enilria
OAG Changes 8/5/2019:AC Drops OMA;NK Builds MCO,Suspends DEN-LAX,FLL-JAX/MCI/GSO/AVL,Adds PHX-SEA;UA Adds DEN-HOB
Sun Aug 04, 2019 12:21 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
4O CUN-SFO OCT 0.5>0.1[0.4]
4O IAH-MTY SEP 1.0>0.7[1.0]
4O JFK-MEX OCT 3>2[3] NOV 3>2[4] DEC 3>2[4] JAN 3>2[4] FEB 3>2[3] MAR 3>2[3] APR 3>2[4]
4O MEX-MIA SEP 1.7>1.2[1.7]
7H BTI-FAI OCT 1.0>0.8[0.3] NOV 0.9>0.7[0.1] DEC 1.0>0.7[0.1] JAN 1.0>0.7[0.1] FEB 1.0>0.7[0.1] MAR 1.0>0.7[0.1] APR 1.0>0.7[0.1] MAY 0.9>0.6[0.1]
9K BOS-HYA SEP 1.3>1.7[1.4] OCT 1.3>1.8[1.5]
AA ABE-ORD DEC 2>1.6[0] FEB 1.6>1.0[0] MAR 2>1.0[0]
AA ABE-PHL NOV 4>3[3]
AA ASE-DFW NOV 1.0>1.3[1.3]
AA AVP-CLT NOV 3>4[3]
AA AVP-PHL NOV 4>3[3]
AA BDL-PHL NOV 6>5[6]
*AA BGR-CLT NOV 0.1>0.7[0.1]
*AA BGR-LGA NOV 0.1>0.8[0.1]
AA BHM-DFW NOV 7>5[5]
AA BHM-PHL NOV 3>2[1.8]
AA BNA-CLT NOV 7>8[8]
AA BNA-PHL NOV 6>5[3]
AA BOS-DCA NOV 14>13[13]
AA BOS-LGA NOV 11>10[10]
AA BOS-MIA NOV 7>6[6]
AA BOS-ORD NOV 9>8[8]
AA BOS-PHL NOV 11>10[10]
AA BTV-CLT DEC 2>3[2.0]
AA BTV-PHL NOV 5>4[4]
AA BUF-DCA NOV 4>3[4]
AA BUF-PHL NOV 6>5[5]
AA BWI-MIA NOV 3>1.9[3]
AA BWI-ORD NOV 5>4[4]
AA BWI-PHL NOV 3>4[3]
AA BZN-DFW NOV 1.0>1.3[1.1]
AA CAE-CLT NOV 7>8[8]
AA CAE-DFW NOV 2>3[1.9]
AA CHS-MIA NOV 3>4[3]
AA CHS-PHL NOV 5>3[3]
AA CID-CLT JAN 2>3[2] FEB 2>3[2] MAR 2>3[2] APR 2>3[2] MAY 2>3[2]
AA CLE-CLT NOV 6>7[6]
AA CLT-DEN NOV 7>5[6] DEC 7>6[5]
AA CLT-EWR NOV 9>8[6]
AA CLT-GPT NOV 1.8>3[1.9] DEC 1.7>2[1.7] JAN 1.7>3[2.0] FEB 1.7>3[1.9] MAR 1.7>3[1.8] APR 1.7>3[2] MAY 1.7>3[2]
AA CLT-GRR NOV 2>3[3] DEC 2>3[3] APR 2>3[3] MAY 2>3[3]
AA CLT-JFK NOV 6>7[6]
AA CLT-LYH NOV 6>7[6]
AA CLT-MDT NOV 5>6[6]
AA CLT-MOB NOV 4>5[4]
AA CLT-MSN JAN 2>3[2] FEB 2>3[2] MAR 2>3[2] APR 2>3[2] MAY 2>3[2]
AA CLT-OKC NOV 2>3[2] DEC 2>3[2.0] JAN 2>3[2] FEB 2>3[2] MAR 2>3[2] APR 2>3[3] MAY 2>3[3]
AA CLT-PBI NOV 4>5[5]
AA CLT-PGV NOV 4>5[4]
AA CLT-PUJ DEC 1.7>1.3[1.6]
AA CLT-PWM DEC 2>3[3] JAN 2>3[3] FEB 2>3[3] MAR 2>3[3] APR 2>3[2] MAY 2>3[2]
AA CLT-RSW NOV 4>5[5]
AA CLT-SAV NOV 9>8[9]
AA CLT-SBY JAN 2>3[2] FEB 2>3[2] MAR 2>3[2] APR 2>3[2] MAY 2>3[2]
AA CLT-SEA NOV 4>3[3]
AA CLT-TYS NOV 7>8[8]
AA CLT-YUL NOV 2>1.6[1.7]
AA CMH-PHL NOV 7>5[5]
AA COS-ORD NOV 1.0>1.3[1.9]
AA CUN-JFK NOV 1.3>0.8[1.8]
AA DCA-EYW NOV 0.3>0.5[0.9]
AA DCA-LGA NOV 11>9[10]
AA DCA-MHT NOV 3>4[3]
AA DCA-MYR NOV 1.1>0.6[1.0]
AA DCA-SYR NOV 3>4[4]
AA DCA-YYZ NOV 3>1.7[2]
AA DEN-MIA NOV 2>3[1.9]
AA DFW-EGE NOV 0.5>0.8[1.1]
AA DFW-FAT NOV 1.9>3[2.0]
*AA DFW-FCA MAY 0>0.8[0]
AA DFW-FLL NOV 6>5[5]
AA DFW-FSD NOV 2>3[2.0]
AA DFW-GSP NOV 2>3[2]
AA DFW-HOU NOV 8>7[7]
AA DFW-IAH NOV 10>9[8]
AA DFW-LAS NOV 12>10[8]
AA DFW-MLU NOV 3>2[3]
*AA DFW-MRY NOV 0.1>0.9[0]
AA DFW-MTJ NOV 1.0>1.3[1.0]
*AA DFW-MYR NOV 0.1>1.0[0]
AA DFW-ORD NOV 14>13[13]
AA DFW-RNO NOV 2>3[2]
AA DFW-SEA NOV 8>7[7]
AA DFW-SLC NOV 6>5[6]
AA DFW-SRQ NOV 1.0>1.6[0]
AA DFW-SUX NOV 1.0>1.3[1.0]
AA DFW-YVR NOV 2.0>1.5[2.0]
AA DRO-PHX NOV 2>3[1.7]
