jetsetterusa
AA ORD Ground Stop 7-29-2019
Mon Jul 29, 2019 5:53 pm
I see a small amount of weather going to ORD so I know that has something to do with a 2hr ground stop but a small amount of weather should not cause a 2hr ground stop could it? is it winds or something else?
Crazy Day Tripper
airstatdfw
Re: AA ORD Ground Stop 7-29-2019
Mon Jul 29, 2019 5:57 pm
Wx has caused multiple directions of the flights to be stopped with avg dept delays over 1.5 hours. With the 2 lines of wx on both sides of ORD there wasn’t many paths to go with the planes.
flight152
Mon Jul 29, 2019 6:05 pm
Small amount of weather? It’s a line of thunderstorms over 500 miles long.
ual763
Mon Jul 29, 2019 6:43 pm
Some intl. flights have also diverted to MKE
From flying to the NOTAM office
PSU.DTW.SCE
Mon Jul 29, 2019 7:25 pm
There is a literal wall of thunderstorms stretching from mid-Michigan down to TN. Literally almost impossible without some serious circumnavigation to get to/from ORD to anywhere in the Northeast / Mid-Atlantic region.
Thus getting too many airplanes on the ground at ORD as well.
Also a few lines of storms have gone through there today earlier.
ytib
This is the current Advisory for ORD.
ATCSCC 081 ORD/ZAU 07/29/2019 CDM GROUND DELAY PROGRAM
CTL ELEMENT: ORD
ELEMENT TYPE: APT
ADL TIME: 1736Z
DELAY ASSIGNMENT MODE: UDP
ARRIVALS ESTIMATED FOR: 29/1736Z - 30/0259Z
CUMULATIVE PROGRAM PERIOD: 29/1600Z - 30/0259Z
PROGRAM RATE: 66/45/54/76/76/88/88/114/114/114
FLT INCL: ALL CONTIGUOUS US DEP
DEP SCOPE: (ALL+CZY_AP) ZLA ZAU ZLC ZTL ZDC ZNY ZHU ZJX ZFW ZOB ZDV
ZOA ZSE ZBW ZMA ZKC ZME ZID ZAB ZMP
CANADIAN DEP ARPTS INCLUDED: CYHZ CYOW CYUL CYYZ
DELAY ASSIGNMENT TABLE APPLIES TO: ZAU
MAXIMUM DELAY: 293
AVERAGE DELAY: 137
IMPACTING CONDITION: WEATHER / THUNDERSTORMS
COMMENTS: ARRIVING AND DEPARTING WESTBOUND. AAL AND SUBS WILL REMAIN
IN STOP UNITL 1930, CENTERS EAST OF THE WEATHER WILL REMAIN IN GS
UNTIL THEY HAVE ROUTES AVAILABLE. GS CANCELLED FOR EVERYONE ELSE,
USE NEW EDCTS.
This one was a little earlier
ATCSCC 078 DCC/ZAU 07/29/2019 AAL AND SUBS ORD STOP
EVENT TIME: 29/1715 -
DESTINATION AIRPORT: ORD
FACILITIES INCLUDED: ALL CENTERS
GROUND STOP PERIOD: 29/1715Z - 29/1930Z
REASON: USER REQ FOR GATE ISSUES
REMARKS: ORD GROUND STOP FOR AAL AND SUBS ONLY. IN ADDITION TO THE
2ND TIER GS AT ORD AT THIS TIME.
318, 319, 320, 321, 332, 333, 388, 707, 717, 722, 732, 733, 734, 73Q, 735, 73G, 738, 7M8, 739, 752, 753, 742, 74L, 744, 762, 763, 772, 77L, 77W, 789, 142, CN1, CR2, CR7, DC8, DH2, DH8, D8Q, D10, D95, EM2, ER3, ER4, E70, 100, J31, M11, M83, M88, M90, SF3
SteelChair
Mon Jul 29, 2019 7:33 pm
The wall of weather is mostly just rain. Big gaps between the yellow. The WSR88 system was the worst thing that ever happened to aviation. Another hysterical overreaction by ATC.
AAlaxfan
Mon Jul 29, 2019 7:51 pm
Hey, was it just AA or did it effect UA also? If so the title of this thread should be changed. Sounds like AA bashing.
