enilria
OAG Changes 8/11/2019:AA Out PHXEGE;AM MAXs Gone;CA Cuts HNLPEK;F9 Drops RDU-CLE/MSY/PBI/RSW/TPA;SA Cuts DSSIAD;WO SAN
Sun Aug 11, 2019 12:11 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
2O ADQ-KLN SEP 3>1.8[3] OCT 3>1.9[1.9] NOV 3>1.9[1.9] DEC 3>1.8[1.8] JAN 3>1.9[1.9] FEB 3>1.9[1.9] MAR 3>1.8[1.8] APR 3>1.9[1.9] MAY 3>1.8[2]
*4P LUK-MMU SEP 0.5>0[0.6] OCT 0.6>0[0.7] NOV 0.5>0[0.7] DEC 0.4>0[0.5] JAN 0.5>0[0.7] FEB 0.6>0[0.6] MAR 0.6>0[0.6] APR 0.6>0[0.6] MAY 0.5>0[0.5]
*AA BUD-ORD MAY 0>0.5[0]
AA BZE-MIA DEC 2>1.5[2]
AA CLT-ELH DEC 0.1>0.3[0.1]
AA CLT-MHH DEC 0.1>0.3[0.1]
AA CUR-MIA DEC 2>1.5[2]
AA DFW-NAS FEB 0.2>0.7[0.2] MAR 0.3>1.0[0.4]
**AA EGE-PHX JAN 1.0>0.2[0.4] FEB 1.0>0[0.5] MAR 1.0>0[0.7] APR 0.2>0[0.0]
*AA KRK-ORD MAY 0>0.6[0]
AA MIA-PUJ JAN 3>2[3]
AA MIA-SAL DEC 1.5>1.0[1.4]
*AA ORD-PRG MAY 0>0.6[0]
AC KOA-YVR DEC 0.4>0.2[0.4] JAN 0.7>0.3[0.5] FEB 0.7>0.3[0.5] MAR 0.7>0.3[0.6] APR 0.5>0.2[0.4]
AC MIA-YUL DEC 0.9>1.3[1.3]
AC MKE-YYZ DEC 1.7>1.2[1.6]
AC PHX-YVR NOV 0.7>1.0[0.7]
AC SFO-YUL NOV 1.4>1.0[1.0]
AG AUA-MIA SEP 0>0.3[1.0] OCT 0.5>0.3[1.0] NOV 1.0>0.3[1.0] DEC 1.0>0.3[0.9] JAN 1.0>0.3[1.0] FEB 1.0>0.3[0.9] MAR 1.0>0.3[0.9] APR 1.0>0.3[0.7] MAY 1.0>0.3[0.5]
Looks like AM just deleted the MAX flying completely. First carrier to do that.
*AM ATL-BJX OCT 1.0>0[1.0] NOV 0.9>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0]
*AM ATL-GDL NOV 0.9>0.3[1.0] DEC 1.0>0.3[1.0] JAN 1.0>0.0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[0]
*AM ATL-QRO OCT 1.0>0[1.0] NOV 0.9>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0]
AM BJX-LAX OCT 0.5>0.1[0.5] NOV 0.6>0.3[0.6] DEC 1.1>0.9[0.7] JAN 0.7>0.4[0.6] FEB 0.6>0[0.6] MAR 0.5>0[0.8] APR 0.6>0[1.0] MAY 0.6>0[0.9]
*AM DTW-GDL APR 0.4>0[0] MAY 0.4>0[0]
*AM DTW-MEX OCT 1.0>0[0.9] NOV 1.0>0[0.9] DEC 0.8>0[0.6] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0]
*AM DTW-SLP APR 0.4>0[0] MAY 0.4>0[0]
AM JFK-MEX OCT 4>3[4] NOV 4>3[4] FEB 4>3[4] MAR 4>3[4] APR 4>3[4] MAY 4>3[4]
AM LAX-MEX OCT 5>4[5] NOV 5>4[5] FEB 5>4[5] MAR 5>4[5] APR 5>4[5] MAY 5>4[3]
AM MEX-ORD OCT 2>1.2[2] NOV 2>1.0[2] JAN 2>1.6[2] FEB 2>1.0[2] MAR 2>1.0[2] APR 2>1.0[2] MAY 2>1.0[2]