AA DSM-PHL NOV 1.9>1.0[1.9]
AA DTW-PHL NOV 6>4[5]
AA ELP-ORD NOV 2>3[2.0]
AA EWR-PHX NOV 4>3[3]
AA EYW-MIA NOV 4>5[4]
AA FLL-ORD NOV 3>2[1.9]
AA FLL-PHL NOV 4>3[3]
AA FWA-PHL NOV 1.9>1.1[1.9]
AA GJT-PHX NOV 2>3[1.9]
AA GRR-PHL NOV 3>1.9[3]
AA HPN-ORD NOV 2>3[1.9]
AA HSV-ORD NOV 2.0>1.5[1.8]
AA IAH-PHL NOV 4>3[3]
AA IND-LAX NOV 1.0>1.2[1.8]
AA IPT-PHL NOV 3>1.9[1.9]
AA ITH-PHL NOV 3>4[3]
AA JAX-ORD NOV 3>2[2.0]
AA JFK-LAX NOV 12>10[11]
AA JFK-ORD NOV 1.7>2[1.0]
AA JFK-RIC NOV 1.0>0.8[0]
AA JFK-YUL NOV 1.9>0.9[1.9]
AA LAS-MIA NOV 3>2.0[3]
AA LAX-MCO NOV 2>3[2]
AA LAX-RDU NOV 1.0>1.2[1.0]
AA LAX-SJD NOV 1.0>1.3[1.9]
AA LAX-STS NOV 0.1>1.0[0]
AA LAX-XNA NOV 2.0>1.6[0.9]
AA LGA-MSP NOV 3>1.8[3]
*AA LGA-PBI NOV 0>0.3[0]
AA LGA-PHL NOV 2>4[3]
AA LGA-PWM NOV 1.7>1.0[1.8]
AA LGA-RIC NOV 3>4[4]
AA LGA-STL NOV 4>3[4]
AA MCI-ORD NOV 7>6[6]
AA MCI-PHX NOV 1.9>1.0[2]
AA MCO-PHX NOV 3>2[1.8]
AA MEM-PHL NOV 3>1.9[1.9]
AA MHT-ORD DEC 2>1.6[0] FEB 1.6>1.0[0] MAR 2>1.0[0]
AA MIA-PIT NOV 2>3[2]
AA MIA-RDU NOV 3>4[3]
AA MIA-TLH JAN 3>4[4] FEB 3>4[4] MAR 3>4[4] APR 3>4[4] MAY 3>4[4]
AA MKE-PHL NOV 5>3[3]
AA MSP-PHL NOV 4>2[2.0]
AA MSP-PHX NOV 4>3[3]
AA MSY-ORD NOV 1.9>2[1.8]
AA MSY-PHL NOV 2>3[2.0]
AA MYR-PHL NOV 3>1.6[1.0]
AA OKC-PHL NOV 1.9>1.0[1.9]
AA OKC-PHX NOV 1.1>1.9[1.0] DEC 1.0>1.5[1.0]
AA OMA-PHL NOV 1.9>1.0[1.8]
*AA ONT-ORD NOV 0>0.3[0]
AA ORD-SCE DEC 2>1.6[0] FEB 1.6>1.0[0] MAR 2>1.0[0]
*AA ORD-SPI NOV 0>0.6[0] DEC 0>0.2[0]
*AA ORD-SRQ NOV 0>0.3[0]
AA PHL-PIT NOV 6>5[5]
AA PHL-PNS NOV 1.0>1.9[1.0]
AA PHL-PVD NOV 6>5[5]
AA PHL-PWM NOV 6>4[6]
AA PHL-RIC NOV 7>6[6]
AA PHL-ROC NOV 6>5[4]
AA PHL-SAN NOV 3>1.9[1.9]
AA PHL-SCE NOV 5>4[4]
AA PHL-SDF NOV 4>3[3]
AA PHL-SEA NOV 4>1.9[1.1]
AA PHL-SFO NOV 5>4[4]
AA PHL-SWF NOV 3>4[3]
AA PHL-YOW NOV 3>1.9[3]
AA PHL-YUL NOV 5>3[4]
AA PHX-PIT NOV 1.0>1.8[1.7]
AA PHX-RNO JAN 4>5[4] FEB 4>5[4] MAR 4>5[4]
AA PHX-SAF NOV 1.0>1.8[0.7]
AA PHX-SBA NOV 5>4[4]
AA PHX-SEA NOV 4>3[4]
AA PHX-SFO NOV 5>4[5]
AA PHX-TUS NOV 6>8[7]
AC HNL-YVR NOV 1.6>1.0[1.0] DEC 1.8>1.0[1.8] JAN 2>1.0[1.9] FEB 2>1.0[2.0] MAR 2>1.0[2] APR 1.7>1.0[1.8]
*AC LIH-YVR DEC 0.2>0[0.2] JAN 0.4>0[0.5] FEB 0.4>0[0.4] MAR 0.4>0[0.4] APR 0.3>0[0.4]
AC OGG-YVR NOV 1.4>1.0[1.4] DEC 1.7>1.0[1.7] JAN 2>1.0[1.9] FEB 2>1.0[2.0] MAR 2>1.0[2] APR 1.7>1.0[1.9]
AC OGG-YYC NOV 0.4>0[0.4] DEC 0.5>0.3[0.5]
*AC OMA-YYZ OCT 1.0>0.1[0.9] NOV 1.0>0[0.9] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[0.9] APR 1.0>0[1.0] MAY 1.0>0[1.0]
AM BJX-LAX NOV 0.8>0.6[0.6]
AS ABQ-SEA NOV 1.5>1.1[1.2] DEC 1.5>1.0[1.5]
*AS ANC-RDB NOV 0.3>0.1[0.3] DEC 0.3>0.0[0.3]
AS ANC-SCC NOV 1.5>2[1.3] DEC 1.4>2[1.3]
AS BOS-SFO NOV 2>1.4[1.9] DEC 2>1.5[1.9]
AS BUR-PDX NOV 3>2[2] DEC 3>2[3]
AS DEN-SEA DEC 4>5[4]
AS FCA-SEA NOV 2>3[2] DEC 2>3[3]
AS GEG-PDX NOV 8>7[7] DEC 8>7[7]
AS GEG-SEA DEC 15>16[15]
AS GTF-SEA NOV 1.3>1.7[1.3] DEC 1.3>1.7[1.2]
AS IAD-SEA NOV 2.0>1.1[1.0] DEC 2>1.0[1.0]