Grumpy. Not a dwarf, not an attitude. It's a lifestyle.
aklrno
Mon Jul 29, 2019 9:11 pm
I had two such ground stops in the last 30 days. Both lasted about two hours, one at DEN and one at ORD. Thunderstorms. Both had all airlines stopped; I was on UA. Ground crews don't work outdoors during thunderstorms.
Nothing to see here. Please just move on.
September11
Mon Jul 29, 2019 9:40 pm
I guess 20 ground stops a year at ORD is typical.
Airliners.net of the Future
PSU.DTW.SCE
Mon Jul 29, 2019 10:09 pm
This has been the case for decades at ORD and nothing new. Lines of thundstorms will to do that.
This issue today is a few things:
1) Two of the primary arrival corridors from the east have effectively been shut down all today.
The only arrival corridor from the east that has been open have required significantly northern routings, up over parts of Canada and Northern Michigan, but much of that has been used by all the inbound TATL flights, leaving little capacity to absorb any additional capacity from other arrival corridors
2) Two of the primary departure routes to the east have also been shut-down.
3) Storms passed over ORD, temporarily halting all arrivals and departures briefly earlier today
3) Storms and lightning passing over ORD, closing the ramp for a few periods this morning today.
Then, add 1, 2, and 3 together that put too many aircraft on the ground without sufficient gate space, which then leads to ...4)
4) Ground stops of holding inbound aircraft at the origin, until they can free-up space for additional arrivals.
While they have added a bunch of runway capacity at ORD, there are still limitations on gate space on the ground and for capacity on the arrival departure corridors in the air.
There isn't a ton of room in to do full-scale re-routes for eastbound arrivals and departures since the air space starts to get pretty congested.
There is all the MDW traffic and specific corridors. DTW & YYZ to the east. Then there is all the flow in/out of the Northeast that starts backing up all the way into Ohio. Cleveland Center doesn't the air space to handle all the ORD re-routing on a day like today.
strfyr51
Mon Jul 29, 2019 11:56 pm
It usually has to do with Lightning and electrical storms in the area. I almost got smoked when a lightning bolt hit the ramp while I was directing an airplane into a gate.
It hit the ground 10 feet away from me and I could fell the Buzz all through my Body. I found out later it was because of the Steel Rebar they used to reinforce the Concrete Parking Pads at the gates. I NEVER questioned it again...
BatonOps
Tue Jul 30, 2019 12:48 am
Gotta love arm chair quarterbacks!!
PSU.DTW.SCE
Tue Jul 30, 2019 1:33 am
I guess I just take offense to the tone of some of these posts that take the tone of blantent armchair quarterbacking or attempts at drive-by bashing.
It’s one thing to ask a question like “hey I noticed AA is in a ground stop at ORD, can anyone tell me what is going on there? How bad is the weather?”
It is a a lot different that “hey wtf is wrong with AA at ORD today? Why are they in a ground stop, surely it can’t be that bad????”
There are a lot of complex aspects to operating in adverse weather conditions. Truthfully all airlines are light years ahead of where they were 2 decades ago and have far better data and resources available to make decisions. Mother Nature can never be overruled though.
Super80Fan
Tue Jul 30, 2019 1:46 am
Wasn't just AA. Tried to get on two different Delta flights to ORD today and both were delayed by over three hours.
Maybe it's the traffic but just like NYC when bad weather hits ORD the airport completely falls apart. Very poorly run airport considering MDW operates just fine.
RIP McDonnell Douglas
RIP US Airways
GoSteelers
Tue Jul 30, 2019 1:53 am
If it’s a GS for a specific airline, as in AA and Subs only, I can pretty much guarantee it was not an ATC issue, it was at the airline request.
Atlwarrior
Tue Jul 30, 2019 11:23 am
ORD recorded over 6 inches of rain over the airport yesterday. I think that warrants delays.
MIflyer12
Tue Jul 30, 2019 11:59 am
One ought to start with the FAA flight delay info map,
https://www.fly.faa.gov/flyfaa/usmap.jsp
and then look at a decent radar weather map, as with weather.com
People are responsible for bringing some skills.