AS BIL-SEA DEC 1.7>2[1.8]
AS GEG-SEA NOV 15>16[15] DEC 16>17[15]
AS LAX-SJD NOV 1.5>1.8[1.8] DEC 1.5>1.9[1.9]
AS MCI-SEA NOV 1.5>2.0[1.4] DEC 1.5>2[1.4]
AV LAX-SAL SEP 3>4[3] OCT 3>4[3] NOV 3>4[3] DEC 3>4[3] JAN 3>4[2] FEB 3>4[3] MAR 3>4[3] APR 3>4[3] MAY 3>4[3]
B6 FLL-NAS DEC 5>4[4]
*CA HNL-PEK NOV 0.4>0[0.4] DEC 0.4>0[0.5] JAN 0.4>0[0.4] FEB 0.4>0[0.5] MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.4>0[0.4]
DL ATL-GDL NOV 0.7>1.0[0.7]
DL ATL-HOU MAY 6>7[5]
DL ATL-PVR APR 1.1>0.8[1.1]
DL BOS-MCI JAN 2>1.7[1.5] FEB 2>1.7[1.5]
DL BOS-PIT FEB 3>4[3]
DL CMH-LAX MAY 1.0>0.7[0.7]
DL DTW-PDX APR 1.0>1.9[1.0]
DL JFK-SXM JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.0]
DL PHL-SLC APR 1.4>1.0[1.0] MAY 1.5>1.0[0.9]
DY JFK-MAD DEC 0.9>0.6[0.6]
*EW FRA-PHX MAY 0>0.7[0]
*EW LAS-MUC APR 0>0.2[0] MAY 0>0.3[0]
*EW MCO-MUC APR 0>0.2[0] MAY 0>0.4[0]
F9 ATL-MCO OCT 1.5>1.9[1.0]
*F9 ATL-RDU NOV 0>0.6[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>0.4[0]
F9 BOS-RDU NOV 0.3>0.5[0] DEC 0>0.5[0] JAN 0>0.4[0] FEB 0>0.4[0]
F9 BUF-RDU OCT 0.3>0.0[0.3]
*F9 CLE-MSP OCT 0.5>0.1[0.4] NOV 0.3>0[0.2]
*F9 CLE-RDU OCT 0.5>0.1[0.4] NOV 0.3>0[0.2]
*F9 CVG-MSP OCT 0.4>0.1[0.3] NOV 0.2>0[0.1]
F9 CVG-RDU OCT 0.5>0.1[0.3]
F9 IAH-RDU OCT 0.3>0.5[0.4]
F9 ISP-MCO OCT 0.8>1.2[0.9]
F9 LAS-ORD SEP 1.3>1.0[1.0] OCT 1.3>1.0[1.0]
F9 LAS-PHX OCT 1.2>1.5[0]
F9 MCO-STL OCT 1.0>1.5[1.0] NOV 1.0>1.3[1.0]
*F9 MIA-RDU NOV 0>0.6[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>0.4[0]
F9 MKE-RDU OCT 0.3>0.0[0.4]
*F9 MSY-RDU NOV 0.4>0.1[0.3] DEC 0.5>0[0.3] JAN 0.4>0[0.3] FEB 0.4>0[0.3]
*F9 PBI-RDU OCT 0.5>0.1[0] NOV 0.4>0[0.2] DEC 0.4>0[0.4] JAN 0.3>0[0.5] FEB 0.3>0[0.4]
F9 PVD-RDU OCT 0.5>0.1[0.4]
*F9 RDU-RSW NOV 0.2>0[0.1] DEC 0.4>0[0.3] JAN 0.3>0[0.3] FEB 0.3>0[0.3]
*F9 RDU-TPA OCT 0.5>0.1[0] NOV 0.5>0[0] DEC 0.5>0[0] JAN 0.5>0[0] FEB 0.4>0[0]
GV AKN-EGX SEP 0>0.4[1.0] MAY 0>0.4[4]
GV AKN-IGG SEP 0>0.4[0.5] MAY 0>0.4[0.5]
GV AKN-KCG SEP 0>0.4[0.5] MAY 0>0.4[0.5]
GV AKN-KLL SEP 0>0.4[0.5] MAY 0>0.4[0.5]
GV AKN-PIP SEP 0>0.4[0.5] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0]
GV AKN-PTH SEP 0>0.4[0.5] MAY 0>0.4[0.5]
GV AKN-WSN SEP 0>1.7[2] MAY 0>1.7[1.9]