AS IAH-SEA NOV 1.4>1.9[1.4] DEC 1.5>2[1.4]
This is a big increase from a year earlier
*AS JNU-SEA NOV 3>4[2] DEC 3>4[2]
AS LAS-PDX NOV 4>3[3] DEC 4>3[3]
AS LAX-PDX NOV 8>7[7] DEC 8>7[7]
AS MSY-SEA DEC 1.5>2[1.0]
AS OAK-PDX NOV 3>2[2] DEC 3>2[2]
AS ONT-SEA NOV 2>3[3] DEC 2>3[2]
AS PDX-SAN NOV 3>4[3] DEC 3>4[3]
AS PDX-SEA DEC 19>20[20]
Trip swapped from SFO to SJC, interesting
AS PDX-SFO NOV 8>7[7] DEC 8>7[7]
AS PDX-SJC NOV 5>6[5] DEC 5>6[5]
AS PDX-STS NOV 1.1>1.5[1.1] DEC 1.0>1.5[1.0]
AS PDX-TUS NOV 0.9>0.7[0.7]
*AS PHL-SEA NOV 1.2>2.0[1.0] DEC 1.0>2[1.0]
AS PUW-SEA DEC 4>5[4]
AS SAT-SEA NOV 1.5>2.0[1.0] DEC 1.5>2[1.0]
AS SEA-SLC OCT 5>6[4]
AS SEA-SMF NOV 5>7[5] DEC 5>7[5]
AS SEA-STL NOV 1.4>1.9[1.5] DEC 1.5>2[1.4]
AS SEA-SUN DEC 0.8>1.1[0.7]
AS SEA-TUS NOV 1.3>1.9[1.4] DEC 1.5>2[1.5]
AS SEA-YLW NOV 1.9>1.0[1.9] DEC 2>1.4[2]
AS SEA-YYC NOV 2>3[2] DEC 2>3[2]
AS SEA-YYJ NOV 3>4[3] DEC 3>4[3]
AS SJC-SNA NOV 4>6[4] DEC 4>6[4]
DL ANC-MSP MAY 1.0>1.3[1.0]
DL ATL-GRB JAN 1.5>1.0[1.0] FEB 1.6>1.0[1.0] MAR 2>1.0[1.0]
DL ATL-HPN DEC 5>6[5] JAN 5>6[5] FEB 4>6[5]
DL ATL-MSN FEB 4>3[3] MAR 4>3[3]
*DL ATL-ONT APR 1.9>3[0.2] MAY 1.8>3[0.7]
DL AUS-RDU NOV 0.5>0.7[0.6]
DL BOS-JFK JAN 7>6[7] FEB 7>6[7]
DL BWI-DTW JAN 3>4[3] FEB 3>4[3]
DL CAE-LGA JAN 0.9>1.5[0.8] FEB 0.9>1.6[0.8]
DL CHO-LGA JAN 1.5>2[1.4] FEB 1.5>2[1.5]
DL CHS-DTW MAY 2>3[2.0]
DL DTW-EWR FEB 5>6[6] MAR 5>6[6] APR 5>6[6] MAY 5>6[6]
DL DTW-SJC NOV 0.6>1.0[0.4] DEC 0.7>1.0[0.8] JAN 0.7>1.3[0.7] FEB 0.7>1.4[0.7] MAR 0.7>1.4[0.7] APR 0.9>1.4[0.7] MAY 0.8>1.5[0.7]
DL EWR-MSP JAN 4>5[4] FEB 4>5[4] MAR 4>5[5] APR 4>5[5] MAY 4>5[5]
DL FAT-SLC MAY 3>4[3]
DL GEG-MSP MAY 1.8>3[1.8]
DL GSP-LGA JAN 1.8>2[1.7] FEB 1.6>2[1.6] MAR 1.9>3[1.8]
DL LAX-SMF FEB 4>5[4]
DL LGA-PWM JAN 2>3[2] FEB 2>3[2]
DL LGA-TYS JAN 1.6>2[1.5] FEB 1.7>2[1.6]
DL MSP-SEA MAY 6>7[6]
DL ONT-SLC MAY 3>5[3]
F9 ATL-MCO SEP 1.1>1.5[1.0] OCT 1.1>1.5[1.0]
*F9 BHM-MCO SEP 0.3>0.1[0.3] OCT 0.5>0[0.3]
F9 CLE-MCO OCT 2>1.3[1.3]
*F9 CMH-RDU SEP 0.4>0.1[0] OCT 0.5>0[0]
F9 COS-MCO SEP 0.6>0.1[0.5]
F9 CVG-MCO SEP 1.3>1.0[1.4] OCT 1.7>1.0[1.4]
F9 DEN-FLL SEP 0.8>1.0[0]
F9 DEN-MCO SEP 2>1.2[1.3]
F9 DEN-ONT SEP 0.7>0.9[1.0]
*F9 JAX-RDU SEP 0.4>0.1[0] OCT 0.5>0[0]
F9 LAS-PHX SEP 0.8>1.2[0]
F9 MCO-MSP SEP 0.7>0.9[0]
F9 MCO-ONT SEP 0.7>0.9[1.0]
F9 MCO-SAN SEP 0.2>0.6[0] OCT 0.5>1.0[0]
F9 MIA-PHL SEP 0.6>0.8[0] OCT 0.5>0.8[0]
F9 ORD-PHX SEP 0.7>1.0[0.6]
F9 PHL-RSW SEP 0.7>0.9[0.4]
I didn't realize MSP was seasonal
*FI KEF-MSP JAN 0.6>0.1[0.1] FEB 0.6>0[0]
G4 AZA-FAR OCT 0.6>0.9[0.5] NOV 0.6>0.9[0.6] DEC 0.8>1.0[0.6]
IB BCN-BOS APR 1.0>0.6[0.4] MAY 1.0>0.6[0.5]
KG DEN-RIW NOV 0>1.4[1.9] DEC 0>1.4[1.7] JAN 0>0.5[1.4]
KG DEN-SHR NOV 0>0.6[1.0] DEC 0>0.6[1.0] JAN 0>0.2[0.6]
KG RIW-SHR NOV 0>1.4[0.9] DEC 0>1.4[0.8] JAN 0>0.5[1.3]
*LO BUD-ORD NOV 0.3>0[0.3] DEC 0.3>0[0.3] JAN 0.3>0[0.3] FEB 0.3>0[0.1] MAR 0.3>0.0[0.3]
NOTE: Apr is a partial schedule. Significant shift to MCO from other Florida airports.
