MonAmQB
July 7 DL583 DTW-PVG uses A332?
Sun Jul 07, 2019 12:32 pm
Delta flight status shows that July 7 DL583 DTW-PVG uses A332. DTW-PVG Great Circle distance is 7,137 miles. Delta lists A332 range at 6,536 miles, which is not even close. Does anyone know why Delta would attempt this?
commpilot
Re: July 7 DL583 DTW-PVG uses A332?
Sun Jul 07, 2019 12:40 pm
DTW-PVG is 6,202 NM ....7,137 is SM
MIflyer12
Sun Jul 07, 2019 12:52 pm
My guess - Look for this as a tech sub in the regular DL widebody thread.
MonAmQB
Sun Jul 07, 2019 12:56 pm
To avoid the confusion of nm vs. sm, let’s use km... DTW-PVG Great Circle distance is 11,485km. Delta lists A332 range at 10,519km, still short by ~1,000km for the distance it intends to cover. This is just weird.
hOMSaR
Sun Jul 07, 2019 2:07 pm
Airplane range is never a single distance number, regardless of measurement units used.
The plural of Airbus is Airbuses. Airbii is not a word.
There is no 787-800, nor 787-900 or 747-800. It's 787-8, 787-9, and 747-8.
A321neoLR is also unnecessary. It's simply A321LR.
Airplanes don't have isles, they have aisles.
tb727
Sun Jul 07, 2019 2:35 pm
They are down a A359 due to a lightning strike in PEK. A/C is in DTW at the moment.
Ziyulu
Sun Jul 07, 2019 2:36 pm
They can always refuel in Alaska if needed.
dcajet
Sun Jul 07, 2019 3:20 pm
Well, do you know what if any load restrictions the flight had? The A332 (and particularly the IGW 242T version) can fly 15hr segments without trouble. AR flies daily the EZE-FCO route, the longest non stop by distance route for the A332, at 6,919 statute miles. With careful planning and some restrictions in place, DTW-PVG is perfectly doable.
MIflyer12
Sun Jul 07, 2019 4:37 pm
Why is it weird? There are tech subs every day. They'll fly light (low passenger and freight load) if they can. If they can't do that they will schedule a tech stop for refueling. They WILL NOT crash into the ocean some hundreds of km short of PVG. Do you think cancelling the outbound and return flights is better than a tech stop in both directions?
Polot
Sun Jul 07, 2019 6:08 pm
DL doesn’t have any 242T A332s. That said DL use to fly the A332 regularly scheduled on DTW-PEK, about 6,600 miles. Being a polar route helps a lot as winds are less of an issue. Obviously the plane flying to PVG will have weight restrictions and probably some seats blocked, but it is better than just canceling the flight due to a lack of available A350 at the moment.