GV DLG-WSN SEP 0>1.7[0.8] OCT 0>1.7[0] NOV 0>1.7[0] DEC 0>1.7[0] JAN 0>1.7[0] MAY 0>1.7[1.9]
GV EGX-UGB SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0]
GV IGG-KLL SEP 0>0.4[0.5] MAY 0>0.4[0.5]
GV KCG-KCL SEP 0>0.4[0.5] MAY 0>0.4[0.5]
GV KCL-KCQ SEP 0>0.4[0.5] MAY 0>0.4[0.5]
GV KCQ-KPV SEP 0>0.4[0.5] MAY 0>0.4[0.5]
GV KPV-PTH SEP 0>0.4[0.5] MAY 0>0.4[0.5]
GV PIP-UGB SEP 0>0.4[0.5] MAY 0>0.4[0.5]
*LH DTW-MUC MAY 0>0.6[0]
LX IAD-ZRH APR 0>1.0[0] MAY 0>1.0[0]
M5 CXH-LKE OCT 0>0.3[0.7]
NK BWI-FLL OCT 3>4[3] NOV 3>4[3] DEC 3>4[3]
NK DTW-FLL OCT 2>3[2] NOV 2>3[2] DEC 2>3[2]
PD MLB-YTZ FEB 0.3>0[0.3] MAR 0.3>0[0.3]
PD MYR-YTZ FEB 0.2>0[0.2] MAR 0.3>0[0.3] APR 0.3>0[0.3] MAY 0.3>0[0.2]
SA ACC-IAD SEP 0.7>1.0[0.6] OCT 0.7>1.0[0.6] NOV 0.7>1.0[0.6] DEC 0.7>1.0[0.6] JAN 0.7>1.0[0.6] FEB 0.7>1.0[0.6] MAR 0.7>1.0[0.5] APR 0.7>1.0[0.7] MAY 0.7>1.0[0.7]
*SA DSS-IAD SEP 0.3>0.0[0.4] OCT 0.3>0[0.4] NOV 0.3>0[0.4] DEC 0.3>0[0.4] JAN 0.3>0[0.4] FEB 0.3>0[0.3] MAR 0.3>0[0.4]
SV IAD-RUH APR 0.2>0.6[0.4] MAY 0.1>0.5[0.6]
SV JED-JFK APR 0.2>0.6[0.6] MAY 0.1>0.5[0.6]
SV JED-LAX APR 0>0.7[0.4] MAY 0>0.7[0.4]
SY LAS-PVD SEP 0.5>0.3[0] OCT 0.5>0.4[0] NOV 0.6>0.3[0] DEC 0.5>0.2[0]
*SY PDX-SJD JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
*SY PUJ-PVD JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.3>0[0]
UA ABQ-ORD OCT 3>2[3]
UA ABQ-SFO OCT 3>2.0[2]
UA AVL-EWR APR 0>0.8[0.1] MAY 0>1.0[1.1]
UA BGR-EWR DEC 1.2>2.0[2.0]
UA BWI-DEN OCT 3>2[1.9]
UA CAK-ORD NOV 5>4[4]
UA CID-DEN OCT 3>2[2]
UA CLE-SFO OCT 1.7>1.2[1.8]
UA CRP-IAH OCT 7>6[6] NOV 7>6[6]
UA DEN-FLL OCT 1.8>1.3[1.0]
UA DEN-IND OCT 3>2[3]
UA DEN-MEM OCT 3>2[2] NOV 3>2.0[2]
UA DEN-MSN OCT 3>2[1.8]
UA DEN-PIT OCT 3>2[2]
UA DEN-SEA NOV 5>4[5]
UA DSM-IAH OCT 3>2[1.9]
UA ELP-IAH OCT 6>5[5] NOV 6>5[5]
UA ELP-ORD OCT 1.8>1.0[2] NOV 1.9>0.9[2.0]
UA HRL-IAH NOV 5>4[4]
UA IAH-MKE OCT 3>2[2]
UA IAH-ORF OCT 1.8>1.0[1.2] NOV 1.8>0.9[1.8]
UA IAH-RIC OCT 3>1.9[2.0] NOV 3>1.9[1.8]
UA IAH-SJC OCT 1.8>1.1[1.0] NOV 1.7>1.0[1.0]
UA IND-SFO OCT 1.4>1.0[1.8]
UA KOA-LAX JAN 1.8>1.3[1.9]
UA MCI-SFO OCT 1.8>1.1[2] NOV 2.0>1.0[3]
UA ORD-SJC OCT 1.8>1.2[1.8] NOV 1.9>1.0[1.7]
VH MDE-MIA NOV 1.0>0.6[0] FEB 0>0.6[0.3] MAR 0>0.6[0.3]
Why?