NK ACY-FLL FEB 1.1>3[3] APR 0>2[3]
NK ACY-MCO FEB 0.8>2[2] APR 0>1.4[2]
NK ACY-MYR FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ACY-PBI FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ACY-RSW FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK ACY-TPA FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ATL-AUS FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK ATL-BOS FEB 0.2>0.4[0.4] MAR 0>0.5[0.4] APR 0>0.3[0.4]
NK ATL-BWI FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK ATL-CLE FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK ATL-DFW FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ATL-DTW FEB 0.8>2[2] APR 0>1.4[2]
NK ATL-EWR FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ATL-FLL JAN 4>5[5] FEB 1.5>5[5] MAR 0>6[5] APR 0>4[5]
NK ATL-IAH FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ATL-LAS FEB 0.8>2[1.0] MAR 0>2[1.0] APR 0>1.4[1.0]
NK ATL-LAX FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ATL-MCO FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK ATL-MSP FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ATL-MSY FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ATL-ORD FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ATL-PHL FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ATL-TPA FEB 0.8>2[1.0] MAR 0>2[1.0] APR 0>1.4[1.5]
NK AUS-BWI FEB 0.4>1.0[0.5] APR 0>0.7[1.0]
NK AUS-DEN FEB 0.4>1.0[0.5] APR 0>0.7[1.0]
NK AUS-DTW FEB 0.4>1.0[0.5] APR 0>0.7[1.0]
NK AUS-FLL FEB 0.4>1.0[0.5] APR 0>0.7[1.0]
NK AUS-LAS FEB 0.4>1.0[0.5] APR 0>0.7[1.0]
NK AUS-LAX FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK AUS-MCO FEB 0.4>1.0[0.5] APR 0>0.7[1.0]
NK AUS-MSY FEB 0.4>1.0[0.5] APR 0>0.7[1.0]
NK AUS-ORD FEB 0.4>1.0[0.5] APR 0>0.7[1.0]
A move back to daily services overall, or just in AVL?
**NK AVL-FLL NOV 1.0>0.4[0.5] DEC 0.9>0[0.5] JAN 1.0>0[0.5] FEB 0.4>0[0.5]
NK AVL-MCO NOV 0.5>0.8[0.5] DEC 0.5>1.0[0.5] JAN 0.5>1.0[0.5] FEB 0.2>1.0[0.5] MAR 0>1.0[0.6] APR 0>0.7[0.6]
**NK AVL-TPA NOV 0.3>0.1[0.4] DEC 0.4>0[0.3] JAN 0.3>0[0.4]
NK AXM-FLL FEB 0.2>0.4[0.4] APR 0>0.3[0.4]
NK BDL-FLL FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK BDL-MCO FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK BDL-MYR MAR 0>0.4[0.3] APR 0>0.4[0.6]
NK BDL-RSW FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK BDL-TPA FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BNA-BWI FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK BNA-FLL FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK BNA-LAS FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK BNA-MCO FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK BNA-MSY FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK BNA-TPA FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK BOG-FLL FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BOG-MCO FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BOS-BWI FEB 0.8>2[2] APR 0>1.4[2]
NK BOS-FLL FEB 0.7>2[1.9] APR 0>1.4[2]
NK BOS-LAS FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BOS-MCO FEB 0.8>1.9[1.9] APR 0>1.4[2]
NK BOS-MSY FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK BOS-MYR FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BOS-PBI FEB 0.4>1.0[1.0] APR 0>0.7[1.5]
NK BOS-RDU FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK BOS-RSW FEB 0.4>1.6[2] APR 0>1.4[2]
NK BOS-TPA FEB 0.4>1.0[1.0] APR 0>0.7[1.5]
NK BQN-FLL FEB 0.1>0.5[0.6] MAR 0>0.5[0.7] APR 0>0.4[0.7]
NK BQN-MCO FEB 0.1>0.4[0.4] APR 0>0.4[0.5]
NK BUR-LAS FEB 1.2>3[0] MAR 0>3[0] APR 0>2[0]
NK BWI-CLT FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK BWI-CUN FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK BWI-DEN FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK BWI-DFW FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BWI-DTW FEB 0.4>1.0[1.5] APR 0>0.7[1.0]
NK BWI-FLL FEB 1.1>3[3] APR 0>2[3]
NK BWI-IAH FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BWI-JAX FEB 0.3>0.9[0.5] APR 0>0.7[1.0]
NK BWI-LAS FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BWI-LAX FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BWI-MBJ FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK BWI-MCO FEB 1.0>3[3] APR 0>2[3]
NK BWI-MSP JAN 1.0>0.2[1.0] APR 0>0.7[1.0]
NK BWI-MSY FEB 0.4>1.0[1.0] MAR 0>1.0[1.4] APR 0>0.7[1.0]
NK BWI-MYR FEB 0.1>0.6[0.6] MAR 0>0.7[1.0] APR 0>0.5[1.0]
NK BWI-ORD FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BWI-RDU FEB 0.3>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK BWI-RSW FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK BWI-SJU FEB 0.1>0.5[0.3] APR 0>0.4[0.5]
NK BWI-TPA FEB 0.4>1.0[1.4] MAR 0>1.0[1.7] APR 0>0.7[1.7]
NK CAK-MCO FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK CAK-RSW FEB 0.2>0.5[0.5] MAR 0>0.5[0.6] APR 0>0.4[0.6]
NK CAK-TPA FEB 0.1>0.3[0.4] MAR 0>0.5[0.4] APR 0>0.3[0.4]
NK CLE-FLL JAN 1.3>1.9[1.2] FEB 0.6>1.8[1.0] MAR 0>1.5[1.0] APR 0>1.1[1.5]
NK CLE-LAS DEC 1.0>1.4[1.0] FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK CLE-LAX FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
*NK CLE-MCO JAN 1.0>1.9[1.2] FEB 0.4>2[1.0] MAR 0>2[1.0] APR 0>1.4[1.5]
NK CLE-MSY FEB 0.1>0.3[0.4] MAR 0>0.5[0.4] APR 0>0.3[0.4]
NK CLE-MYR MAR 0>0.3[0.2] APR 0>0.3[0.4]
NK CLE-RSW FEB 0.3>0.9[0.9] MAR 0>1.0[1.4] APR 0>0.7[1.3]