SteelChair
Tue Jul 30, 2019 2:43 pm
There were multiple GS and a GDP. For -TSRA that was moving and has huge holes in it.
reednavy
Tue Jul 30, 2019 3:35 pm
When it's abundantly clear a person does not understand ATC and the multiple layers that go into these decisions. Either that or just a blowhard troll.
alasizon
Tue Jul 30, 2019 6:03 pm
Read the notice, it clearly says that AA requested an internal one for gate issues in addition to the existing GS that was in place for ORD. So one the storm started to move and break-up a little bit, the ORD specific stop was cancelled and the AA internal one remained in place due to gate issues.
ckfred
Tue Jul 30, 2019 6:20 pm
This was probably 15 years ago, but I had dropped off my wife at ORD. She was flying Eagle that evening to CLT. About the time I pulled in the driveway, she called to say that the flight was cancelled, as were many other flights. The AA baggage office was a madhouse, because people were trying to get their checked bags, so they could go home or check into a hotel.
It turns out that there was a line of thunderstorms extending from Detroit to South Bend and down to St. Louis. While the weather in Chicago was fine, the airspace to the northeast, east, southeast and south of Chicago was closed. So, flights to Boston, New York, Washington, Atlanta, all of Florida, Nashville, and New Orleans was cancelled. If you were going to MSP, LAX, SEA, DFW, MCI, or DEN, you may have been delayed due to aircraft not where they were supposed to be, but the air space was clear.
I remember looking at the Weather Channel later, and the storm from was just a thick line of orange, red, and purple. Those are the storm fronts where the cloud tops can easily reach to 30,000 feet and higher.
SteelChair
Tue Jul 30, 2019 6:38 pm
There were many notices that day.
There were 5 ORD Ground Stops that day that included all carriers from various centers.
The GDP was issued and then reissued.
So in summary, all day GDP, in and out of GS, in addition to the AAL only GS. Yes the AAL only one was at AA request.
All because of -TSRA that was moving and had massive holes.
airstatdfw
Tue Jul 30, 2019 7:41 pm
We will try to vector aircraft though holes in the wx. But sometimes pilots will still ask to deviate or not go through the hole. Once you start deviating it backs everything up. It’s even worse if the arrivals deviate into the dept corridor, we lose the corridor for depts and then have to reroute a/c to other directions, which also may be stopped. Yesterday there was a time that the East, North and South were all stopped. Some east bound jets didn’t have enough fuel for a Westbound reroute and went back to the gate for fuel, which then causes gates issues.
Wingtips56
Tue Jul 30, 2019 9:57 pm
AA has for decades imposed it's own flow control when a hub starts to back up. Essentially they delay banks following the one currently involved with the affected hub operation, so that the next bank doesn't arrive while the previous one is still there. And that can stagger back through the rest of that day. Holds are at origin rather than have planes stacked up at the hub with no place to go. It actually works better for the connections as everything essentially runs on a new schedule once the weather or operations event clears. So while a single flight of another carrier can arrive and depart whenever it can (with whatever is going on with ATC), trickling in banks of connecting flights doesn't work that way; rampant misconnects. If it really goes south, entire banks can be cancelled in order to get the system back on track.
I assume other hub carriers do the same; I'm just basing my reply on past experience as an AA airport agent. "CAC" in FLIFO meant to us that we didn't have to rebook connections for our delayed flight because everything was going to be delayed and just flow together later. (Flights at curfewed airports, like SNA, wouldn't usually be held, so those would generate overnight misconnects.)
Worked for WestAir, Apollo Airways, Desert Pacific, Western, AirCal and American Airlines (Retired). Flight Memory: 181 airports, 92 airlines, 78 a/c types, 403 routes, 58 countries (by air), 6 continents. 1,119,414 passenger miles.
Home airport : CEC
Oilman
Tue Jul 30, 2019 10:38 pm
Why would AA (or any airline) need to have a ground stop issued by the FAA for only their own flights? Can’t they simply delay their own flights at origin without FAA help?
GalaxyFlyer
Tue Jul 30, 2019 11:05 pm
Brings ATC into the loop at the command center and at the departure airports. Now ATC can plan knowing there’s a GS for AA flights
September11
Tue Jul 30, 2019 11:57 pm
Is this one of WN’s reasons not to fly to ORD?