*WO SAN-YEG OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.5>0[0] JAN 0.4>0[0] FEB 0.4>0[0] MAR 0.5>0[0] APR 0.3>0[0]
*WO SAN-YXX OCT 0.3>0[0] NOV 0.3>0[0] DEC 0.3>0[0] JAN 0.3>0[0] FEB 0.4>0[0] MAR 0.5>0[0] APR 0.2>0[0]
diseased
Re: OAG Changes 8/11/2019:AA Out PHXEGE;AM MAXs Gone;CA Cuts HNLPEK;F9 Drops RDU-CLE/MSY/PBI/RSW/TPA;SA Cuts DSSIAD;WO S
Sun Aug 11, 2019 12:36 pm
F9 and RDU surprises me. I figured that was a sure win. Good thing I'm not an airline CEO...
Midwestindy
Sun Aug 11, 2019 12:37 pm
Frontier is going to do Frontier things.....
Max trims?
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
aaflyer777
Sun Aug 11, 2019 1:00 pm
Honestly not surprised PVD isn't working for them. F9 didn't seem to have much luck in PVD either and now they're back in BOS, I wonder if SY will follow
MIflyer12
Sun Aug 11, 2019 1:13 pm
With AM pulling MAX flying out of DL hubs will we see more DL substitutions (next week, or beyond)? That would be a nice bonus for DL pilots looking for extra flying in the off season.
enilria
Sun Aug 11, 2019 1:44 pm
I suspect. They said it in the quarterly call which would imply it is a significant level of flying. I think it's a big deal that AM is the first carrier to remove all future MAX flying. That turns temporary route decisions into more permanent route decisions.
enilria
Sun Aug 11, 2019 1:47 pm
I agree that pulling Florida routes from RDU going into peak is surprising.
True dat
PVD-PUJ was probably paid mostly by Apple and when that went away they needed to also pull the setup flight which was probably a LAS "based" plane.
WN732
Max trims?
Many of those are Express flights.
rnorth6920
Sun Aug 11, 2019 1:48 pm
I come here every week for this post, thank you!!
Ishrion
Sun Aug 11, 2019 2:10 pm
Nice to see an increase on AA's Charlotte to North Eleuthera and Marsh Harbour destinations. I think they were just launched last December?
Interesting small cuts on MIA-BZE/CUR/PUJ/SAL... MAX cuts?
Why?
https://thepointsguy.com/news/why-swoop ... grounding/
"Canadian low-cost carrier Swoop has delayed its new San Diego flights until 2020, citing the grounding of the Boeing 737 MAX -– an aircraft it doesn’t fly."
WestJet problems, it looks like.
Chuska
Sun Aug 11, 2019 2:25 pm
UA ABQ-ORD Oct 3>2[3]
UA ABQ-SFO Oct 3>2[3]
Both of these deletions were going to be new additions with UA mainline aircraft, The SFO would have been the first mainline flight on the ABQ-SFO route. Almost everytime UA adds more flights from ABQ (and who knows how many other places), they pull them before they start.
friendlyskies22
Sun Aug 11, 2019 2:27 pm
Good info on this report.