NK CLE-TPA FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK CLO-FLL FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK CLT-EWR FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK CLT-FLL FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK CLT-MCO FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK CMH-FLL FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK CMH-LAS FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK CMH-MCO FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK CMH-RSW FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK CMH-TPA FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK CTG-FLL FEB 0.2>0.6[0.6] APR 0>0.4[0.6]
NK CTG-MCO APR 0>0.2[0.3]
NK CUN-DFW FEB 0.1>0.3[0.4] MAR 0>0.5[0.4] APR 0>0.3[0.4]
NK CUN-DTW FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK CUN-FLL FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK CUN-IAH FEB 0.1>0.4[0.4] APR 0>0.3[0.4]
NK CUN-ORD FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK DEN-DFW FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DEN-DTW FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK DEN-FLL FEB 0.7>2[1.9] APR 0>1.4[2]
NK DEN-IAH FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DEN-LAS NOV 1.7>1.1[1.0] DEC 1.8>1.0[1.0] JAN 1.7>1.0[1.0] FEB 0.7>1.0[1.0] APR 0>0.7[1.0]
*NK DEN-LAX NOV 0.9>0.3[0] DEC 0.8>0[0] JAN 0.7>0[0] FEB 0.3>0.6[0] MAR 0>1.0[0] APR 0>0.7[0]
NK DEN-MCO FEB 0.4>1.0[0.0] APR 0>0.7[1.0]
NK DEN-MSY FEB 0.4>1.0[0.5] APR 0>0.7[1.0]
NK DEN-ORD FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DFW-DTW FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DFW-LAS FEB 1.2>3[3] APR 0>3[4]
NK DFW-LAX FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK DFW-LGA FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DFW-MCO FEB 0.8>2[2] APR 0>1.4[2]
NK DFW-ORD FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DFW-PHL FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DFW-PHX FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DFW-TPA FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DTW-IAH FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DTW-JAX FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK DTW-LAX FEB 0.4>1.0[1.5] APR 0>0.7[1.0]
NK DTW-LGA FEB 0.8>2[2] APR 0>1.4[2]
NK DTW-MBJ FEB 0.2>0.4[0.4] MAR 0>0.5[0.4] APR 0>0.3[0.4]
*NK DTW-MCI JAN 1.0>0.7[1.0] FEB 0.4>0.9[1.0] APR 0>0.7[1.0]
NK DTW-MCO FEB 1.4>4[4] MAR 0>4[5] APR 0>3[4]
*NK DTW-MSP JAN 1.0>0.2[1.0] APR 0>0.7[1.0]
NK DTW-MSY FEB 0.4>1.0[1.1] MAR 0>1.0[1.4] APR 0>0.7[1.0]
NK DTW-MYR FEB 0>0.6[0.5] APR 0>0.7[1.0]
NK DTW-PBI JAN 0.6>0.2[0.5] MAR 0>0.5[0.6] APR 0>0.4[0.6]
NK DTW-RDU FEB 0.3>0.9[0] MAR 0>1.0[0] APR 0>0.7[0]
NK DTW-RSW NOV 3>2[3] DEC 3>2[3] JAN 3>2[4] FEB 1.1>3[4] MAR 0>3[4] APR 0>2[4]
NK DTW-TPA JAN 3>4[3] FEB 1.1>3[3] APR 0>2[3]
NK EWR-FLL FEB 1.0>2[2] APR 0>1.7[2]
NK EWR-IAH FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK EWR-LAS FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK EWR-MCO FEB 1.1>3[3] APR 0>2[3]
NK EWR-MSY FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK EWR-MYR FEB 0.2>0.6[0.6] MAR 0>0.5[0.6] APR 0>0.4[0.6]
NK EWR-RSW FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK EWR-SDQ FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK EWR-TPA FEB 0.4>1.0[0] APR 0>0.7[0.3]
*NK FLL-GSO NOV 0.3>0.1[0.4] DEC 0.4>0[0.3] JAN 0.3>0[0.4]
NK FLL-GUA FEB 0.3>1.0[1.0] APR 0>0.7[1.0]
NK FLL-GYE FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-IAG FEB 0.2>0.8[0.8] APR 0>0.7[1.0]
NK FLL-IAH FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
*NK FLL-JAX NOV 1.0>0.4[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 0.4>0[0.5]
NK FLL-KIN FEB 0.2>0.7[0.7] APR 0>0.5[0.7]
NK FLL-LAS FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-LAX FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-LBE FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK FLL-LGA FEB 1.7>4[4] APR 0>3[4]
NK FLL-LIM JAN 0.3>1.0[0.8] FEB 0.1>1.0[0.9] APR 0>0.7[1.0]
NK FLL-MBJ FEB 0.3>0.9[1.0] APR 0>0.7[1.0]
*NK FLL-MCI NOV 0.3>0[0.4] DEC 0.5>0[0.5] JAN 0.5>0[0.5]
NK FLL-MCO FEB 0.8>2[2] APR 0>1.4[2]
NK FLL-MDE FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-MGA FEB 0.4>1.0[0.6] MAR 0>1.0[0.6] APR 0>0.7[0.6]
NK FLL-MSP FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-MSY FEB 0.8>2[2] APR 0>1.4[2]
NK FLL-MYR NOV 1.2>1.5[1.3] FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-PAP FEB 0.3>0.9[1.0] APR 0>0.7[1.0]
NK FLL-PBG FEB 0.2>0.8[0.8] APR 0>0.7[1.0]
NK FLL-PIT NOV 1.1>1.7[1.0] DEC 1.0>2.0[1.0] JAN 1.0>2[1.0] FEB 0.4>2[1.0] MAR 0>2[1.0] APR 0>1.4[1.0]
NK FLL-PTY FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-PUJ FEB 0.1>0.3[0.4] APR 0>0.3[0.4]
NK FLL-RDU JAN 0.7>1.0[0] FEB 0.3>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK FLL-RIC FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-SAP FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-SDQ FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK FLL-SJO FEB 0.8>2[2] MAR 0>2[2.0] APR 0>1.4[2]
NK FLL-SJU NOV 0.8>1.1[0.5] DEC 0.8>1.3[1.0] JAN 1.0>1.9[1.5] FEB 0.4>1.7[1.2] MAR 0>1.5[1.0] APR 0>1.1[1.0]
NK FLL-STI FEB 0.2>0.6[0.6] MAR 0>0.5[0.6] APR 0>0.4[0.6]
NK FLL-STT FEB 0.2>0.5[0.5] APR 0>0.4[0.5]
NK FLL-TPA FEB 0.8>2[2] APR 0>1.4[2]
Similar to AVL
*NK GSO-MCO NOV 0.5>0.8[0.5] DEC 0.5>1.0[0.5] JAN 0.5>1.0[0.5] FEB 0.2>1.0[0.5] MAR 0>1.0[0.6] APR 0>0.7[0.6]
*NK GSO-TPA NOV 0.3>0.1[0.4] DEC 0.4>0[0.3] JAN 0.3>0[0.4]
NK GUA-IAH FEB 0.2>0.6[0.6] MAR 0>0.5[0.6] APR 0>0.4[0.6]
NK GUA-MCO FEB 0.2>0.6[0.6] APR 0>0.4[0.6]
NK IAG-MYR APR 0>0.3[0.4]
NK IAH-LAS FEB 0.8>2[2] APR 0>1.4[2]
