul 11, 2019 5:45 pm
asdf wrote:
yes, sir ...
The test pilots didn't "insist" on anything. They discovered that a similar issue that was originally thought to only occur at high speed was also present at low speed. That doesn't mean normal situations.
The reason for the increased authority is simple. At low speed the control surface needs to move more to achieve the same result. Just look out the window on your next flight. Shortly after takeoff or before landing the ailerons deflect a lot (and are augmented at least on the 737 by spoilers) to bank. At cruise speed they barely deflect at all.
It's the exact same concept with MCAS. They didn't "increase the power" because the stability issue was worse. They increased the authority because it needed to provide the same stick force increase at low speed that it did at high speed.
frmrCapCadet
Thu Jul 11, 2019 5:53 pm
To repeat: Not all issues have to be fixed immediately. MCAS obviously first and now. We don't know about the others.
DenverTed
Thu Jul 11, 2019 6:21 pm
If they can rent an airplane for 1/2 M a month, that is 24 airplanes x 3 months x 1/2 = 36 M per quarter, which is quite a bit less than 185 M per quarter.
But maybe there are no airplanes to rent.
FluidFlow
Thu Jul 11, 2019 7:10 pm
Its actually not only the rent you can claim. Say you have to rent a 737-800 to replace the Max-8. Its the rent + the cost for the capital to rent it + the cost for the additional manpower to organize everything + the cost for parking the Max + the cost for the additional fuel burn of the -800 + the additional cost for compensation eventually stranded passengers + additoonal insurance costs because your fleet is actually now bigger and the Max aircraft need ground insirance and so on. There is actually a huge tally of costs airlines are facing especially in the background.
flyingphil
Thu Jul 11, 2019 8:54 pm
The BILLION dollar question - When will the 737MAX be flying again?
So.. do we know the extent of the issues that need fixing? Errr well kinda
Do we know what the fix is? Software or Software and Hardware? More training? A new bigger trim wheel, new flight computer .. errr… we are working on it
So when will my shiny new 737MAX be back earning me money? September! Umm October. .January.. soon..
The cost of the eventual fix and the compensation payments must have wiped out any profit Boeing could hope to make on these birds.
Boeing must be bleeding dollars at an incredible rate right now.
If I was a Boeing customer I would not be making stage payments on a bird that cant fly.. plus it would be costing me money in pilots wages, parking fees, maintenance, chartering in replacement planes.. and on and on.
A tipping point must be coming up where if a fix is not agreed worldwide, and soon, they will have to halt production at Renton.
I really hope someone at Boeing is working on a Plan B.
14ccKemiskt
Thu Jul 11, 2019 9:25 pm
Rest assured that Plan B is identical to Plan A – Get that MAX back in the air, whatever it takes! Included in "whatever" is money, time and PR. Boeing will have this as its only goal before desciding to do anything else.
The 737 MAX isn't that bad of a plane, it's just that people don't trust it right now. Also, right now people does not really trust Boeing. Or the FAA. Or Boeing's relation to the FAA. The Plan has a good chance of succeeding but it will be expensive, time consuming and embarrassing. It kind of HAS to be all that, in order for people to really feel that every stone has been turned, that the authorities are back in charge and that Boeing has been fully "reprimanded" for their misuse of FAA trust and poor engineering choices.
hivue
Thu Jul 11, 2019 10:08 pm
I'm going to go waaaaaaaaay out on a limb ( :D ) and predict that the MAX eventually will end up just as much a cash cow for Boeing as its ancestors have been.
Correct. It's good that they have way more dollars than they could ever possibly bleed out.
...plus it would be costing me money in pilots wages...
If you were a Boeing customer and paying your pilots not to fly, you'd have more problems than Boeing has right now.
DenverTed
Thu Jul 11, 2019 10:11 pm
Does Boeing get any credit for saved hours and cycles which would otherwise be on the aircraft over the quarter?
TTailedTiger
Thu Jul 11, 2019 10:18 pm
Why aren't airlines held to this level of contempt when their maintenance practices or pilots are responsible for a deadly crash?
flyingphil
Thu Jul 11, 2019 10:45 pm
So Ryanair are getting restless..
So their Plan B is to order 100 Airbus for its Laudamotion subsidary.
planecane
Fri Jul 12, 2019 1:30 am
Good point! You should work at Boeing PR! :-)
That and the fuel savings are big positives.
Revelation
Fri Jul 12, 2019 1:31 am
Reuters has a few spicy leads:
I find the first article to be the most interesting. I wonder if this is the last "retirement" we will be seeing. It's interesting that the NMA guy now owns fixing MAX, and a.net punching bag Mike Sinnett now owns NMA while retaining the role of MAX punching bag.
MSPNWA
Fri Jul 12, 2019 2:55 am
Sadly not a publicly or politically engaging contempt. It's not interesting.
This has never been about true safety.
ShamrockBoi330
Fri Jul 12, 2019 3:09 am
flyingphil wrote:
https://www.reuters.com/article/us-ryanair-hldgs-boeing-737/ryanair-sees-risk-to-2020-growth-if-737-max-grounded-beyond-november-idUSKCN1U52ME
That was always Plan A for Laudamotion and has not been a secret.
Planetalk
Fri Jul 12, 2019 3:33 am
Well its kind of hard to prove that every pilot in an airline behaves the same way, but I would hope every 737 Max does.