Am I imagining things, but didn't this site offer once the ability to hover or click on either a city code
or airline code and a tiny popup window would open showing the city name or airline name?
I know a-netters know most of the codes, but I always see a few weird ones that make me think:
"where's that or who's that."
Thanks a*net.
Rdh3e
Sun Aug 11, 2019 2:31 pm
[Sarcasm] Close in mainline cuts, what could that possibly be related to? [/Sarcasm]
AirFiero
Sun Aug 11, 2019 2:34 pm
It doesn’t surprise me. F9 breezes into town announcing all kinds of routes. If they are even there a year later, then celebrate. They did this at SJC, big route adds all over the place, then a year later only DEN and LAS remained and neither were daily.
RDUDDJI
Sun Aug 11, 2019 2:35 pm
I don't know of it's possible to be surprised by F9 anymore. :)
Seems interesting that they cut Fla flights, but yet they still have service to PWM, SYR, ALB, etc. I'd actually rather have PWM, SYR, and ALB than more flights to Florida.
RDU-Florida from memory: DL (TPA, MCO, MIA, FLL, soon JAX), F9 (MCO, TPA, PBI, RSW, JAX), WN (TPA, MCO, FLL), G4 (PIE, SFB, PGD), AA (MIA), B6 (FLL).
Sometimes we don't realize the good times when we're in them
AirFiero
Sun Aug 11, 2019 2:37 pm
Max trims?
And, probably, seasonal like SJC-ORD/IAH. I’m pretty sure I’ve seen that one before.
PSAatSAN4Ever
Sun Aug 11, 2019 2:45 pm
Why?
The story in the San Diego thread is that this is also a MAX cut. No confirmation, but the best explanation available thus far.
Gulfstream500
I'm sure that DL is jumping with joy about F9's schedule trimming in RDU... This year, DL is supposed to break the 4 million passenger mark in RDU in 2019, and will likely become bigger in RDU than UA was in CLE!
So... when will the Northwest DC-9s be retired?
Rafale9312
Sun Aug 11, 2019 2:56 pm
I'd guess the F9 cuts to RDU are seasonal (who really knows at this point), but I am surprised (even though I shouldn't be because this is F9 we're talking about) that they're cutting Florida routes in the winter, when more people would be flying down there for vacation, but I guess this is why I'm not a network planner.
SANFan
Sun Aug 11, 2019 3:07 pm
PSAatSAN4Ever wrote:
Why?
Confirmed somewhat in an article (here's the link):
A Swoop spokesperson confirmed to The Points Guy that San Diego flights were delayed due to the grounding of the 737MAX at parent WestJet and they now plan to begin serving SAN in summer 2020.
(Thanks to Hawaiian717 for this over on the SAN-thread.)
I'm not holding my breath that this will ever happen but at least there's an explanation from the carrier so I can hope we will see this new carrier in SAN some time next year!
bb
Scarebus34
Sun Aug 11, 2019 3:22 pm
With the Max out, they simply don’t have enough mainline aircraft.
tlecam
Sun Aug 11, 2019 4:22 pm
Enilria - Thank you as always!
BOS-LGA-JFK | A:319/20/21, 332/3, 346 || B:717, 735, 737, 738, 739, 752, 753, 762, 763, 764, 787, 772, 744 || MD80, MD90
Aliqiout
Sun Aug 11, 2019 5:07 pm
Are you saying that these flights were going to be upgraded to mainline, but were canceled instead? Because the report and my memory both say that these were 3 daily last October.
Aliqiout
Sun Aug 11, 2019 5:12 pm
Max trims?
Right, but that doesn't mean they are not MAX related. When faced with an unexpected aircraft shortage the airlines have two basic choices for each effected flight, cancel it, or replace the planned aircraft with one from a less important flight.
MIflyer12
Sun Aug 11, 2019 5:47 pm
I don't know that 'bigger than UA in Cleveland' is worth celebrating but DL's ops in RDU do seem to show patient expansion year after year.
alasizon
Sun Aug 11, 2019 6:03 pm
Looks like it'll be Dec 2H/New Years for EGE only, jives with them doubling down on GJT a week or two ago. Yes it is a drive from GJT to EGE but half the time the EGE flight diverts or cancels due to WX and most people end up going to GJT or DEN and driving.