NK IAH-LAX FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK IAH-MSY FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK IAH-ORD FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK IAH-SAL FEB 0.2>0.4[0.4] MAR 0>0.5[0.4] APR 0>0.3[0.4]
NK IAH-SAN FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK IAH-SAP FEB 0.2>0.6[0.6] APR 0>0.4[0.6]
NK IAH-TPA FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK IND-LAS FEB 0.4>1.0[0] MAR 0>1.0[0.6] APR 0>0.7[1.0]
NK IND-MCO FEB 0.4>1.0[0] MAR 0>1.0[0.6] APR 0>0.7[1.0]
NK IND-RSW FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK IND-TPA FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK JAX-ORD FEB 0.3>0.9[1.0] APR 0>0.7[1.0]
NK KIN-MCO FEB 0.2>0.4[0] APR 0>0.3[0.4]
NK LAS-LAX FEB 1.1>3[3] APR 0>2[3]
NK LAS-MCI FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LAS-MCO FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LAS-MSP FEB 0.7>1.9[1.9] MAR 0>2.0[2] APR 0>1.4[2]
NK LAS-MSY DEC 1.6>1.0[1.0] FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LAS-OAK FEB 1.1>3[3] APR 0>2[3]
NK LAS-ORD FEB 0.9>3[3] APR 0>2[3]
NK LAS-PDX FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK LAS-PHL FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LAS-PIT FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LAS-SAN FEB 1.1>3[3] APR 0>2[3]
NK LAS-SEA FEB 1.1>3[3] APR 0>2[3]
NK LAS-SMF FEB 1.2>3[0] MAR 0>3[0] APR 0>2[0]
NK LAS-TPA FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LAX-MCI FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK LAX-MSP FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LAX-MSY FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LAX-OAK FEB 0.8>2[2] APR 0>1.4[2]
NK LAX-ORD FEB 0.8>2[2] APR 0>1.4[2]
NK LAX-PHL FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LAX-PIT FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LBE-MCO FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK LBE-MYR FEB 0>0.4[0.3] APR 0>0.5[0.9]
NK LBE-RSW FEB 0.2>0.5[0.5] MAR 0>0.5[0.6] APR 0>0.4[0.6]
NK LBE-TPA FEB 0.1>0.3[0.4] MAR 0>0.5[0.4] APR 0>0.3[0.4]
NK LGA-MCO FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK LGA-MYR FEB 0.4>1.0[2] MAR 0>1.0[2] APR 0>0.7[2]
NK LGA-ORD FEB 0.4>1.0[2] MAR 0>1.0[2] APR 0>0.7[2]
NK LGA-TPA FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK MBJ-MCO FEB 0.2>0.4[0.0] MAR 0>0.5[0.6] APR 0>0.3[0.6]
NK MCI-MCO FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK MCO-MDE APR 0>0.2[0.3]
NK MCO-MSP FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK MCO-MSY FEB 0.3>0.9[0.9] MAR 0>1.0[1.4] APR 0>0.7[1.0]
NK MCO-MYR APR 0>0.2[0.3]
NK MCO-ORD FEB 0.7>2[2] APR 0>1.4[2]
NK MCO-PHL FEB 1.1>3[3] APR 0>2[3]
NK MCO-PIT JAN 1.0>1.8[1.0] FEB 0.4>1.8[1.0] MAR 0>1.5[1.0] APR 0>1.1[1.0]
NK MCO-RDU FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK MCO-RIC FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK MCO-SAL APR 0>0.2[0.3]
NK MCO-SAP APR 0>0.2[0.3]
NK MCO-SDQ FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK MCO-SJO FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK MCO-SJU JAN 0.8>1.2[1.6] FEB 0.3>1.1[1.2] APR 0>0.7[1.0]
NK MSP-MSY FEB 0.2>0.5[0.5] MAR 0>0.5[0.6] APR 0>0.4[0.6]
NK MSP-PHX FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK MSP-RSW FEB 0.4>1.0[1.0] MAR 0>1.0[1.4] APR 0>0.7[1.3]
NK MSP-TPA FEB 0.4>1.0[1.0] MAR 0>1.0[2] APR 0>0.7[1.3]
NK MSY-ORD FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK MSY-PHL FEB 0>0.3[0] MAR 0>0.5[0] APR 0>0.4[0]
NK MSY-RDU FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK MSY-TPA FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK MYR-ORD MAR 0>0.7[0.6] APR 0>0.7[1.0]
NK MYR-PHL MAR 0>0.4[0.5] APR 0>0.3[0.6]
NK MYR-PIT APR 0>0.3[0.4]
NK ORD-PHX FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK ORD-RDU FEB 0.4>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK ORD-RSW FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK ORD-SAN FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK ORD-TPA FEB 0.7>1.9[1.9] APR 0>1.4[2]
NK PHL-RSW FEB 0.2>0.5[0.4] MAR 0>0.5[0.4] APR 0>0.3[0.4]
NK PHL-SJU FEB 0.1>0.4[0] MAR 0>0.5[0] APR 0>0.4[0]
NK PHL-TPA FEB 0.2>0.5[0.5] MAR 0>0.5[0.6] APR 0>0.4[0.6]
*NK PHX-SEA NOV 0>0.6[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.7[0]
NK PIT-RSW FEB 0.3>0.9[0.9] APR 0>0.7[1.0]
NK PIT-TPA FEB 0.4>1.0[1.0] APR 0>0.7[1.0]
NK SJU-TPA FEB 0.1>0.4[0.3] APR 0>0.4[0.5]
PD MYR-YTZ MAY 0>0.3[0.2]
UA ACA-IAH JAN 0.6>1.0[0.5] FEB 0.6>1.1[0.6] MAR 0.5>0.9[0.6]
UA BZE-ORD JAN 1.0>0.5[1.0] FEB 1.0>0.4[1.0]
**UA DEN-HOB NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0]
UA DEN-TYS DEC 2>1.6[1.6]
UA EWR-FCO JAN 0.5>0.2[0.5] FEB 0.7>0.3[0.6]
UA EWR-MBJ JAN 1.2>2[1.2] FEB 1.6>2[1.5]
UA IAH-NAS JAN 0.3>0.5[0.5] FEB 0.2>0.4[0.4] MAR 0.8>1.0[1.0]
UA LAX-MEL NOV 1.0>0.6[1.0] FEB 1.0>0.6[1.0] MAR 1.0>0.6[1.0]
UA ORD-PLS JAN 0.2>0.5[0.1] FEB 0.2>0.6[0.1] MAR 0.3>0.6[0.4]
UA PHX-SFO NOV 4>3[5]
**VA GTP-LAX APR 0.5>0[0] MAY 0.5>0[0]
Ishrion
Re: OAG Changes 8/5/2019:AC Drops OMA;NK Builds MCO,Suspends DEN-LAX,FLL-JAX/MCI/GSO/AVL,Adds PHX-SEA;UA Adds DEN-HOB
Sun Aug 04, 2019 12:43 pm
Thanks as always. Nice to see AA’s DFW-Kalispell return and start a month earlier.
AA’s reducing DFW-YVR in November, after the ORD cut...
Sucks that AC’s ending OMA. Saw their CRJ-200 land the one time I connected through there.
Reduction on UA’s LAX-MEL... will be interesting to see if that’s in anticipation of the AA/QF JV... or from them launching SFO-MEL.