In any case airlines have suffered severe reputational damage and penalties in the past. See Korean Air. And plenty of people avoid Air France, though I don't think that's at all justified anymore.
Not sure your point though, Boeing should just be left alone and an unsafe plane allowed to fly, because otherwise its not fair?
Interested
Fri Jul 12, 2019 5:36 am
https://www.bbc.co.uk/news/world-asia-48953892
The negative stories about Boeing keep building.
"Families cheated of Boeing crash compensation"
74k per family - I've no doubt with the level of focus on this crash Boeing wont get away with this. Maybe they would in the past. But not this time.
marcelh
Fri Jul 12, 2019 7:18 am
For those who are blaming the airlines, maintenance department and pilots for crashing the MAX, I have one question:
Why are those people perfectly able not to kill hundreds of people within a few months with the 737NG?
qf789
Fri Jul 12, 2019 7:21 am
Seriously just discuss the topic without trying to provoke others users or engaging in personal attacks. If you can not engage with other users in a respectful manner, remove yourself from the discussion. This will be the last warning posted by moderators in this thread, the next time the thread will be locked for good.
Forum Moderator
journeyperson
Fri Jul 12, 2019 7:22 am
Morning ritual: Scroll through 737 Max thread looking for links to actual developments...
Absynth
Fri Jul 12, 2019 7:27 am
I'm not quite sure why some of the Boeing 'defenders' (whitewashing is a forbidden word so it seems) object to the notion of ill-intent.
If this truely is a case of a complete failure of SE processes, gross incompetence in engineering and design and failure to verify and (in this case most importantly) validate the system that would be the worst possible outcome for Boeing.
It changes the root cause from an easily replacable management set on specific targets like economics and planning over safety, to the complete organisation itself. That would, for me personally, change my position from 'MAX on probation' to 'if it's Boeing I ain't going'.
TheFlyingDisk
Fri Jul 12, 2019 8:03 am
Good question. But..
ET lost a 737NG back in 2010 off Beirut, to which the probable cause was described by Lebanese authorities to be "the flight crew's mismanagement of the aircraft's speed, altitude, headings and attitude through inconsistent flight control inputs resulting in a loss of control and their failure to abide by CRM". The airline obviously refutes the conclusion.
As for JT, they did write off a 737NG within two months of delivery back in 2013, luckily without any fatalities. Not to mention several other incidents throughout the years right up until JT610,
Granted the NG accidents weren't consecutively. But that's just the luck of the draw to be honest.
I FLY KLM+ALASKA+QATAR+MALAYSIA+AIRASIA+MALINDO
B777LRF
Fri Jul 12, 2019 8:19 am
You only need to ask one simple question: Would those two aircraft have crashed if they were NGs. The answer is obviously a resounding NO, which leads us right back to the point of Max airworthiness. It stands to reason the Max with MCAS V1.0 should never have been certified to operate commercial services, question is whether its many, and seemingly increasing on a weekly basis, flaws can be fixed in a reasonable timeframe and to the satisfaction of aviation regulators around the world.
There are people here fighting Boeing's corner, and will do so regardless of the evidence stacked against them. Nothing is going to change that; they're blinded by loyalty and/or on the payroll of a PR firm hired by Boeing.
Signature. You just read one.
uta999
Fri Jul 12, 2019 8:20 am
Some of this thread should be moved to the equivalent Technical/Operations, particularly when discussing the operating system and chips used. I thought that is what it was for.
Your computer just got better
max999
Fri Jul 12, 2019 8:28 am
A 'retirement' means he leaves with his golden parachute intact without being held accountable. Senior executives in the US corporate culture can only fail upward.
While workers who screw up at work get shoved out the door with nothing at all.
All the things I really like to do are either immoral, illegal, or fattening.
Virtual737
Fri Jul 12, 2019 8:34 am
A couple of interesting quotes from the first article:
'Boeing Co. said 737 program chief Eric Lindblad is retiring after about a year in the post'
'Lindblad, 57, “shared with me his desire to retire last year, and we will now begin to embark on a thoughtful and seamless transition plan,” '
So apparently he was planning on early retirement within a few months either side of his appointment as head on the MAX program.
majano
Fri Jul 12, 2019 8:46 am
Thank you for all these responses. If it is based on cost incurred, then I would agree that any cost "saved" due to the grounding has to be seen as a credit.
bgm
Fri Jul 12, 2019 8:50 am
Thank you. Couldn’t have put it better myself.
████ ███ █ ███████ ██ █ █████ ██ ████ [redacted]
PW100
Fri Jul 12, 2019 9:34 am
I'm probably missing the sarcastics behind this.
Customers fork out north of 50 million dollars to purchase a machine with the intent to generate income.
Now they are making ZERO income out of this machine, but still face all the capital costs, monthly lease payments, storing costs, etc.
Not sure where there is credit to be found in that . . .
Or are you your suggesting that Boeing assumes all of the customer's financing and operating costs, and then somehow gets reimbursed for not having the operating costs?
Francoflier
Fri Jul 12, 2019 9:48 am
Boeing is saving the airlines' money by preventing them from spending it on new aircraft!
:rotfl:
(Sorry, couldn't resist)
maint123
Fri Jul 12, 2019 9:50 am
Wasn't the lion air report due this month ?
Any updates from ppl in the know ?
ArgentoSystems
Fri Jul 12, 2019 10:06 am
Haha, good catch! :thumbsup: Funny he had to lie about that.