SurfandSnow
Sun Aug 11, 2019 7:02 pm
Very exciting! Given AA's apparent success with BUD (this time around), I can't help but wonder if DL and/or UA may be considering BUD services of their own?
What a shame this didn't work out. Then again, getting AA to resume PHL-EGE is probably much more important for a resort that caters so heavily to European travelers!
Interesting - I certainly didn't expect this to be the first U.S. carrier service to Poland in recent times!
Looks like ORD has a bright future with AA after all :-)
I suspect many newer U.S.-China routes must be struggling these days...
More wonderful news for PHX!
And more wonderful news for DTW too!
flyguy89
Sun Aug 11, 2019 7:37 pm
Yes...seasonal. A three-year seasonal hiatus until they re-announce it :duck:
grbauc
Sun Aug 11, 2019 7:53 pm
Thanks a*net.
I miss it also
The old version had that. I also miss the paid membership part too.
Rafale9312
Sun Aug 11, 2019 9:19 pm
I mean, you're probably not wrong! :biggrin:
AirFiero
Sun Aug 11, 2019 9:55 pm
Does anyone know if DL is setting RDU up for connecting traffic?
Rafale9312
Sun Aug 11, 2019 10:03 pm
DL's operation at RDU is mainly set up for O&D traffic. Someone can add more details or correct me if I'm wrong, but DL does sell some connections at RDU, but the number of connections are low and the amount people doing connections here is not that many.
Also, I've been forgetting to mention, but thank you Enilria for posting these every week!
PVD757
Sun Aug 11, 2019 11:08 pm
The PUJ cut has everything to do with the well publicized deaths of tourists in the DR and the David Ortiz shooting. The LAS is a trim from 4 per week to 2 per week except certain weeks in October.
They are still launching new service to MSY and LAS and run both MSP and BNA 4 or 5 times weekly since they entered PVD. BOS goes away for the season completely. Not sure how that equates to “not working.”
F9 runs flights to 6 destinations from PVD and 4 from BOS, again, not sure how this means they didn’t have “much luck.”
enilria
Sun Aug 11, 2019 11:41 pm
Max trims?
Airlines replace mainline flights with RJs and then cancel RJ routes as a common strategy to minimize impact. So it could be MAX related. Probably is.
Appreciated
Thanks a*net.
I liked it too. Went away when they did that big site “upgrade” years ago.
If Winter isn’t the season for Florida, when is the season? Those aren’t seasonal cuts.
I’ve actually seen surprisingly little capacity pulled from PUJ. Ortiz death has zero to do with tourism, despite the coverage.
aaflyer777
Mon Aug 12, 2019 12:08 am
F9 has tried AUS, ATL, MYR, MIA, and MSY from PVD and they've all been cut so I would call that not having "much luck". Who knows, maybe SY will be a huge success in PVD, we'll see if these routes are still around next year.
Rafale9312
Mon Aug 12, 2019 12:16 am
I was guessing this was seasonal because nothing on Frontier's website is bookable beyond the first week in March, and the summer seasonals usually return to RDU in April, IIRC.
jayunited
Mon Aug 12, 2019 12:49 am
United just added an all new United Club to its list of locations this is the first new location added in 15 years. The new United Club is located at RDU, and it opened officially on Aug 10th. According to UA they built this club in this brand new location because we are seeing increasing premium demand as we attract more high value customers living and working in and around the Raleigh/Durham area.
Although DL has a sizable lead at RDU in this market, UA under Kirby and Munoz are doing all they can to to catch up and UA is continuing to attract more business and leisure traffic out of RDU.
Side note MSY's new United Club opens later this year. I have no problem with Gulfstream500's celebration, DL is the clear industry leader here in the U.S.. However, I wouldn't be so quick to discount UA. Smisek and and his administration are gone, UA under Munoz now has their eye focused on the domestic market and UA is clearly seeing growth.
enilria
Mon Aug 12, 2019 1:15 am
Sure they could fly them for March only, but skipping Winter to add Florida for April would be quite illogical.