If not, things will get interesting.
Cubsrule
Sun Aug 04, 2019 12:48 pm
Thanks, as always, enilria.
I assume this is related to the withdrawal of Georgian 50-seat CRJs. Many if not most of the routes that will see upgauging will also see some frequency reduction. That’s hard to do at 1x/day.
The AC Hawaii cuts are almost certainly MAX-related.
BA744PHX
Sun Aug 04, 2019 1:05 pm
AA PHX-YVR will also be suspend from 11/21, however both ORD/PHX-YVR are scheduled to resume 06/04.
I wonder why AA cant make YVR work.
jayunited
Sun Aug 04, 2019 1:35 pm
It could be in response to the AA/QF however looking at the schedule UA still maintains an overall 7x weekly service to MEL from the US.
While this years IATA summer 2019 reduction on LAX-SYD can be directly attributed to a shortage of 788/789's equipment (with the current schedule we only have 1 spare 789 frame to cover both the 788 and 789 fleet), the reduction of LAX-MEL during November, February and March can not be attributed equipment shortage even though several 788s/789s will be out of service for Polaris/PE installation. What will be equally as interesting is if UA restores LAX-MEL to daily service at the beginning of IATA spring 2020 once the seasonal SFO flight ends.
izbtmnhd
Sun Aug 04, 2019 1:50 pm
I’m curious about ANC-RDB. Is it going to chartered service or is there something up with mine?
MIflyer12
Sun Aug 04, 2019 2:06 pm
Frack you, frack you very much eastern New Mexico.
CMHtraveler
Sun Aug 04, 2019 2:07 pm
I believe this route was always going to be seasonal but is now being cut in September instead of November. Who knows if it will return in spring. Either way, it’s a mystery why they chose to compete against DL daily/2x service on this route with Tuesday and Thursday only seasonal flights. To no one’s surprise it appears that lasted about 4 months.
ytib
Sun Aug 04, 2019 2:20 pm
It is a charter service they have been doing was quite some time as the airfield PADG is owned by the mine.
AS9671 is the outbound flight number, with AS9672 on the return.
318, 319, 320, 321, 332, 333, 388, 707, 717, 722, 732, 733, 734, 73Q, 735, 73G, 738, 7M8, 739, 752, 753, 742, 74L, 744, 762, 763, 772, 77L, 77W, 789, 142, CN1, CR2, CR7, DC8, DH2, DH8, D8Q, D10, D95, EM2, ER3, ER4, E70, 100, J31, M11, M83, M88, M90, SF3
axiom
Sun Aug 04, 2019 2:25 pm
Thanks as always, e.
re NK in MCO/Florida, I wouldn’t say that this is a major shift one way or the other. In TPA, you see two sub-daily routes shift to MCO, yet the overall trend is up 4-5 daily flights YoY, for example. The only story I see is the shift from sub-daily flights (a la AirTran) to a consolidation at a single destination.
AirFiero
Sun Aug 04, 2019 2:48 pm
Yes, interesting indeed :D
jplatts
Sun Aug 04, 2019 2:54 pm
I am surprised to see NK add PHX-SEA nonstop service, especially since NK has a minimal presence in the PHX market.
There are still some other nonstop routes that could be added by NK out of PHX such as PHX-ATL, PHX-DTW, PHX-FLL, PHX-LAS, PHX-MCO, and PHX-TPA.
BA744PHX
Sun Aug 04, 2019 2:58 pm
NK served LAS & LAX twice daily, neither worked for them. I do wonder if DTW/FLL-PHX are on the horizon for NK
Chuska
Sun Aug 04, 2019 3:03 pm
Looks like the new UA* DEN-HOB will start Oct 27 and operate by SkyWest with a CRJ-200. The current flights from HOB to IAH will switch from ExpressJet ER4's to SkyWest CRJ's as well.
enilria
Sun Aug 04, 2019 3:06 pm
This article says the aircraft are staying, but moving to another operator within AC. Are you sure they are now getting ride of the CRJ-200s? I need to know for something I'm working on. Thanks!
https://www.ch-aviation.com/portal/news ... ve-to-jazz
izbtmnhd
Sun Aug 04, 2019 3:07 pm
Thanks. Who’s going to operate the charter now?
enilria
Sun Aug 04, 2019 3:10 pm
It's still interesting to see them move anything from FLL. Things are so constrained there I'd think they'd be reluctant to give up any "slots".
We both know it's just one trip, but in terms of reading the tea leaves...
It may just be because it is a charter. Since they are not selling the flight via GDS they may not pay too much attention to whether it is correct in OAG. Or who knows...
Cubsrule
I think they are generally moving off of transborder routes. Places like BNA get CR9s with less frequency in the fall.
enilria
Sun Aug 04, 2019 3:11 pm
I like it it. Feels like I'm on Entourage! :)
AVLAirlineFreq
Sun Aug 04, 2019 3:14 pm
I don't know the answer to your question, but I do know in the year they have been in the market NK has had a tough time getting traction on AVL-Florida vs. G4. MCO is the one airport where NK has a little bit of differentiation vs. G4 (closer to Disney than SFB), and although I haven't looked at the schedules, MCO maintains the NK connections to the Caribbean and Latin America which are also a selling point in AVL vs. G4.
AirFiero
Sun Aug 04, 2019 3:17 pm
Countdown to SFOphiles posting it doesn’t mean anything, they’re still building up SFO, etc... ;)
Beechtobus
Quite surprising indeed, especially that it’s going to be flown with a 321.
avi8
Sun Aug 04, 2019 3:21 pm
So NK’s GUA’s schedule remains unchanged? I get confused when the schedules are published until the middle of the month.
avi8
Aliqiout
Sun Aug 04, 2019 3:31 pm
Looks like a small drop in March from IAH 0.6/week to 0.5/week. Maybe dropping one flight per week.
jplatts
Sun Aug 04, 2019 3:33 pm
I agree that NK adding PHX-DTW and PHX-FLL might happen since PHX-DTW and PHX-FLL/MIA are two of the top routes out of PHX that aren't currently served nonstop by NK. There are also currently no ULCC's serving the DTW or FLL/MIA markets nonstop from PHX or AZA, and both DTW and FLL are two of the largest NK stations.
WN732
ONT is on a roll! So good to see the increased service.
many321
Sun Aug 04, 2019 3:44 pm
I'm shocked to see the increase of service to ONT...They must be seeing $$$ Perhaps they should up-gauge from the 738, to 757/A321/767.
enilria
Sun Aug 04, 2019 4:27 pm
Ok, so not certain. Just tea leaf reading?
enilria
Sun Aug 04, 2019 4:32 pm
No longer true as of Nov.
https://www.azcentral.com/story/travel/ ... 735827001/
SANFan
Sun Aug 04, 2019 4:37 pm
With about 36 changes listed -- the most I've seen in a LONG time -- it looks like AS's Nov 5 sked is finally released. Not that this is the final version, but at least some serious work is being done it. Nothing terribly exciting (particularly for my city) but we'll see what happens next.