Dominion301
Mon Aug 12, 2019 1:27 am
Why?
bb
With the MAX grounded until at least January (looking longer than that) Mainline don’t have the 738s to spare to ramp WO up to the planned fleet of 10 by year’s end.
What’s up with Porter and the seasonal MLB and MYR routes? That must be a filing error. I just saw PD advertising MLB earlier today.
Rafale9312
Mon Aug 12, 2019 1:44 am
We're on the same page that it is illogical for the Florida destinations (sans MCO and MIA) to be skipped in the winter and resume in the spring, I just find it hard to believe that those destinations are cancelled altogether. I'm a little biased in my confusion as RDU is my home airport, but all of the routes that F9 are dropping from RDU were only operating in the summer season anyway (except for RSW, which started as a winter seasonal route, TPA only just started this year as a summer route and I was under the impression that MSY and PBI were year-round service).
Planeboy17
Mon Aug 12, 2019 2:06 am
enilria wrote:
WN732 wrote:
Max trims?
Appreciated
Thanks a*net.
Just to be clear. David Ortiz is alive and well now, still recovering from the shooting, but I agree with you that I can’t imagine that having much to do with the drop in tourists to the DR.
By the way, thank you so much for doing this. I’m always excited to see this thread every Sunday.
avtcle
Mon Aug 12, 2019 2:35 am
I find it unlikely that Frontier is dropping ALL of those listed airports from Raleigh... This year they are kickstarting a lot of new winter service a lot earlier than usual — so this could simply be the shifting of aircraft to routes that can be more successful in the winter. Doesn’t necessarily mean all the routes have been dropped.
pdx
Mon Aug 12, 2019 5:57 am
Thanks a*net.
This website will decode cities and airlines:
https://www.iata.org/publications/pages ... earch.aspx
EvanWSFO
Mon Aug 12, 2019 1:39 pm
Planeboy17 wrote:
Appreciated
Thanks a*net.
It's just not Ortiz. Quite a few Americans have gone missing and/or murdered in the D.R. this year. I had to cancel a trip made through Southwest Vacations to Hawaii this year, and the agent on the phone said they are getting an unusual amount of cancellations to PUJ, so my refund took longer than anticipated.
I have been on this site 15 years. A unrecoverable email account led me to starting over. Those of you who call me a rookie, you may stop ok?
PVD757
Mon Aug 12, 2019 2:00 pm
I was trying to make a point about the news coverage about the Ortiz shooting in New England compounding the issues and news coverage of the many mysterious deaths in the DR and have cast a very negative shadow about vacationing there, more so in New England than in other regions because of the shooting.
Planeboy17
Mon Aug 12, 2019 2:24 pm
I understand, but I was just trying to clarify that David Ortiz was not killed because eniliria wrote “Ortiz death” in an earlier post is all.
c933103
Mon Aug 12, 2019 2:37 pm
The CA cut mean more available frequency for Zone 1 Chinese cities to America on Chinese side if anyone still want to start new flights out of the three cities.
It's pointless to attempt winning internet debate. 求同存異. よく見て・よく聞いて・よく考える
(≧▽≦) Nyan! Nyan! Nyan! Nyan! Nyan! Nyan! Nyan! Nyan!
(≧▽≦) Meow Meow Meow! Meow Meow Meow Meow!
WN732
Mon Aug 12, 2019 2:56 pm
EvanWSFO wrote:
Planeboy17 wrote:
Appreciated
Yes they had the incidents where people would die suddenly in their hotel rooms. Typically after having a drink at a bar. Although that seems to have stopped.
RDUDDJI
Mon Aug 12, 2019 3:09 pm
According to the RDUAA statistics, RDU had 3800 connecting pax in June. Assuming all of those are on DL that would still be less than 2% of their boardings.
3,800 connections for June is a 68% increase over last June, which leads me be believe much of that growth is F9 (who's added many flights in the last year).
I'm not sure how the airport measures connections, but I feel like DL's is probably more like 5-8% connections.
Dominion301
Mon Aug 12, 2019 3:21 pm
I would imagine WN and AA (to LHR) have a handful of pax connecting as well at RDU.