I really do think it's a bit early to get too excited about the redux of SFO-PDX and a perhaps coincidental increase in the market down the Bay; heck, it might just be a/c changes...
What I find even more interesting is the increase in SJC-SNA by 2 daily departures! Where did 2 new SNA slots come from? (I see no other changes at John Wayne at this time.)
bb
SANFan
Sun Aug 04, 2019 4:55 pm
In fact I just looked at the Nov skeds for AS and guess what? In November, PDX-SFO will op with 6 mainline jets & 1 EMJ (totaling 7 per day) while PDX-SJC will be 6 flights a day, but 4 will be EMJs & 2 Boeings. Looks like definitely more capacity at SFO than SJC.
I also see that AS is putting an EMJ on PDX-SAN -- as the new 4th daily flight -- so there does appear to be re-gauging of a/c in some markets. In fact, that could explain the increase in SJC-SNA service although I still don't know where AS got the additional slots at SNA.
bb
AirFiero
Sun Aug 04, 2019 4:57 pm
bb
A story that stands on its own is SJC gaining on two routes, including slot controlled SNA. And SFO loses again. Like our host said, reading the tea leaves.
Edit..ok, capacity adjustments. Fair enough.
I didn’t notice, anything significant at SAN?
tphuang
Sun Aug 04, 2019 5:00 pm
I'm still waiting for those WN changes to show up. Hopefully anyday now. Maybe at the same time they announce SAN/SMF-HI services.
As for SNA, I remember something about additional slots opening up later in the year when it hasn't been fully utilized up to that point.
AirFiero
Sun Aug 04, 2019 5:01 pm
bb
Not surprising, given the total passenger count at SFO versus SJC.
MIflyer12
Sun Aug 04, 2019 5:04 pm
Calm down. DL's domestic F 767s are gone, and there's zero - and I mean zero - chance of a lie-flat int'l config DL 767 regularly scheduled on ATL-ONT.
many321
Sun Aug 04, 2019 5:16 pm
Umm I did add the 757/A321. Talk about to pick and chose....
Cubsrule
Sun Aug 04, 2019 5:25 pm
I think some things have changed with the transition of Air Georgian aircraft from to Chorus/Jazz but can’t find any announcement. The CRJs originally were to transition to Jazz by the end of 2019 but in the January timetable I see Air Georgian flights to virtually all current cities (the exceptions are CLT, BNA, and RDU, which see upgrades to 76-seat equipment). I can’t help with the current plan.
jplatts
Sun Aug 04, 2019 5:33 pm
WN re-adding SNA-MDW on a year-round basis will probably happen once additional slots become available at SNA and/or capacity restrictions are loosened at SNA as the lack of SNA-MDW nonstop service is one of the biggest holes.
EA CO AS
Sun Aug 04, 2019 5:39 pm
One interesting note that isn't reflected in the fall schedule is that on 11/5, DCA becomes an all-A321neo station for AS.
flyfresno
Sun Aug 04, 2019 5:48 pm
737-900 seems the most likely, and *maybe* 321. Being as ONT doesn’t require the 757’s performance, I would say it would be unlikely other than random equipment subs.
SANFan
Sun Aug 04, 2019 6:59 pm
AirFiero wrote:
bb
As I mentioned in my post reflected above, nothing exciting for SAN except that our service to PDX looks like it's heading for a permanent increase (year-round.) Maybe that's due to SY adding token service in the market but whatever, I'll take it! (AS protecting it's PDX hub or it's focus city of SAN from outside intrusion?! Yeah right!)
Otherwise, I'm still creating a turn-sked for SAN effective Nov 5 and so far have seen some changes, including retiming of some markets, but not much else.
BTW, I don't think I've asked this question before but does anyone know why AS is starting their fall schedule on Nov 5, in the middle of the week following the loss of Daylight Savings Time on Sunday, Nov 3? Seems kind of odd to me... It's another tradition -- issuing schedule changes usually on the Sundays that DST starts and stops -- that I suppose isn't really that relevant anymore but hey, it's a tradition! "Does that mean nothing to anyone anymore?!" ;)
bb
Runway28L
Sun Aug 04, 2019 7:05 pm
SEA-PIT is also transitioning to the A321neo.
Runway28L
Sun Aug 04, 2019 7:14 pm
With NK building up MCO, perhaps they are not only trying to compete against WN, but also getting ahead of B6? Terminal C will open in a few years and JetBlue is supposed to be the largest tenant IINM. I wonder how NK could affect any long-term expansion planned by B6.
lhpdx
Sun Aug 04, 2019 7:41 pm
Looks like AS is decreasing its PDX hub to fuel it's explosive growth at SEA................
admanager
Sun Aug 04, 2019 8:10 pm
According to Captain Obvious, one AS east coast route that will not go to the A321neo is the "Boeing shuttle" to CHS.
USAavdork
Sun Aug 04, 2019 8:46 pm
EA CO AS:
Since you mentioned DCA going to all A321NEO, do you know anything about BOS? BOS-SFO/SAN and LAX are all still A320. BOS-SAN/SFO are most concerning as the A320 will constantly be tech stopping for fuel? Do you know if they’ll will switch to A321NEO or back to Boeing?
AirFiero
Sun Aug 04, 2019 8:53 pm
SANFan wrote:
AirFiero wrote:
bb
bb
Oops, sorry, in the middle of the first reading of the OAG thread (aka “coffee with enilria”) the coffee hadn’t kicked in yet. :lol:
red66mustang
Sun Aug 04, 2019 8:54 pm
NK's new VP of Network was the VP at AS before he got sacked in the layoffs last fall. I have to wonder if this route is based on knowledge gained on the market at AS.
TYSflyer
Sun Aug 04, 2019 9:03 pm
Couldn’t agree more with your assessment. It has obviously been hard for NK to compete with multiple daily flights offered by G4 to FLL. I thought that NK might have more name recognition in South Florida which would help the service but clearly it hasn’t. I think refocusing on MCO where, as you mentioned, they have an advantage based on location will help them. This will be quite similar to the old FL days that focused on MCO. They will have numerous connections and daily flights. I think they should fare well with this approach. I worry about GSO though. Reducing destinations by NK is concerning for their service there. I’m afraid opening RDU will hamper any growth at GSO by NK.
MDW22L31C
Sun Aug 04, 2019 9:21 pm
Nice to see increase in flights to ONT by DL And AS. Finally a non-stop flight from ORD to ONT by AA
